PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Deciding on Clutch Kit
  2. Ign Coil bracket -- Help
  3. h23 worth rebuilding??
  4. 97 PRELUDE - Fans kicking in late?
  5. h22a balance shafts
  6. 92 prelude fuel pump relay problems
  7. H swap help
  8. H22A4 crank sensor problem
  9. G-Force Prelude 7 seconds?
  10. how high is to high?
  11. how can i tell what h22a i have?
  12. HElp i need to fix my vtec wiring on my h23a due to someone cuttin my wires on it
  13. rough idle/vtec problem
  14. random misfire, misfire on 1 and misfire on 3 at idle please help
  15. Type S head on usdm block?
  16. I'm just might be an idiot?
  17. new 11 sec all motor prelude
  18. ecu problem
  19. Next step for 97 sh lude
  20. New 94 Si owner needs brake help!
  21. 1991 SI speed sensor question?
  22. 1992 Lude Si
  23. 92 Prelude Si Question
  24. Logic Motorsport Header on a Prelude
  25. Wiper arm
  26. Rod Knock? Spun Rod Bearing? - Video Included
  27. ► FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Nov/Dec 2011
  28. 4 wheel steering issue
  29. Hard to start and runs sluggishly
  30. ecu Question
  31. 88 Prelude
  32. O2 Sensor with bad voltage
  33. 99 prelude swap
  34. JRSC and maintenance
  35. Is this gonna be a problem?
  36. high flow cat question?
  37. keep blowing a fuse....
  38. Catalytic Converter Question
  39. How To Check/Set Timing On 98
  40. Intermittently jumpy OEM tachometer on 2001 Prelude SE (VIDEO)
  41. 99 prelude tach jumping and running ROUGH!
  42. few questions on 87 prelude
  43. my 5 speed transmission acts like a automatic
  44. 93 lude headlight problem.. HELP
  45. Car died and no start
  46. To those who race with 94-96 center console
  47. 4-1 Headers
  48. 5th gen prelude with automatic transmission record thread
  49. '93 Honda Prelude problems.
  50. 97 Prelude w/F22b1+H22A4 manual tranny. Need help asap.
  51. crank might be bent, rebuild, e-swap, or bail
  52. Upper control arm?
  53. How many miles from your JDM H22A so far?
  54. H22 head gasket leak (HELP)
  55. h22a4 nitrous help
  56. Rhd BB6 In Canada?
  57. 1998 Type SH ECU in a 1998 base 5spd???
  58. 92 prelude with 94 accord f22b1 sohc vtec
  59. Speedo/Tach Gauge backlight not working. Ideas?
  60. New to Honda-Tech
  61. 4th gen speaker and subwoofer
  62. M2B4 question
  63. Dream Come True - Cleanest Lude
  64. 93 prelude Si throwing cel 7 and 23
  65. No Spark
  66. 99 Prelude project
  67. h22a swap help.. Do jdm ecus check for vtec pressure switch ?
  68. 5th gen Short Shift kit
  69. Air Intake
  70. 4th gen fog light install link no longer up - can someone please upload or send?
  71. 5th gen Rack indecision (Rebuilt vs New)
  72. 2000 prelude h22a swap
  73. H22A compression test results
  74. h22 options
  75. crower 3 cams
  76. 92 Prelude speedometer not working and D4 light flashes
  77. Stock struts On Lowering Springs
  78. H23a1 swap and speedometer doesn't work...why
  79. ball joint safety recall?!!!
  80. Lookin for luders
  81. h22a4 wont start
  82. H22
  83. 2.75" exhaust Prelude 97
  84. H22a4 Turbo?
  85. Weird wear marks on piston
  86. Tachometer Issue
  87. Negative ground?
  88. Automatic H22 tranny question
  89. Tri Y to Apexi N1?
  90. Where to find tsx projector?
  91. Cat-Back Exhaust
  92. NEED HELP wiring dizzy/msd coil!
  93. Need help with Venom Intake install H22a!!!!!
  94. Help! Where does this go?
  95. What should i do? im lost....
  96. Strange check engine light CEL problem
  97. 4th Gen - Clock and Radio stopped working
  98. antenna on bb6?
  99. Will 14" steelies fit on Prelude SE?
  100. Gas tank drain plug leaking?
  101. Suggestions on a radiator....?
  102. Rear toe problem
  103. psud3ity's oh hai honda-tech thread
  104. 1990 Prelude -Cannot shift to 2nd, 4th, or Reverse
  105. 01' Prelude Sh: Turning off, and Hard Starts...
  106. How much did you pay for your prelude??
  107. guge converter
  108. Remote Central Locking
  109. Ninjas 93 Lude: Introduction
  110. quick question with probably an easy answer
  111. weight difference in f2.2 and h2.3 vtec
  112. Transmission question. M2u4 SH tranny gear set into other h22 or f series tranny?
  113. Fuel Requirement on H22A4
  114. HID or Halo's?
  115. Anyone know where this connect to?
  116. Loud VT after tuner 2 swap (with video)
  117. 4th Gen Remake
  118. H22a4 head question
  119. 98 Prelude Head Gasket
  120. AEM fuel pressure gauge
  121. 2000 Prelude - Strong Gas Smell on Driving - after Intake Manifold cleanup
  122. 94 prelude si h22a or 97 b18c1
  123. 3rd Gen Si issues when accelerating
  124. h22a in prelude bad tranny or something else?
  125. need advice with my h 2.2 hydraulic tensioner on my timing belt please!!!
