View Full Version : Honda Prelude
- h22a4 in an 1993 integra
- Phone/contact #s for Parts distributors(AEM, HKS, and many more) No more searching
- h22 head
- need help...
- NO Vtec out of my 93' Hdouce douce in my 1991 Accord! NEED HELP!
- I can use this oil pump * Pix*
- Replacing Differential Bearings Yourself - need answer by tonight!!!!!
- no pressure on clutch pedal
- my prelude is dead
- Help Me Please
- Couple all motor questions?
- wiring issues
- h22a specs
- Guess what I heard!!!!
- AEM V2 intake
- Need help/suggestions with exhaust
- CEL #13, 65?
- Supercharger Install Times?? ( searched )
- 89 prelude takes 4 or more times to start ???
- h22 rebuilt 63 miles later motor seizes
- h22a lead cover
- air fuel gauge fitting
- help.!!!!
- Spoiler light (quick question)
- headlight conversion
- ecu- please respond asap
- okay i've had enouhg with my car (ek h22)
- h22a map sensor?
- 91 prelude si
- important suspension question!??? HELP
- what kind of NGK spark plug would u guy use for h22a vtec
- FIRST FULL CARBON FIBER MUGEN KIT ON A PRELUDE....
- Very weird picture request...
- prelude starting problems
- How much should i charge
- **HELP!!!** IN NEED OF A CAR!!
- Head gasket blown..
- 92 prelude
- Volk Ce28n
- 4th gen seat interchangability
- Jun cams vs. Crower vs. Rocket vs. ? vs. stock
- h22 FAL fan??
- JDM climate control swap
- I'm sick of the same bench-racing questions...
- WTB: Built h22
- Skunk2 Manifold Pics??
- RMF Header...
- 1991 honda prelude alternator diy
- Type S pistons
- no vtec??
- Temperature Gauge
- ~~~ EGR VALVE ~~~
- H22A vs. H22A4 in a 1998 Prelude need help
- what the best spark plug to use for the h22a beside iridium
- Preludeonline.com
- why cant i put a type s or sh tranny on my base
- putting back the parts (inside) blower motor? 88 prelude
- how long is YOUR cat. converter
- jdm LSD in usdm tranny
- Electronic climate control
- small lights not working
- 97 VTEC in a 92 Prelude Help Wiring Harness
- HELP!!! Can the base model struts/springs fit an SH?
- honda prelude auto won't start
- New(?) Jun cams.
- distributor timing help
- The "How to Fix My Climate Controls, A/C Switch, Fan Switch"
- 92-96 Prelude Base Model Header.. which one fits? F22
- Question about spark plug wires on my 5th gen prelude
- exhaust leak, can I weld?
- Fog Relay!!!!!
- Type S Pistons?
- problems with installing clutch master cylinder
- 94 Prelude Si
- Buying use Tein SS Coilovers.
- questions on final gear on the h22
- Different Oil when Boosting?
- radiator!!! help help!!!
- go ahead and call me names, intake question
- prelude with h22a engine swaped in?
- true or false
- 9006 ---->H4 JDM headlights HID related
- 88-91 armrest?
- real short shifter for 97-02 prelude
- Prelude leather seats
- Heel-Toe
- any 5th gen-ers make air dam under bumper turn signal?
- Engine replacements for OBD2 car
- Pinstripe removal (searched and posted in a/c--no replies)
- Clicking noise
- Fuel Gauge not working...
- Struts
- car boggs h22a jdm
- Exhaust help
- Flywheel Question (quick)
- Anyone running aftermarket oil cooler?
- K&N Filter
- Uhm, so how do you adjust the yellow paint mark on the front sensor? 4WS
- H22A v. H22AS
- '89 Engine Specs
- 92-96 4th Gen. Climate Control Fix Write-Up. HVAC
- Hydrolock - What does it take?
- Will a h23 ecu work w/a f22 motor?
- inline fuel pump installation, i need help!!!!
- H22A1 hp question
- 4 Gen Lude Info
- Help - Exhaust sounds like s#*!
- Can the front steering angle sensor be calibrated at 12 oclock? (4WS)
- Do it yourself harness adaptor(OBDII - OBDI) can it be done ?
- Can the steering shaft be turned without turning the wheels?
- CAI filter question...
- Just as Good?
- Possesed RPM needle
- RMF + SMSP Header Ground Clearance
- Exhuast trouble
- short ram intake..
- Tsudo Exhaust
- Review : H22a with 4.78 final drive as a daily driver
- How do I fix this? Cel code 112
- H22 head P&P by Pocketrockets Racing, crower dual vs, tit ret, crower ss valves
- CEL light - o2 sensor, cat, or both?
