- Oil Pump Difference
- shaved door kit
- h22 weight?
- P13 Ecu problems
- Red Maintenance Key......G-D DAMN worthless piece of shit......#2(continued)
- Some advice for a H22 swap
- Does anyone know the pinout for the IAB?????
- H22 Wiring diagram and vaccum diagram. Anyone have one?
- apexi ws question
- 12s' prelude
- Tein S-tech springs....Anyone have them?
- lining up balance shafts for belt
- Need pics of Power steering rack, the lines and the Engine bay for a Power steering removal kit
- Is a bypass valve necessary for the V2?
- Customs and regulations in US...
- Help Me Troubleshoot My B*tch....I Mean Prelude
- DC Sports Short Shifter Adapter
- type s cams info...
- 3rd gear
- redlining...harmful?
- Prelude Rev Hard 4-2-1 manifold
- Anybody have a cable reel they aren't using?
- h22a swap, immobilizer problems?
- graduation money what to do with..help...
- TPS problem possibly broken
- Honda Prelude Computer
- looking for technical info
- First mod?
- Flowmaster on Honda?
- Jumping ECU on OBD2 Prelude to advance/retard timing?
- ECU ?
- why not to use badger, sleeves on high boost apps....
- Looking for 97 and up Prelude for sale in Chicago
- The Red Maintenance Key--Word to the Wise Don't Lose Your Car Keys
- Hot brakes on a track (video)
- Ported H22 manifold
- Ported H22 intake manifold
- 4th gen Automatic Tranny reliability/life span?
- differential rebuild question
- RE: jun prelude ex. piping design
- control arm interchangablity
- what system is everyone rolling with nowadays?!
- prelude hesitation
- FMIC sizes?
- I mis-shifted.....
- 4th gen prelude h1 harness
- Jackson Racing Springs
- h23 rebuild Parts???
- induction kit OBX
- Misc bolts for the engine?
- 92 h23 si running rough at idle and missing
- HP estimates help!
- idle problems.. err yea.
- EGR CEL question
- 5th Gen AEM big brake kit
- Parts list for auto to manual tensioner swap?
- repairing CF hood...need help
- To syncromesh? Any experiences
- Greddy Turbo Kit for '01 Prelude
- has any 1 used jb weld
- 1/4 for the stock lude 4gen vtec?
- How do you read an Engine Code??
- Can you Identify this tranny??
- Check Engine Light Doesnt Work
- h22a 92 prelude swap to 88 prelude
- Car tilts?
- base or SH???
- placing vtec calipers on rear
- h22a lsd
- nitrous help
- ZEX WET nitrous for automatic 2000 prelude non sh
- Automatic or Manual Faster...
- how can i get up to higher revs?
- Simple Vtec Question
- 94 prelude si 2.3
- Quick help on getting rear strut out
- Amplifier power wire: drill or use existing hole?
- itr 5 lug calipers and rotors same has bb6?
- what do you think
- Intake Manifold?
- no weight on rear left wheel
- Can I use my USDM trans/ecu with a JDM h22a?
- who has heard about ohio sleeves??
- H22a4 SKUNK2 STAGE2 CAMSHAFT & TYPE S PISTONS - QUESTIONS
- Is This A SCAM?
- I dont know why I cant remember this... H23 crank in a 98+ H22 Q's????
- Help - 94 Prelude S radiator fans...
- Greddy Type 24 intercooler
- juns
- some good (non-technical) news for prelude fans
- Anyone ever weld the combustion chamber of the H22???
- Cel problems.
- 98 or 103 octane
- rear suspension removal?
- Engine studder???
- Blueprints for 4th gen Prelude.
- Ring Gap
- SOLD my Lude sniff sniff
- H22a4 SKUNK2 STAGE2 CAMSHAFT & TYPE S PISTONS - estimated wHP?
- how to find 1992 prelude stock fog light switch wiring location?
- my lude vs hyundai s coupe
- any feedback on the crower stage 2 cams?
- Alternator problems!!!!!! 89 prelude, anyone with alt. knowledge please help
- Random Tech Cat converter any good?
- has anyone gotten their block done by z10
- Dual Exhaust
- piston compresion ratio
- an you remove or turn off ATTS on a 2000 SH
- help with AC!
- Took some mroe weight out...
- s-afc
- V TECH baby!!!!!!!!!!!!!!!!!!! Everyone read :)
- Prelude "H" emblems..
- removing a/c compressor, what belt to use??
- 2.3L VTEC
- 11 second Prelude....
- a few FRM questions
- Base and SH catalyctic converters same lenght?
- Need to know whats been going on in the lude world the last 8 months. Warning alot o f ranting.
- Fuel Pressure Gauge on Stock Fuel Rail 5th gen?
