PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. engine light on h22 vtec not working
  2. Oil pressure gauge install Mechanical
  3. HELP!! Problem! Turnsignals
  4. My Progress Thread
  5. prelude parts pricing, i need a little help
  6. TIming belt broke. what to do?
  7. Making my 97 Prelude better
  8. Which motor can I put in my prelude? (1989)
  9. problem, car hesitates/spuders, getting too much fuel?
  10. Restoration Help -- Primer overspray on door panel
  11. tranny swap in socal
  12. F22a Fully built...CAM???
  13. Wierd Alignment Issue
  14. guages
  15. 4WS code....please help
  16. Sway bar Endlinks
  17. Power steering fluid (foaming from cap)
  18. All motor H22 exhaust size
  19. 97-01 Honda Prelude Projection Headlights CCFL Halo
  20. hid install ?'s
  21. vafc drawback?
  22. ABS Removal
  23. OIL BURNING LIKE CRAZY!!!
  24. Removing SH spring and shock
  25. 4ws problems!!
  26. h22a4 engine replacement?
  27. Do i need all this stuff? (Shock absorber hardware)
  28. QUICK QUESTION ABOUT: PRELUDE TYPE SH...
  29. doesnt want to rev past 6500.....
  30. Replacing radiator... other cooling parts to replace at 135k?
  31. removing 4ws ECU
  32. Can you break a ball joint?
  33. h22 swap issues
  34. removing rear seats? 4th gen
  35. !?Can anyone help me with my New Years Resolution!?
  36. h22a4 owners head milling
  37. Distributor and spark plugs
  38. 98 Base H22A Tranny/Axle Noise
  39. Whats interchangable with the prelude?
  40. Any difference between the JDM H22A and H22A1 Cylinder Head?
  41. Won't Start
  42. need help crashed prelude
  43. what does vtec controller do?
  44. clutch- never seen it this bad. help?
  45. neep help, idle problem
  46. Progress Rear Sway Bar torque Specs
  47. throttle body
  48. parts swap
  49. ground control problem
  50. Skunk2 Intake Manifold with s2000 Throttle Body
  51. H22A4 Eagle Rods
  52. Bent rim?
  53. What tool is used to measure to wall clearance?
  54. h22a4 block with a h22a jdm head can it be done?
  55. h22a --- wheres the map sensor
  56. Spark Plug Question
  57. NEED HELP ASAP!!!!!
  58. GSR and H22 HELP!
  59. ABS pump
  60. Balance Shaft Removal
  61. ignition problem
  62. would a bad inner tie rod affect alignment?
  63. need help rewire tiptronic trans.
  64. Fuel
  65. Je pistons stamped 87m under the crown, is this the bore it is inteded for?
  66. What do you all use to clean the Instrument panel cover?
  67. 91 honda prelude si!!!!!!!
  68. Leather or Vinyl?
  69. single row crank pulley
  70. jdm emblems
  71. Anybody know the diameter of the Prelude clutch master cylinder?
  72. Teaser Pics- New turbo
  73. looking for an automatic short geared b series trans or a shift kit for a b20 swap
  74. Happy NewYears
  75. Please help me with my manual timing belt tensioner...
  76. h22 tranny problem??
  77. H22 head swap advice and warnings
  78. Starter Motor
  79. burnt 2 p13's
  80. spark plug gaping
  81. H23 vtec compression?
  82. ABS light came on while driving...
  83. stalled and won't turn over
  84. Radius Rod, Left or Right?
  85. few quickies
  86. prelude 2.0
  87. Ignition Problems, Idle Problems, and then some
  88. K Series mounts for 92-96 prelude??
  89. barometric pressure diagram?need to intall sensor
  90. A vanity plate for my 4th gen
  91. H23 build
  92. WTB: h22a 5spd VSS Speed Sensor
  93. valve cover ground pic request
  94. Paint flake on rear window and weather stripping
  95. Deck Height?
  96. factory muffler!
  97. exhaust picture off car
  98. wiring mystery
  99. Just wondering...
  100. No audio from all speakers. Radio still works.. Thoughts?
  101. Base exhaust on an SH
  102. EGR Fix....$?
  103. 93 si with a h22 factory?
  104. leaking headgasket .. what to do
  105. Clutch noise 2
  106. hid
  107. valve adjustment
  108. how to do a burnout?
  109. Another "sound" thread. Halp plz. n
  110. rust repair
  111. Oil Pressure Gauge
  112. Knock Sensor
  113. TypeS Prelude dyno result and question
  114. Stock looking aftermarket muffler
  115. Problems starting my car
  116. Rust a common problem with older Preludes?
  117. Black smoke
  118. BBS WHEEL QUESTION! #2!
  119. wiring question for spoiler
  120. 92 just did h22 swap now shows code 41? need help
  121. Does anyone know what this color is called?
  122. Drag Radials-What you running/size/rims?
  123. Engine Chip
  124. ECU options?
  125. ebay headers
  126. prelude injector?
  127. GOOD NEWS!
  128. I'm in need of some eBay help.
  129. steering wheel
  130. wat r the best ways or producing torque? need feedback
  131. Seat Belt retractor stuck on
  132. problem with cranking my prelude.
