PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 [129] 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Any tall 5th gen drivers in here? 5'11" +
  2. h22 crank pulley + h23 alternator pulley + h23 ac pulley = ?
  3. Megan racing h22 header.how good ist?
  4. Strange idle when moving, and shaky accelerater
  5. used speed cluster
  6. JRSC power???....realiablity???? powerband?
  7. a transmission questions
  8. Is the RS-R ExMag still for sale anywhere?
  9. fast tail light help!
  10. 1992 Prelude Si non-vtech
  11. S2000 in a 92.
  12. Prelude AC Issues
  13. yellow bulb
  14. weird tranny tooth count and gear ratios
  15. How hot does your valve cover get?
  16. a'pexi ws sound
  17. 4th gen front side bumper light wiring relay problems.
  18. Jdm parts: Add or remove value
  19. Max Speed coilovers--> good or bad??
  20. Nippon pistons type S for H22A any experiences???good???FRM compatible???
  21. I need 97 h22a4 tranny bolts
  22. Looking for a good H23A DOHC non-vtec
  23. H23A to F22B swap
  24. Opinions on Invidia N1
  25. what you think ? thinking of selling my prelude
  26. first time workin on prelude, need help with swap and auto to manual conversion
  27. speedometer gone out rev limiter fine
  28. H22 w/ P28 questions...increase or decrease fuel?
  29. titanium retainers and valve springs
  30. 95 Prelude S - H22 Swap - What parts from which car? Modification?
  31. venom vcn-1000 on fifth gen
  32. 89 si power window problems
  33. instrument panel / gauge cluster install, fit
  34. 4th gen spoon lip
  35. '88 si starting problems
  36. Abs light??
  37. whistling exhaust
  38. 92 Prelude A/C Problem
  39. Speedometer Problem....bad VSS?
  40. 96 H22 Tranny on 97 H22? (Auto)
  41. Faulty Crankshaft Postition Sensor
  42. H22 Turbo Manifold
  43. KYB AGX and Eibach pro kit reviews
  44. H23 Crank
  45. Parking Light removal
  46. Torque Converter Fluid Question
  47. p72 obd2 with hondata!!!
  48. h23 catch can setup
  49. exhaust questions
  50. What is a Aem Fuel rail
  51. OEM Replica front lip?
  52. Compression with spray ?
  53. What parts should I get for Timing Belt change?
  54. really weird noise on my lude
  55. problems with innovative mounts
  56. Coolant in Intake M.
  57. 1997 to 2001 prelude hid light for sale
  58. new ecu new keys?
  59. Smoke upon start up
  60. Quick Question: Main Relay.
  61. Wheel Bearring Question (2gen)
  62. IAT sensor.
  63. 4ws error
  64. :( with 1/4 mile time, Problems? Injectors, etc?
  65. Es Tuning Exhaust
  66. h22 problem
  67. Looking for a good manual for a 1992 Si
  68. should i do a 2.5" collector mod on a megan header, any1 do this?
  69. Jdm climate control - Anyone install one?
  70. h23 h22 vtec
  71. any1 know how to open a .drf file from dyno?
  72. Gas Mileage between base and sh
  73. 92 prelude s/si starting problems
  74. ................VAFC..H22a..................tuning
  75. obx twin loop exhaust.
  76. Help please!
  77. Idle still low at times
  78. driving around with no fans, how good of an idea is this?
  79. Cusco Catch Can
  80. resetting computer???
  81. bad idle when a/c is on
  82. *Confused* how do i gauge the rocker arm clearense
  83. 96 Srv problems
  84. Best Transmission for H22A4
  85. sound when braking
  86. Rod bearings
  87. Window Vent/Wind deflectors Question?
  88. OBD1 p13 on a OBD2 car
  89. Car won't idle after installing cam gears!
  90. MHR Performance Shop
  91. Knock sensor interchangable?
  92. clutch fluid issue on 5th gen sh
  93. NEED HELP, 4th gen brake pads/rotor swap...
  94. Need Help, Starting problem
  95. Tranny Nightmare
  96. Headgasket Issue? Losing coolant and burning lots of oil
  97. Gen 5 Front dash speaker cover
  98. Header/cat/exhaust help...
  99. 5th gen H22 with an automatic upgrading head is it safe?
  100. H22 Lag Through Low RPMS (0k - 4k!) Need Help!
  101. how do i fix my air vent? 5th gen prelude
  102. New Bosch o2 sensor, worse gas mileage WTF?
  103. H23 vtec????
  104. N/A motor compression question
  105. Smog Test
  106. h22 tranny problem
  107. 87 prelude
  108. EGR hose removal question
  109. ITB...worth it for the $$ ?
  110. How will this sound ?
  111. Ferrea or JUN valve springs and retainers
  112. Pricing for 97-01 leather seats
  113. 5th gen rattling sound
  114. How to pull codes on 5th gen
  115. Short shifter
  116. Clutch problem? 4G
  117. high flow cat, which type to buy?
  118. TW: 4 18" Momo X-1's w/ tires
  119. need help with crank pulley bolt
  120. Took camshafts out, need help reinstalling and set timing.
  121. what color white for a 97 lude
  122. Another Turbo Question h22a (Yes, I searched)
  123. H22A wiring searched!
  124. 3rd gen Prelude H22A swap!