- theft question (searched)
- Creaking Clutch Pedal Fix
- Prelude M/T Fifth Gear Grinds on Upshift
- Power Door Locks malfunction fix(alldata)
- My RHD JDM 88 Lude *Pics*
- code 16 in a prelude???
- 97-01 lights above fogs?
- CAI to SRI
- Pissed!!!
- condensation
- EMERGENCY, need valve adjustment specs
- for the N/A H22 guys.....some hope....315HP dynojet
- 5w-30 or 10w-30?
- H2B adaptar plate
- Replaced USDM throttle body with JDM one.. now problems
- lower timing belt cover
- will an under drive crank pulley wear out bearings???????
- Header suggestions...
- Interior color code/name?
- turbo?
- Gas Pedal sometime feels like it's stock or hard when pressing Gas on first gear
- Accord lip
- jdm parts
- new engine install
- Would appreciate some advice on the best internal parts to get for next setup...
- does ne one now the 0-60 on a 2.0 prelude 131 bhp sohc UK 92-97 model
- open deck versus closed deck
- Power drivers window?
- JDM vs USDM Fog Switch
- Turbo Charger or Supercharger?
- Testing Foglights
- under drive crank pulley
- Running rich ?
- mugen items
- Oil Catch Can
- 94 jdm prelude
- Harmonic Balencer question need helppppp
- Help! Spark Plug question applicaiton specific
- Oaks Racing Prelude finally broke into the 10
- Anybody plz answer is that dangerous to have a BBK without ABS?
- HAVE A H22A1 question
- H22 question
- alternator amperage?
- Thermal R&D Exhuasts for 4th gens
- New clutch, pressure plate, and flywheel and a problem
- reccomended replacement parts for tensioner swap
- h23 to h22 distributer problems
- Several questions about JDM h22a swap
- in desperate need of input
- h22a clutch problems how much 4 a new one ?
- Pacesetter Catback Exhaust System ~ Good Or Bad?
- problem with headlights dying out. pulley related?
- prelude brake ?
- 94-96 center console ebrake handle conversion
- Highway Driving= Oil Burn?
- Rear Interior on a 4th Gen
- 5th grinds
- OBD2 Alternator in an OBD1 vehicle?
- engine hydrolocked!!?? what to do
- 97 SH with boost? help please
- H22 JDM Vtec Cluster in a H23 Non Vtec car
- Look what happened to my rear sway bar.
- Friends Prelude wont shift
- electrical problem?
- Anyone know how much the H22 manual tranny weighs?
- do prelude crossmembers....
- 2nd Gen lude
- Blew my downpipe...
- trying to paint my valve cover
- wanted h23 shortblock modesto, ca
- Thottle Position Sensor H22
- Cam Gear Install
- jdm oem lsd
- shortshifter?
- HELP! just did a compression test.
- stage 2 cams for h23
- JDM H22 valve adjustment
- how much nitrous for i/h/e, cam H22A?
- Help with 98 prelude aftermarket catalytic converter!!!
- suspension fork question
- Volt stablizers, grounding kits??
- 4th gen turning radius....
- fuel cut relay?
- Suspension problem with my 97 Prelude SH?
- H22 & H22a
- windshield wiper problem
- h23vtec questions
- heres a question
- 95 h22a1 and 97 h22a4 pistons interchangable
- Need help w/ problems on my new 98 Lude
- car wont start plese help searched every topic.
- Intakes
- Help: Engine went off while on freeway...
- RSX-S Brake Swap on 5th Gen?
- obx valve cover?
- fender wall
- CM stage3 good for 450HP?
- h22a .030 headshave... how much advance of cam gears??
- 99 prelude break change?
- Greddy E-Manage how to ...
- f23 vtec head on an f22 non-vtec block???
- s2k oil filter
- confused
- 91 jdm prelude ?
- Just got my car out the body shop - damn CF hood won't close
- Mugen headers
- h23\h22 help
- need anyone with serious ATTS experience
- 4th gen fog light ???
- Recent Timing Belt Change: Now Wierd Sound Start-Up
- Air intake bypass
- can u use vafc2 on 98 sh
- Stock Intake Manifold mods: Have we arrived at a conclusion??
- Greddy e-manage
- Best exhaust for my 96 prelude si
- ??????type-s quiztion???????
- 92-96 Power Steering Cooler Hose
- Good Twin loop or bad???
- WTB 97-01 OEM Front Bumper
- sawp question..again :(
- Off to the machine shop, I need some suggestions...
- 98 jdm h22 atts
- balance belt pulley and retainer clip
- bulbs????
- Anyone giving Carfax's?
- pro-comp ultra-lite autometer gauges question
- h 23 internals
- clutch problem need help
- 1998 prelude factory sound system