  133. problems with my prelude
  134. Best pre-cat o2 4 5th gen?
  135. 1996 prelude ABS PUMP
  136. jdm f22b dohc headgasket same has h23A ?
  137. Grinding when slowing down. Only 2100-1700 rpm. WTF?
  138. dubs on a lude???
  139. funky smell?
  140. where are you grounding your amp in your trunk(5th gens)
  141. ABS brake problem (pump motor over run)
  142. lower tie bar
  143. Stalling at part throttle
  144. Prelude Steering Wheel
  145. solid cel light
  146. Problem with deck in 1996 prelude
  147. What transmission oil should I use???
  148. Quick question guys about h22 swap.
  149. PS Steering Rack
  150. main seal
  151. h23a1 timing belt install question
  152. Hot Weather Ignition problems... Black 94 4th Gen Si-Vtec...
  153. Need crankshaft For H22A4,5 or 7
  154. exhaust wrap on stock headers
  155. Swap or new car?
  156. is this the part i need?
  157. o2 sensor
  158. Timeline of the death of the Black SHEEP
  159. H22 swap into 94 H23 automatic prelude...
  160. Balance Shaft Removal???
  161. brake swap?
  162. Grinding noise under timing cover... Ideas?
  163. 97 PRELUDE IDLE STILL NOT RESOLVED ANY IDEAS????????????
  164. stock headers
  165. slimline fans
  166. what is this and what does it do ?
  167. Megan lowering springs---Any opinions
  168. 1997 SH Speed Sensor install
  169. Reading a code on an obd1 prelude ?
  170. new timing belt install, belt starts to rub after a few crank revolutions
  171. tokico blues + skunk2 coilovers = won't go that low?
  172. Bleeding the ABS Modulator on 92 Prelude
  173. new here
  174. Code 22
  175. MERRY CHRISTMAS LUDERS!
  176. f20a turbo
  177. Header and catback wont line up
  178. how to adjust ignition timing?
  179. bb4 fmic install question
  180. 4th gen interior swapping questions.
  181. questionon SLS ramhorn in a 5 gen?
  182. Tein Basic vs. Tein Superstreet
  183. Blinker problems
  184. bent valve?
  185. Upper rad hose expands after driving
  186. IDLE SEARCHES FROM 1000 TO 3000
  187. good tuning shop/dyno shop in Austin Texas?
  188. bent LCA suggestions
  189. Timing belt noise?
  190. Authentic Mugen aero kit?
  191. looking for an h22 swap..
  192. Interior rear panels.
  193. yIdle problem 01lude
  194. So I did a valve adjustment today...
  195. Euro R Intake Install Problems....
  196. Megan Racing header gaskets
  197. Finally some weight data for my track car
  198. Is there a difference in neuspeed strut bar?
  199. Can you guys give me this measurement?
  200. my f22/h23 hybrid about done, but question about this timing belt
  201. ecu problems??
  202. Hesitation & misfire at all RPM and all throttle ranges. Plugs are lean. Just did headgasket, ran f
  203. PLEASE HELP!
  204. h22 question
  205. gas mileage is horrible
  206. Installed s300 need to get atts light off
  207. Do Not Buy Products From JAPANESE ENGINES INC. in N. Jersey
  208. Master Cylinder Help(brake)
  209. 1996 Prelude ABS LIGHT ON
  210. yes another sea foam question but its easy.
  211. cleaning dirty head
  212. front main seal
  213. Ground Control Coilover/ Koni SPort Hardware Question
  214. removed distributor before i changed flywheel, need help with timing!!!
  215. lowering my 4th gen by cutting springs?
  216. driver side window problem
  217. Rear defroster in 4th Gen
  218. where is the tach wire.?
  219. Should I have an ECT on front water neck? 1992 H23A
  220. O ring leak
  221. crdcz03's prelude project thread. abs removal/manual rack conversion/wire tucking
  222. 5th gen rear seat removal
  223. Power Failure..
  224. 4th Gen. Mirrors
  225. Do any of you have 5th gen springs laying around?
  226. code p1259....please help!!!!
  227. my 96 prelude jdm-
  228. Weird Ignition Problem
  229. Need opinion, Which Rim? Gt3, Circuit8, JMAG
  230. SH headers
  231. High Res. Pic
  232. will innovative 4th gen prelude REAR engine mount fit on the rear 5th gen?
  233. will this ecu work with a h22a4 engine???
  234. Damn hood doesn't shut....
  235. 4WS Issue
  236. type s cams lift and duration??
  237. Upper control arms for 4th gen, can I use 5th gen arms?
  238. Smell coming from heater
  239. Gas Tank
  240. H23 All Motor?
  241. Quick question on clutch line fittings
  242. My M2B4 tranny...Screwed
  243. Rebuilding track-car suspension: Thoughts on adjustable ball-joints?
  244. Prelude Rear Lip
  245. Vibrant flat-black muffler sound clips on 5th gens??!!
  246. Tranny Issue Manual
  247. what year did they start putting h22s in preludes?
  248. From a tech standpoint, what's wrong with this eBay ad for a 'turbo head'?
  249. Memory is clearing on Aftermarket Head Unit when i start the car
  250. Partial throttle hesitation?
