PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 [176] 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 5th Gen turbo questions
  2. Reassembly-I need some numbers!
  3. No signal from TDC sensor? Pls help!
  4. RMF recieved! pics pics pics
  5. ok now whats the best tire size for a 16" rim
  6. h23a1 main caps in to another h23a
  7. H22a exhuast ?
  8. tiptronic piece missing......
  9. Fairly stupid question, I'm sure...
  10. Power Steering Pressure (PSP) Sensor
  11. PLEASE help with my new 5th GEN camshafts
  12. h22a4 head on h23 block
  13. Anyone know where to get rod bearings??
  14. 1988-1991 Prelude Owners..
  15. Wheels on 4th gen......
  16. Ready for my swap need help with last questions
  17. F22A Gears... will anything transfer over into the H22A tranny?
  18. Accord Euro R intake on a H22?
  19. emblem removal
  20. Import JDM Car
  21. 5th gen 5 lug conversion, s2000, front bumper
  22. Will the stock tire size on a 5th gen fit these wheels?
  23. broken driver's side door, need help
  24. anyone else have this problem with their hood?
  25. h22 turbo question
  26. ANYBODY have big brake kits on their 5th gens?
  27. carb number???
  28. Power Steering Pump
  29. BlackTrax Intake Manifold
  30. camshaft ? rocket motorsport
  31. CEL code #16, can't find what it means (searched)
  32. 89 Si swap
  33. need h22 cam cap part numbers!!!
  34. Code 22 - VTEC Oil Pressure, & Can't rev past 6500RPM P72 OBD2
  35. where can i find 97 and 2000 prelude wiring schematics?
  36. changing tranny fluid
  37. How far does the Prelude thermostat open?
  38. What ARP bolts/nuts do you want made that you can provide?
  39. pictures of magnaflow es oval
  40. 5th Gen VTEC Problem
  41. early 80s prelude any performance support?
  42. Anyone know a Machine shop competent/experienced with H-22 blocks in No. VA?
  43. WIERD ASS noise coming from brake, accelerator, and clutch paddle parts
  44. Hard starting JDM swap
  45. 92 prelude rotor removal
  46. Cruising RPM?
  47. 1994 H22a water pump
  48. how to do the timing belt?
  49. 4th gen balljoint replacement (about time)
  50. headgasket???
  51. Looking for header gasket and bolts...HELP!
  52. 4ws,speedo problem,sports light flashes
  53. 1/4 mile time w/ mods list
  54. Prelude SI already wired for VTEC? (not 56k friendly)
  55. stuck in 5th gear
  56. A/C compressor not getting power HELP!!! it's HOT in TEXAS!!!
  57. 95 Honda Prelude Overheating at stop
  58. **gauging interest** Prelude Engine w/ B series trannys????
  59. Weird Problem
  60. 92 Prelude running lean after swapping in 2001 H22 motor
  61. Tranny/clutch/linkage Problem... car jolted to a stop, now doesnt go in gear.
  62. Where to find parts diagram for 5 gen lude
  63. my prelude wouldnt go into gear
  64. Installed koni sports + H&R race
  65. newby here looking for keyless entry and fog lamps
  66. FS: 97+ Prelude Wings West RS and Greddy full lip kit side skirt CHEAP
  67. need to know what oil pump i can use
  68. Running Rich???? Help please
  69. A few questions...H22A1
  70. driveway problems
  71. any difference between h22a4 auto and manual engine?
  72. problem with my lude. how do i fix this?
  73. What cams for my h22 all motor setup?
  74. rear exhaust section question
  75. Where to buy a B-pipe for my 92 Prelude.
  76. ABS Code
  77. AEM Pulley install...engine out?
  78. problem getting in gear on first; clutch or tranny?
  79. f22 tranny on h22a4 99 lude....
  80. 5th gen sound systems
  81. 92 lude a/c wiring
  82. how do i adjust the clutch on a 1995 honda prelude Si
  83. Valve Adjustment Specs (Need Help)
  84. Suspension HELP?
  85. someone please help......
  86. Rear sunshade from Honda
  87. Intake Manifold Gasket 4 Pieces!
  88. 97' stock SH 1/4 times...?
  89. msd digital 6 plus, 2 step rev limit...
  90. 5th gen hesistation when starting
  91. Need to go faster
  92. 90 Prelude head swap????? GSR possibly if I can?????????
  93. rpm issue
  94. Tapping lifters???
  95. Odd sound...
  96. ATTS problem
  97. size of fittings and hydraulic line for clutch line.
  98. 95 prelude turbo
  99. 92 lude s1 for sale...needs work
  100. what dizzy do i need?
  101. Broken tranny from pothole
  102. another stupid headlight bulb issue
  103. is the negative terminal the ground?
  104. Pic Request: Wiring harness 92-95 VTEC
  105. Big Brake Kit 4th gen
  106. Do i need a new filter on aem cai?
  107. obd-2 tuning
  108. help with failing smog...
  109. Right side tail light doesnt light up..
  110. carbon fiber mirror
  111. 215/45 or 215/40 tire size?
  112. Problem with Neuspeed spark plug wires
  113. Question about h1 harness (spade terminal) jdm headlight
  114. recharing battery
  115. skunk intakemanifold
  116. the answer for rev up and down syndrome!!!!!!!!!!!!!!!!!!!!!!!
  117. dont you think b20b(CRV) head fit b21a1 block?
  118. Strange Header Sound After Install
  119. 5th gen light problem?
