PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. F22/h22/H23 Build Questions
  2. 2001 honda prelude splitters
  3. Cv axle help
  4. 92 Prelude Headlight Housing?
  5. Valve spring Compressor V-Tec . . .
  6. valve cover question
  7. 1997 Prelude Base A/C issue
  8. .
  9. sidewinder turbo manifolds
  10. turbo h22a4 high miliage?
  11. 1992 H23 to 1994 H22 . . .
  12. cams?
  13. new car! some pics, and some question!
  14. Good setup?
  15. JDM H23A swap into 5th gen lude .. ?? help ??
  16. Hey guys im new, but worries about my mpg...
  17. 93 Si for sale
  18. THERMOSTAT HOUSING
  19. H22 intake gasket leaking?
  20. Begging for help for my son....
  21. 93 wit H23 trans and F20B motor?
  22. Grounding Wire
  23. help! need some help on car
  24. Why isn't the prelude popular?
  25. new prelude owner
  26. Engine running lean!
  27. help remove ac
  28. 97 Auto tranny swap. Need help.
  29. Cant get my idle down past 1700rpm
  30. anyone have pics of gold painted stock blades?
  31. 5th gen: 16x7 +40 will it rub?
  32. NEED HELP!!! 98 prelude Swapped H22A4 for a H22A
  33. Mishimoto thermostat gasket?
  34. Nevr ending PS problems!
  35. Prelude Color B-64P
  36. Changing radius rod bushings...
  37. question about 99 prelude stock rims
  38. 1993 hood latch problem
  39. Tiptronic slamming into 1st from 3rd
  40. Help? Removal PS
  41. Moog adjustable upper ball joints
  42. OBD1 f22a1 Main Relay + 92 Si w/ f22a
  43. F23????
  44. 86 prelude good buy??
  45. Removing Engine help! 5th gen
  46. prelude petition
  47. h22 tranny questions
  48. 99 Prelude Fuel Trim Malfunction/Too Rich Bank 1
  49. bluetop swap
  50. H22 overheating at idle
  51. 3rd Gen problem - fans always on. Please Help!!!
  52. prelude round track racing
  53. Any suggestions for a Short Throw Shifter?
  54. 3rd gen SI overheating...or is it????
  55. H23 Vtec fuel injector size and compression?
  56. doing a clutch on h22, stupidest question ever....:)
  57. Skunk2 h22 pro2 cams
  58. Chipped ECU Question
  59. Instrumentation / Dashboard Lights Problem
  60. 92 h22 vss sensor question!!!!!!!!!!!!
  61. new to HT
  62. HELP! I'm at a loss
  63. Exhaust puffing?
  64. clutch advice
  65. Anyone using VTEC Controllers?
  66. A/C Help
  67. Fidanza flywheel 45k later...
  68. anybody have any ideas on tucking the bay of an H22?
  69. Time for new street tires *Help*
  70. 92 Prelude F22, F23A swap
  71. Looking for a body kit
  72. LMA questions..
  73. Tilton petal and master cylinder set up????
  74. h22 euro motor im
  75. Omaha/Midwest Prelude Meet
  76. shocks?
  77. jdm fog lights problem
  78. cam shafts?
  79. Will it fit?
  80. H23 to H22 swap guide
  81. Intermediate Shaft Bearing
  82. BB6 NON ABS MASTER CYLINDER
  83. picking up a bb6 prelude
  84. jdm h22a speed problem
  85. h22 type s swap in sh, help???
  86. what engine will fit h23 tranny
  87. bb6 inteior conversion...help.
  88. Need your technical advice
  89. manual tensioner woes!!
  90. 93 clutch problems
  91. H22a code 22 came on >>vtec pressure valve<< ?
  92. Problems replacing the fuel pump
  93. where is this sensor located on the vehicle?
  94. ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - March 2010
  95. ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - March 2010
  96. jdm f22b dohc on prelude. what axles do i use
  97. f20c in a 93 lude wit h23 trans??
  98. H22 oil consumption question.
  99. OBD1 ECU + Immobilizer
  100. major prelude problems
  101. BB4 dash and brake light problem
  102. Prelude and H22 Reliability
  103. Another prelude noob
  104. looking for BB4 parts
  105. Prelude Vacum lines
  106. Need advice on headers and exhaust!
  107. prelude h22a wont start please read.
  108. HELP! Alternator or Battery or What?
  109. H22A4 Block with an H22A1 Head?
  110. tuning options?
  111. 5th generation type S chassis numbers
  112. Want to do future H22 swap into my Ludey..
  113. Showing CEL Multiple Codes
  114. turbo coolant lines?
  115. 93 prelude f22b1 timing belt/ balancer belt
  116. Cluster pinout for '01 lude.
  117. have a jdm f22b dohc motor and need part specs
  118. WTB Koni sports needing rebuild
  119. h23 trans...what rpms should i be at?
  120. Auto TO manual Tranny
  121. h22a from 94 accord into 97 prelude
  122. real spoon h22a ecu, advantages?
  123. Just got 99 lude now what to do?
  124. 4th gen Lude. Digi Fuel and Temp Gauge. Problem.
