PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 [210] 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Winter TIRES for 2001 PRELUDE
  2. H22 Rebuild help
  3. ? Tokico Illumina Shocks with H&R Springs
  4. BB6 Side Mirros
  5. obx intake manifold
  6. How would I test JDM power steering pump/ac condensor not on a car?
  7. MAP Sensor
  8. Clutch / Flywheel combo
  9. Engine Management System
  10. doing 5spd swap to 95SI...do i need both axles?
  11. STR intake manifold and S2K projector/BMW angel eyes conversion
  12. Question about Bezel Rings
  13. Anyone here running ITB's?!
  14. Brake ligt?
  15. Oil pump difference
  16. VTEC need help help
  17. I have an automatic prelude S what can I do for HP?
  18. newbie question: what are IAB's and how do you know if they are working?
  19. Prelude handbrake
  20. for all the turbo h22 people
  21. h22/itbs movies
  22. knock sensor?
  23. REVIEW: Megan Stainless Steel Header :PICS:
  24. Broken Clutch Fork?
  25. JDM one piece wiring harness
  26. prelude rotor size
  27. 97 Prelude CD deck
  28. Will H-series engine mate up to 3rd gen Prelude transaxle?
  29. Odometer not working
  30. Nitrous users
  31. Carbon fouled spark plugs
  32. turbo charged prelude?
  33. so I helped someone now ?????
  34. i cant get anything right!!
  35. 2gen prelude, ES1 Engine...
  36. No more h23 vtec back to the h22!
  37. 5th gen tru short shifter ever possible?
  38. Spark Plugs
  39. CRV wheels on a 5th gen (winter steelies)
  40. Englishtown red prelude sh turbo 11.1 bullshit or possible????
  41. Question about my 01 prelude
  42. HeadGasket ?
  43. hondata s200
  44. 92 lude h23 mods?
  45. Anyone running this setup?
  46. Is a camber kit needed for a 98 prelude? Also what springs woul you reccommend?
  47. Bad day at the track... internal damage? (vid link included)
  48. Will Honda use my oil if i take it there to be changed?
  49. 91 2.0L Si.......swap options+$$?
  50. Broken piston ring?
  51. Honda Prelude Triple Pillar Gauge Pod
  52. 4th gens in the snow?
  53. burning oil.... anything you guys recommend?
  54. Estimate on Front End Repair
  55. upper control arm on 4th gen
  56. 5th gen exhuast on 4th gen no vtec?
  57. lightened flywheel worth doing
  58. Help!! Tein SS Coilovers rusting on shock stem
  59. What to look for
  60. Accord suspension ?
  61. b20a5 idle and acceleration problems
  62. Temp. Gauge Problems?
  63. new h22 heads?
  64. flow rate for f22b jdm injectors
  65. Few quick questions about my 4th gen (93 S)..
  66. 9 months of wait for VTEC.....
  67. Good cams for nitrous
  68. Please help me with my shifter problem...
  69. ECU help
  70. looking to buy some used cams.anybody here have a set for sell?
  71. anyone know of B18C5 into Lude
  72. powerband?
  73. Oil Drain Plug?
  74. 4g h&r race spring rates
  75. SH Transmission w/TTS on H23 Block.
  76. grindin into 3rd
  77. anybody replace tensioner with engine inside the car?
  78. really loud starting noise??
  79. Taking off bumper (ww big mouth)
  80. removing the front bumper support
  81. Bastard B20A Turbo Pics
  82. My compression results?
  83. H22 tranny question
  84. AEM FMU
  85. falken azenis?? good?
  86. Phantom Grip Lsd ratings......
  87. rebuilding my h23 block
  88. unburnt fuel
  89. H22 Swap: DETAILED instructions on shaving Prelude driver's side mount to fit?
  90. Launching my h22 accord.
  91. Where to mount a temp gauge in a 4th gen?
  92. At 35mph what rpm are you at??? jdmh22 and tranny with lsd
  93. Cold air intake or ram air intake????
  94. almost OEM kit...
  95. sunroof leaks
  96. h23 aftermarket cams?
  97. Best turbos
  98. Vtec controller? safe ?
  99. have intake,exhaust,headers, wut should be next
  100. I have a Prelude Si 4ws, is it worth fixing up?
  101. power on stock axles
  102. Update links on FAQ page.....
  103. Can somone give me a link so I can host this Prelude Video....
  104. Injectors
  105. Short Shifter for 5th gen
  106. HELP NEEDED WITH MY PRELUDE
  107. Greddy front lip with lowered 5th generation lude???
  108. Air control
  109. 4th gen timing
  110. need hlep 4th gen shift knob removal
  111. O2 sensor
  112. Recomended upgrades??
  113. H23 VTEC: Increased Crankcase Pressure/Oil Out of Valve Cover?
  114. Aem EMS for 4th gen H22a1
  115. Under hood fuse box
  116. Oaks Racing Prelude 788WHP - Traction setup is complete
  117. throttlebody
  118. 1994 h22a rotora nad distributor
  119. anyone use the gt35/40r or gt40r on there h22 yet?
