- car keeps dieing????
- tranny cable
- another oil burning question
- CEL # 12? What should i do
- EDM REAR BUMPER
- JDM BB4 PRELUDE FOLDING MIRRORS
- amber corner jdm headlight(not the light)
- crankshaft bolt size
- need some inspiration!!!!
- Anyone experienced with 4th gen dash speaker and 6x9 free air kicker sub?
- Front Mud Flaps - '95 4th Gen
- Engine Build F22A1/H22A Hybrid in 91 Accord. Some questions for you prelude folks.
- Changing intake gasket....help!!
- CF fenders?
- H22/H23 IACV
- Need help with my gauges!!
- 97-01 headlights help
- need help with 91 prelude issues plz
- jdm ecu
- Upper Ball Joint How To DIY:
- difference with a lighten flywheel.
- how much boost you guys running???
- 12lb flywheel idle problems?????
- H23 Fuel pump flow
- Scat rods
- Precautions
- what i need fa JDM h22 to pass smog?
- rb26dett in prelude?
- Oil Cooler o-ring socket
- leak problem
- MSD SCI on AEM EMS
- Question on my clutch
- RSX Rims on 98 Prelude?
- I accidently bought 100W headlights...
- LSD Installation
- Boost = Need to modify Ignition? (searched)
- need help with H23A1
- parts
- keyless entry question
- oil leaking form my tokico blue shocks?!!?
- weight
- inline fuel pump and regulator for h22a
- injector resitor
- ht newbie with a question
- 95 h22 OEM downpipe and cat part numbers??? PLEASE!!!!!
- Pic Request / Information needed....
- Missfire at idle
- Wheel weight of a stock swirly?
- TIRE question
- Caster Plates
- Pic request of this radiator.
- master cylinder help
- Code 20: ELD
- DH-racing good? bad? ugly?
- Have you ever seen this cover?
- 5th gen oil pan removal????
- car had trouble starting up today (searched)
- Spark Plugs and wires...
- rsx wheels on 5gen
- Best place to get used engine.
- Port/Polished head for F22?
- My h22 wont start.
- is the 00 prelude sh vtec ecu interchangeable with 99 prelude sh vtec?
- 4th gen 93=96 WW RS LIP Kit
- Anyone ever use this Clutch.Flywheel b4?
- In need of a ECU for my H22A
- Oem Front Chin Spoiler
- Throttle problem, help!!!
- how much to find a short? blown fuse
- ignition switch
- Honda Parts Store??
- jdm h22 v tec not workin
- idle too high!!!
- 95 prelude air/fuel guage
- Recaro seat bracket?
- h23 tranny
- Need help with ECU wiring from H23A1 to H22A
- 94 4ws prelude for trade or buy
- Break in and clutch questions...
- any oem type-s strut bar? pics please!
- 15) Ignition Output Signal - Missing or defective ignition output signal ????? need help
- can i use 4th gen JDM oil pump on 5th gen H22a motor?
- Ok..Cons and Pro about jdm H22A?
- jdm h22a swap shops nor cal bay area
- jdm h22a smog california
- Should I get a genuine Honda PCV valve?
- first prelude
- h22a help
- egr comaptibility??????
- New tires 215/35 good or bad?
- which heard is better
- Anybody try the Streetimports exhaust
- h22 q's
- underground racing merch. SEARCHED
- Airbag question
- Cosworth pistons?
- Car will not start!
- Alignment ?
- 5th gen rim lug pattern and offset
- Boosting a f22a...
- Maintence Required Light
- weird problems out of no where.. help please
- Heater help
- fuel pressure
- HELP Car Trouble
- FPR gauge BandM trying to put it on fuel rail no luck? help?
- Harness Wiring Diagram
- f22 5th gear into h23 tranny
- Questions about my JDM H22A obd1 manual trans swap into 88 prelude si.
- engine problem
- 92-96 prelude stock h22
- 4th gen Nostril Assembly?
- Compression test results on the Lude
- jdm headlight wiring guide
- how do i know if my clutch is slipping?
- oil change. please help
- 4th gen vs 5th gen
- Burning 1/2 quart of oil a week ---- 97 H22?!?!?!
- Question about CAM Gears
- Looking For 92-96 Honda Prelude Rear 6x9 speaker center Console panel...
- where can i find a Camshaft/Valvetrain DIY Write-up
- RSX/ s2k seats in 4th gen?
- Catalytic converter dimensions : 4th gen vs 5th
- 5th gen auto conversion to stick with 4th gen tranny plz help
- how much does an b18b engine weigh?
- 5gen radio installation
- Damper Question
- Radius Rod Replacement
- h22a4???
- 98 lude brake pad swap... problem w/ rear caliper piston...
