View Full Version : Honda Prelude
- goin to obd 1
- 3" Exhaust
- Catalytic Converter
- Idle speed drops to 500 rpm's when turning on A/C????
- JDM H22a distributor tuneup?
- how should i run the exhaust system on my prelude?
- im hearing a squeek @high rpms
- Does anyone know where i might be able to find these parts?
- FS: prelude headlights (92-96) jdm climate control
- suspension questions
- Which 4th gen is best???
- Should i put 3" exhaust on a none turbo 5th gen?
- Milling H22A Head questions
- Does anyone have any 97-up prelude injectors just lying around?
- Nopi Nationals
- 215/40/19 tire ?
- Prelude Just Cut Off
- Every one check out my new avatar!
- Anyone know where i can buy a head package port and polished?
- 99 Prelude coin holder liner peeling...
- 88' prelude auto to manual, plus carb ques..
- Sport Shift to manual conversion (5th gen)
- Exhaust Problems
- 92 prelude Si question...
- Oil Filter leak?
- 3rd Gen Questions....
- Black smoke!! but why???
- Shocks & Springs (Type SH)
- 5W vs. 10W oil
- WTB vtec ecu for a 4th gen lude
- need some specs ASAP!!!!
- h23a to h22a swap
- pics of drag 2 on a 4th gen??? Please
- Hybrid heat problems?
- A/C problems
- How much to shave of head!??? H23A
- Turbo Prelude, YES!!
- Anyone here running Type-S pistons w/ aftermarket cams?
- AC Probs
- h22 type s motor...
- Apex N1 exhaust question?
- Opinons Please: JUN chipped P72 in a 93 SR-V (H22A1)
- Great Video of Last Honda Challenge Race Me VS ITR....
- opinion on track time
- Okay, here's the situation. My parents went away for a...
- OMFG!!!! what do you guys think about this?
- New addition to the family!
- H22 shift linkage
- pics of my motor apart
- 3" Prelude Exhaust and Downpipes....
- Rattling Below 2300 RPM. May be from the engine..help
- reverse indiglo for 96 prelude
- 4th gen lude power window
- ludeuser just dropping a line...
- 4th Gen Apex-i V-AFC Install
- '99 Prelude CEL - code # - P0133
- 96 JDM Motor- H22A1? H22A4? H22A?
- Wheel Questions
- JDM Fog Lights Install
- FYI: About the "extra hose" everyone has after an intake install....
- WTB: The upper radiator hose neck that bolts on to the head for an H22.....
- Idles like ASS
- Prelude R/C Car EBAY Auction ENDS TODAY!!!
- 4th gen dash... mods?
- Jrsc lude video
- Skunk2 Stage 2 Cams w/ N2O?
- Nice or Rice?
- FS: Front+Side skirt kit ALL-$110.
- misshift
- WHO had/has a TYPE R jdm ? LSD in his H22a tranny ??
- 94-96 console in a 92 Lude...
- Aftermarket injectors
- anyone need a vin number run.
- OEM in-dash CD changer help!
- Need Answers: GS-R ECU on H22a
- waht plugs and wires do you use?
- what to do next?
- which block with which tranny should I go for?
- Need advice for a suspension setup that gives a 1.5 inch drop
- Difference on 4th and 5th gen coil-overs...
- h23
- Stunna wrecked his car
- Need Opinions on Drag Turbo's
- Where to find cheap prices for replacement Honda caps for Type SH rims?
- One more wheel question...
- Any opinions on RevHard's equal length turbo manifold for the H22A?
- Rear End
- Are longer head studs needed when installing the Hondata gasket onto H22A?
- ADVICE 91 prelude SI motor shot
- Guides to Timing belt and valve adjustment!?
- If everything goes well, this time next week I should have a Prelude
- ballpark figure for suspension setup.... which one?
- what needs to be done to install cai?
- Cam specs for JUN, Skunk, etc.
- Field Vtec SFC Controller
- h22 bore
- Should I buy these wheels?
- How to mess up the speedometer
- Prelude R/C ON EBAY!!!!!
- Big Brake Kit upgrades
- will an type-sh head fit on a base block?
- Hi new user...
- Here is one of the best Show Preludes for sale!
- i/c piping
- Does anyone...
- Bolt ons, gutted cat and OBDII... it actually worked.
- WTB: 96- prelude shifter lever
- ~~~orange county, i need help retenshion the belt.....~~~
- kyb agx's?
- Crower Cams
- FS: Prelude Service Manual 97-01
- someone with a prelude and a digicam do this for me.
- Is it bad to install shocks without dustcover?
- Volk Le37t in 4x114.3 lug pattern?
- Need Help!!!
- Quick question ..... how to remove Stock oil press unit from block? -need help ASAP please.
- AEM CAI install question
- Cure to shock knock
- Need help with turbo size + trim.
- PGM FI Light on 86 Lude?
- what knife edge crank?
- legend/nsx caliper swap
- ATF for 3rd gen
- Brembo brake kits
- Is there a difference between "S" and "Si" brakes for 3rd gens?
- GS-R ECU Test...More to come.