  120. battery question
  121. Radaitor fan switch?
  122. H22A engine manual? Anyone know where to find out how tight you have to tighten the bolts/screws for
  123. 99 Prelude Radiator Fan Not Coming On - Help!!!
  124. anyone selling a 97+ grille?
  125. I need help
  126. already searched, working on my first 92-96 lude can't find the damn ecu jumper?
  127. OVERHEATING? 97 Prelude overheats when at a stop?? What's going on??
  128. advance/retarding cam gears with NEW CAMSHAFTS?!?!
  129. 5th gen on Eibach Pro-Kit - How's low is it?
  130. Car cuts off when i stop? (5th gen.)
  131. Does RC make an injector that plugs into the factory OBDII injector harness
  132. abs speed sensor help
  133. What's the set-up for long term storage?
  134. Breaking in a rebuilt h22a4, whats your school of thought?
  135. Type S.. prelude SH?
  136. 225/50/16 Are they too big
  137. Help please...
  138. best cams for an all motor project ???
  139. Looking for some suggestions please...
  140. Bizzare Clutch problem
  141. Kyb GR-2 vs Kyb AGX vs Tokico Illumina
  142. shift lock release cover
  143. wierd noises coming out of my left front tire
  144. sent a rod through my mofuggin built block!!!
  145. balance shaft belt removal
  146. Switching to Synthetic
  147. Need a Honda-tech assessment on a used Prelude.
  148. 94-96 Center Console?
  149. TRACK TIMES... how do they sound??
  150. Help! How to replace cabin air filter.
  151. how do i tighten the hand brake cable?
  152. JDM h23 vtec into 3rd Gen?
  153. Problem with the Lude' Already!!
  154. Driver Seat
  155. 4th gen wings west headlight eyebrows
  156. Burning Oil!!!!!!!!!
  157. JDM foglights for 4th gen
  158. Clutch problems after swap
  159. JDM H22A Rod Berrings? Sequence? Colors?
  160. test pipe for 95 prelude
  161. Different kind of broken alternator..HELP!
  162. 4th gen wheel rub
  163. 4th gen vtec sputtering in the 6-7krpm range
  164. steering wheel install?
  165. h22a power???
  166. About How much HP will you get from a Pulley set like Unorthodox SS?
  167. please help me......
  168. timing question
  169. parts to fab fule lines?
  170. What are the symtoms if you have a bent rear lower sway bar?
  171. 93 prelude turned off while in idle and would not start back up...?
  172. 6x9 Subwoofer
  173. FYI: 5th gen rear creaking noise / shock knock fixed
  174. VAFC problem
  175. Rubbing possible?
  176. Head Part Swap
  177. H22A4 2001 stock motor swapped into 92 Prelude SI
  178. cooling fans
  179. east coast motor distributors
  180. RUST ON MY AEM INTAKE
  181. Problem with 2.2 vtec prelude
  182. s2000 Antenna?
  183. ACT PROLITE vs STREETLITE
  184. SuSpension
  185. Cannot launch my car (help)
  186. 16 or 17" rims?
  187. something is not right help!
  188. Are these decent springs?
  189. jumpy grumpy lude
  190. relocated the battery but blew the fuse... help!
  191. Found root of idle surge problem... TOP port in tb (*see pics*)
  192. holy bad luck batman
  193. Headlight Bulbs question
  194. Axle Install
  195. steering wheel for 92-96 prelude
  196. Front crankshaft oil seal
  197. Valve seals
  198. Teach me about the Lude'
  199. OBX Valve Cover H22A1
  200. bought new 95 lude si, feedback..... (new here)
  201. NEEd pics of a h22 with any supercharger.wanna know your setup
  202. Would this cause vtec not to engage?
  203. post pics: rota rims on prelude.. 5 gen..
  204. Parts of PRELUDE engine
  205. Tein Flex's (searched)
  206. i need a clutch
  207. Odd sound coming from my intake manifold.....
  208. CEL woes.. code 1 and code 43
  209. H23a crank sensor
  210. h22 heads for an h23?
  211. turbo prelude pressure problem
  212. Do I need a camber kit?
  213. carbon fiber 1/4 panels...
  214. Carbon Fiber 5th Gen Prelude
  215. Goint to have to do the tranny conversion
  216. Jdm H22 92-96 Redline?
  217. Brake Master Cyclinder
  218. 92-96 & 97+ header different?
  219. oil pressure gauge
  220. rust???
  221. Almost finished: Swap Questions
  222. Air Ride for Prelude?
  223. got into an accident
  224. Need some help
  225. Retrofitting AC system with OEM Honda retrofit kit - any experiences ???
  226. tiptronic shift piece
  227. tiptronic sport shift.....
  228. shift lever & air mode buttons
  229. Clutchless shifting?
  230. firing order on h22 distributor
  231. B21 TDC markings
  232. JDM Speaker 1992-1996 installation?
  233. H22 help!!
  234. will 98 prelude alloys fit a 02 accord 4 door?
  235. Selling my 90 Prelude SI for a parts car!!!
  236. last generation prelude engine differences?
  237. Is this considered negative camber?>pics inside.
  238. How low can you go before you need a camber kit?
  239. HEADLIGHT QUESTIONS!!!!
  240. replacing piston rings
  241. Need help finding a prelude owner.
  242. Primed Cappa???
  243. Need Help With Turbo Install
  244. 92-96 prelude wiring harness h22
  245. Handling/Suspension upgrades
  246. Gas Tank Question.
  247. which flywheel be more suitable for a h22 motor?
  248. Back seats removal...
  249. Dc Header Install
  250. Help w/ cousins new Lude
