Energy Suspention Motor Mount inserts
Old Oct 16, 2003 | 12:13 PM
97luder's Avatar
Default Energy Suspention Motor Mount inserts
OK, I've done a search and found out that the Energy Suspension motor mounts only cover the Front and the Rear. I have a torn motor mount on the timing belt side (Driver side). It's actually kind of strange, the rubber must be oil filled cause when it tore, oil started leaking out of the mount...hmmmm strange.
Anyhow, do I have to go back to Honda to buy that motor mount or is there a "stiffer" aftermarket one that I can purchase?
Thanks for your help guys!
Old Oct 16, 2003 | 01:03 PM
spoolinlude's Avatar
I live under a rock
Default Re: Energy Suspention Motor Mount inserts (97luder)
There's always the place racing solids mounts........ overboost.com has them, they're like 160 something each.... don't buy all four thou, you'll regret it
Old Oct 16, 2003 | 02:47 PM
ballzac's Avatar
yeah, the front and back ones are the "torque" mounts, designed to keep the engine movement to a minimum. i have them in my car, and its rides fine.
as for as the ones your looking for, my friend just bought some of the side ones for his 4th gen, next time i talk to him ill ask him what kind they are.
Old Oct 17, 2003 | 07:08 AM
97luder's Avatar
I heard the front and back mounts are the same from the 4th and 5th gen. Dou you guys know if the side mounts are the same as well between 4th and 5th gen ludes?
Old Oct 17, 2003 | 08:43 AM
del_parker's Avatar
you can get some plastic welding epoxy to fix the mount too. the one you're talking about was ripped in half on mine, it's holding together alright now.
Old Oct 17, 2003 | 10:47 AM
H22Si's Avatar
Default Re: Energy Suspention Motor Mount inserts (del_parker)
Also, low cost window urethane is an excellent substitute for the mount inserts. It can be found at any hardware store and is packaged in tubes much like caulking.
If you let it properly dry for a day or two prior to installation, it will posses the same qualities as standard urethane.
Old Oct 17, 2003 | 11:04 AM
Daemione's Avatar
Default Re: Energy Suspention Motor Mount inserts (H22Si)
Guys, he's talking about the driver side hydraulic mount, not the rubber ones on the front, rear, & tranny. There's no inserts, or anyway you can repair it reliably if it tears. You either have to get a new one from Honda, or find one used somewhere. I don't know if the 4th gen used the same mount (or if it's at least interchangeable).
The only other possibility might be to convert to the rubber mount that was used in the 90-93 Accord. But I don't know if it mounts the same to the chassis or not.
#1rudebwoy
Oct 6, 2010 08:12 AM
Mr.Luder
Jul 1, 2008 04:35 AM
NOTENOUGHBOOST
Nov 6, 2003 04:27 PM
5gencivic
11
Jun 7, 2003 06:11 PM
2000Accord5sp
Apr 23, 2003 09:41 PM
