- look to buy a prelude
- Oil burning around vtec
- Timing camshafts to TDC
- b21a1 "vtec"???
- JDM (type s) cams in USDM H22A4
- door panel help!
- where do you buy all your parts?
- High Oil Pressure
- Pre H22a drop checklist( I searched and did my homework)
- help with starting issue
- h23 non vtec
- need help from lude guys for my hatch
- 92 Si Starting Problem
- wheel question!
- H23 head swap?
- Which knuckle ball joint?
- How to Smoke the USDM sidemarker bb6
- 88 Accord wife put pos and neg cables on backwards.....
- Transmissions... How is yours
- intake control solenoid valve
- Abs control unit...
- CEL Code 7 - Throttle Position Sensor Assistance
- 97 h22a4 head bolt size?
- help purchasing obd2 to obd1 harness
- early redline
- What HID kit???
- what is an axleback?
- putting an h23 dohc si into a 1989 crx
- Question about Valve adjustment specs
- help! cam cap bolt part numbers
- Very Foggy Interior Windows 5gen
- fully built h22a TURBO project
- which tranny is better f22 manuel or h22 manuel
- what kind of injectors do i have?
- 550 injectors to big?
- b20 question
- AFC Neo
- h22 intake mani flange
- problems adjusting tokico illuminas
- F22B1 from 96 accord into 96 prelude
- Clutch pedal issues....
- How to install Window Visor for a 5th gen.
- turbo kit
- control panel
- Clutch Line Leak
- Torque specs...
- How to adjust tension on alterntor belt
- need specs on jdm injectors and TB
- jdm digital climate control in 2000?
- 4th gen antenna replacement
- Honda Lifetime Seat Belt Limited Warranty
- Difficult question, i hope you noobz are up for the challenge
- procharger supercharger placment ideas
- shower me with wisdom
- jdm h22 in 92 lude si need help
- skunk2 on SH
- 1998 Prelude Maint. Light half yellow/ green
- SH to base
- will innovative 4th gen Rear enigne mount fit on 5th gen?
- Oregon import shop
- Exhaust fitting
- ecu precautions before removing
- Speedometer not working
- Tien Springs on Stock SH Shocks
- Base and SH gauge cluster
- Prelude won't start
- what can i do to increase my high rpms?
- Crazy h22a timing issue, wtf is going on?
- GReddy VS Vibrant
- Should my tranny fluid or engine fluids be replaced, or clutch?
- Spark Plug Issue>?
- screech sound from clutch?
- mahale gold all motor pistons?
- Interest in custom 5th gen floormats
- balancer shaft seal retainer..
- for the mid pipe
- I got the car dyno'd today
- 86' Prelude Doorhandle
- Recommended Camber kits
- Question about nitrous and an H22
- Car won't start?Wtf?
- Check Engine light
- Retainers for Skunk2 springs
- need help again....
- So my stolen 96 prelude was recovered...
- Alarm malfunction
- will P5P ecu with on a base model motor?
- I need some helpful input.
- turnkey h22 race motors, are they really worth the drop of coin?
- HID bulb size!!!!!!
- Tokico "blues" vs. KYB GR-2 shocks
- will USDM h23 knock sensor work on usdm h22a4?
- Megan Racing Cat-Back Exhaust any good?
- high idle
- car only runs on 2 cylinders and wont rev past 3500! need help. searched
- auto-manual daily driver= hp safety limit
- help disassemble trans
- why do i lose power on second gear??? 93 prelude vtec
- cold air intake
- SH/Base exhuast difference
- h22 sroker
- NEED HELP
- fan knocking?
- H22 swap to F22...
- Odd Ignition Switch Drain Problem.
- h22a alternator belt
- Using 97auto engine harness on manual transmission?
- h22 type-sh help...please..!!!
- h23 block with h22 head or h22 block with h23 head...
- paint color help
- 99 prelude auto tranny problem? Please help!
- h23 vtec
- Looking at a '93 Prelude VTEC, some questions.
- No fifth gear
- F22 sohc to H23 swap
- vafc
- Oil in the cylinders? on Built H22
- 4th gen w/ 90-93accord trans
- Random smoke issue ....(H23)
- Auto to Manual Timing Belt Tensioner (new?/cheap way) auto failure failed
- accord oem front lip
- 1997 Prelude, how do i know if it has Factory keyless entry???
- Help! Timing Camshafts?
