PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Cutting Slotted Rotors
  2. h22 trans hard too shift, any suggestions appreciated
  3. 90 Prelude SI Performance options?
  4. H22 Dizzy Wiring? Where does the light blue & black/yellow wire goes to?
  5. 1993 underdash fuse box map?
  6. Trying to pinpoint low compressin...
  7. interchangeable obd1 coils and dizzys?
  8. ATTS codes
  9. Brake issue
  10. 5th gen high clutch engagement
  11. h23 swap
  12. unplug my atts ecu
  13. compression check psi for a h22a4 engine
  14. swap mount kits question
  15. S2000 wheels on 5th gen prelude
  16. thermostat housing question ...
  17. skunk2 pro2 valve lash
  18. Part # to JDM H22A 10.6.1 CR pistons in std or oversized / where to get them?
  19. JDM F22 swam to JDM h22a qestion!
  20. This is probably a stupid question
  21. Crappy Speakers need help
  22. timing retard question
  23. 4th gen rim width
  24. 94 Accord Oil Pressure Switch
  25. ATTS pressure sensor problem
  26. Head Gasket (Lowering Compression)
  27. h22 wont pass 6500
  28. Freakish Oil leak on 97 lude
  29. Tranny Speed Sensor
  30. Apexi N1 exhaust?
  31. Failing Transmission ON 5th Gen Prelude
  32. 5th gen suspension
  33. JDM fenders
  34. Code 43 - Please help!
  35. boosting an H23
  36. headwork
  37. Long Term Effects of ATTS 5th Gen Preludes
  38. OBDI engine harness and distributor into OBDII lude questions
  39. Power steering fluid leak, take a look.
  40. can someone help me with compression test.h22
  41. what all should i do??????
  42. LEAVE feed back so we can get some gears made for out H22s
  43. EL Harness
  44. ****ULTIMATE H22****
  45. need some help
  46. 84 prelude 1.8 clutch issues
  47. number 1 turbo for h22
  48. Let's talk about struts and coilovers...
  49. H23 Vtec ?'s?
  50. i got a ? concerning my oil pan!!! help plzz!!
  51. H23 Vtec what pistons to use Type S or H22a4
  52. 2.2 Engine
  53. Engine swap coming soon..
  54. H23 Non-Vtec Base Map ...
  55. hmm question about vtec ?
  56. any one with an SH
  57. i want to get to 300hp
  58. Trying to pull the cylinder head off...
  59. JDM TCS swapped at last :)
  60. Dual Exhaust 97-01 ?
  61. limp mode and code 21
  62. Honda Prelude Service Questions
  63. E-Beer. almost friday
  64. Prelude S cat on an Si?
  65. FLYWHEEL and CLUTCH
  66. h22 in a EG...what do i need???help plz..
  67. ingalls camber kit - upper control arm mount or Balljoint?
  68. oil cooler question...
  69. Where can I buy bulb adapters for my headlights 5th gen
  70. H23 build- Opinions?
  71. body kit help.
  72. suspension advice...
  73. project advice needed... all is helpful
  74. drove through crazy puddles need help!!
  75. new here with a few questions
  76. nut and bolt torque specs
  77. Need some experienced advice on H23
  78. Rota subzeros
  79. Engine rattle getting louder
  80. clutch pedeal engagement inconsistent with temperature
  81. H23 vtec
  82. G23 question please help
  83. cd player
  84. Tokico blue struts
  85. help buying new headlights for hids
  86. TPS adjustment
  87. Hit 15psi w/ sc61 on stock block...yikes
  88. Distributor rotor burning?
  89. NO VTEC!?!?!?
  90. Well I think my prelude is near its end..
  91. Clutch lines
  92. Extremely violent window shaking at higher speeds...
  93. Kimini, mid-engine Honda-powered Mini up for sale
  94. H22A 3" Exhaust
  95. Question about boosting a h22
  96. Can anyone help me out with an Oil problem ?
  97. My bb4
  98. Brake Fluid for your Prelude
  99. 3rd Gen Prelude w/ a JDM B20a... i know, i know...
  100. Installing a new wheel stud non-sh
  101. Weird mushy brake problem
  102. Parts for a 1991 Prelude SR
  103. Spark Plugs and wires
  104. h22 pistons?
  105. H23A1 Engine Removal
  106. Need h22a1 Power steering bracket!!!!!!!!!
  107. Will the LSD in my M2B4 swap on to my new M2A4?
  108. Question about the p13 ecu.
  109. f22a to h22a swap question
  110. rim size
  111. engine idoles
  112. 5th gen axleback exhaust on stock 4th gen?
  113. Official "Where Did You Get Your Motor" Thread
  114. Need engine...looking for reputable sellers
  115. Timing Belt Cover - do I need to replace it?
  116. car won't start after swap
  117. clock in the dash
  118. H22a4 best gear???
  119. new dizzy still have a no start problem
  120. suspension installation advice !
  121. Alignment Problem????
  122. auto p13 question
  123. Idle bounce when fans are on
  124. Buddy Club Kit
  125. HELP PLEASE Looking for a H22A crank pulley ASAP !!!!!
  126. what do you use..
