U2Q7 on board :) At last...
Old Oct 16, 2003 | 06:29 AM
pentaq's Avatar
Default U2Q7 on board :) At last...
Of course it was bolt-on as expected. All clutch assembly fits directly. The gearbox looks much stronger than a regular one: the outer walls are doubled, has more reinforced arms inside, the differential has a special supporting arm. U2Q7 gearbox is much heavier than stock one... No problem with VSS and mounting...
Impressions?
One word: wow
No more jumping on a wet surfaces while starting. You can feel on the steering wheel which wheel is getting the traction. Making corners is awesome I spent whole gas tank driving around in the night
Gears are way shorter and the car accelerates better. Fourth gear feels like it is third
I could also notice that my trip speed is higher... I usually travel at 140 km/h and now it started to be 160-180 km/h as I play with gears more...
pentaq
Old Oct 16, 2003 | 07:03 AM
fastludeh22's Avatar
Default Re: U2Q7 on board :) At last... (pentaq)
what car is that out of? how do the gear ratios compare to a m2b4?
Old Oct 16, 2003 | 07:09 AM
poison's Avatar
Default Re: U2Q7 on board :) At last... (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">what car is that out of? how do the gear ratios compare to a m2b4?</TD></TR></TABLE>
M2B4 (JDM LSD) M2J5 (JDM) M2A4 (JDM)
1. 3.307 1. 3.307 1. 3.307
2. 1.950 2. 1.810 2. 1.950
3. 1.360 3. 1.269 3. 1.160
4. 1.034 4. 0.966 4. 1.034
5. 0.787 5. 0.787 5. 0.787
FD 4.266 FD 4.062 FD 4.266
Accord Type-R (u2Q7).
1st - 3.285
2nd - 2.090
3rd - 1.481
4th - 1.071
5th - 0.870
FD - 4.266
Old Oct 16, 2003 | 08:30 AM
2point6's Avatar
Default Re: U2Q7 on board :) At last... (poison)
Great... NOW WHERE IS MINE!
Old Oct 16, 2003 | 09:18 AM
pentaq's Avatar
Default Re: U2Q7 on board :) At last... (2point6)
I'm looking for that Be sure you'll be informed as I find it.
Start saving your money
pentaq
Old Oct 16, 2003 | 12:54 PM
juicedh22's Avatar
find 2 of them
Old Oct 16, 2003 | 01:56 PM
satan_srv's Avatar
Default Re: U2Q7 on board :) At last... (juicedh22)
how much did it cost? My Euro-R was only 500 pounds
Old Oct 16, 2003 | 01:58 PM
pentaq's Avatar
Default Re: U2Q7 on board :) At last... (satan_srv)
550Euro and let's call it bargain... It's 71k km and runs perfect.
Old Oct 16, 2003 | 02:12 PM
satan_srv's Avatar
mine had 0
Old Oct 16, 2003 | 02:17 PM
pentaq's Avatar
That's why is 25% more expensive Mine, besides of a bit dirt on the housing, works perfectly. No grinding etc. Like new. I poured it with Honda MTF and I love it butter-shifting
Old Oct 16, 2003 | 02:21 PM
2point6's Avatar
I am counting on you pentaq.
Old Oct 16, 2003 | 02:44 PM
SweepeR 7's Avatar
ok im lost on whats going on, but whtas the best tranny for a lude going turbo? i have a 97 SH and since were talking about trannies htought i'd ask...thanks guy.
Old Oct 16, 2003 | 06:07 PM
juicedh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 &raquo;</TD></TR><TR><TD CLASS="quote">I am counting on you pentaq.</TD></TR></TABLE>
I am too
Old Oct 16, 2003 | 08:39 PM
Default Re: U2Q7 on board :) At last... (SweepeR 7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SweepeR 7 &raquo;</TD></TR><TR><TD CLASS="quote">ok im lost on whats going on, but whtas the best tranny for a lude going turbo? i have a 97 SH and since were talking about trannies htought i'd ask...thanks guy.</TD></TR></TABLE>
ok, assuming traction. the shorter the gears the better. hands down. the only time it comes a prob, is when you run out of gear, but then you get bigger slicks
Modified by fastludeh22 at 1:40 AM 10/17/2003
Old Oct 16, 2003 | 08:49 PM
SweepeR 7's Avatar
how much is it for shorter gears? or to change the gears if so possible?
