View Full Version : Honda Prelude
- Front Engine Mount bolt won't thread (the one in front of the header)
- Honda Prelude Clutch install
- what do i need?
- transmission problems
- 97 Prelude Base is lowered...alignment specs inside...will I have excess tire wear?
- crankshaft pulley removal 2nd gen
- H22 Heads, do they differ?
- Nam's new prelude turbo build project!!!
- help with suspension?
- H22a Knocking/ticking noise??
- Need help!! anyone with a 1996 honda prelude si
- OEM type s pistons with sleeved block
- Hybrid F22A1
- if i have a 99 base can i swap in a type s h22?
- tips on reinstalling transmission
- Brake hardlines, help!
- h23vtec pistons
- Going rate for a H22A4?
- running hot
- Transmission
- tps?'s
- Error-3 Car Cd Player
- need opinion on used crower cams
- Labor time?
- H23 prelude that broke timing belt
- Where is the rear torque bolt? (transmission swap in progress)
- H22A Balancer belt TDC ?
- Opinion on Cat Converter on Ebay
- what year accord rear lip will fit a 4th gen lude
- prelude 93 what to do?!
- smog question
- want to change h22a4(atts) to a non atts suggestions
- GC coilovers lower in rear than front
- 92-96 Honda Prelude EL Gauges
- Toggling Power Steering
- Testing for vacum leaks.
- Rack and Pinion problem
- factory radio in 89 prelude just died
- shaking in 3, 4, and 5 gear...
- clutch problem
- 95 lude question
- H22 trans question HELP
- aem tru-power pulleys
- How much my car is worth???
- Timing belt tension question - F22
- How to wire up jdm h22 distributor to obd2 97 prelude?
- ? about act clutch kit
- best spark plug wires for my h22
- Prelude died during normal driving. ECU is showing a Solid CEL.
- A/C not blowing ANY air after 90k maintenance
- H22 Crank
- what are the smartest (bang for my buck) motor upgrades for an sh motor
- What is the difference between an sh and an si which is better?
- Where can i find decent priced Carbon fiber trim?
- Battery, Alternator..HELP ME
- prelude exhaust muffler
- black interior market question
- yellow housing fog lights 98 prelude
- Pic request... 97-01 prelude with tein H-tech springs please
- what size throttle body?
- 90k tune up
- what kinda 4th gen lip is this???
- k20 or k24
- Heater Core question
- Pic Request
- how come prelude require 91 octane or better?
- Need a Little Help guys!!!
- Wierd Noise From Engine Bay ( I HAVE A VIDEO )
- rear sway bar poly bushings squeaky as hell!!!
- Higher RPM's on a 5 spd vs Auto
- will a oil cap & dip stick from 92 lude fit 97 lude?
- JR supercharge for 5th gen
- H22 not staying running
- Blown head gasket
- CEL is on and im lost.
- obd2 h22a swap in a 94 prelude type s,what probloms will we run into??
- ? ABOUT INGALLS TORQUE DAMPER
- h22 idle problems. please help
- 12lbs flywheel
- ecu ?
- 5-lug conversion on a 4th gen--- (for those of you who've already done this or considering this)
- oil pressure
- H23A1 to F22A1, a few questions.
- LSD Swap Question
- M2B4 into 5th Gen Auto
- Ticking Noise Drivers Side Front
- weird idle bounce car dies need help ASAP!!!
- Check Out this intake. . .
- ECU Tuning which one
- 5th gen weight reduction in engine bay
- prelude turbo
- will other flywheel bolts fit h series?
- Caster adjustment...use shims or trim the bushings....or use washers? 97 prelude base
- Wiring Issues-H22A1
- Hubcentric Ring - 5th gen
- any known 5th gen prelude a/c compatible tubular turbo manifolds
- h22 head to a h23 block bolt up no tuning?
- Looking for replacement parts
- tsudos springs
- Vtec Solenoid problem
- What should I do nexts
- Possible faulty 02 Sensor?????
- H22 oil pump prime
- NEED HELP IS THIS A REAL TYPE S (PICS)?
- H22 turbo manifold+ turbo
- High Idle
- tien s tech or sprint lowering springs?
- *SEARCHED, No results. Wheel Bearing going out...
- crower stage 3 cams..do i just have to upgrade the valvetrain?
- can you put a f22 vtec head on a h23 block?
- 96 Si with tired motor ,which option would you go with?
- 98 turbo prelude issue? (clutch erratically lets loose)
- 92 Honda prelude help
- H23vtec won't crank
- crank position sensor and limp mode
- new Oxygen sensor but still throwing codes
- 4 ws prob
- timing issue help!!!
- H22A4 oil pan on H22A1 block??
- 4th Gen H23A1 balancer belt install ?
- broken timing belt, thought it was something else and tried to push start the car. Did I screw it up
- ANYBODY
- H22 MPG Question
- CEL 174 :: Evap System 5th gen
- 96 Si 2.3L blown timing belt.. I think
- any body put 2 15inch subs in a prelude?