- Need Speedometer Calibration Scam
- what are u guys talkin about the dp and the exhaust?
- CHEAP GOOD shocks... what to get?
- Radiators!!!
- Turbo-Performance Prelude Manifold and 3" dp...
- Whats up with these Ebay ECUs
- aem fuel rail
- Eliminating heater heat source on H22a when installing hondata intake manifold gasket?
- HELP!! 4 wheel steering - Prelude
- Trouble with car starting.
- torque spec for h22a
- how does one put icons on your names ?
- Prelude guys with 3" custom exhausts and downpipe....
- Weigth question
- those with jdm h22's...ignition question
- check it out
- spray painting
- You Turbo Ludes What kind of fuel managment do you have?
- tightening a ball joint?
- NEED H22 Specs!!!!!
- Have Tanabe exhaust - thinking of something different...
- Spoon test pipe ...
- Differences between 2001 Preludes & 2000 Preludes?
- axle back exhaust
- gsr or h22 ecu
- what lip is this???????
- Is there a Drag Gen 4 Kit out for the 5th gen Lude yet?
- Massive Weight Reduction
- EyELids For A 95 Honda Prelude...Anyone Know Where To Find Them?
- cams for h22a
- 94si custom rod project
- Who makes a 3" exhausts for my 4gen Prelude Si?
- Prelude tried to race me today.....
- Lowering and shocks/Struts
- 5th Gen Turbo Kit
- polished intakes?
- Head work on a H22
- Should I coat/wrap my header?
- Anyone Need a body kit? Ground Design Black Widow 1 Full Kit F/S
- 85 prelude flooding...PLEASE HELP ME!!
- morning start ups
- turbo Lude pics
- 2001 Prelude Type SH (NEW PICS)
- 3rd Gen Prelude motor?
- reliability of h22?
- Tell me yur Turbo Setup on yur Lude
- specs on prelude TYPE S and EURO ACCORD TYPE R camshafts? anyone know
- Finished up my Drag Gen II install on my 92 si...but have one problem.....
- JDM Fogs (97' & Up)
- vtec an f22?? things to do with an f22
- 4th gen VTEC supercharger....
- question about an intercooler
- O2 sensor - what does it do???
- For Sale - SMSP H22 4-1 Header
- Jiggalicious!
- Question about fuel system pressure and experiences of other AEM fuel system peeps.....
- What do you think?
- 86 Prelude SI
- H23 Valve timing
- tail lights
- Si engine
- How much does A/C and P/S weigh?
- Help....
- Synchro Hubs and Honda UK
- Todd 94??? need some info for a H22 buildup
- What size is my muffler?
- Aluminum Wings?
- my full tank of gas only went 135 miles!!!
- apex exhaust
- whats better 14 or 15 rims on slicks
- Anyone needs a JDM Header?? from F20B
- 4th gen msd blaster ss coil install help?
- How many RPMs is the H22 bottom end good for?
- type s piston and cam specs?
- JRSC and Cams
- Helms please (main journals, JDM and USDM?)...
- Group Buy for Prelude Quaifes is ON
- Indoglow Gauges for 01 lude
- RAD Fan wiring
- ot, but please read.........
- Lighter connecting rods for H22a. Worth it on an n/a motor?
- JDM stuff on ebay...
- Why do you have to Resleeve the block?
- Turbo H22a in 91 Accord
- Quaife LSD and injector size
- Good Source for H22a Longblock and looking for OEM LSD tranni
- Need help with diagram on 4th gen sunroof.... help?
- HELP!!! Anyone have a 92-95 Prelude (all model) distrubitor ? $$.$$
- looking for a quiet exhaust w/a tip thats not huge
- I'm back!
- Imagine..... an Si Blue 4th Gen Prelude.......HELP!!!
- OBDII->OBDI Conversion
- What is the POINT?
- Need ecu pinouts for 00 prelude
- piston rings
- those with Turbo Preludes....does your car overheat??
- G2 Suspension trouble, struts or shocks? Sealed or Take Apart?
- 97 prelude SH Tranny for sale $400
- 98 Trpe-sh
- why can't i post to some threads? - kill stories etc....
- WTB: SH Rims
- H23 with h22 head??
- does jdm h22a type-s have lsd or atts?
- OT: want the advice of the Ludes..PY JDM Type-R (to emblem or not to emblem.. that is the question..
- CV Joint
- Requesting pics: OEM kit on your lude
- Anyone need 98+ h22a main bearings??
- Massive Motorsports?
- Test Pipe for OBDII...
- Need new clutch, anyone got good deals for 5G lude, preferebly factory clutch
- Running on low compression?
- gf buying prelude, wants to go fast.....
- Parting/selling my 98 Prelude, who wants parts? and/or is interested in the car?
- Wheel Locks?
- I need help from the best on this. please !!!!!!!!!!!!!!!!!!
- Wrong motor?
- Balancer Shaft Oil Seal?
- Running hot
- What hasn't gone wrong...(attn: anyone who has done a swap on a 4th gen lude) please help
- prelude cams: crower...skunk2...
- whats the word on underdrive pullies?
- Can someone with a helms manuel help me please
- cylinder head sensor?
