View Full Version : Honda Prelude
- i wrecked my 92 prelude si what can i put the motor in
- el gauge swap almost done. what should I do about grounding the wire??
- Oil Pan Baffling
- Wald Prelude. Any Information?
- Dropping Gas Tank in 5th gen
- cheap/free DIYs to do when you're bored
- Calling all 5th geners without abs
- motor isnt dropping in
- where is the thermostat?
- Gauge, Vtec, Alternator Problem
- what are the lightest and heaviest stock 4th gen rims?
- SH to base swap
- Weight Distribution
- Prelude SH Suspension Tweaking
- Those with C&R radiator, what fan are you guys running for NA setup?
- Brake Line Flare
- Best Honda Prelude Tranny Fluid?
- Battery Relocation: Do i need an inline fuse?
- Oil pressure check
- when does the stock thermo on a 5th gen go on?
- H22A4 Normal compression rating ?
- wondering if there is a site were i can buy a built h22 for turbo???
- Tranny Install, I need help ASAP
- what is this plug for??
- jdm window visors
- jdm mirrors problem
- f22 turbo
- h22 all motor dyno thread
- Hood Damnpers
- Backpressure Myth and destroying it
- Wheel Bearing Replacement Front and Rear DYI
- Carbon Fiber hood...Find and get paid!
- Need help with wiring...
- S2000 seats in BB6
- what do you guys think is good price for this 92 sir?
- Need to find a few wires.
- Lude won't turn over, thinking it's the fuel pump?
- catback
- Bent rim=brakes squeaking?
- Airbag Replacement question
- Straight Pipe or Cat Back ?
- SRS light
- h22 injetors
- can I remove the radiator fan switch with coolant still in the car
- whats the lenght of the 14mm 1.25mm thread Crank shaft pulley bolt??
- speedometer quite 1988 prelude
- Anybody have their crank pulley shear off key (with bolt snapping) and the journal in the crank for
- Need advice on a bad oil leak on H23a1
- knock sensor CEL =bad peformance?
- i need some advice....how far can....
- oil pump problem
- Sheared crank pulley and the key!
- anybody run ~185/70/15? I got great mileage after dropping to 195/65/15
- 5th Gen On H&R Race Springs Question!
- prelude dash swap?
- Interesting H22a intake manifold!
- 1989 Prelude Plug ID Please Help
- is anyone running the mahle pistons with non sleeved blocks
- Removing the Timming belt cover!
- SH 5-Speed vs. Base 5-speed?
- bad engine management?
- Ebay XTUNE SH Header... $68
- PS pump
- Starter??? Relays??? Lights???
- cooling fan?
- car wont start....
- Question on heating problem?
- 88 Prelude coolant leak
- HELP! wiring harness question JDM H22A obd2 into 01 prelude
- do it right the first time....
- H23 vs. H23a1
- Any K20 Gen4 out there?
- ACT Prolite flywheel? check light?
- Ludes in CO
- Major electrical problem
- wiring tucking under fuse box
- tranny problem
- timing belt
- JDM H22 and Tranny Question
- engine swap research.. better/ best engine??
- what is the stroke of the h22 crank
- a/c question
- Prelude 88-headlight
- f22b1 help searched
- Knock Sensor Question - Broken Clip
- h22 head and the f22 block question
- discuss this rebuild kit i saw on ebay interesting "type s rebuild kit"
- steering wheel shaking
- Oxygen Sensor Replacement
- H22a overheat on highway
- Turbo Recommendation
- Injectors Help!!! running lean... running rich....???
- A/C dosent blow very cold. Recharged and converted still nothing *searched*
- how hard is it to put an F20C or F22C in a 4thgen prelude
- Precision turbos any good?
- crome tuning problem
- Ingalls or SPC adjustable ball joint?
- will airbag deploy if i remove srs comp?
- H23 TURBO
- car automatically reading 15psi
- bad idler motor ???
- problems with a/c
- Oil in intercooler piping???
- 4th gen jdm tv anybody have any information?
- 4th gen....disabling passenger door lock?
- 98 head on 96 block
- how to install adjuster dial on strut
- ABS light comes on intermittently
- anyone heard of ES TUNING? muffler?
- H22 BLOCK
- fs h22a4 pistons
- Vapor lock
- Newbie to honda and fwd
- is it easy to break into at 95 prelude?
- Serviced distributor, accidently advanced timing a couple degrees, and removed sputtering from idle?
- Looking for a f22 Turbo Manifold
- What kind of engine has the same clutch as the F20Z1?
- progress sway bar
- P0700 and P0740
- recal void?
- El Gauge Write-up
- 92 prelude sr
- fuel pump relay
- h23 vtec conversion kit
- TURBOING an F22a
- H23 Ringlands.