Old Oct 16, 2003 | 10:04 PM
LudeyKrus's Avatar
Modified by fastludeh22 at 1:40 AM 10/17/2003</TD></TR></TABLE>
I always went w/ shorter gears, but for boosted cars the old VW turbo guys say longer gears are better, b/c it loads down the motor more, making for a better traction, heavier boost run...?! I believe that's about what they say...
Personally, i'd stay w/ the H23 tranny just for traction's sake.
Old Oct 16, 2003 | 10:13 PM
Default Re: U2Q7 on board :) At last... (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
Personally, i'd stay w/ the H23 tranny just for traction's sake.</TD></TR></TABLE>
about the only thing longer gears are good for is more lag. a lot of people seem to like the h23 tranny, and thats fine, but for all out accel. and race shorter is better. m2b4 here and loving it.
if you want traction, get lsd and some good tires.
Old Oct 16, 2003 | 10:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SweepeR 7 &raquo;</TD></TR><TR><TD CLASS="quote">how much is it for shorter gears? or to change the gears if so possible? </TD></TR></TABLE>
you have to buy a new tranny, basically. try to get one w/lsd. so far my factory lsd is still holdin it down at 300+
Old Oct 16, 2003 | 10:19 PM
SweepeR 7's Avatar
u have a facotry lsd onur lude? how many lbs are u pushing out? and how much hp? ran the 1/4? or oh sorry is it n/a?
Old Oct 16, 2003 | 10:25 PM
piotrush's Avatar
If I ever go back to Poland (hopefully soon) you HAVE to take me for a ride.
Old Oct 16, 2003 | 10:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SweepeR 7 &raquo;</TD></TR><TR><TD CLASS="quote">u have a facotry lsd onur lude? how many lbs are u pushing out? and how much hp? ran the 1/4? or oh sorry is it n/a? </TD></TR></TABLE>
lsd-yes
psi-~8 for now
whp-272 whp UNtuned@9psi(spiked). it kept crepping so we just richen up the fuel, and retarted the timing. still made 272 on 2 passes. this was on a fully stock motor that had been sitting half disassembled for over a year. has about 80k mi on it.
since then i swapped heads. my built head has full ferria .5mm oversized valvetrain, tit. ret. bumped compression from 9.5:1, to about 10.5-11:1. disconnected balancer belt.(only cause its a bitch to put on in the car). put in walbro 255hp. ported the **** out the wastegate port. changing to 3 bar map. some other little stuff. we'll see what happens on thursday...going to the dyno
Old Oct 17, 2003 | 12:35 AM
pentaq's Avatar
Default Re: U2Q7 on board :) At last... (piotrush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piotrush &raquo;</TD></TR><TR><TD CLASS="quote">If I ever go back to Poland (hopefully soon) you HAVE to take me for a ride. </TD></TR></TABLE>
Yea, right. Last time it was totally screwed
Old Oct 17, 2003 | 04:20 AM
rjr162's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">»
This is true, as is the saying the old VW guys say. I've read it many, many times. NA and Nitrous use smaller slicks that allow for a smaller "final drive" since you'll need quicker accel off the line, but with a turbo setup you want bigger slicks to control wheel spin and also for the longer gears it provides, seeing how the turbo will make up for any difference in accel, and with the fewer shifts it's all the better.
quickster
Nov 11, 2010 06:29 AM
mike001
Oct 16, 2006 10:29 AM
speedking
13
Feb 27, 2006 09:02 AM
Mike95lude
Mar 25, 2003 09:46 AM
Mike95lude
Mar 14, 2003 04:43 PM