  125. A new 4th gen prelude on the scene!!!!
  126. HELP! cali. smog
  127. How do I install high beams on my 5th gen prelude
  128. Please Help !!!! Idle Problem, all sensors good. Now what?
  129. Who has a bike rack????
  130. Noise
  131. H22A NEW EGR Question
  132. Simple Question, hoping for a detailed answer
  133. ecu help plz
  134. CF Integra Mirrors on 4th gen 'Lude?
  135. 5 lug conversion
  136. Stcok header
  137. Rear mount question for 5th gen
  138. o2 sensor problem
  139. Check engine light heater malfunction?? o2 sensor??
  140. EL oil pressure guage problems... need help ASAP
  141. Can't find a certain fitting for a Prelude SS clutch line...
  142. Suggestions for timing belt issue please
  143. h22,Bad surging low idle, won't rev high, timing bad?
  144. Best place to wire things to... 12v source
  145. Broken Clutch Pedal Bracket
  146. how much boost on stock h22a4 injectors?
  147. Took my ej8 H22 to the dyno (vid/graph)
  148. got pulled over again
  149. Lowering prelude's
  150. need real bad
  151. changing clutch hose
  152. new AEM SRI problems
  153. something blew up and i dunno what... :(
  154. cheap camber kit
  155. Anyone here running the Nuespeed rear sway bar on their 5th gen?
  156. hood pins.
  157. Cutting bump stop in shocks
  158. how do you remove your factory steering hub?
  159. how do you pop off the cruise control... controls?
  160. Help Setting Timing?
  161. 5th gen prelude ac system removal
  162. Bilstein Sport - spring perch
  163. clutch pedal
  164. Loose gas cap
  165. stalling while driving and stopping??? help needed fast!
  166. ATTS Light.
  167. Compare Prelude f22a to Accord f22a
  168. Power steering removal ....... legal ??
  169. adjusting my valves
  170. Sqeaking noise...
  171. Tranny grinds only when clutch is pressed
  172. 5-lug conversion on a 4th geration
  173. 90 - 93 accord f22a1 to 92-96 prelude f22a1
  174. need to pass a thin wire throu firewall... help
  175. gas grades
  176. Boosted H22
  177. coolant drain and refill/flush questions
  178. high milaged body
  179. so the type s cams are bad for stock internals?
  180. h22 tb question
  181. h22 head gasket question
  182. 3rd gen a/c problem
  183. OBD2 to OBD1 wiring haness
  184. Antenna Removal
  185. exhaust set up.would this work??
  186. Leaking injector problem
  187. acheive 450hp with H22A4
  188. Autometer guages? help me PLEASE!!!
  189. BB Squad
  190. venom fuel rail problems
  191. suspension quetion(NEED HELP ASAP)
  192. switch indicator lights for switches never come on (cruise/fog/half/ABS light also)??
  193. cruise control
  194. Buying Prelude. Need serious help
  195. rust in engine bay
  196. What Manual Transmission will fit H23
  197. Rear bumper detaching and side lights.
  198. S2K seats in BB6
  199. 2 problems with my 4th gen prelude. help please
  200. need help with tires
  201. Knock Sensor question...
  202. couple probs i need help with for my 94 Si please
  203. front license plate
  204. Timing Belt Tension.
  205. transmission hybrid
  206. mild engine build? Please help!
  207. shocks/struts?
  208. Buzzing Main Relay cause Solid cel and no start?
  209. How to find the burned fuse? need help ASAP
  210. h22a swap
  211. h23a1, not sure what to do with it?
  212. i can't aim my head lamp b/c the up and down tab is broke
  213. 5th Gen lude.. just bought it. weird noise.
  214. 4th gen, 5 lug, rsx type-s
  215. replacing alternator on 4th gen
  216. H23 crank vs H22 crank?
  217. Can I do it for around a grand?
  218. energy suspension hyperflex
  219. radiator??
  220. engine bay cleanup!?
  221. IACV - removal?
  222. 93 prelude vtec, missing 2nd ecu fuse plz help « » 2:39 PM 7/11/2006
  223. Need some opinions/suggestions from the H22 professionals.. check this out please
  224. External coil : What year cap?
  225. hi-flow cat
  226. Spark plug drenched in oil---searched. Plz help!
  227. where did you buy...
  228. Problem with Skunk2 TB
  229. boosting then a loud bang
  230. Eibach springs
  231. Vacuum Lines
  232. speedo not working and other misc quetions
  233. Euro-R Intake Manifold Vacuum Lines
  234. 1st, 3rd, and 5th nothing....
  235. +.5mm intake valves
  236. 4ws code 20 related to recall??
  237. exhaust size reduce???
  238. Tucson, Az Turbo OBDII cars help. (searched)
  239. 93 prelude vtec, missing 2nd ecu fuse plz help
  240. knock sensor for 95 h22a1 - can i use one from any other engine/year/model??
  241. Prelude - good deal or no deal?
  242. Stereo Mounting kit not fitting in 97 Prelude
  243. 94 and 96 si models
  244. battery not charging ??? please help
  245. 99 Prelude Shift linkage
  246. New Version Apexi Rev/Speed Version...what settings to use?
  247. coil wire
  248. How much hp do i have??
  249. Need help breaking loose the Crank pulley bolt
  250. FITV repair (does coolant system need to be bled afterwards?)
