View Full Version : Honda Prelude
- H22 turbo opinions
- 4TH GEN PRELUDE MANUAL CONVERSION
- Have you run a chipped P06?
- H22 block shopping
- '00 prelude ecm trouble not cranking
- 98 Honda prelude windshield
- doing 4th gen 5 speed conversion NEED HELP
- Please help. Good battery not starting Prelude
- Are both camshafts the same? H22a engine
- 4WS not working NO dash light '93
- Distributor Rotor Screw size?
- 2000 Prelude auto transmission makes noise when in park or neutral
- 97 prelude auto tranny slipping?
- Smashed into a curb- need some help
- Is my 97 Preludes Auto Transmission ok?
- Helpp !!! Starting up jdm h22a
- Please help : Spoiler Brake light
- Valve Adjustment Questions
- Does this look like oil pump failure?
- Thinking Buying This Need Help
- prelude timing issues.
- 1995 Prelude Speedometer not working
- battery and brake light are coming on
- 01 prelude dash lights help
- 4th gen prelude oil leaking from driver side behind engine mount
- Removing top mount brake light cover and bubbled purple tint
- project not starting :'(
- Oil In Spark Plug Tubes
- 1997 Honda Prelude Base 5-sp - H22A4 to H23A Blue top
- fault codes
- Need to remove the door chime. Where is it?!
- Need help, 96 obd2 s prelude
- swapping a f22a for a f23a
- Can a f23a fit in a 96 s prelude
- P0132 + flashing CEL
- Bad power steering pump?
- retrofit options 95 lude
- need advice obd1 VTEC conversion h22a4
- A/C and Heater vent issue.
- 1995 Prelude Si H23a1 auto to manual conversion
- 95 prelude keeps stalling
- 93 honda prelude
- testing EACV
- Passenger axle chirping noise
- I'm I running lean?
- What exhaust should i get??
- 93 prelude si loud knocking noise
- h22a1 obd2 question
- Prelude eating gas
- H23 Serpentine belt noise
- Swapping transmissions between 4th and 5th gen
- 92' si h22a vtec wire-up?
- 4th gen JDM 1 piece headlight install
- Installing 4th gen 1 piece headlights
- 88 Prelude 2.0S Stalling after running for a few minutes.
- 95 Prelude No fuel Cyl 2,3,4 F22B2 Swap
- H23A vtec blue top build
- vtec solenoid questions. please help
- Is it okay to run straight distilled water?
- Whats wrong with my prelude hood?
- Removing front drive shafts
- 2001 prelude sh engine compartment wiring diagram
- H series question
- steering column ignition swap question
- h22 timing mark location issue.
- 1993 H23A1 Starts Then Dies
- H22 to JDM H23 swap question... Please!!!
- '99 Honda Prelude base crank pulley options
- how do I remove the AC High Side Discharge line?
- Where to find Magnaflow Cat + Greddy Evo 2 Catback
- H22 help ! ?
- h22 type s swap into 96 vtec
- Boosted h22 tuning question
- check out my low profile timing belt (what started as no spark lead me to this)
- fuel pump kill switch not working
- my prelude needs your help!!
- F22 No Spark
- H22A Red Top Leak Down (100%)
- retainer ?'s
- Any experience with this ebay exhaust?
- The revised h22 auto tensioner
- faded paint and painted rims- sign of neglect?
- Whistling Sound
- 1997 Type SH Starting Problem
- 97 prelude intake. Please help
- 5th gen, bad misfire issue
- Overheating and I'm dying for answers.
- Timing belt walk (please help!!)
- 2000 Prelude SH burns oil, what to do
- need serious help with my 01 lude
- F20b swap need help please
- Cooling fan not coming on when I shut the engine off
- Intermittent spark and no injector pulse.
- 4th gen & 5th gen stock intake the same?
- vacuum line on back right side of intake mani missing.
- oil when I take spark plug out??
- Rear tires scrubing from wide rims and tires.. HELP
- Does a used ECU have to be programmed to the car? 00 Prelude.
- H22A Vtec doesn't work after swapping to manual gearbox (but there is a pressure on t
- Backup Lights Not Working
- how to fix fuel system monitor malfunction?
- a/c problems
- 01 prelude tachometer jumping
- 5th gen rear control arm - inner bushing
- 92 civic hatch h22a4 swap questions
- DRL light..p. side high beam not working
- Rocker shaft bolt help
- good cylinder head still?
- F20b won't crank need help asap!!
- h22a swap problems help!
- 01 prelude cutting out driving me nuts please help
- how to tell if i have obd1 or 2
- Prelude Transmission
- H23A1 with no spark.
- Random Issues
- Why are they Priced like this?
