PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. is it ok to run a chipped p28 ecu for f20 on a h22 motor?
  2. adjusting tps
  3. 5th gen prelude oem cd player NEEDED
  4. injector area modification for euro R intake manifold
  5. Replacing Struts for 00 SH
  6. Tires on 17" wheels - 5th gen
  7. FRM lining and F20a & F22 engines
  8. Lightweight Fly Wheel Good or Bad
  9. M2B4 lsd vs. M2A4 with quaife lsd
  10. quick question
  11. Need some quick help from someone with a 96
  12. Just got a new skunk2 manifold and 66mm TB----idle problems/check engine light
  13. CV joint
  14. NGK different plug numbers which one to get for 55 shot nitrous???
  15. Measurements/info on the OEM H22 Plenum.....
  16. prelude axles
  17. diy painting how to??
  18. How many miles after adjusting new valves before getting on the gas.
  19. Blew ACC fuse. car wont start.
  20. H22 cam markings???
  21. No FRM on H22A?
  22. need pics of h22 block.
  23. EURO-R Intake Manifold..???
  24. m2b4(1996) tranny onto a h22a4(2000) PirateMcfred**
  25. F20b block w/ H22a head? Will this work, or be usefull in turbo set-up?
  26. can someone give a list of codes for 89 prelude si
  27. Oil Light
  28. p13 ecu problems
  29. How to get to the fuel pump in a 4th gen?
  30. Advice For An F22
  31. 99 Prelude Shift Assembly
  32. vacuum at idle??
  33. h22 oem rod weight? weigh stock rods h22a4 h22a1 (added for search)
  34. 6th gen lude
  35. DYNO OF SKUNK PRO 1 in stock h22
  36. Spun bearing how long will it last?
  37. rims and tires 4th gen accord
  38. AEM CAM Gear for 92-01 H22A1 Prelude For Sale
  39. Too Much Fuel
  40. H22a Vtec
  41. Quick newbie question.
  42. Half size civic radiator on 93 prelude
  43. LMA's keep going bad
  44. long block and short block?????
  45. Throwing IACV code, how can I clean it?
  46. Cryo-treated Stock Pistons
  47. wiper switch
  48. Competition In the Acura/Honda Family
  49. 1996 Used Prelude Si 34,000 - Bad Rings?
  50. To All The 5th Generation Prelude Lovers
  51. Baker precision oil relocation kit
  52. 5th gen front lip only - no sides or rear
  53. why is lightened crank pulley bad but not lightened flywheel?
  54. H22 oil pan question
  55. HELP! Bad Oil Leak -- SEARCHED!
  56. dash lights not working
  57. Turbo Manifold
  58. ? with install on ground control with koni yell sturts
  59. Measurement help - 90-91 Lude Steering Wheel Diameter
  60. CEL for oxygen sensor
  61. How to remove 5th Gen. bumper letters?
  62. p28 chipped?
  63. Venom vcn-1000
  64. Which battery is the best for a sound system...Yellow or Red Optima
  65. Question about the fitment for the JENSEN VM9021TS on a prelude...will it fit?
  66. rc injectors 310 cc in a h22
  67. H22 Adjustable Cam Gears, which isn't prone to breaking
  68. GSR injectors in a h22?
  69. Distributor Help....
  70. Slipstreams
  71. Spoon Head Gasket???
  72. Fuel Injectors -- Pintle vs. Disk Type vs. Ball and Seat
  73. H22 Bog/Backfire
  74. wtb mugen or oem sides for 97-01 prelude
  75. ignition in the number 2 spot. Face plate taken out. is there any battery drain?
  76. Car won't idle/fuel pressure problem?
  77. Car stalling Yes i have searched ... !!! help plz
  78. How to check CEL codes?
  79. How do adjust power steering belt tension
  80. Pic request (TSX rims on 5th gen prelude)
  81. JDM folding mirrors - one side not closing fully
  82. Random piece
  83. RSX Type S exhaust on 4th Gen??
  84. CLutch issues
  85. Engine's
  86. Looking for intercooler pipes
  87. shifter/linkage cable from 4th gen to 5th gen
  88. wtb
  89. intake manifold question
  90. fuel pump question
  91. Glowing cat after H22 swap
  92. moved battery to trunk=4ws light code 20
  93. Lightweight flywheel good for turbo h22?
  94. p13 with secondaries connected to vtec?
  95. H22a vtec
  96. vacum gauge
  97. Valves to tight...
  98. air fuel ratio gauge
  99. base model prelude wheels
  100. Removing middle layer from headgasket safe?
  101. 1997 Prelude SH Sterio Code
  102. ATTS light
  103. Crower S2 cams/RM Valvetrain install ?'s
  104. stroker kit questions?
  105. Engine knock, stalling engine h23
  106. Which is the rear engine mount? H22
  107. 4th gen AC panel led's going on and off (eletrical related)
  108. Headgasket
  109. Advice on my N/A setup (type s cams, euro-r...)
  110. Crank Seal
  111. Help with Tranny mounting
  112. 89 lude intermitten miss and backfire?
  113. clutch
  114. car wont turn on
  115. two quick questions
  116. Cleaning the pistons
  117. SO It's Kind Of A Newbie Question but just need some honest answers
  118. s2k wheel on prelude..
  119. Radiator..help
  120. F22 vs H22 clutch
  121. IT'S DONE! EG- BB foglight Conversion.
  122. engine makes whirring noise
  123. ebay intake
  124. 5th Gen. Prelude Manual Swap ECU Programming?