  125. 3rd gen water leaking in trunk & back seat plz help!
  126. 5gen: massive oil leak, bolt breakage? pics of leak point
  127. 4th gen floor mats....where to buy
  128. can someone indentify this engine mount h22a
  129. I am new to honda-tech
  130. Timing Belt walking off.
  131. will this motor work
  132. h22 swapped cb7, drivability issues, no cel, checked timing
  133. help with vafc tuning
  134. my car took a sh!t on me this morning
  135. ITB'S ON H22 TURBO ?
  136. Prelude one of the best
  137. h22 exhaust manifold gasket?
  138. Need help with information
  139. new member, 2.3 idle issues, HELP! please
  140. one last valve question
  141. New Parts?
  142. G23 (F23 block/H23 Head) and Emissions....
  143. TB for Euro-R manifolds
  144. prelude map sensor
  145. Prelude start/ no electrical anything problem....
  146. Help, I heard a loud CRACK?
  147. H22A4 Won't Start.. Help
  148. how do i convert from carb to fi?
  149. F22a4 timing Question
  150. Need help pinpointing this noise...
  151. H22A4 Shifting Problems!! HELP!!
  152. i need h22 help
  153. indecisive about Skunk2 cams
  154. setting up a correct valetrain for a cam?
  155. Defouler Question???
  156. I cant find the right sensor anywhere plz help
  157. Omni power yo
  158. ECU replacement and immobilizer system
  159. 93 lude suspension help
  160. 497hp 403tq h22?
  161. Rods
  162. 4th Gen gas pipe size
  163. does anyone have a write up for replacing a coolant heater hose??!
  164. will 5th gen powersteering rack fit 4th gen?
  165. help me with this set up
  166. Common problems to look for
  167. inputs on 5th gen prelude
  168. idle jump problem
  169. wont go into 2nd..
  170. 5th gen prelude and ap1 steering wheel
  171. bent valve
  172. bent vaLVE
  173. h22 rods
  174. Can't fix radiator leak on drainbolt!
  175. 4th gen mishimoto radiator
  176. H22A2, why only 185hp??
  177. H23a3?
  178. My new '89 Si......
  179. H22 and H23 a/c compessor the some?
  180. alternator not responding
  181. 4ws prelude question
  182. Gauging Interest for Products From Hybrid Racing
  183. h22a and h22a4 issues
  184. Piston rings
  185. 4ws light is on
  186. Question about my tune with oem cams
  187. help me choose transmission
  188. honda prelude f22b engine
  189. clutch/tranny problems 93si
  190. engine oil and valve help on h22....
  191. First time lude build.
  192. Identify this aftermarket company?
  193. F22a/H22 WHICH ****ING HEAD-STUDS???
  194. need help
  195. engine tick video inside plz help
  196. need help with my 2nd gen tranny swap
  197. 4th Gen rear engine mount
  198. Help! Question about fuel for my 5th Gen 'lude
  199. JDM Headlights?
  200. H23/H22 with type S pistions/cams ??
  201. Cel P0170 P0171 Please help!!!
  202. 97 compression test results.. what now??
  203. single vs double exhaust
  204. Little Things for granted.
  205. Need Help! Prelude 4th Gen Engine Hydrolock
  206. Headers on a 4th generation?
  207. F22B to a H22A- wiring harness questions
  208. Getting A reaplace ment Head
  209. speed needle not moving?
  210. Vibrant Performance timing belt tensioner without power steering relocation
  211. 3rd gen cabin air intake filter?
  212. crankshaft probs
  213. valve issue
  214. I dont know how to turn off caps, help!
  215. need help asap
  216. H22a vtec not sure about advice i got
  217. 95 Prelude Vtec Problems. NEED HELP!
  218. best h22 swap
  219. Replaced ignition switch...car starts with rough idle then dies...
  220. Rear Strut Bar Install
  221. fuel problem
  222. 1994 prelude 2.2 Vtec help
  223. Custom grease fittings for poly bushings
  224. F22a1 ?'s
  225. Prelude Chassis Tech adjustable UCA review/comparison
  226. h22 swap
  227. Not a prelude but I need help! *stripped bolt*
  228. 1997 Prelude Auto to Manual Woes Code P1655
  229. Haynes Repair Manual Online?
  230. TAX SEASON SALE!!!!
  231. 89 Carbureted Prelude rough idle
  232. engine keeps shuting of HELP
  233. H22a4 problems need suggestions
  234. Cannot Open DOOR!
  235. Popular strut/spring combos.
  236. bearing question...
  237. 4gen engine mounts into 5th
  238. What's wrong with my fully built H22a prelude..
  239. apexi neo
  240. is it a must?
  241. 92'-93' Prelude control arms
  242. 92 prelude heat question
  243. H22a4 to h22a keeping OBD2
  244. idling high
  245. jdm f22 dohc timing issues
  246. Overheating.. Fans dont turn on.
  247. 3rd Gen fog light issue
  248. Looking to get a 4th gen
  249. Power Sunroof
  250. Wheel Bearing?
