PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 [269] 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Takin offers on the lude... Sam approved...
  2. Can turns off DURING nitrous run!
  3. RPM Guage Is Jumpy...... not a constant increase or decrease.
  4. Dope ASS T25 Turbo Kit for H23 *LQQK*
  5. Well.. Ill be damned
  6. 5th Gen Bass
  7. HID for 5th gen?
  8. I have an extra H23 intake manifold.
  9. anybody have a junk h23 block around? I need something off it...(knock sensor?)
  10. Fuel rail disassembly
  11. oil tap???
  12. Times for auto ludes?
  13. h23 shift linkage, will it work with a h22?
  14. anyone have the PS completely removed?
  15. JDM Side marker wiring
  16. Greddy oil filter block adapter.
  17. h22 swap in a 4th gen, exhaust manifold
  18. Need help, Check light:code 21, wont idle
  19. My fifth gear just started doing it's infamous grinding...
  20. removing intake resonator
  21. 97 CAI into a 92
  22. need advice on fpg and ecu running h22
  23. H23 engine for sale
  24. Anyone dyno there h22
  25. Head gasket for Higher Compression?
  26. Brand new Quaife for sale!!!(H22)
  27. check engine light is on, O2 sensor maybe?? (HELP!)
  28. what country is this prelude in?
  29. is there a fuse somewhere for the cig lighter in a 4th gen??
  30. 5th gen questions
  31. When putting on the air bypass valve on your aem cai........
  32. pulley
  33. i really need your help... H22 question
  34. Generic to AEM CAI???
  35. Need some info/advice/help... please
  36. Downfall of my H23
  37. Who says SS Preludes are slow. :)
  38. Installing Injen intake
  39. 92si- at what rpm will you shift out of fifth gear. like how low...
  40. help: installing type s strut bar
  41. what hp is a h23 si motor?
  42. Do I need a fuel pump?
  43. Totalled or not?
  44. HMMM....What to do with $650....
  45. I'm famous.
  46. resleeving an h22a
  47. CARB exempt intake cer. needed
  48. jdm fog install (4th gen)
  49. What PSI can I run with a 10.6 compression?
  50. Engine Questions to Jog the Mind
  51. Prelude online members
  52. 5th gen and 4th gen coilover suspensions
  53. ls/vtec motor or 97 prelude motor which is better
  54. Shaved doors for 4th gen prelude's for sale
  55. Oil pan tech: Which oil pans are identical to H22's? H23's? F20's?
  56. Vtec?
  57. gapping on a JDM 95 H22A motor spark plugs???
  58. h23 CAT
  59. the 5th gear grind....
  60. Best ECU for boosted Ludes?
  61. thinkin of selling her.. how much u think..
  62. 88-91 Si 4WS
  63. Standard BREMBO brake discs better than stock?
  64. Oil Light Flashing....
  65. zex on an 88 'lude
  66. Exhaust
  67. 2001 SE Lude Vs. 95 240sx SE
  68. Removal of front bumper on 4th gen, need help
  69. Oil consumption H22
  70. Someone tell me what the hell is wrong with my 1st gear
  71. Will forged pistons work with stock sleeves h22a1?
  72. Wiring Aftermarket Coil (YEL wire?)
  73. Where to buy JDM type-S tranny?
  74. Prelude rims
  75. Moto Mounts
  76. Anyone have instructions on how to do a valve adjustment, for an H22?
  77. h22a injectors
  78. Exhaust leak..need info.
  79. why do cars get in a wrecked an dont start back up???
  80. Coilover Problem
  81. what is slipping in the clutch? (new to manual) how does it feel?
  82. What is needed to convert an sh prelude to base specs?
  83. RS*R for h22, i have h23...
  84. ground control coilovers..
  85. Tokico Shocks
  86. Auto-x results from HT sponsored Prelude.
  87. Protect yourselfs, cover your vin #s
  88. vtec problem 97 lude
  89. does all this look ok
  90. which freon to use?
  91. Remove/Install Steering wheel Please HELP!!
  92. Distributor Timing and Loss of Power Problems Please Help Me
  93. this a ? for those turboed ludes (please dont lock)
  94. Will a H22 EuroR Intake mount?
  95. Can an auto 5th gen run 12's w/o nos but major mods?
  96. Manual 4th gen tranny is in my 5th gen Prelude -> swap 95% complete.
  97. h22 with boost or h23 with boost
  98. SH*T!!!! clutch problems on my 4th gen Si
  99. Any good shops in VA?
  100. has anyone here ever tried to make an intake manifold
  101. somthin wrong wit my alternator or somthinG?
  102. problems with lights
  103. 4th gear problem
  104. Who's runnin F22A in a 4th gen? What mods you got done? Pics plz.
  105. Mother Fn pot holes... anything i can do bout this
  106. Would someone please tell me where their battery is grounded on a 3rd gen prelude?
  107. price of drag4 kit?
  108. Help What kinda car?
  109. Please direct me to a link
  110. how do i adjust my koni shocks
  111. Need some B21A1 specs.
  112. 4th gen headlight removal
  113. Distributor and Timing Please Help me
  114. Shifting Problem....Not 5th gear grind.
  115. Wiring A/F
  116. Camber Kit Problems
  117. MSD SS Blaster coil/Stock coil question? plz help
  118. What engine oil is best?
  119. frame damage
  120. I have an H23 block that I had inspected
  121. Sites to buy JDM motors
  122. 91 Prelude SR - Cooling fan prob?