- A/c acting up turning off and on
- Just did a compression test
- [4th Gen] Window problem.
- WTB: H22a4 or H22a block
- Paint on and MSD Blaster SS
- 5th gen/bb6 prelude spring removal
- 01 prelude
- auto to manual swap 2000 prelude
- h23 crank in h22
- 2000 prelude chip key (help needed)
- Car won't run for long....
- How much shock travel do you all have with Koni Yellows?
- FINALLY ESP 5th Gen Motor Mounts
- Replacing my front speakers, in a 95 prelude
- need help with broken throttle cable(diagram attached)
- what happened to that skunk2 intake mani write up
- JDM H22a motor and trans swap...
- AC on = Car Dies later
- Odyssey PC680 not holding charge nemore :(
- prelude sh headers
- Head Gasket
- airbag question
- Rusty (or otherwise nasty) Gas Tank
- Car burning coolant...
- Prelude Axles
- Should i buy an OEM distributor, or after market, or remanufactured
- odd charging light problem... wierd...
- Car dies after driving?
- Metallic sparking noise from left wheel O_o
- Prelude Vs LS EG Hatch
- trouble code p1399
- JDM Side Marker Installation
- inside distributor the plastic shield, is it necessary?
- Greddy Evo
- Thinking of getting a prelude..
- Smog check coming up, need advice/help
- CEL problem
- do we need the powersteering cooler in my prelude its a 1992?
- Will a 98 Accord body harness on the firewall work for a 98 prelude?
- Question about the A/C Compressor
- Car fails to start, have it narrowed down.
- H23 boost
- h23 stock internals
- any advice on smoke?
- What wheels?
- Engine going out on me?
- Forced the sell my clean lude? Help.
- The Right Way to Make a Hybrid H23/H22
- Buying a prelude........
- weird humming
- Target A/F ratio...
- how long will you keep your preludes?
- advice on buying prelude
- CLutch Qustion
- 1992 Prelude with oil on my plugs...
- A little scared about what could happen
- Anybody have...
- Why do I have brown Rusty-looking dust in my Distributor ??
- How much for Spoon Strut bars front and back?
- sandwich plate
- Honda Challenge Race Preport from that other not as fast Prelude
- Clutch Woes
- Does that window trim that rots and flakes off actually seal anything?
- jdm h22 distributor
- High output alternator for the prelude?
- Stock Oil Pressure Sending Unit?
- How to check the code ?
- anyone knows if euro r steering wheel fits 4gen?
- problem with my vtec boggs when it engages, or doesn't work at all.
- FlowMonster Cats????
- Best Engine swap for 92 prelude?
- Valve cover studs
- Magnaflow muffler
- 4TH GEN CHARGING PROBLEM: HELP
- Dyno'ed my lude on AWD Mustang Dyno
- Looking For a Hood
- gsr Leather seats in prelude. Has anyone done this?
- Removing Air Con. and Sound Deadening Tar/Material
- Should I buy??
- temp guage
- smoke
- How stiff are oem shocks?
- throttle body removal
- Compression on h22a
- Best place to order a H23 tranny from?
- Cant take offor put on Alternator belt
- Quick question car not starting
- twinloop sound clip?anyone
- Aftermath of EGR removal
- Forged pistons
- oil light and subs
- OEM VS Aftermarket plug wires
- evo 2
- ATF in a manual transmission
- How to change oil?
- Which is better?
- H22A4 civic ej8 using 96 obd2 p13 ecu. EGR grrrrrrrrrr
- Anybody have any comments on TCS clutches?
- H22a jdm turbo
- Nitrous on 11.5:1 + compression on pump gas
- BB6 PRELUDE FACTORY SERVICE MANUAL! FAST DOWNLOAD! *BIG FILE*
- question about my fluids
- Timing Belt Install Problem
- My 97 Prelude motor is bent. Please help too rich too lean
- h22 help
- Changing/Flushing Radiator
- OEM vs. Aftermarket...
- 2001 red prelude hood for sale!! CHEAP!!
- NEED HELP!! 97 prelude auto CEL for gear selection switch circut
- Accord side skirts
- HIDs
- flasher location
- I recommend this product...
- Euro-R Manifold with Skunk2 68mm TB
- *-Muffler/exhaust-*
- WTT-LOWRIDER BIKE FOR RIMS
- turn signals wont blink
- H22A swapped Accord bogging and sputtering at part throttle
- 92-95 Civic Fog Lights on a 92-96 Prelude?
- Alright! OEM Optional CD Changer Controller
- Quick question regarding H22A1 swap
- alternator belt *help*
- what is this?
