PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 [147] 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. lug nut question...
  2. apexi vafc II or hondata gains after tuning a/f ratio cams and bolt-ons?
  3. h22a block vs h22a4
  4. 3rd gen questions
  5. 4th gen help??
  6. need help.
  7. FS: '91 Prelude Si
  8. question about JDM F22B...
  9. Need help fast..!!
  10. Improving on 260WHP NA
  11. suggestions on vtec setting for chipped p72 on h22a4
  12. Review: JDm Y0 Ebay Radiator
  13. type s pistons and tuning
  14. any 5th gen amber bumper turn signals out there?
  15. gutting the car
  16. FRM question
  17. harmonic balancer
  18. Where can i find sleeves?
  19. Homemade Projecters. I took my HID kit off.
  20. 1984 prelude engine swap.
  21. H23 is a interferance engine right?
  22. H22 Transmission Problems??
  23. 5th gen head on 4th gen block H22? Compatible??
  24. looking for new wheels for my 4th gen
  25. Can We Swap 97-01 interior into 92-96 lude
  26. walbro 255 fuel pump question
  27. to those with 11/12:1 compression
  28. WHAT IS STOCK H22 1/4 TIME?
  29. M2B4 tranny in a 99 civic...what axles...?
  30. 4th gen corner removal
  31. is my battery dead?
  32. AEM EMS base map will not work on my 2000 prelude
  33. cotter pin
  34. Quick VSS question
  35. Pics of my new ITB manifold -- built by me
  36. Searched: Engine whine
  37. torque specs on balljoint
  38. what should I do..?
  39. Will a 96 accord TIEN suspension fit on a 97 honda prelude non SH????
  40. bore block
  41. Will a 93 H22A Header fit a 97 H22A4???
  42. NEED HELP! Cam Gertile tourqe specs and cam cap seals tourqe specs???????
  43. Highway shimmy. Cold mornings - fades away
  44. Death by freezing temps?
  45. H22 modified oil pans for ground clearance?
  46. Fan turns on when car turns off
  47. CEL 61 gone after new 02 sensor - still misfiring on 1 and 2
  48. Corner Bulbs...
  49. car won't start up after a couple stalls
  50. knocking?
  51. Which strut is best?
  52. Auto Lude prob
  53. ECT sensor
  54. Will this fit my 93 Si?
  55. 4th gens painted?
  56. LEGEND GS caliper AEM big rotors...too heavy?
  57. JDM...Platform
  58. what radiator options do I have?
  59. crower stg 3 adjustment
  60. How do you slide the timing belt on? (jdm h22a)
  61. NOISE from pulley side of engine bay. belts come off!!
  62. another clutch problem
  63. Lets Play!!!! Name that Ground!!
  64. Question for 2 point 6
  65. Is my O2 sensor gone?
  66. advice adivice advice advice advice??????
  67. can anybody help!!
  68. anyone know the wrench size of the B&M fuel regulator adjuster size?
  69. install B&M fuel regulator and adjust it, fuel gauge jump a lil is this normal?
  70. Prelude Top Hats (suspension)
  71. where can i find after market body parts for 89 2.0si
  72. whats the difference on b20 a-5 and b20 a-1
  73. tranny probs; in neutral, but engages a gear somehow?
  74. Bought a 3rd gen SI
  75. Corner lens 4th gen
  76. head work
  77. help boosting my prleude.... any one?
  78. koni install oops's
  79. sohc help for my prelude
  80. 97 Prelude ECU diagnosis trick help
  81. Intake Manifold Question
  82. Bushing Fitment Help
  83. Valve Adustment
  84. pulling the head
  85. The alternative to sheetmetal intake manifolds inside...
  86. Eibach prokit springs on 5th gen. lude (pic request) (searched)
  87. d16y8 base settings safc
  88. 1999 honda prelude keyless entry?
  89. How do I stop SPRING RATTLE!??
  90. FS - 97-01 Stock OEM Prelude SH Sideskirts ( Pearl White)
  91. Type S Distributor cap...
  92. Chips?
  93. 3 Problems please help
  94. Fitment of aftermarket seats in 4th gen Prelude? (searched)
  95. Help with sidemarkers! ASAP!!!! (searched...)
  96. Fog lights?
  97. 4th Gen Question:
  98. Crank lower timing gear
  99. Support hitting trans....
  100. Clutch Slip?
  101. Switching from Bilstein to Koni
  102. 5th gen airbag block off?
  103. Is there a difference in CAI for S/SRV?
  104. Final drive ratios that'll fit an H22A1
  105. are these good number on my dyno?
  106. good news an bad news....
  107. Searched to no avail: Brake Line interchangability
  108. 15PSI+ Turbo = Changing Exhaust?
  109. Breaks Squeeking? help
  110. Best Security System/Remote START
  111. Throttle Body advice??? Skunk 2 vs BBL
  112. worth fixin (bumper cover taken off.)
  113. slowing blinkers
  114. Can I use a H23 block for H22 setup ?
  115. 5G Preludes with CF Hoods and no hood pins..... Question
  116. 1997 prelude sh transmission swap questions?