- !ATTENTION ENGINE BUILDERS! Need your opinion
- Tranny fluid
- Looking for pics of a h23 combustion chamber...
- 97 SH and 98 SH...any difference???
- Installing universal o2...
- Radiator fan problem
- water pump trouble ...
- Modifying SH Exhaust to fit a Base model.
- Put in new clutch/flywheel - first impressions and questions
- Oil leak in h23 prelude
- Need help with my 2nd gen Prelude Si
- need a few parts and have a few questions
- can you guys tell me some things about 92 LUDES?
- M2b4 rebuild help!
- Prelude Swap kit help>.............
- H22A vtec conversion on a non-vtec '93SI prelude?
- Turbo for 99 Prelude
- anr header or skunk2 cams
- Can anyone help with a dealer price/discount price for OEM Part...
- exhaust leak ...
- O2 sensor test pipe?
- B series motor in 4th gen prelude... why cant i?
- 5spd conversion on 5thgen.
- memory button....
- advancing timing?
- Whats a good muffler for my prelude
- Ghetto Fab Turbo H23
- startin up my engine problem?
- Ignitor problems?
- Vacum leak
- What Should I Do Next?
- throttle cable
- Advanced Timing
- My 1/4 mile time???????
- code 21?? vtec solenoid
- 4TH Gen Prelude Question
- Thermal Stealth Owners, question.
- Free Mods!
- 89 Prelude moonroof leaking water?? HELP
- I have no VTEC!! WTF??
- changing tranny fluid.. a few questions!
- Stumbling and hard starting. Help!
- JDM OEM intake:::: where does it go?
- replaced fast idle valve, still have problems
- Strange CEL
- installing a skunk2 manifold on a h22 motor.
- Best Clutch and Flywheel for 5th gen Prelude??
- Bottoming out...Question.
- Help with stagnant lude
- Glass Sunroof
- Old strut and camber wear?
- How can I put more HP on the wheels?
- which octane gas?
- What tire Pressure to run with 205/45/17's?
- Whats wrong with the T4?
- no brainer h22 head Q
- CEL from working on throttle body
- fuel pressure
- 91 strut bar?
- 16 or 17" steelies? what donor?
- H22 tranny question
- 2.5 or 3
- weird h22 probs
- CA Bay Area Shops: I have H22a4 engine parts I want installed anyone have any recommendations for sh
- why you can't change 5th gears in your tranny
- Bad Gas mileage.
- H22 Problems
- Hondata is on its way...
- Rubber housing around ball-joint: Where to get this piece replaced??
- Dyno Results: H22a
- DO USDM H22s come with LSD...if so how to tell....??thank you
- vtec controller setup
- H22 Hatchback Project - Max Ouput..?
- What are the valve adjust specs for h23a? Anyone?
- alternator questiion
- Turbo for H22a
- k20 vs built h23 ?? could a j30a v6 fit?
- 97-01 Prelude Bumper Lights...??
- Mb quart speakers ?
- drag/turbonetics
- help electrical problem
- Turbo
- whats the best tire to buy?
- 92-96 tranny and 97-xx tranny
- full-race kit
- is this my s2s1 cams causing this problem
- oil leak
- JRSC for Prelude SH
- ok need help 93 with h22
- Anyone running an oil cooler for their cars?
- To anyone who has bled their coolant.
- H23 Tuning
- Question About Dyno Tuning and High Altitude
- CASTER forward or backwards?
- High Flow Cat: Good thing? Bad thing?
- Wiring Schematic for '98 Lude
- How To Remake Right Hand Drive To Left Hand Drive?
- broken tranny anyone?
- need help on installing springs for my 98 prelude?
- Looking for some fellow luders or car lovers in Irvine
- dash board shaking
- i need help i need pin out for a p13
- Upper Ball joint
- anyone got the honda tool to remove the crank pulley in ct/lower ma area
- how much does a h23 engine weigh
- Prelude Si Cluster question
- help with my turbo
- curious question????
- Those of you who installed suspension on 4WS Preludes. Need help with the rears.
- Greddy front lip
- Need Help with car ALARM !!!! FAST
- difference between base and sh motors
- Oil and A/C
- 4th generation JDM Honda Prelude VTEC shifter assembly...
- f22a problems/radiator fan/auto-revving while AC on etc...
- Help with suspension!
- 450whp@19 PSI....finally
- skunk2 or str ?
- J's intake for preludes?
- Fidanza FW/ACT Clutch: Info Needed
- Where to get a Helms Manual?
- Desperate: Procedure to adjust valve timing, What specs?for stock/ or for turbo
- hydrolock+h23 = new engine ....help me decide h22 or h23-details inside
- H22A & 50 shot wet N20
- i think my piston rings are fried
- Headers/Intake For 5th gen 2.0l lude
- foglight install...
- prelude camber kit
- upgrading h22a engine?
