View Full Version : Honda Prelude
- cel code 43
- Head Light Cleaning-Need help!
- valves bent? vid included
- speedometer needle messed up?
- will f22a1 head bolt up to sohc f22b1 block?
- 3rd potential
- more on a h22a
- Need Help!!! Check Engine Light code 70, automatic transaxle???
- Review: BPi Flow Stack
- ***Here is an interesting thread to watch!!! May lead to some unanwered questions!
- backwards heater hoses = coolant leak?
- difference between si and sh
- sidemarker wiring.
- 95 Accord/93 Prelude Ignition Coil??
- Different Timming Belt for JDM H22 vs USDM H22???
- H22 Rod bolts? ARP? Anyone?
- New to Honda-Tech
- crank trigger
- NO SPARK - 1990 2.1 Si Auto - extenstive troubleshooting, electrical problem?
- Axles not seperating.
- OEM Upgrades Thread
- my car runs great untill warm than i smell lots of gas
- Starting Problems after Swap (searched)
- 5th gen OEM steering wheel on a 4th gen
- Reset Check Engine light
- 4th Gen center console...JDM...?
- Pirelli PZero Nero M+S
- my 87 lude si has a problem mabye others are familiar with....
- Oil Pressure Gauge
- JDM H22a or H22a4
- shift knob rattle
- Very stiff clutch and rattles no matter how hard you try to smoothly engage.
- Weird sound
- Side Marker Help??
- A'pexi WS2?
- hey prelude guys .... identify this please !!!
- Turn signals no worky
- how much for a tranny swap?
- No bump stops?
- PSPEC tuning short shifter combo?
- FS: 2000 Prelude 65k miles Clean Title
- ignition timing on h22
- How much is this worth
- Honda security system...???
- 4th gen, unmodded Vtec for sale.
- Blaster SS Coil Blew Up
- kansas citians check this out
- advice on erebuild
- anyone have this interior color???
- HELP Code problem
- H23 to H22A - No Spark at Distributor
- H22 trans help!!!
- Seperate Transmission Control Unit
- Sticky brakes
- Clutch squeak -> slave clutch cylinder
- Upgrading Calipers?
- DIRTYsouthBB6's guide to selecting tools
- 5th gen High level amp Input- Were at?
- Piston/Valve Clearance with Type-S cams
- need help!!!! what i need to do to put ITR SPOON calipers on a BB6
- Throttle Response
- Rubbing Issue
- 1/4 mile times
- Idle and firing problem please help!!!!
- 89 Prelude motor swap?
- Aftermarket brake set-up gen4 JDM spec car
- Help. P5P ECU missing emission functions
- TPS problem.. car dies?
- quick question about the factory oil pressure sender...
- Braking Question
- 1988 prelude si automatic ecu
- ARP rod bolts / main studs for F22/H23 + F23/H22
- Will 3rd gen steering wheel fit 4th gen?
- Quick Question:
- Cold air + ram air in one intake
- Help Needed
- One-Piece headlights
- Rear washer trick... To fix negative Camber
- Alternate option for VSS?
- Question after running a vin. ALB/SR
- 91 Prelude (2.1 engine) able to use a 2.2 crankshaft pulley?
- engine weight
- speedometer HELP!!!!
- Molding Piece Removal?
- Speedometer not working neither does the vtec...
- Which H22 Engines were available in the U.S.?
- My prelude wont start!! Help!
- ps and alt pully removal
- wireing a tach,temp an oil gauge
- Ball Joint Boot Replacement, same boot for upper/lower?
- Has anyone used Hydra EMS yet?
- bore out tb/im good for boost?
- high pitched sqealing sound
- Skunk2 Intake mani/throttle body
- Sanding headlights
- TECH HELP NEEDED: LIGHTS
- DIY - 4th gen Black Housing Headlights
- 4th gen coilover kit
- vtec pressure switch
- Nostril painting
- how to install SAFC Ver.1 on F22A1
- these headers any good???
- OEM Stereo Security Code
- Battery relocations (not the trunk)
- Odd solenoid on gen 4 1994 VTEC
- I need to adjust the timing on my 1991 Prelude Si.. How can I do this?
- Searched! Cant find Anything really like mine!
- H22 Wire harness.
- Prelude Radiator - Integra Radiator ?
- can someone help me w/this question...im confused! ASAP
- The Phil and I have a question regarding suspension... quick answer appreciated
- Upgrading Ignition Coil
- will these whells fit on my lude??
- Will 1990 Prelude 4ws struts fit in a 1990 civic lx
- 87 lude swap
- Car jerks hard when deacelerating...
- 1992 prelude si 4ws of death?
- New engine? New car? What to do now?
- Will 92 Prelude Si brakes fit a 5th gen accord?
- what are some of the top rated batteries?
- Whats the best assembly lude?