  117. H22A Compression test Results.....just got motor in
  118. Time for a clutch...need help finding he right one. XTD ACT Excedy?
  119. how do you get 89 prelude out of "limp" or "safe" mode
  120. Prelude Maintence!
  121. dust
  122. Turbo on H23A. Need help and opinions opinions.
  123. Valve spring color
  124. Pic Request - Partially Painted Vis Invader Type 6 Carbon Fiber Hood 5th Gen
  125. New Clutch
  126. Got some new tie rods, Thought I would share the pics
  127. "Hiccupping" in VTEC
  128. 5th gen. oem exhaust
  129. Roll cage time
  130. high flow cat
  131. power steering boots ripped. 4th gen
  132. Strange, intermittent idle problem. '95 JDM H22 in '92 civic hatch. Please help me.
  133. Lets say I am able to find a 4th gen at a junk yard...
  134. JDM Headlight Bulb
  135. do all 1998+ preludes come with h22a motor???
  136. noise when clutch is disengaged?
  137. Clutch Performance Inc.
  138. problems in boost
  139. h22 in civic coupe
  140. Have to start car twice when Cold?
  141. compression question asap
  142. prelude engine codes
  143. JDM H22A running way to rich help!!!
  144. tires
  145. need some help asap
  146. disabling the 4th gen el gauge cluster dimmer
  147. jdm swap? how much $ and what can i expect in whp? lsd or no lsd? quarter time of typs s stock?
  148. VIN location on USDM H22a4?
  149. block fitting?
  150. Cant Find Oil Filter
  151. Aftermarket clutch for 5th Gen
  152. bogs in reverse
  153. my shift knobs almost done. check out the design here.
  154. prelude won't rev over 3k
  155. Does H22A4 Downpipe fit the H23 catalytic converter?
  156. bogs after motor install??
  157. Need some opinions (frustrated)
  158. Physical properties of the ECU
  159. Need Help ASAP....suspension
  160. Service Problems
  161. Help... idle/throttle problem (4th / H22A)
  162. Notchy Transmission, with NEW MOTOR and TRANNY olny in for 4 days
  163. '92 headers
  164. F20c head onto an F22B engine. WILL IT WORK ???
  165. for those who swapped auto -> 5spd
  166. Pully question....whining
  167. Guage swap?
  168. H series water pumps
  169. h22 idle problem
  170. planning to get a jackson supercharger for my 5th gen prelude got question
  171. Whats the deal with my plugs & wires? Pics attached.
  172. can they fit?
  173. Final Drive good idea?
  174. Rear Sway Bar w/ Stock Suspension
  175. FUEL pump relay on 4gen, Where is it?
  176. 2 questions egr, Engine ?
  177. JDM Headlight fix!
  178. GReddy Turbo
  179. Does anyone know how to remove the swaybar endlink?
  180. Replacing Rod Bearings!! Noob questions!! H22a JDM
  181. NASTY noise coming from engine bay? second gen.
  182. Problem with power locks
  183. vss still not working
  184. Best struts to go with h&r race springs?
  185. any one do this? crower stage II w/type s head and valvetrain?
  186. what's the diameter of the oil bolt rubber seal. Need to get me another seal
  187. tick normal on VTEC car?
  188. brake lights wont work
  189. Is this rod knock??? video clip!!!
  190. No vtec AFTER 1st gear, NO CEL, checked: wiring,grounds,oil,
  191. how would u know you have a spun rod bearing? symptoms?
  192. 2.5in exhaust for 4th gen?
  193. cluncking in rear of 01 prelude
  194. 96 prelude .,F22b block with h22a Head
  195. 4th gen Owners: Do all of you have bumper/hood gap?
  196. all 5th gens do this?
  197. Seating Valves
  198. SRS control unit
  199. Koni Yellow and Ground Ride
  200. been using Honda oem 10w30 oil should i change to synthetic?
  201. 4ws resoldering??? HELP ME!!!!!!
  202. Does anyone have trouble drawing a decent charge out of the cig lighter?
  203. WTB h23,h22, or f22 oil pan
  204. Wheres all the 3rd gen sites at???
  205. Metal Flakes in exhaust
  206. GSR tranny into prelude
  207. Suspension
  208. bumper mounting
  209. Quick ECU Question
  210. difference between jdm and usdm tranny's
  211. RSX Tranny In 5th Gen?
  212. IM back people Need advice
  213. CAN I USE THIS TRANNY AND KEEP SPORTSHIFT IN MY 5TH GEN
  214. trying to tune and dyno
  215. SE tan carpet request
  216. passeger headlight problem
  217. Euro-R Throttle Body/IM vacuum lines...*Pics*
  218. H23 throttle cable with H22 swap
  219. transmission swap
  220. p72 ecu
  221. obd?
  222. What is this and is it bad its bent? (pics)
  223. removing window tint
  224. CEL 0 But car still runs rev limit 6500 and no vtec
  225. Code 17 Help.
  226. Secondary Question
  227. Prelude eibach pro kit
  228. Tranny/Clutch Issue??
  229. Stock H22 studs torque to yield?
  230. Valve seals
  231. High reving problem during idle
  232. h22a4 ebay block - Opinions?
  233. Power From the H
  234. H22 S-spec head swap
  235. Southern California H22 SHOPS?
  236. Will 5th gen springs fit a 4th gen
  237. D2 RS Coilovers are they good?
  238. H22 vs H23?
  239. Timing belt tensioner problems
  240. 5th gen front side markers
  241. 97 Prelude non SH Sport Tronic problem help!!!
  242. just did compression test, is these number correct?
  243. RSX muffler on a 5th gen?
  244. Will a 4th gen exhaust work on a base 5th gen?
  245. Auto to Manual Swap
  246. ATTS Reliability/Issues
  247. Non Electric Turbine
  248. Distributor Install?????
  249. question bout battery and brake lights...
  250. Car not starting (need help)