- clutch or trany problem i never seen before
- OEM front lip
- Camshaft upgrade on stock bottom end
- H23 Compression Test
- 70 - Ignition is turned from OFF to ON while driving
- 5th Gen nearing 150k...what to replace?
- Aftermarket Radio install trouble!
- Part number questions
- Idle Issue
- rewireing distributor? help!!!!
- Head CC with flat valves
- Need help on motor. i did a f22b1 swap and it cranks but wont start.
- Disscussion of cost and efficency NA Vs FI ( turbo)
- 91 Prelude SI!!
- What to look for when buying a head?
- h22a4 transmission question?
- turbo or supercharger or n/a
- prelude auto transmission
- OBD1 Oil pressure switch bypass
- foglight install with relay?
- h22 crankcase breather/catchcan setups
- Head Removal ?
- fix ticket
- Knock-off Dry cell batteries! someone link me!
- H23 vtec oil squirter question
- Quick question re: F22 crank/rods
- passenger airbag?
- 97 Prelude H22A - which auto transmission
- Looking for an LSD Tranny
- Please help me with part numbers for timing belt on '97 Prelude
- Timing belt tensioner question.
- IACV target RPM for idle control
- Check engine light is on and not steady RPM
- Leaking sunroof.
- how do i know if my p13 is chipped?
- A little help please.
- clock spring question
- how to install autostart
- Troubleshooting Help
- 4th gen interior?
- Skunk2 TB on H22, no cold idle
- quick question: oil splash guard needed??
- Remove Resistor Box and run Saturated Fuel Injectors in 4th Gen?
- installing tacho-need help asap
- Starting Problems with a 92 Honda prelude w/ 95 H22a
- Removing amber from rear tail lights (4th gen)
- _+Timing or compression+_
- H2U5 tranny in a 4th gen?
- 96 vtec ECU code
- p13-L12
- question about trunk emblem
- Oil light stays on
- Egr Nonsense
- 2nd gen prelude group buy on suspension.
- will an lsd fit
- Does Anyone have these Projector Headlights 5th Gen
- all right...im starting a back up plan B.
- my car starts but when i put into drive it doesn't move.
- SH engine is shot, rebuild or replace?
- BB1 Prelude's compression
- Running Isolators on Cockpit mounted gauges
- help with diy jumper harness
- H22a injector lag time?
- CHip 5th GEN Prelude...
- h23 oil jets help or not?
- power steering problem
- which ecu to get or should i get it
- side mirrors heating problem
- Lowering the lude.
- question about powersteering
- HOW TO: get BETTER replies from people with experience
- HELP No Spark!
- Will a Euro R exhaust manifold fit on a 92 Prelude w/ H22?
- after my rod bearing went out... the motor idles all the way down... why?
- H22 Vtec Problem? Please help!!!!!!
- pic request
- Wheel Hop
- Car Randomly Dies
- H22 ecu ??? 2000
- RC injectors
- changing corner light
- you'll see
- Need h22a cam cap part#'s
- HELP
- re ringing an h22
- H22A AUTO/MANU ?
- Oil Pan - Drain hole stripped out
- brake balance ?
- F22B DOHC into fifth generation Accord
- why does the h23a3 has 158 hp and 152ftlb?
- how do you jump the prelude
- shaved side marker. dual filament blinker/side marker LEGAL?
- what to do what to do
- axle shake probs m2b4 trans
- Close to stalling.
- boosted h22a4
- Starting/running problems
- MORE POWER!
- quick wiper question
- BB8
- please help!
- will 99 h22a4 work in a 1998 Honda prelude
- GReddy Header vs DC Header
- Transmission Problems.
- Need help verifying a diagnostics error.
- h23a1 forged rod piston combo?
- JDM retrofits
- hid for the 5th gen
- TPS problem
- Bore out a H23 TB?
- Where Can I Find Yellow Hids For My Prelude?
- H23a1 Problem.....and just wondering about swaps??
- prelude-S2000
- Magnaflow Mufflers
- ADVICE!!!!! Recaro SRDs in 5th gen.
- H22 oil leak
- Difference in Auto and Manual Halfshafts
- Quiet Muffler for 5th Gen?
- Custom Rage Header
- how many inch drop
- DaMN This motor...please help
- too long the legs, too short the hands?
- 'legs work'
- JDM H22a and Type S pistons
- H22 Egr an Iacv problem?
- Oil Pressure Switch wire Gauge
- rod cap came off h22 prelude