- Question for Tein Type-Flex Owners
- big problem?
- Finishinig off my car: last little problems
- f22 swap
- Wiring front bumper lights to stay on constantly
- any noticeable diff. going from 15's on my 92si to 14's?
- just gotta a new engine
- Timing belt for a h22 1997
- using the extra cassette mode as a aux?
- compression test........
- which helms manual to buy?
- NGK plugs for '94 h22a prelude? Is part no. PZFR6F-11 correct?
- suspension help
- H22 boosting need help
- ECU harness
- I need a half/mid/intermediate shaft for my H22, what else would fit?
- pulling h23, got a question
- No choice to bottom out, left or right?
- Bad wheel bearing=steering vibrations?
- 5th gen auto to stick
- 90 lude turbo ???
- type-s engine compatible in 4th gen prelude ?
- do 95 special edition tach clusters fit 92 ludes
- anyone know how to remove those white mark on rims polish lip?
- Scared of HIDs
- Engine limits at 6600 rpm..
- Interior Lights Fuse Keeps Blowing
- JDM preludes
- e-brake question (searched)
- Anybody know what is the speed converter?
- Interior parts
- Exact set-ups of your build
- Transmission Lock-Up
- Couple of issues.. tps and axle woes
- h22 auto to h23 manual belt conversion?
- Can you run OBD-1 P28 ecu for 98 SH?
- Limitation in Gearbox with LSD from a -95 Lude vtec?
- H22A alternator/tensioner kit to run either H or D series alternator in 2 different spots!
- H22 exhaust clips or suggestions
- Supra lip???
- Common Honda Maintenance Repairs?
- AEM EMS vs. Hondata S300
- roller rockers vs. factory design?
- quick header question
- 1990 prelude motor swap
- HELP@@@ How do u tighten your h23 manuel belt tensioner
- car backfire everytime i shift to another gear, what could be wrong? lean or ricH?
- BB6 VTiR Prelude from Australia Pics/Specs
- What is the difference ??
- Getting more out of my car
- Well.....
- bb4 won't start, I'm sad
- Difference between SH and Non SH
- prelude brake upgrade???
- installing an amp in 97 lude
- spark plug gap for jdm h22
- need help on type-S cams
- problem with my 00 prelude
- Just picked up a 3rd gen..
- 2 oem headgaskets for boost?
- turbonator?
- Problem with headlights not goin down
- RMF HEADER - I want one, do I need a custom?
- can i put japan pistons in my........
- wiring harness
- check engine light and atts?
- good/trustworthy mechanic in No. Virginia?
- pics of a 5th gen prelude with MSR wheels
- Just ordered Falken Azenis Sport - question
- Prelude injectors in an Integra
- ABS modulator on a 5th gen . . .
- Honda Prelude not starting
- Is this an abs plug? and another unknown plug.
- valves are super loud. tapping?
- Code 15 prelude, smashed wire, help me ANYONE!
- anyone know how to remove the Clifford AUTO IMMOBILIZER?
- manifold gasket
- Is it the megan header or the muffler?
- 5th Gen Clutch Master Cylinder and Slave Question (Same as Civic/Integ?)
- Way OT: check out jackie chang's Thunderbolt. why? 4th gen. inside...
- jdm h22 auto or manual tensioner
- Wanted 92-93 Amber Turn signals for prelude
- Weapon R vs ALL
- Tearing apart 2point6's engine
- Side to side play in axle...
- Smoke coming from motor...
- sequential shift light
- looking for a lonk to mod my collector
- Help taking out prelude gauge cluster?
- how much extra clearance do u need for a turbo motor
- how do you remove the axles?
- h22 cam question.
- 5th gen rear speaker question
- OaksRacing - Gearspeed transmission
- Rebuilding H22A4 block -- Questions
- changing clutch
- 4th gen in Grassroots Motorsports
- Anyone know for sure is the 98-02 accord mt shifter interchangeable with h22 mt shifter assembly?
- axles and ABS??
- h23 vtec oil lines
- Needing 88 Prelude Carburetor
- WW rs?
- What's a good Timing Belt for performance?
- im kinda a newbie with hondas and cars in general
- Fan not working
- Stock exhaust minus resonator?(searched)
- head gasket leak question
- Questions about an N/A setup
- Just another Crash Thread..
- Another Frankenstein
- question on buying a prelude
- New Type-R
- Are there grades for hoses?
- Battery Fuse Keeps Blowing ? Fusible Link ????
- C&R Radiators
- You guys ever had ur car start kind of funny?
- Jspec H22a w/ turbo
- what flywheel should i use?
- honda prelude type sh 98.. up grade help
- Need Help
