PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 [163] 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Buying a Prelude?
  2. Strange sound coming from engine. Please help!
  3. abs problems
  4. koyo radiator???
  5. 92-96 lude best suspension for street??
  6. h22 firing order?
  7. Could use a bit of help?
  8. A T T S is it more problems then good ??
  9. Spark Plugs
  10. H22 time?
  11. NEED JDM H22A TRANNY ASAP.......know any websites?
  12. Looking for some advice...
  13. anyone help me find
  14. MSD Coil Blaster, can't get it going ?#$!
  15. 89 Prelude Just cranking after Head Repair (car's 1st, now I need MY head fixed!)
  16. S300
  17. 1996 lude with a 2000 vtec swap
  18. you think vortech will ever come out with a supercharger for us ludes?
  19. drain bolt thread size?
  20. JRSC?on a 94 h22a
  21. EL Digital gauges 4th gen (Old exist mileage, searched)
  22. mugen parts
  23. random tech. cats (searched)
  24. Leather Interior Swap 4gen
  25. H23 Stuff W/ H22 Stuff??
  26. Oil leak from drain bolt
  27. need a Write up on At tranny install
  28. shortened swaybar links??
  29. poll: h22+h23 h23vtec, bull or no bull?
  30. extended studs + notch method = ok?
  31. 98 prelude stock weehl size
  32. 225 series tires with 18s: do they fit on a lowered 5th gen?
  33. track
  34. Speaker locations and sizes for a 94 vtec
  35. Bad gas milage and strong exhaust smell ?
  36. 92 si ?
  37. 95 lude
  38. Ring Gap
  39. tried installing JDM LSD
  40. i love my car
  41. test pipe question again!
  42. 5th gen headlight cover lense
  43. searched, how do i clean my EGR ports!?
  44. Full H22 Swap
  45. anybody have video of a supercharged prelude??
  46. Searched-Hasting Rings On H22a4
  47. fuel filter
  48. subfram braces (5th gen.)
  49. Titanium
  50. Opinion needed:buy this lude?
  51. 5th gen ELD question
  52. 1989 Prelude Si 4WS specs?
  53. Trying to supercharge. HELP!
  54. ATTS - life and what happens at the end? -searched-
  55. tranny blew a hole
  56. H22 tech question
  57. H22 will not pull or turn up past 6k!!!!
  58. m2b4 lsd tranny
  59. Suspension setting question?
  60. Benson Sleeving Web site??? phone #???
  61. scatter shield...
  62. Exhaust
  63. carbon Issue
  64. Help me choose a tire size...
  65. Pic Request.. JRSC on a 5th gen lude...
  66. suspension advice
  67. Prelude ECU...P72 question????
  68. H23 Sleeving question
  69. stock H22A1 retainer
  70. Suspension questions for 4th gen prelude.
  71. dyno'd car today
  72. 2 Questions
  73. H23 Oil Filter Relocation???
  74. 85prelude broken T-Belt is head ok?
  75. Taking out the A/C and power steering!! i need help
  76. blower motor removal
  77. Exhaust Decision
  78. Code 43 help...
  79. SRI or 2.5" CAI?
  80. external coil to internal coil?
  81. 15's or 16's on a 4th gen
  82. compressing auto tensioner?
  83. v-spec suspension system ??
  84. Differences between h23 & h22
  85. How do I access the stock sub in Gen 4's
  86. ok i found out the ebay drop intake is gay now what
  87. header/downpipe issues
  88. CSF radiator.. wtf? plz help
  89. 97 Carbon Fiber hood OR Zex nos kit
  90. help Crankshaft bolt/pulley
  91. 97-01 or pre-97???
  92. shift linkage
  93. Chrome exhaust tips
  94. 14 inch wheels fit in the rear of 4th,5th gen preludes?
  95. monster tach or shift light
  96. H22 Head onto h23 block
  97. Tranny Experts - Will a JDM OEM LSD work in USDM tranny case?
  98. Dome light wont come on when driver's door is opened (4th Gen)
  99. where to buy h22...searched
  100. VAFC plug and Play..question
  101. Valve Clearances on n/a build
  102. Rocker Arm Piston Test Question - H22A
  103. Mugen Exhaust For Type SH
  104. HELP i think im screwed can someone post a pic................
  105. 5th gen prelude help on reving
  106. 5th gen prelude help on exhaust
  107. Wheel Hop?
  108. Auto meter A/F gauge reading 9-10 LED bars with A/C on!
  109. Preludes'
  110. MSD blaster coil wire install on 01 prelude
  111. ebay "carbon fiber" intake box for 4th gen
  112. F22A/B in 5th gen prelude?
  113. upgrading external coil
  114. Exhaust Decision
  115. ECU upgrades
  116. What's the verdict ? Balance shaft belt removal and engine reliability?
  117. RCA connectors?
  118. AEM Bypass Valve
  119. Oil cooler nut size
  120. dc rear lower tie bar
  121. 93 h22a block, 97 h22 head?
  122. clutch problem
  123. CEL--->Cylinder position sensor?
  124. front drop intake
  125. M2A4 5th gear woes...
  126. 97 prelude overheatings problem HELP!!!! before i trade it in
  127. H22 header
  128. does anyone have the timing belt cover for a h22
  129. tightening timing belt
  130. Symptoms of what?
  131. hondata s300 or greddy ultimate
  132. electrical problem, cant figure it out
  133. knock sensor question.
