View Full Version : Honda Prelude
- 84, 1.8, 12 valve tuning settings
- what kind of injectors?
- turn the key, *click*. car doesnt turn on?
- 5th gear thumping/knocking
- tenzo wheels
- accord front lip pics, any kind, 4th gen
- Parking & cluster lights out on '90 Prelude.
- Energy Suspension Motor Mount Inserts
- CALLING ALL TURBO LUDES!!!
- what exhaust?
- Car is acting up please help!!!
- motor strength
- how can you tell front and rear stock prelude springs.
- Question: 88' Lude from an 89' Lude
- 4th to 2nd misshift sort of
- AEM CAI or short ram air ? ? ? ?
- Radio Codes...
- VTEC givin out symptoms?
- How u tell if vtec sol. is givig out?
- Car jerks on highway? WHY?
- all people with cam gears, searched
- H22a engine fit H23a manual transmission/H23a ACT clutch fite H22a transmission? Help
- JDM h22 is more like usdm 92-96 or 997 up?
- cam timing was off
- H22 VS H23 TB
- Brake Lamp Sensor?
- Rear Suspension Squeek
- Stock jdm h22a dyno chart
- Can someone help me with the alternator rebuild?
- brake light
- 1988 honda prelude Si
- Skunk 2 Intake Manifold
- Tein EDFC
- put the prospeed header on
- Questions and concerns about cleaning my engine bay....
- My 88 Si is running rich
- vacuum diagram 4 85 prelude
- Do you guys leave your suspention bushings in?
- wiring the iab
- My St00pid Turbo Lude SH
- ECU upgrade for my H23
- h23a1 vs h23a2 differentiates ?¿?¿
- is there any difference between H22 v-tec dizzy and h23 none v-tec dizzy??
- Ok wtf is wrong with my automatic prelude...
- Transmission problem???
- cam lobe primary, mid, secondary...
- engine miss fires
- BURNING OIL...HOW MUCH IS NORMAL?
- drop zone shocks ?
- 92 si o2 sensor throwing check engine light
- Tein SS vs. GC/Koni
- Please help....H22 ecu
- Type R spoiler Mounting
- idel problem in need of serious help""""""
- 4th gen foglights
- Labor costs for h22a swap in 4th gen, and a good install shop/people in the greater Cincinnati area?
- VAFC and FPR tuning
- Apexi WS 4th GEN
- Rear Brake Rotor Noise
- h22a header basic install "?"
- Workshop Manual?
- no engine hoist, how do I transport an h23 ?
- Oil Filter Relocation Kit?
- 5th gen dash in 4th gen?
- problem after installing new plugs
- Shaking problem
- bent valve?
- prelude intake manifold question... please help..
- Happy Whiste or Bad Whistle?
- Getting a little creative with tranny cooling lines in radiator
- help!! no secondaries (after clutch change)..what did I do
- valve spring compressor
- Stock 97-01 Base Prelude exhaust up for grabs.
- a good set of tires
- Jun chipped P13 ecu: yay or nay
- What else should i get for my car before i tune?
- 5Gen prelude type-s strut bar ? on 4Gen prelude?
- hello!.......everybody
- valve springs h22 to h23
- iab
- any 5th gen prelude owners interested in Tanabe Sustec Pro Coilovers?
- Short shifter?
- Dead Cylinder, Guess What Broke!
- plz list all possible reasons why i might have low oil pressure
- Guages too dark, can't see anything
- Rebuilding My H22 Tranny
- Engine Light On, AGAIN... Really Weird Flash Code
- Thinner headgasket on h22a
- weird ongoing electrical gremlins!
- Aftermarket parts to get for 5 spd swap
- Any turboed H22A1s?
- Installing new o2 sensor, F22b 92 prelude
- About to do GC/Koni install - have some questions from those that did it themselves!
- how difficult will this be (famous last words)
- Just got back from the track times inside
- 6000 RPM chugging?
- Fixing the Camber Angle
- gsr dizzy on a h22 head?
- Took my car to the show, running like Sh**T
- Using a 4th gen tranny on a 5th gen engine?
- Type S intake installed, butt dyno very happy :)
- failed smog, please help
- How to Change dash LEDs?
- Does an H22 having about 120.000 miles need overboring or not?
- Valve Springs: Upgraded Cams w/ Only Upgraded Inner Spring?
- dizzy swap
- reidculous question that i need QUICK! DISTRIBUTOR CAP AND ROTOR HELP
- Any one has Project Mu brake pads.
- Custom Intake Job...
- Won't Turn Over
- Anyone know where I can find a NR>G seat brackets for my 4th gen?
- where to purchase pro-drive oil pump gears??
- Are there any down sides to using an 4th tranny on an h22a4 (5th gen)?
- made it to the track got one past, yes its a h23
- Differences between USDM and JDM pistons?
- Rm H22 cams dyno'd: very pleased results
- Looking for general suggestions and input
- speedometer doesnt work till the cars warmed up
- shock problem ?
