View Full Version : Honda Prelude
- 92 lude heater problem
- Energy Motor Mount Inserts, Bad? (searched)
- how to go from obd II to obd I
- H22 Custom Intake Manifold...No IACV or IAC
- H22 compression, really low. Blowing smoke, say goodbye?
- TDO5 Manifolds or Adapter Plates?
- Why am i still a trial User?????
- ABS Help!!!!!!
- h22a engine build
- h22a cams
- f22 intake manifold, on h22
- can anyone confirm 97+ prelude short shifters work with 98-02 accords?
- Noob Questions...
- Type sh flywheel/clutch questions
- Zero Idle!!! Car shuts down, replaced EGR Valve, and IACV but problems comes and goes.
- whats the name of this gasket ?
- black and white 2-tone 5th gen lude
- You in luck...
- All motor build up... what I have learned.
- 2001 Prelude no heat!!! Please Help!
- -Question about 93 lude-
- type r front lip for 4th gen
- Prelude vs. RSX Type S
- Vacuum Line Sizes
- how much is to much how much nos is too much
- Exedy Clutch/F1 X-Lite Racing Flywheel Question
- weird a/c problem
- eAnyone running E85 on 5gen ludes
- how to get at moonroof drain tubes
- Clutch
- Dizzy help?
- Kilometers or Miles?
- ABS system removal.
- Digital Climate Control
- turbo question
- h22 dizzy question will paypal $10.00 for answer
- Cam Gears and Camshafts
- F20a into a 92 Si
- 5th gen Auto to Manual help
- Help, check engine light.
- B&M fuel pressure gauge on 5th gen?
- 90 prelude in an 87 si lude???
- XTD CLUTCH / FLYWHEEL REVIEW!!!! ALL Prelude owners read....
- Crank Pulley bolt
- Rear Toe Arm???
- Resurfacing head and block deck ... how much do you take off ??
- sandwich plate problem
- Stock Flwheel ?
- Turbo question for 97 jdm h22a
- Need something cleared out, h22a head milled...
- Another Civic Radiator Thread
- Sounds like Marbles in engine?!?!
- h22a engine
- h22a head
- Biggest tire on stock SH wheels?
- Need input on a price for my car
- 4th gen gauge install pic/teaser, center console above radio semi sleeper aka not pillar gauges
- Q for those w/ Neuspeed Race's
- Found Out I Got Water In My Engine What's Options?
- *********Need Your help, ABS********
- How much Nawws i can use??
- Good-Bye Prelude Forum
- removing ps as far back as possible
- Milling the H22a head
- Nautrally assperated vs. forced induction
- MFactory Final Drive gears after 1 year of racing
- p14 pin out
- Variable Air intake
- ATTS Shit
- h22
- 93 VTEC motor into 96 prelude question
- 2000 Prelude Transaxle leak
- Engine problem
- Cooling Issues
- NEED URGENT HELP with hesitation & other issues
- H23vtec built w/12.5:1 comp and Bottle
- Misfire/skip under load and at high rpms...
- Catback EXHAUST!
- Craftsman...when only the best will do
- Installing a gauge behind the dash, need help finding a dimming wire
- *********Need YOur Opinion********
- Prelude problems...
- How much gas am I going to lose while replacing my fuel pump?
- Installing jdm fender markers
- For those 4th gen auto to manual people!
- 5th gen Blue clock
- speed sensor
- hooking up vtech
- H23 Cams
- Top Dead Center
- can't fit usdm downpipe/header onto my h22a jdm - help!
- battery dies fast
- Limp Mode???
- ABS Help!!!!!!
- Installed AutoGauge Tach and now my small light keeps blowing fuses!
- Is it worth getting a GREDDY EXTREME TIMING & BALANCER BELT for $180 shipped??
- Greddy EVO vs Apex'i WS2 (in terms of noise level)
- 93 motor in 00 lude. OBD2 Dizzy not working. SEARCH DONE!
- RSR exmag muffler
- Oversteer?
- c32 question
- gas tank drain plug
- AEM pulley problem maybe????
- jdm downpipe
- FS: Last generation prelude type sh 5spd (traction control)
- h22 question
- HELP compression too HIGH!
- Wondering if anybody would know what would cause Sputtering, erratic idling while warming up, and al
- 1988 Prelude 2.0S MT engine problems need help
- (Contaditory Goggle Info) What is the bolt pattern of a 98 Prelude SH???
- factory radio
- S2000 steering wheel
- How bout some opinions on my setup...
- AC questions
- write up
- Best place to jack car up
- Can I test my TDC/CKP sensors?