- Bearings: OEM vs. Aftermarket
- H23 Blue Top Swap - Another Thread
- H22A; downpipe touching oil pan
- no spark on 96 vtec prelude
- fuel tank leak (pics)
- 93 Honda prelude misses
- My lude has bad idling issues
- Size (length) of OEM cat?
- H22A4 Head Gasket
- Engine idles low when hot
- Possible IACV failure
- Does anyone know where this vacuum hose goes??
- H22A AC delete question
- ecu issue
- 96 H22a cylinder & h22a4
- dash problems
- My fabricated engine mount. Critique it
- Euro R intake manifold + RDX injectors
- F23a or F20b
- 92 Honda prelude project....Again
- AC compressor suggestions
- h23a swap help
- 1999 prelude at, base misfire issue
- H22 arp head studs nuts are stuck
- h22 turbo build question
- 97 prelude sh stalling problem
- Having axle trouble with JDM T2W4 in 4th Gen
- need your opinions :)
- 92 prelude transmission problem
- 5th Gen Euro-R swap w/ chipped P28.
- H22a swap starts for couple seconds then stalls
- 5th Gen Prelude SH the only car I've loved GONE/ resurrect or no?
- Weak clutch
- 92 prelude f22 needs some help!
- H22a w/ PCD in 5th gen; custom harness
- how do i replace my timing belt?
- Trany M2S4 internals into M2Y4 case
- a few questions/suggestions about a very mild turbo h22a4
- quick question for any chipped ecu gurus
- H22a1 issues
- Help, how to set camshafts back in time after jumping
- Can someone do me a huge favor, please!
- Top strut broke
- TANK, VACUUM???
- Hood Release Cable Broke
- knock sensor code wont go away
- M2k4 lsd
- High Idle after SRI Install
- '99 Prelude Front Lower Ball Joints
- Low idle after ECU change
- 97 Prelude Engine Swap Cranking but not starting.. VIDEO INCLUDED
- 92 Lude H23A help
- 98 prelude sh brake light problems
- help me i keep breaking axles like no tomorrow wtf!!
- h22 running rich
- JDM H22A Fitment Questions
- Clunking noise in rear
- H22 Jun Cam Valve Lash Specs
- 88 Prelude 2.0 si 4ws ball joints same as 87 jdm?
- Climate control help
- Lock Cylinder fell into door... door is locked now help!
- How to test the fans?
- H23 VTEC new build oil in intake manifold
- OBD2 Code P1382 on 97 prelude...changed everything and tracked wiring.
- help no spark 94 lude h22
- Wanting to buy a prelude
- m/t oil cooling lines?
- Balancer Shaft Seal Retainer Part Number
- Help Blow Engine Replacement 96 Prelude SI
- How Much Is It Worth
- Engine swap advice
- Mahle GoldSeries on Stock H22A1 rods
- Original owners manual
- H23A swap received in poor condition, asking opinions/advice
- 2000 honda prelude sh won't start
- 2000 Prelude Sh
- NKK clutch
- Question about stamps on the engine
- usdm h22 to jdm h22 dizzy conversion
- Advice/Help
- couple quick questions, 92 si h23a
- 96 prelude so with h22
- h22 help
- Picked up a '92 sr
- weird gear like thing sticking out of engine
- immobilizer problem? help please
- f20b full swap into 96' prelude ?s
- Looking for a 4th gen hood cover
- eBay coil over sleeves.
- H22a spark plugs
- 5th Gen Prelude Engine Problems. Please give your inputs.
- '91 Prelude 2.1L
- drilling egr ports prelude sh 99
- h22a4 build.. questions
- squealing noise?
- 93 hondaprelude AC
- Swapping F20A4 to H22A2
- Newly Installed JDM M6HA Auto Tranny Fail To Operate
- KNOCK SENSOR square and circle plugs HELP!
- wiring problems
- 87 2.0si info?
- need help with v tech please
- M2S4 trans help
- 4g cruise control location?
- Starting issue
- Bolt pattern 92 honda prelude
- Turbo Prelude Question
- secondary butterflies not functioning! missing low end torque
- Where to get this fog light?
- Can you point where this vacuum line should be?
- SRS Light Challenge
- Rosko Racing Prelude H2B Kit
- Question about auto tranny
- Car want start
- who can USDM to JDM climate control converion
- HELP radiator problem
- 2000 BB6 prelude problem!!!!
- Is my mechanical timing off?
- 1988 Prelude 2.0Si 4WS starting issues
- Short Ram to stock with a K&N fitler
- Intake question...
- Won't start.
- ticking noise when accel
- Is it this simple? - Resistorbox bypass
- hoping you can help my identify these injectors.
- Prelude with moments :/
- H22a help?
- H22A4 crank
- clicking noise when accelerating
- DIY complete body resto-mod of my 95 Prelude
- shifting problems
- Help needed to identify Front brake calipers from 1992 Prelude
- Who to get a good base map from
- bama's project