  126. need advice with my h 2.2 hydraulic tensioner on timing belt please!!!
  127. Coming to the dark side...1996 Si
  128. Rear view mirror
  129. CL1 spoiler on BB6 ?
  130. why is the h 2.2 not respected like the b 1.8 by many ?
  131. Rays Gramlights 57s (pic request)
  132. accord coilovers on preludes???;
  133. b16 or h22
  134. how can i increase the ho on my h22a4??.
  135. how can i make my prelude lighter??
  136. h22 block/h23 crank
  137. 3G electrical issues - please help!
  138. need help with ecu
  139. How to: Vtec Brake Upgrade
  140. H22 Help
  141. h22a4 help no vtec
  142. Idle issues, please read
  143. 98 prelude wont turn battery dies only when ignition turned
  144. 5th gen prelude kswap
  145. Help on Prelude
  146. Distributor Problems... Questions Need Answer...
  147. 98 lude sh, knocking/scrapping noise
  148. Halo Projector Head Lights Assembly - Please HELP
  149. Dsm 450cc blue top injectors on a h23a vtec
  150. eg skunk 2 struts on a 92 prelude si
  151. 1992 Lude
  152. Door Speakers/Vtec head Swap on 95 lude
  153. Told to dp am H2B setup?
  154. MD23vtec goes 9.41 @ 159 at E-town
  155. Oil Leaks,busted boots and wobbly pulleys HELP.
  156. Valve stem seal replacement with head on
  157. Fifth Gen Radiator...
  158. 98 base model prelude with that fun no starting problem
  159. 98 base mofel prelude with that fun no starting problem
  160. Wiring for H22a EGR Questions? not running good
  161. CV Joint Replacement - Difficult?
  162. 1992 Prelude Headlight Problem
  163. 1997 Prelude F20B swap questions.
  164. 1994 prelude si cloth converted to black vtec interior help!
  165. major electrical problems after flood
  166. Dash removal 5th gen?
  167. f22a1 performance
  168. Jun Camshafts
  169. haunted sunroof
  170. new to preludes, total failure, need help with 90 si states edition gold top
  171. any other mirrors fit on preludes? or which is closest...
  172. ATTS on an H23?
  173. power sterring pump bracket mount needed
  174. Thinking about Buying an 3rd gen Prelude
  175. b series TB
  176. prelude problem! (sorry if this isnt the right place to post)
  177. F22b1 into 93-96 Prelude and Vise Versa
  178. Can ATTS be added to a base model?
  179. 1992 prelude with H22 having problems! please help
  180. quaife install diy?
  181. want yo buy 97-01(bb6)engine harness
  182. Valve tick...
  183. Head gasket thickness for H22 turbo build
  184. best rim choices for the bb6?
  185. H22/H23 wire harness pictures
  186. LSD Tranny for sale?
  187. Time for the first major service H22A, any suggestions?
  188. Just bought my first Lude!
  189. 97 prelude compression test result questions
  190. key on engine off tach reads 1000 rpm
  191. 2001 Prelude Keyless Entry Issue
  192. 3 inch exhaust setups/prices/ideas
  193. h22 for sale?
  194. h22 trans question
  195. intermitten no start
  196. bought my first prelude today. i have a few ?s
  197. Who is "LUDEGRL"?
  198. Clutch issue
  199. Which ECU and where?
  200. What are the most cost effective mods?
  201. problem starting my 99 prelude up
  202. 92 prelude single cam f22 water problem
  203. H22 p28 question
  204. 16x8 xxr 002's 0 offset fit on prelude??
  205. ES bushing issue, need a part #
  206. Whats the best Kind of trans fluid
  207. New user rust removal question
  208. New 98' Prelude SH Owner (Pics) Need Help
  209. 1998 Prelude SH Battery
  210. 85 si boggs down until 3500 rpm or so, then takes off.
  211. Problem with Crower valvetrain
  212. Motor question
  213. H23 in 4th gen issues
  214. EPIC H22A1 VTEC GLORIOUS SOUND! #2
  215. EPIC H22A1 VTEC GLORIOUS SOUND!
  216. 5th gen door speakers... I searched to no avail
  217. Low idle at cold temps. Stalling. Please help!!
  218. question about a random plug
  219. Sunroof swap questions
  220. H23VTEC build problems! :/
  221. How much HP do you think i can make?
  222. Need help on skunk2 pro series manifold for 97-01 prelude
  223. 4th gen vs 5th gen.
  224. Intermediate half shafts .. 92-96 vs. 97-01 Base .. different part numbers ?
  225. quiet muffler. ?
  226. brake booster differences
  227. vtec brakes 57mm bore?
  228. What steering wheel hubs work for the 4g?
  229. vtec question
  230. A/C System Question.
  231. select cable for my 5 speed?
  232. H23 intake manifold?
  233. Rear glass
  234. Prelude similarities to other Hondas
  235. A little help.
  236. 1995 SI prelude oil pan
  237. Flywheel weights!!
  238. JDM F22B Dohc non vtec timing belt
  239. Strange RPM issue after Transmission swap and new clutch, help anyone?
  240. 92 prelude s ecu to run with h22a4 boosted ???
  241. 5 speed Shift cable question
  242. help please? turn signal wont work
  243. Screwed timing belt
  244. 4th gen seats and rail mounting question
  245. SRS Light
  246. Hid Fog Problem.
  247. Swapping cylinder heads
  248. How about seafoam?
  249. h22a4 installation Question
  250. 92 prelude h22a swap clutch starting issue
