PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 [140] 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. noise at idle
  2. 5th gens with aftermarket LSD?
  3. JDM H22a swap into F22a US
  4. Getting Crank Shaft Pulley Bolt-Need help ASAP
  5. Jun 9lb vs Fidanza 8 lb Flywheels
  6. i need to know how much of a difference beteween these trannies a 1/4 times
  7. h22a4 - h22a obd2-ob1 Clear it up!
  8. 5th Gen Engine Removal..... ANY GOOD write ups?
  9. H22 HEAD BOLTS... TORQUE
  10. which is better 4-1 or 4-2-1 header (searched)
  11. H22a4-----Bad Rings, Shall i rebuild or replace
  12. H23a IM ... Need Help Finding a Part (With Pics)
  13. 4th gen Heated Seats
  14. 94-96 ebrake conversion
  15. jdm bumper pole
  16. H22a4 Parts needed and HELP
  17. RSR EXMAG in a 01 SH?
  18. valve cover is all oily. leaky o-rings?
  19. Prelude 4th gen cabrio conversion
  20. Turbo Gas cut out problem.
  21. Prelude suspension components
  22. who thinks there should be a prelude-tech?
  23. will a 15x6 and 48 offset fit my car?
  24. EL gauges + EL dash harness = no more foggies. how do i wire them to work again?
  25. Espelir Exhaust
  26. DYNOMAX Muffler for H22 EG Setup...what would you recommed???(also posted on all-motor thread)
  27. Lowered suspension...uneven ride height
  28. h22,h23 blocks
  29. This water pump work??
  30. another h22 issue that i need help with please help i need to get this done.
  31. S2000 cluster in 5th gen?
  32. 4WS prelude for sale
  33. My gas gauge isn't reading accurate help :(
  34. Can codes clear themselves?
  35. Thermostat not opening! whatf the fk!
  36. Help with Engine swap - AC Lines in the way
  37. Will S2000 Spoon Calipers fit a 5th gen lude.....?
  38. The Definitive Guide to Prelude Factory Brake Swaps
  39. catalytic converter question
  40. Radiator Question
  41. 5th gen fog light installation instruction
  42. Problem with transmission help me out cable tranny guys
  43. cheap h22??would this make sense?
  44. Could this problem be fixed by the Ignition switch recalls..5th gen ignition problem
  45. best vtec oil?
  46. sensor wiring
  47. 4th gen optional strutbar ever existed?
  48. Everyone says it's ok for water to splash on your filter w/ a CAI...
  49. How do I tell if I have the factory alarm/keyless entry system on my 97 SH
  50. h22 shifter feels tight even in neutral is that normal? and tach question???
  51. my engine fell down 3 inches...
  52. Intermediate SHaft Assistance
  53. F1 racing clutches, anybody hear of them?
  54. timing belt rubbing....?!?
  55. another engine management question
  56. question about hydrolock
  57. NA H22a I/M and TB >>???<<<
  58. couple of questions about fuel
  59. H22 won't start after Swap
  60. Brake question: VTEC vs Non-VTEC fitment
  61. Skunk2 Intake Manifold Runner Length
  62. V-tec having trouble kicking over
  63. opinions needed
  64. crank pulley??
  65. 5th gen stock steering wheel fit in 4th gen?>
  66. code p0401 help
  67. h22 parts onto a f22??
  68. ignitor wiring?? OBD2 Dizzy
  69. h22 parts on a h22??
  70. harness problem???
  71. Will door panel close with 13mm speaker spacer?
  72. Some Suspension/Spring Questions.. cutting?!?
  73. Has anyone Changed a 5th gen from auto to manual?
  74. 8" width wheel on 4th gen
  75. JDM Rear window wipers
  76. O2 senors
  77. Exhaust system
  78. Intake Manifold
  79. WTB: VIS MUGEN REAR
  80. h22 parts fit on f22??
  81. do air filters also need a carb exempt sticker?????
  82. 4th gen intercooler plumbing
  83. h22 egr question????
  84. Prelude love...
  85. DOHC VTEC TypeSH logo on rear bumper of 5th gen
  86. Help! car won't start
  87. TL wheels on your 5 Lug prelude.
  88. Air/fuel gauge worth it?
  89. 2 step launch controller
  90. headlights 5th gen
  91. JDM 4th gen speaker size (Rear)
  92. front/rear o2 sensor
  93. f20a and h23 questions
  94. car not running right......
  95. Help on JDM headlights
  96. which projectors look best on 5th gen prelude headlight? E46 or E55
  97. is my p28 safe in my prelude???
  98. Clutch engagement = squeak?
  99. question regarding stock h22a exhaust manifold
  100. Hi flow Cat/ Resonator with stock muffler?
  101. oil problem!
  102. HELP INSTALLING DECK IN PRELUDE!
  103. need help my car smokes like crazy ( exaust )
  104. Need Help!!
  105. single belt pulleys for our H/F series
  106. popping out of fifth gear
  107. Trunk Lid
  108. Replacing Alternator belt????
  109. 92 lude timing problem
  110. TEST PIPE
  111. Headlight Assembly Condensastion
  112. Upgrading a 5th gen Auto trans Prelude??
  113. More H22 problems.... Vtec problems
  114. o2 Sensor question
  115. distributor question
  116. Looking for an aggresive h22 chip
  117. how much does it cost to get a block sleeved from Golden Eagle
  118. rear lower control arms
  119. hazard fuse
  120. accord type r front lip. how much?
