View Full Version : Honda Prelude
- accord type m lip?
- h22 lsd question?
- smoke coming out from under the hood
- catalytic converter QQQQ's
- 92-96 honda prelude turbo piping kit
- For ALL who have the "HESSITATION" Problem
- Ignition Switch Replacement
- screwed up speedometer???
- No knock sensor = no CEL
- Individual Throttle Bodies
- Does any company make fiberglass hoods for 92-96
- Engine Type
- prelude leather
- H23 Parts on F22?
- Anybody make after market mounts for the lude?
- 5th Gen Dies occasionally in when shifted into Nuetral or at a light
- Thrust washer
- frozen antenna(for all u northerners)
- H22A2 Changing pistons?
- thinking about buying a 01 prelude questions!
- May be getting 5th Gen Lude Tomorrow...Need Advice!
- is the vtec controller worth it
- Lude 5G S-Spec JDM - LSD type ???
- 17s? lowering?
- Refugee from ITR forum checking in :)
- Coolant leak?
- question
- ExplicitSpeed Traction Bars for SH
- Bigger TB really worth it?
- Dim headlights
- What H22A is this?
- (Not sure if right place) Anyone want to trade type r lip for mugen?
- I may be getting a 5th Gen tomorrow...
- Help! I am swapping out a blown H22A4(non SH) with a H22A.
- need help
- Does anyone know if a company makes these rims in 17"??
- need a lil help removing intake manifold
- EGR Valve Question
- Automatic performance
- Hit a duck....
- jeeeze this h23 is a big prob
- Which models get the black housing headlights?
- head bolts h23
- Suggestions of Intake! anyone?!!!
- Surprise and a question
- Few Problems with 5th Gen...
- !! Hello !!
- Skunk2 coilovers with Tokico blues on a 4th gen ...
- solid cel... is my ecu bad?
- accord type R lip kit
- Interested in buying a 2000 prelude need advice...
- 92 Prelude Rearview Mirror button removal?
- Rod bearings and Piston Rings
- Daily Driver Oil
- New Suspension
- Axle
- Bumper Question
- my led gauge lights dont work
- Prelude Trans
- 17x8 Wheels... What off set Needed??
- Ok, I have one quick question about the FITV.
- mgags seven CHECK THIS THREAD
- bolt pattern
- Intake coupler Q??? Need you HELP!
- car wont start!! no fire! please help!
- what do the conner lights use for bulbs
- r/s ratio
- Question About Suspension.
- Valve Cover bolts and nuts - stripped
- H&R Race Springs on a 4th gen
- 4th and 5th gen front bumper suuport the same?
- My new 1998 Honda Prelude Type SH (pics)
- DH racing throttle body+ FPR ANY GOOD??
- FITV Question
- Timing belt broke...Is this damage?
- quick rmf header question
- Vaccum Hoses/Where do these go? (56K warned)
- Cylinder tolerances
- i am looking 4 the rewire site i cant find it
- Which header for ann H22a4 all motors?
- stupid question about bleeding my coolant system
- VSS location on 1995 2.2vtec prelude
- Two hoses under throttle body?
- High vs. Low Impedence Injectors
- Type S Swap into 98 SH
- Leaking Oil!!!! Help me now!
- hmmm...4340 eagle rods??
- Prelude Type-S camshafts on EUDM H22A2...
- crankshaft bridge damage
- light weight wheels?
- Steering wheel
- BDL Fuel Rail... post up if you got one, cuz this is pissing me off haha
- i have a problem!! my cars a 92 the h22 is 97 i had 2 order a crank tdc and the plug do fit
- rsx wheels on 97 and up lude?..
- Bolt-On Power Help (Searched)
- Added some Hood Dampers...
- 1992 Honda Accord w/ H23 non vtech 4 sale
- HELP! car crash
- '90 Prelude Speedo, Tach, Gas Guage won't work
- Rebuilding Bottom end
- ecu location
- 6 puck clutch
- 4g prelude calipers
- 2001 Prelude TypeSH for sale
- My H23 vtec dyno
- Instrument Cluster Replacments or Retrofits?
- Vtec Controller, Good or Loose Power?
- War against muscle!!! Let's show them!!
- another "where the hell does this go?" post (56k beware)
- is this a fuel line??
- tps question
- Help: Running too rich CEL PO172
- JDM wiring harness
- Full floating wrist pins
- Weird Idle Question....
- H22 A4 compression test...motor has not been running for few months before testing
- what size is the oil drain bolt?
- oil pressure sensor adapter
- No coolant coming out of bleed screw
- maxbore H22?
- Best clutch kit and flywheel combo?