  127. Any Exhaust System tips for a noob?
  128. Anyone have any vtec solenoid cover?
  129. My Prelude Build (K-swap)
  130. Timing belt keeps breaking!!!
  131. 2 wire 02 sensor.... Cant find a replacement
  132. What (if anything) can help stop the h22(a4) from burning so much oil?
  133. Problem with Innovative H22 lower alternator mount
  134. misfire......
  135. tune without ems on stock pcm?
  136. Got a small problem with new KYB GR-2 strut.
  137. Diagnosis
  138. Bog/misfire above 30% throttle after running 10+ min
  139. lower balljoint squeak
  140. Skunk2 Throttle Body Issues
  141. 5th gen exhaust on 4th gen
  142. My JDM H22A won't engage VTEC
  143. HELP! looking to build my h22
  144. Gauge Clusters
  145. need help big time 96 prelude...swap with obd1 h22
  146. Engine turns off while driving
  147. front stabilizer link broke, any other part compatible?
  148. new brake lines..
  149. Intermittent VTEC
  150. Will i pass Emission with the Knock and 02 Disabled?
  151. adding pics to a new topic (noob question)
  152. I need a picture of the preludes under belly!
  153. Windsheild wiper issue 1992 S Model
  154. Mahle Gold Piston wrist pin size
  155. alternator making horrible sounds
  156. Help please, my prelude is having problems
  157. 4th gen seats transplant into 5th gen?
  158. need help wid setup
  159. replacement 1/4s
  160. 93prelude si 2.3-abs light code 43...need help
  161. 5 gen front bumper evolution (base and SH)
  162. Need Some Advice!
  163. Whats The Correct Ecu for the Jdm f22b
  164. F22b Again :(
  165. Wing on a 5th gen...
  166. where do i find the ecu on 97 sh to hook up a/f ratio gauge
  167. Unknown ECU??????????
  168. FS: Mugen Oil Cap & PasswordJDM CF Spark Plug Wire Cover for H22
  169. I'm sure this is covered but any info on Xenocron Tuning products and software?
  170. Vtec oil pres. sensor wiring
  171. New to Honda, Need thoughts on a possible purchase.
  172. Distributor rotor screw
  173. Prelude Question Regarding computer systems
  174. Slips out of 5th gear
  175. question about transmission
  176. H series exhaust
  177. What Ecu should i use for My Jdm f22b 4th Gen Prelude
  178. Computor chips///modules
  179. Can someone confirm this information about a tranny??
  180. 1994 jdm h22 swap in my 2000
  181. Axle/suspension Suggestions
  182. need a hondata s300 f22A1 stock base map
  183. turbo h22... need help
  184. how to install 95-96 digital gauge panel in 92-94 si model help please!!!!
  185. turn signal CAI duct
  186. 1997 prelude
  187. Traction issue in 1st :: Not referring to a burnout
  188. Engine damper
  189. Noob Question about F20b
  190. Weird idle problem
  191. Ticking
  192. Looking for a Complete K24 engine
  193. another brake lamp ?
  194. MAIN RELAY fix
  195. Exhaust Delimmas...
  196. O2 Specs....
  197. Rod Bearing Problem 92 Si lude
  198. how to install a/f ratio and oil pressure gauge?
  199. h23 vtec hose question
  200. broken valve spring....what to do???
  201. Why am i throwing a code 6?
  202. I drove a Prelude for the first time.
  203. mod list
  204. Quick pressure plate question
  205. i just got my prelude back
  206. Post up your front lips!!
  207. jdm h22 timing belt
  208. jdm h22 timing belt
  209. 2000 SH valvetrain build and timing belt
  210. Strut tower braces
  211. F22B and H23A Prelude Swap
  212. HOW BIG IS TOO BIG????
  213. k series mounts for 92-96 preludes
  214. My H23vtec 87x95 semi-budget build
  215. Car getting hot
  216. clutch damper prelude 1991 from France
  217. Just bought my first Prelude!!!!
  218. which motor to use daily driver all motor.... f20b or h22a
  219. h22 f23 5th gear question
  220. i need an answer
  221. wheres the other o2 sensor at?
  222. Where do you drill firewall to get power wire thru?
  223. msd coil better?
  224. Are there problems if you touch your clutch?
  225. missing brass rings on coil
  226. D.I.Y painting VC Gone bad (Header Smoking)
  227. 4thgen prelude rear lip/ accord lip
  228. prelude speedometer not working
  229. Anyone running D-Series Alternator in their 5th gen?
  230. Mahle Gold pistons FRM compatible now?
  231. Name this lip
  232. KOYO Racing Radiator Question
  233. Timing mark on flywheel?
  234. Auto Transmission Weird Noise H22 Engine
  235. NGK V-power
  236. clutch pedal will not bleed the lines
  237. gauges
  238. TB/IM
  239. Royal Purple vs. Mobil1 Synthetic
  240. taking out my a/c wat do i do??????????? prelude h22
  241. BB6 back seat removal
  242. Money $hift: Doh'
  243. Fan and A/C Compressor problems
  244. Lip Kits
  245. h23 engine swap..What are possibe matches?
  246. 97 Prelude SH... Car Won't Start
  247. Radiator.
  248. "R" on prop valve, Quick question
  249. Not redlining in 1st Gear
  250. s2k seats in 95 prelude