  121. TOOK THE CAR TO THE DEALER !!!
  122. H23 IM vs H22 IM
  123. OBD 1 JDM/USDM H22 Distributor Queston???????
  124. Some metal on metal rubbage (rubbish?)
  125. need pics of h22 shifter cables where it mounts to the tranny fast please thankx
  126. First autocross of Prelude-powered Mini.
  127. p28 ecu conversion success
  128. timing belt and squealing sound when start.
  129. possible piston rings burned????
  130. Password JDM cold air intake question.
  131. speedo problems
  132. Performance mods help!
  133. E brake light stays on
  134. SH Lip Kit
  135. making it easy
  136. Adjusting 4th Gen JDM Housings Headlight Cutoff
  137. rear brakes... wtf?...
  138. valve seals and bearings
  139. H23 -> F22 Swap Questions
  140. H23 -> F22 Swap Questions
  141. Failed Smog - Help appreciated
  142. ABS; Fail-safe function. Does tire size matters?
  143. Reverse problem, did a search and related problems are not the same as mind
  144. engine needed
  145. 94-96 digital gauge cluster, will it work in a 92-93 prelude?
  146. front end vibration/wobble?
  147. For all you nitrous and plug reading experts please help me>>>
  148. 5th Gen Lude performance problems.
  149. car will rev but wont go into any gear
  150. How to change the O ring between the block and oil cooler?
  151. Prelude owner seeking help
  152. ecu swap gone terrible??
  153. Need links: Timing Belt Change on 97 SH, using H23 manual tensioner
  154. Pull or Drop Engine?
  155. HELP!
  156. heLP!!!! nEED MAP SENSOR
  157. Easiest swap for my prelude.
  158. Need to replace Multiplex
  159. Low fuel light
  160. H23a Head / ECU Question
  161. Oxygen sensor questions.. searched..
  162. help installing CF trunk
  163. Idle Surging HELP! location of idle screw??
  164. help REINSTALLING drivers side window/motor/control arms...
  165. sensor problems?
  166. Type-S Piston/Rod Confusion!?!?!?
  167. 97-01 OEM front/rear with WWRS sides
  168. RHD Conversion?
  169. which is better?
  170. brake rotors/pads
  171. Help: ABS light is on and something burnt. (read inside)
  172. VAFC question
  173. ODB1 - ODB2 difference
  174. H22 EG Dead - Camshaft Issues
  175. Funny Idle When I turn my Headlights on....
  176. Quest for 200whp...
  177. cheap tranny in my 5th gen auto base
  178. smoke from the engine... need help fast
  179. Weird wistleing sound @ 4000RPM
  180. Distributor Dismay
  181. 1990 prelude b21
  182. i am geting ready to install LSD whats the bearing for the tranny
  183. What is this inside my H22?
  184. prelude drive shaft?
  185. prelude rims?
  186. Please Help! Car turns off while driving...
  187. problem with 5th gen and rain
  188. my prelude with altezza's won't start---> HELP!!
  189. crank and balance shaft seals part #?
  190. need info fast on h22a type s swap
  191. racing seat options...
  192. help i hope
  193. 92-96 prelude..what to look out for??
  194. Hmotorsonline.com good? complete h22a into f22 help
  195. Neuspeed Springs
  196. Gray and white smoke at startup?
  197. Extended Studs and Lug Nuts
  198. need your opnion.
  199. hey, new prelude owner.
  200. Car running lean after timing belt snapped and replaced..help!! searched
  201. H22 Main Bolt Specs
  202. h22 sleeving or sleeved h22
  203. f22a swap question
  204. My turbo prelude has a bad voltage problem???? Running real bad, please help???
  205. PFI has 3 traction bars in stock now.
  206. 91 prelude knocking noise
  207. Cleaning EGR
  208. What ATF, preferably synthetic, and how much to use on a 00 Prelude for an oil change?
  209. swap finally done!!
  210. HP estimate
  211. P13 insufficient, looking for something better...
  212. Oil Pan Gasket leaking, how to solve
  213. Starting Problems
  214. Lightweight power steering pulley
  215. is my prelude running rich?
  216. EGR blockoff plate on OBD II
  217. OBX underdrive pulleys
  218. ES motor mounts pics ?
  219. H22 Distributor
  220. h22 camshafts?
  221. TypeR steering wheel in a 4th gen?
  222. Question & Possible Problem
  223. how do you remove headlights?
  224. 92-96 front lip
  225. 5th gen and 4th gen coilovers the same????
  226. How To: Remove Side Moldings
  227. Rust on header
  228. All this talk about Auto Tensioners..
  229. are gates products any good?
  230. freind got a new swap...
  231. does any one have a complete h22 engine.
  232. 92-96 prelude AUTO TO MANUAL conversion
  233. F22A - H22A Horrow Swap!
  234. Stepped H22 Vtec discussion
  235. Putting H23a Head Together ...
  236. H22 intake valve
  237. Finished installing my JDM Type S seats !
  238. strange motor behavior... kinda worried
  239. a/c making noises
  240. i cant find it..!!
  241. new rear seats
  242. F20A timing
  243. worth it? i think so
  244. 00 Prelude Audio Installation Schematics
  245. Prelude Stats
  246. F22 to H22a4 SH
  247. headlights
  248. Is the Under-braces worth it?
  249. f20b transmission
  250. Engine turned off while driving .. help....