- cold weather have affect on oil?
- help plz i wanna buy a prelude but confused???
- Clearing ATTS Codes
- does the valve cover gasket have...
- Weird running after timing belt replacement
- H22 Cam caps??? please help!!!
- Cant get timing belt on
- Smoke from throttle body/ injectors area..help???
- h23 or h22
- car doesn't start
- vtec engagment point
- rear performance mount
- 96 Prelude Rear Lip
- emblems and badging
- rear caliper emergency brake disconnect? 1989
- guard broken on bottom of car
- ARP products for h22 pressure plate and flywheel
- Headgasket modification
- Prelude Shift linkage ?
- Starter valve???
- question if my car is OK
- H23 performance timing belt has been made!
- Rebuilt Engine
- High flow Cat or Test Pipe?
- skunk2 intake and throttle body?
- H22a underdrive belt?
- Passenger door won't open
- Worse mileage on highway than in city
- stock intake box on 2001 prelude
- URGENt help identify part behind dash glass next to gas gauge
- USDM vs JDM
- OBD 1 ecu upgrades
- h22 h23 oil pump ?
- rebuilt h22a built head
- exhaust question... 2 1/4 to 1 3/4?
- car won't pass smog!!! need help
- who's got aftermarket motor mounts
- JDM EL gauge cluster...
- H22 Header
- skunk2 iac
- need help with heated seats!!
- anyone seen this carbon fiber sunroof?
- lots of ???? about h22a motor
- LeTs see some 5th gen preLudes
- is this how you tell the h22 have ATTS
- sunroof
- front lip
- 4th gen oil light blinking
- Fuel Pump
- Putting load on motor
- Pressure Plate bolts ?
- Accord/Prelude Flywheels ?
- Clicking sound and stalling constantly.
- Clutch/Manual Transmission problems....
- Keyless Entry
- ignition switch recall
- What to use to clean vtec solonoid?
- Sold my prelude, but it wont pass smog this time around, thoughts?
- Which Seats for 3g
- SRS: Would I be doomed if I got rid of it?
- Clutch Part
- No VTEC
- 1990 Prelude Si
- Hidden Headlights
- gsr in a prelude
- stock SH header same as the stock base header on an h22a4?
- Need swap help badly
- leOEM LSD will it fit in a m two y four tranny
- Oil Pump Seal
- Name that H22 game ^.-
- H22A Balancer shaft pully?
- Explicitspeed motor mounts
- Okay guys, Wont start need help:) New car
- someone help..
- Can you put a VTEC head on a '90 Prelude block (B20A) ?????
- H22A Euro-R rocker arms
- Seat Belt Question
- How do you remove JDM Fog lights on a 97?
- connecting rod question
- head light. . . built in vents. . .one piece
- '01 radio removal
- H22 swap into a 96' lude...HELP!
- Re: turbo oil lines......
- Another prelude made it on the magazine!!!!
- nightmare!
- anyone made their own balance shaft removal kit??
- Pics and Advice needed
- F22a1-F20a swap questions
- converting to obd1
- momo sliders for s two thousand will they fit in a prelude
- 99 prelude obd2a? any downloadable basemaps for obd1 conversion?
- 5th Gen Anyone's experiences with a 17x7 42mm offset
- type of fluid for 90 prelude s MT
- turbo kit and what else????
- I've got a few questions.....
- does anyone have a picture of euro r wheels on a 5th gen
- piston ?
- highest cr you've seen h22 running
- crower camshaft vs skunk2 camshaft vs jun camshaft
- rear strut tower
- falken azenies
- Who contacted me
- '85 prelude clutch problem
- clutch differnces?
- Is the power steering supposed to be firmer than other cars on 98 Prelude
- Dont know how to read my Air Fuel Ratio chart, tell me what it says!
- set up for BB2 Vtec
- car wont start
- Power Steering rack
- High Idle, can bad O2 Sensor be the cause? No CEL.
- ABS system for prelude, frustrated...
- Car over heating yet cold air coming out and windows freezing up.
- 100 octane fuel help
- turbo kit on ebay?
- 'rolling' digital odometer
- ACL Race Main Rod and thrust bearings
- please help me 1992 driver seat
- h22a1 shot a rod, due to oil pump failure! going jdm h22a..help
- Looking @ a Prelude SH
- knock sensor questiona
- Possible to quiet down a loud HAYAME exhaust?
- cd player not working right
- HELP!!! Rearview mirror came out-AHHH!!
- anyone noticed?
- cams?
- open or closed deck?
- lsd?
- Low 14 Sec 92 Lude
- Prelude ECU question