- hondata for a turbo 5th gen
- Custom h22 Turbo set-up!
- 1/4 mile time on an auto h22 prelude (4th gen)
- 2 questions that have been puzzling me...
- resonator
- ATTS Breather hose
- ignition timing ?s h22a1
- 3IN CATBACK
- What are the specs on a D16A1?
- GReddy EVO 2 Installed today
- Installing an MSD SCI w/ external coil
- No power in VTEC after buildup. What am I missing?
- Turbo knock sensor help...please....
- Auto to manual swap, will 4th gen pedal assembly fit a 5th gen??
- problem with 92 jdm prelude underdrive pulley. Help!
- MSD Installation; how to?
- Forged Pistons in stock H22 BLOCK.... Finally
- new swap car wont crank....
- vtec mode real jolty? why?
- h23 dc headers 2.5" collector mod
- oem 14"option rims...
- difference between obd2a and obd2b??
- Can anyone tell me what these vacuum lines are supposed to do???
- Could a bad PCV valve cause you to fail an emissions test?
- spoon calipers or nsx calipers ????
- Anyone try seafoam?
- Finally got my Lude, few problems tho
- Cruise control and Vtec controller.
- BEST TRANNY????
- grinding in 4'th and 5'th ( i know need a synchro) but...
- which intake mani sensor is this? (pic)
- anyone with a "test only" smog hookup? please!!!!!(norcal preferably)
- quick question about parts.
- JDM H22 question
- Shifting problems.
- Obx camshafts?
- Acid Bath?
- Invidia exhaust 4th gen H23
- ? about motor sound
- rebuilding shocks
- Does anyone know if any company that makes full race mounts for 4th gen or 5th gen ludes?
- Check engine light...cat converter?
- Forged Pistons in stock sleeves? (searched)
- I think i have a big problem.
- Satan SRV Can you please clue me in..........
- H22a Euro R head gasket.
- OBX camshafts , reliable or not?
- ? 4gen and 5gen brake difference ?
- ? 4gen and 5gen brakes ?
- H22 running rich
- buying a 5th gen?
- engine seal
- possible collector mod on stainless ?
- Governor on prelude?
- car randomly dies
- where can i get a wiring diagram for my 5th gen lude?
- Wanted JDM FOG LIGHTS with wiring
- Need help installing gauge faces
- Is it necessary to align water pump and oil pump when doing timing belt change?
- Leaking transmission - opinions ?
- fuel pressure, uberdata
- Header
- lighter wheels on 1 side
- i want to see some turbo setting on H22
- Possible clutch problem?
- VTEC Solniod
- accord sideskirts?
- manifolds: searched but found nothing
- Tranny swap...confused...need help fast....
- JDM H22A Swap into a 5th gen... what do I need to know?
- V-AFC LOCATION
- Prelude B20A si non-vtec to vtec
- 95 prelude sr-v abs prob
- will this worth the buck of stock 2000 pre
- Vtec launching techniques.
- GM Synchromesh and honda transmissions
- Kit question
- my h22 wont go in reverse
- 6.5 comps in a 2000 lude will it fit?
- H22A in DC2 PROBS
- Tire fitting
- brake Upgrade
- List of parts to reach 200whp
- Jun cams vs Crower. + emissions?
- ECU Program Standard vs Hondata
- Ok I'm taking shiftyperformance's advice..help :P
- Please help with whp estimate
- What am I missing for my suspension install?
- greddy e-manage
- Prelude enthusiast sites?
- idle shakeing
- Dyno'ed my lude today
- Prelude New JDM Type S pistons and rods
- Mugen Stuff?
- RWD or AWD Prelude....which?
- Chromoly rings?
- Elf LSD Fluid
- who or what company makes this intake manifold
- need help about steering wheel.
- Prelude Exaust Advise
- What camber kit too BUY
- While we are on Megan products...
- worth it?
- needs picture?
- h22 throtle body
- Lowering: What all is involved?
- ABS operation fault
- crank position sensor
- Why take out spark plugs when doing timing belt change?
- gayness in my undercarriage
- crank fluctuation sensor and to all people that converted obd2b-obd1
- camber kit q, replaced upper arm bushings?
- why 4700-4900rpms???
- V-AFC II Setup for my H22A4
- which prelude?
- installed new gearbox...after 1 day...cant get into gear past 4,000rpm
- h23 to f22b swap, knock synsor??
- RC 650 injectors
- WTB: RC 650cc sat injectors for 5th gen
- help help
- Analog to digital cluster conversion in 93 prelude
- type s cam valve lash???
- H-23 Head work
- O1 prelude sh I need an Intake Manifold HELP
- $2,500 left on mods.
- what shocks
- LIMP MODE with Vtec?! What's happening! HELP
- I called Portflow today..............
- What are the specs on a B18C1???
- Blah.. 92 Prelude won't start up. Any help needed
- automatic tranny issue