  120. bought universal racing buckets..will they fit in my 4th gen 93?
  121. waht is this car worth
  122. braided brake lines
  123. Already searched HEADER INSTALL
  124. hp gains?
  125. web sites
  126. 92 Prelude SI stock wheels F/S
  127. Whose running a tanabe racing medalion w/o a cat or resanator?
  128. Hi, I'm new with a few questions.
  129. Shaking
  130. FULL-RACE
  131. H22 trying to boost..Need Help!
  132. back to the dyno tuned off the wastegate spring
  133. possible good deal on cai w/ k&N filter
  134. New book on the shelves everyone here should read...
  135. prelude running lean
  136. h23 cam kit (Is there such a thing!!!!!)
  137. PLEASE HELP MY H23
  138. neuspeed ss adapter inquiry
  139. Tuning an H22? VAFC-Related Question
  140. quick question on cam gears
  141. Car jerking, need help SERIOUSLY...:)
  142. f22 swapped for h22
  143. prelude mugen body kit?
  144. h22a needed for prelude
  145. Running rich?
  146. from 4 stud to 5 stud?????
  147. prelude H22 cams
  148. web cams for sale (prelude h22)
  149. rattleing noise from engine bay which one of 3 fixes should I persue
  150. What size piping.??
  151. Final drive swap???
  152. TYPE S?
  153. ecu p5m
  154. Engine codes?
  155. NEED HELP m2a4 tranny
  156. Type-s Intake....help
  157. hondata and automatic tranny
  158. JRSC and nitrous
  159. H23A won't start!!!!
  160. paint 5th gen base side skirts
  161. Question about radiator fan
  162. Performance parts places in Michigan
  163. test pipe and cat
  164. massive clutch problems
  165. battery light weight
  166. Prelude Clutch Padal help!!
  167. interior lights out , and cig lighter?
  168. dyno results in =\
  169. h23 head problems
  170. i read the rules
  171. Will a jrsc off a base lude fit an sh lude? and vice verca?
  172. VAFCII whats it do
  173. an idea concerning the intake manifold related to the egr
  174. egr ?
  175. Weather affecting CAI and Short Ram intakes
  176. Hmm how heavy are the stock buckets in a 4th gen?
  177. Running hot after Skunk2 Install
  178. anyone put the accord rear lip on their 4th g?
  179. led glow
  180. How's the theft rate with preludes?
  181. H22a on stock compression and 6lbs of boost.. has anyone run this?
  182. I Have kind of a rant.
  183. must sell my motorized in dash monitor and dvd player
  184. Selling ACT CLUTCH, Fidanza Flywhee, VAFC.........
  185. Turbo H23 prelude with ALS (anti-lag system, misfiring system)?
  186. noisy
  187. Will Skunk2 Intake Manifold throw codes?
  188. will accord stock springs work in my prelude
  189. squeeky clutch
  190. will this cat fit?
  191. install door unlock kit
  192. Question about msd on my h22
  193. rear speaker install?
  194. type sh prelude and oil feed??! please help
  195. Prefered brake pads
  196. NEED HELP WITH VTEC PLEASE!!!!
  197. anything to do for DYNO prep??
  198. big favor for prelude owner
  199. VTEC controller instructions....WHERE?
  200. H22 or Rebuild H23 ??
  201. 2nd gen engine/trans match ups
  202. Prelude race car San Diego
  203. bad luck
  204. DZUS fasteners for CF hood?
  205. help me pass smog visual
  206. Car wont start...
  207. Frozen ide adjust screw: Hmm??
  208. torque converter
  209. header/exhause rattle???
  210. chipping p14
  211. 2001 Type SH
  212. 4gen prelude carbon-fiber trunk?
  213. my first dyno, tomorow =)
  214. DC header install
  215. good ol' bolt-ons
  216. Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods
  217. If I can use the front calipers off a TL or a NSX, what do I do with the rear?
  218. Found this intake on ebay...need some answers :/
  219. transmission? flywheel? clutch?
  220. so i got hit this week
  221. Does anyone have a type S or stock timing map that they could possible send me?
  222. H22 Crank Differences?
  223. 2001 theft recovery lude worth it?
  224. removing transmision help
  225. i need help with my distributor
  226. Crower stage 2 cams?
  227. Manley Forged Pistons in Stock H22 Sleeves
  228. ecu upgrades
  229. for all that are running uberdata look!
  230. Problems with clutch
  231. Vafc2 wire harness?
  232. Old gas and clogged injectors???
  233. suspension question
  234. Body Parts
  235. I need a cheap cai that will give similar power to aem intake
  236. lopeing idle fix!
  237. Axxis Ultimate Brake Pads
  238. H3c bulbs???
  239. squeeking
  240. header
  241. my car sounds diffrent when on the gas
  242. I need some help - Searched - clutch pedal
  243. 89 Lude engine swap.
  244. H22 Sensor wiring question
  245. Differences between cold air intake brands?
  246. code 5 map sensor
  247. comparing dc and greddy headers
  248. 95 F22 lude
  249. piping question
  250. winter daily driver - opinions