- Underhood pics of painted valve cover, strut bar, intake, spark plug cover and other
- coil springs/coilovers
- H22A in EG running rich.
- Car won't even push start, no spark, distributor rotor not spinning when trying to start
- clutch fluid
- passing smog with misfiring???
- TICKING noise coming from lower timing belt?
- Help with CELL CODE
- Anyone have Mishimoto installed?
- Need new factoy alarm remote, any options?
- knocking noise
- H22 oil prime
- Seaibon carbon fiber hood, valver cover clearance problems.
- How To: apply adjustable coilovers...
- Need help with my prelude
- 4th gen prelude question. having +20 offset wheels on the lude?
- BA Squad stickers
- where and what does the main relay look like on the 4th gen?
- Radiator wiring question
- QUESTION ABOUT TIMING BELT???
- Cat Converter
- 4th gen f22b1vtec swap, speedometer not working
- 5th gen ss tiptronic manual swap atgps wiring
- H22A1 to H22A swap. Looking for a write up or advice.
- mfactory fd
- windshield wipers
- 4th Gen with a f22b1 Revs out at 5k rpms?
- pocketrocketsracing??
- sh upper control arm base model control arm
- Change F20 timing belt
- New H22 Tri-Y Header is being developed for half the cost of a Hytech
- H22 oil pump install
- Check out my water pump...
- HELP!!! no oil in h22
- "D" on the Lude is flashing and the car won't start
- wtb ATTS removal adapter
- usdm jdm?
- rolling my fenders
- tranny transmission squeal & whine
- power steering
- What if I disconnected ATTS fluid
- Side Mirror Glass replacement
- h23 crank, h23 rods, h23 pistons in h22a block
- car decides not to start this morning---(help here guys?)
- i hate people that steal!!!!
- need help with h22a
- new motor
- H22a 105k miles...Vibrates at all speeds during accel...what could it be?
- need help in chino hills replacing main relay
- prelude '95 2.2 4ws crank angle sensor fault.! Lots of broken dizzy's!!!
- H22 in 94 Prelude. Fuel wont stop pouring. Yes "pouring" with KOEO
- quick question
- CEL issue...tried searching and found nothing
- Honda prelude doors
- quick question...
- Dist. Cap & VTEC question
- Coverting to Manual??
- Noisy Air Compressor
- Massive fender rub issues...
- HELP...93 Prelude si problem
- Gutting my lude - taking out the center console button
- Need a new door handle, which is pass. side?
- Seat replacement options for 4th Gen...
- piston rod confusion
- 3g and newer flywheel size/bolt pattern Q
- ?? 97 H22A p13 stamped - Open or Closed deck ??
- wiring h22 dizzy
- messing with stock suspension springs
- Right Side Wheel Vibration? Diagnosiage anyone?
- Prelude with a f22b1 Swap, Automatic to manual will not start
- Apexi N1 or GT-Spec
- h23 fitv on h22
- Just a little desktop background collage I made if anyone's interested---
- 3rd gen carburetor help
- Interesting Idle Problem
- Hey guys about h23 swap over to h22 please help!
- Worn Struts, and Resonance
- Looking for alternatives to replace radio antenna.
- 5th gen prelude steering wheel fit 4th gen?
- bad starter/ignition? car starts once in a while
- Adam's 4th gen De-rice Turbo Restoration Built
- swapping OBD2 H22 into OBD2 integra
- _*Coolant thermostat problem*_ (Searched)
- just curious
- h2j4
- h22a1 and h22a4 questions
- What is this plug?
- What side is top on my energy suspension bump stops? 97 prelude
- harmonic balancer 98
- 5th gen base vs type sh?
- Throttle body intall ?
- The FPR hose getting smashed
- Acceleration problem above 6500 RPM
- Pro1s or Pro2s
- strut bar?
- 92-96 or 97-01 half shaft
- Wheel size on a 94 prelude
- Pooped out some coolant yesterday...damnit.
- some issues
- f20 f22 hybrid question
- What do I do with this adjusting nut (part of auto tensioner assy)
- Stock H22 Swap running a little too rich.
- Passenger door not locking....
- How many teeth on timing belt between TDC arrows on cam gears?
- 82 Honda Prelude Starting When Warm Problem
- ARP H22 head studs question.
- h22a1 swap
- AC not blowing cold while driving on the highway....
- No Start
- whats going on with my timing? I need an expert
- neonxiii's Fully Built H23 Turbo 4th gen project!
- Difinitive way to convert 5th gen rack to a TRUE manual rack?
- Type S in the Prelude sh
- Closed Loop Issues, Searched..and searched again...
- Chip or no chip..
- not getting any spark for 93 prelude
- need help bad.. timing marks on flywheel
- h22a1 head with b18a1 block???????
- 4th GEN: 5 lug conversion, accord or acura parts possible?
- 98 prelude bogging when it hits v-tec
- Just a Thank You for your support and what you did for Danny.
- Those of us that don't like LOUD Exhaust