  134. 1998 prelude ecu problems!
  135. Best Mod After I/H/E
  136. Help with crank pulley
  137. HPOA.ORG
  138. Meter fuse keeps blowing(4th gen)
  139. Anyone running Tenzo-R GT5's or Enkei RSV's?
  140. shocked on shocks
  141. - Car Won't Shift Into Gear -
  142. is this a good set-up for autocross?
  143. Will an smsp header fit a greddy sp2 exhaust?
  144. NEED INFO 90 PRELUDE H22 SWAP
  145. can a harness be attached to this?
  146. SAFC for H23?
  147. Plug differences ? Copper plugs
  148. ...h22 tranny options...
  149. What's the ideal comp ratio for a streetable NA car that can spray nitrous as well?
  150. Gas mileage
  151. b16 head on b20a block??
  152. Exhaust systems?
  153. DOES THE 4G PRELUDE COME STOCK WITH SWAY BARS, JUST GOT MINE NOT SURE
  154. a few questions?
  155. H23 tranny ?
  156. Can u switch out the vtec head?
  157. 99 and up prelude headlights
  158. Skunk2 coilovers with Illuminas?
  159. type s cam/ piston question
  160. What kinda numbers?
  161. a/c problem in my brothers 4th gen?
  162. timing belt issue
  163. headgasket+mill,will pistons hit valves??
  164. Exhaust Sounds?
  165. wwrs kit(searched)
  166. what intake?
  167. Plug Wire Resistance...
  168. 3rd gear 75000 RPM slipped into 2nd gear big problems
  169. PLEASE HELP
  170. wat exhaust system on a lude B20a4 ?
  171. How to Sunroof Removal?
  172. 88 lude clutch
  173. hpoa for sale?
  174. 92' lude won't crank sometimes; also crazy rattling/grinding sound at about 3100 rpm
  175. I can use this crankshaft ?? * PICS *
  176. Odd skipping/grinding sound on brakes only in gear - 4th gen
  177. new brakes and bearings.
  178. prelude si worth it? or just get a 2000
  179. JDM Prelude question
  180. Complete 4gen Leather Interior Swap (Katzkin kit)
  181. I had a question about Turbos
  182. 92' lude won't crank sometimes; also crazy rattling/grinding sound at about 3100 rpm
  183. Intake Sound
  184. Coolant smell
  185. FOR ARIZONA OWNERS, tucson mainly.
  186. Car wont start plzz help!
  187. 97 prelude lip
  188. oil pressure problem when warm
  189. Balance shaft eliminator kit install Question
  190. radiator brackets?
  191. Gimme your honest opinion on the VIS techno-R kit... (5th gen)
  192. progress sway bars
  193. Which exhaustand header would you recommend if I want to do a NA/nitrous build-up?
  194. 92-97 Questions
  195. F23 swap in 4th gen
  196. 13.4 @coastal plains, NC
  197. Indiglo Gauges
  198. Megan 4th gen.......
  199. 92 Prelude Si help!!
  200. cracked radiator?? how??
  201. distributer
  202. Just bought a 94 Prelude vtec with 73000 miles in mint condition
  203. Apexi intake filter for 01 sh, will 92-96 fit?
  204. Opinion on vtec controller
  205. Looks like hpoa.org is dead...
  206. Stock Headlights for sale!
  207. Angel Eye Projector headlights...not an easy bolt on for 93 Lude
  208. 16 inch wheels on 3rd gen Prelude - ride quality?
  209. anyone have a transmission manual
  210. weird electrical problem
  211. Average Power of JRSC 5th Gen?
  212. H23 V-tech. GOOD?
  213. What to do first to my 5th gen?
  214. Why do my spark plug wires keep popping up?
  215. CROWER stock idle cams worth the extra cash ?
  216. Type-S Spoiler?
  217. My H22CL BAR'd! Thanks everybody. (Pics and long story)
  218. Ignition Upgrade......MSD 6AL or MSD SCI-L for 5th gen.
  219. 93 h23a1 question...
  220. good deal or what?
  221. What should i do Next
  222. Gears are acting up!!!
  223. H22a HUGE power loss... WHY>?
  224. Aem Pullies 92-96 VTEC
  225. CAI Assembly
  226. Engine clicks during low end acceleratin
  227. code16 fuel injection - little help
  228. Car dies, no power in system, no battery light, not the alternator... (searched) HELP
  229. 5zigen FNR01-C on a prelude?
  230. bb4 h23 questions
  231. Spec II
  232. can someone help
  233. jdm ecu
  234. vtec engagement issue
  235. Need Oversize Bearing Please help
  236. Need assistance with a progress 27mm adjustable sway bar
  237. What do i want?
  238. Lowering 93 4WS Need suggestions
  239. Cold Start idle bouncing?? (searched)
  240. OBX Camber Kits
  241. when will somebody STEP UP and fabricate this manifold....
  242. boost trouble
  243. Intake manifold removal steps for 97 SH
  244. how many map sensors are on the 92-96 h22a
  245. cant pass smog
  246. What could cause my prelude to stall?
  247. AEM V2
  248. ROTORS
  249. Looking to get a new exhaust
  250. car accident