- Need This Part
- Foglights
- H23 Vtec
- Dashboard Removal
- Wet system on a stock h22
- What Motor to Build?
- a little hesitation on acceleration
- really scared look and see if you can help please
- G23 advice
- Whos running a 70mm TB on their H22 and what brand are you using? Please comment
- Oil pump gear for h22, 80mm or 84mm?
- Anyone seen or tried this??? Aftermarket H22A tensioner???
- OBDI H22 into 5th Gen Type SH
- fourth gen front lip
- 4x114 heads, rare JDM wheels
- fuel filter
- Main Relays (SEARCHED) Interchangable ??
- ARP rod bolts for F22-H22-H23
- I go through throwout bearings MUCH too often
- H22 water pump interchangeability
- Will a 94h22 v-tech head work with 01h22 block
- h23 vtec..
- Honda Prelulde 2.2 Vtec Automatic tranmission 0-60MPH
- Your opinion:best spring rate/settings for coilovers AMR!?
- tein ss vs. gc+koni yellow
- Replacing AC Compressor.
- Front suspension more bouncy than normal...
- um b20 in a prelude? WTF?
- h23 build
- need help with hid kit
- Prelude Suspension Set-up.
- Intake makes a blow off noise?
- Clicking before start up
- bb1 axle stuck in hub??
- Sticking throttle "only while cars running" (searched)
- iceman cai with BPi flowstack?
- 4th Gen H23 Fuel Pump Relay
- prelude turbo
- Those of you who are running drag slicks on 5th gen
- update
- Bleeding the brakes
- changing to a msd external coil????
- searched... whats type SH mean?
- Rear speaker/sub Amplifier ....??.... Harness exists ??
- Hi HC(PPM) & CO(%) = Running Too Rich?
- car stalling, screwy idle, help
- no electrical components working WTF?
- what is this part?
- someones picture stolen for ebay auction?
- smog question
- Need More Power...??
- JDM H22 not sparking. got fuel. no spark. HELP! *searched*
- Painting
- PRELUDE FOR SALE
- 240-250whp Prelude Build - Some help would be nice
- what to look for in a intermediate shaft?
- tach jumping and car sputtering sometimes...need help fast!
- bb4 headlight opinion question
- oil change?
- WTB: gram lights 57pro in gold
- Higher Compression=Higher HP but how to figure?
- AllData for headlights
- H22a block posting
- h22/f20b oil pressure questions
- HELP!!
- Contact Innovation aka Rick?
- 4th Gen Fuse Diagram
- ur pullies
- Reverse Lights after 5speed swap
- need help....tranny swap from a.t to m.t .........
- question about tuning
- kamikaze header??
- starting air valve/air boost valve?
- Megan Header...?
- Who's going to NOPI in Atl, GA?
- CEL code 80
- bb4 front lip
- 350-400bhp Turbo Prelude H22 Build
- what motor would you preffer on a bb6 chasis
- fog lights
- Looking to complete the "flow" ;)
- AC Compressor Question
- CEL codes, don't know how to fix them
- HELP!!!!!--pgm-fi location
- Pilot bushing?
- NO COMPRESSION @ ALL!!! HELP....please
- Nitrous help
- re-doing door pannel inserts and door bottoms? any help or pics?
- want to order some floor mats for the 4th gen....
- Help crank pulley not flush?
- best 4th gen shocks and springs
- advise me on some wheels please!
- loose camshaft sprocket bolt sounds like valve clatter
- Writeup: Clutch and Flywheel Install (another one)
- DIY 1996 Prelude Help
- LIP KITS FOR 4th Gen preludes..?
- H22a1 vs H22a4 rods - Differences?
- F20B valves...
- can someone give me a quick hand here (compression testing)
- TOP RINGS FOR ARIAS PISTONS
- need help and feed back
- Tranny Identification (Already Well Searched)
- Synchromesh
- Clutch - tranny problem
- ~~BEST HEADER~~ what do u think??
- A Fix For The Crappy H22 Transmission?
- wtb BB4 Honda Prelude nose cut
- Grounding Wire? PICS
- h23 engine put in 95 prelude vtec?
- exhaust ground clearance
- Clutch write up?
- idle problem 1200 rpms
- SRS light
- h22 tranny weight.....
- Plate for mounting base trans on SH block
- transmission changeover, now no electrical
- Im going to choke myself with this O-ring!!!
- 92-96 JDM Prelude Retrofit
- white and red where MSD where do the connect to? help please
- what programs and ecu are u running in your lude?
- MCJ oil drained out. how to re-fill
- JDM Transmission Ratios
- Uh oh...Idle problem....another problem with my H
- Hesitation problem out of nowhere, very specific
- F22 Work
- pic request: ssr type x's on a 4th gen
- 5th Gen Prelude seats into a 4th Gen - HOW TO
- WWRS lip kit from teggy on 4th gen prelude?