- apexi neo install...
- euro r injectors? are they peak and hold?
- question about JDM fogs
- Cam Gears
- Megan Header, hanger issues?
- My 1/4 mile Time????
- Accord type R Lip install
- This Is Why You TUNE YOUR ENGINE!!!!!!!!!!!!
- New shoes on the whip. Mugen Inside :)
- my ride
- Need some help with smog
- Which O2 sensor?
- oil pressure sender unit..
- Flywheels
- are they the same
- my prelude miss fires under heavy load
- Fires.. now... timing
- H22A S engine swap to a 89 prelude 2carb
- question about OBD2 H22's????
- Car runs... now.. just want to double check the firing order....
- EL cluster conversion
- Will this fit my 5th Gen?
- heart transplant
- My lude's build-up... start 3/15/07
- *Help* What size tire and how low could i go with these rims???
- My Prelude shuts off on the freeway!
- Gagues all messed up....
- Motor mounts- options
- What cams?
- Headlight Question
- Any one have experience with OE replacement front bumpers?
- a pillars
- fuel rail
- Headlights stopped working
- instrument cluster
- Camshafts?
- RS*R Cat Back
- MES connector location
- Help! Need Ecu pin outs for jdm p13 AUTO 4 plugs
- shocks and springs
- My 1992 Prelude S Project
- This tire still good?
- taking aprt the oil cooler?
- Injector Installation
- 5th gen seats
- 4th gen JDM headlights what kind of bulb?
- 98 prelude sh rear speaker problem?!!!!!!!!!
- 95 prelude VTEC engine harness diagram
- question on rods n pistons
- cylinder #1 misfire after stock header install.
- a little water
- p/s and alternator pulleys and underdrive pulley.... which belts to use
- Help! What basic upgrades needed?
- AWD is it a Option?
- Header decision needing advice
- illumination doesnt work
- need to pass a smog in cali
- 99 Prelude Random Code!! p1399 Car started running like crap.
- removing evap stuff on 5th gen
- F/R Suspension Diagram ????
- internals
- car dies???????????????
- How to grease shift linkage ??
- My 89 prelude.....H22 project vehicle.
- Oil filter bolt
- Good shops address for Prelude's parts in Miami?
- Clutch replacment
- transmission syncro
- JDM Front clip
- need to polish valve cover...
- m2b4 rebuild
- H22 now in my teg - check it out
- CV Joint
- i need some help..questions about climate control and gauges..plz help
- ESP - header comparison - dyno proven
- H22 Gear Set Question (I searched already)
- silencers and resonators
- Where to buy H22A Type-s oversize pistons with rings?
- Important Safety Recall: Ignition Switch
- F22 ECU
- Can muffler
- 96 h22 injector question
- Prelude intercooler kit?
- Injector help please!
- about to lower my 97lude, what should i change?...
- H22 Swap
- h22a4 swapped accord i hear clicking from the dash while driving and the lights flicker
- Clicking sound when first accelerating, not while turning.
- Car running like dog poo!!
- h22 trans oil?
- spark plug help needed
- aftermarket motor mounts(searched)
- question about piston ring install gapping issue on type s OS pistons
- White Gauge Face Plate
- Where Is The Best Place To Buy An H22A1?
- Tinted Windows
- if i remove driver side aigbag..
- Transmission rebuid???
- Just bought another lude
- bumper repair (San Diego)
- H22 Cam timing
- Thanks
- Dyno results and findings
- obd2 h22 vs f20b
- test pipe..
- 92-96 OEM Spoiler LED Length?
- h22/h23 build question
- Troubleshooting code?
- transmission(will it butt up???)
- Honda Prelude Transmission-Help!
- Second best place to get oil
- gasket
- will f series injectors work in my h22?
- adjustable fpr on stock rail
- weird ass noise
- Results of rear lip/ mudflaps install :]
- Complete Bushing kit Install
- Piston help
- Fog Lights ( after market )
- worked euro R injector ports (are they good enough??) (intake manifold type s port)
- Head build and Ferrea
- Driveside seat broke (keeps relining everytime i launch) bracket help...
- Did I Install This Damper right?
- Gtech RR Comparison: 95 Prelude VTEC before and after mods.
- Euro R intake manifold
- F22b........ time to swap.
- Type-S Piston in H23A1 Block ?
- turn signal mod
- Forbiden...zzzz
- Haynes or chilton
- HID Connection help
- JDM H22 head vs USDM H22 head
- vafc2 or a hondata set up? lude running rich, want to maximize performance on a stock lude searched.