  125. 96 obdII h22 swap into 95 obdI accord
  126. engine locked up. solutions?
  127. 4th gen exhaust
  128. AM I paranoid? Skunk Cams & Ferrea Valvetrain
  129. 96' Si 2.3 Stats for only a few seconds
  130. Wierd. 4th gen prelude-Car pretends to start but doesnt.
  131. Temp/Fuel Gauge Problem
  132. Tach reads alot higher then motor (searched)
  133. Power steering cap, loop, fluid , no fluid??(PICS!)
  134. motor/tranny question
  135. engine shops in So Cal... are there only 3? *searched*
  136. 4th gear feels notchy
  137. i neeed some jdm headlights
  138. Tips on Brake Pad Install
  139. headlights died, not working
  140. Claying an engine
  141. will home depot or similar places make a copy of my car key?
  142. Fuel Pump Wont Prime
  143. Turbo kit for 5th gen
  144. What company makes a 2.5" cat-back exhaust system for 5th gen ludes??
  145. Injectors?
  146. need help asap
  147. Tire Questions???
  148. Need fog lights!!!
  149. anybody use k20 oil filter on a h22?
  150. Installing oil pressure sender/gauge
  151. Trunk won't stay shut
  152. Car is bucking between 70 to 80 mph.
  153. How do u check for ABS codes on 92 Prelude?
  154. auto h23 to auto h22 OBD2a 96
  155. cant find the right belt
  156. SAFC II pin out for PK2 OBD0 ?
  157. nothing
  158. Wheel Size
  159. so it's been realy cold lately and now when I try to start my car the key won't turn
  160. JDM h22a Checklist
  161. should I be worried about these lobes?
  162. 98 prelude wont start none of lights on dash turns on??? help
  163. M2f4 vs the following
  164. what goes here?
  165. Manual rack conversion problems
  166. Losing Compression and burning alot of oil
  167. Replacing valve stem seals with head on
  168. h22 stroker kit questions
  169. Removing front headlights
  170. JDM Climate control
  171. door doesnt unlock in the winter
  172. having idle problems
  173. E85 Prelude????
  174. Stock H22 Cams
  175. 92-01 Lude Owners with Tein SS/HA/etc.
  176. BDL/str Throttle Body
  177. engine proble. HELP
  178. 5th gen front lip
  179. How loud is your H22?
  180. Should I change wires and plugs before I tune or does it matter?
  181. front lip
  182. H22 PISTONS IN AN H23?
  183. Electical Short???
  184. Re: 5th gen ECU is it OBDIIa or OBDIIb
  185. All motor H22 set up?
  186. 4th gen. preludes?
  187. JDM Sir S-spec ECU code ?
  188. pilot bearing??
  189. B series to F Series
  190. skipping speedo
  191. h23 crankshaft
  192. Rest In Peace Earl Laskey
  193. Pulley Eccentric ?
  194. Spun bearing H22a, should i fix it??
  195. quick tranny question
  196. VR4 Turbo on H22...?
  197. Identifying a small piece
  198. brake calipers problem
  199. constant velocity joint
  200. New Breaks Installed
  201. check engine
  202. anyone try AMSOIL Synthetic Synchromesh Transmission Fluid 5W-30 in their transmission
  203. Odyssey Battery Location---WTF man....
  204. Installed my header now Im missing slightly.
  205. starter problem?
  206. What are all the parts to do 5th gen SS to 5spd?
  207. Help can't find a part
  208. Feeler: Fast Car
  209. What next?
  210. Cam Timing Off a Tooth??
  211. WTB 92 prelude heater core
  212. broke the lens off the corner of usdm headlights
  213. Skunk 2 IM problem with Type SH
  214. Water pump/ Oil pan
  215. Aftermarket H23 Manifold
  216. from h23 to h22
  217. m2b4 tranny with no lsd??
  218. JDM headlights, wha kind of bulbs?
  219. Shaved Powder coated H22 Valve cover on H23
  220. Wont Start PLEASE HELP!!
  221. what's the best intake manifold?
  222. 2001 Prelude
  223. anyone know if i can run 88mm pistons safely with stock sleeves? h22a block?
  224. UNORTHODOX help
  225. NRG quick release install
  226. water inlet pipe removal, tech assistance requested
  227. Crank pulley TDC location PLEASE HELP!!!!
  228. how does this set up sound
  229. SRS airbag light reset on a Prelude
  230. checking h22 timing...advanced or retarded too much?
  231. 4-1 vs 4-2-1 header
  232. Running rich, have tried everything
  233. h22 crankshaft dowel pin problem?
  234. Seat install
  235. OBD2 to OBD1 conversion?
  236. Help!! how to tell h22a injectors from others??
  237. Si badges
  238. Heater blowing cold air after H22 swap
  239. Clutch Pedal no pressure
  240. 97 h22 5th gear tranny grind.
  241. pic request... *wheel help*
  242. h22 tranny issue
  243. h22a
  244. Oil Pump Options for h22
  245. :+: Need H23a p14 ECU Pin diagram:+:
  246. Need Help badly
  247. Difference between a 4th gen. 1996 tranny & 5th gen. 1997-2001 tranny??
  248. What could be wrong?
  249. Built H22 Turbo Dyno Plot - Pressed in iron liners
  250. The "What Parts from other motors could physically FIT" Thread