  123. Looking for an item
  124. Need help with my Twin Carbs.
  125. whats a good camber kit
  126. pop when clutch lets out
  127. where to get helm's manual for 92 si lude
  128. Car accident
  129. pics of my build h23 yerrrd!!
  130. Just wonderin...who's got a f22?
  131. how to tap fuel rail for nitrous wet kit?
  132. Question about the lude 97 and up
  133. 98 lude - smooth shifting?
  134. '91 Prelude running woes......!!!!!!!
  135. 92-96 JDM Foglights
  136. Distributor Help
  137. Help! Headlight Help!
  138. How do I get my friggin tail light fixtures out!?!
  139. what kind of signal lights are these?
  140. Best Exhaust for H23 prelude...?
  141. h22 throttle body
  142. Where to buy a transmission
  143. lookin for some 4g lude 7 spoke wheels
  144. bare h23a engine weight?
  145. ?What size is an H22 throttle body?
  146. What's a good, reputable Tune shop in Orange County for Honda's
  147. blew my block
  148. How do you do a valve adjustment for H22
  149. where to buy prelude headlight
  150. good price?
  151. Has anyone ever tried this???
  152. 4gen 2.3vtec prelude with vafc question
  153. rolling the odometer?
  154. anyone use a AN-R header on there h22's???
  155. Front blinkers on 5th gen?
  156. Crower Cams - Stage 2 w/stock idle lobes - Anyone get these recently?
  157. Fuse box diagram needed.......ASAP
  158. tsb question
  159. help^ my lude is makin a knockin sounds at 3500 rpms
  160. questions about h's
  161. Is there a lambo door kit for 93 ludes?
  162. Intake Manifolds (4th Gen)
  163. Cam Gears....
  164. how much hp can an SS take??
  165. car stalls at stand stills
  166. what is the valve clearance for h22 valve adjustments
  167. A/F gauge help
  168. Are H22 and H23 headers the same length??
  169. Hondata in an auto.
  170. '91 Prelude idle loping????
  171. wrecked the prelude, might sell parts?
  172. h22a headgasket, removing middle layer, more compression etc.
  173. Anyone using skunk2 stage 1 cams in their h22?
  174. Didn't see any related posts in recent or archived messages so... Type S airbox Q?
  175. car doesnt rev like before
  176. abnormal wear with lightweight flywheel???
  177. Anyone running Tein S tech springs on their 5th gen?
  178. Type-S piston question
  179. Whats the best handling springs for under $300
  180. hks
  181. Videos
  182. Strut Tower Bar Installation??
  183. which forum
  184. Power enterprise timing belt
  185. Exhaust Questions....I SEARCHED
  186. Did they buy these headlights like this or was it a DIY project...
  187. Greddy Turbo Kits?
  188. wow, i am an idiot look here!!!
  189. 98 prelude SH 5 speed value
  190. Anybody have a stock header assembly that they wanna get rid of????
  191. I tried Ubertegs chip in my Prelude...
  192. Street tune VS Dyno tune?
  193. Coil question
  194. Gettin' boosted ??
  195. Help quick question
  196. stupid yet somewhat relevent
  197. Thought i'd share some pics of my broken motor (56k beware)
  198. really stupid question: How to install shift boot on 5th gen?
  199. clutch pedal lost pressure.. help get it back?
  200. Which Prelude to buy?
  201. Adjusting Coilovers
  202. I dont know what to do
  203. obd2 lude to obd1?
  204. VAFC pros
  205. 135 ish mph Heeeeeehaaaaa (is this going to be locked?)
  206. attention JRSC Prelude owners
  207. Question regarding Koni Yellows and Ground Control.
  208. 1997-2001 Prelude base model tranny casing
  209. ecu discussion
  210. CEL code 7
  211. SMSP's New Email
  212. Does anyone know anything about jdm coil over sleevs
  213. Tein S. Tech Springs
  214. who is the fastest top speed prelude and what speed?
  215. best shifting points on a 97 lude
  216. how do i reset my comp?
  217. autometer gauges
  218. 1988 Prelude S
  219. help me please
  220. Would a Type r engine fit in 91 prelude
  221. Head rebuild need help with a quick question please read...
  222. What are u H23 guys shifting at
  223. Final assembly point?
  224. H22a INjectors
  225. GC coilovers 5th gen vs. 4th
  226. Anyone looking for a 4g H22a Swap or a Carbon Fiber Hood for a 4g Prelude?
  227. tail light
  228. fix it for my greddy evo
  229. cotter pin
  230. prelude type s cams
  231. Light Harness!
  232. RPM at 80MPH in 5th gear on a 4th gen Vtec
  233. A curious kinda thing...
  234. I can't figure out what color this is..
  235. best gains
  236. Just curious....how do u bleed coolant?
  237. Mitsubishi 14b turbo into my 93' Prelude Si???
  238. Newbie Questions about Prelude
  239. how big are the benifits of swapping out my h23 to a h22 (besides vtec)
  240. I usually don't ask for group opinions, but...
  241. act clutches suck...
  242. painting an intake
  243. Idea of a new swap
  244. AEM pulley kit...
  245. H22 Redlines?
  246. a question about my prelude
  247. how do i get more performace out of my vtech
  248. Looking for H22a
  249. problem starting car
  250. Dyno pics and new toy.
