turbo probs need help
Old Oct 23, 2003 | 02:43 AM
h22acclude's Avatar
Default turbo probs need help
ive just put on a turbo kit and was gettin it tuned and when boost hits the map sensor code comes up ,car is gettin tuned with stard ecu and a piggy back chip
is there a different map sensor that can handle more pressure ?? or is there a way that i can trick the ecu so that it wont go 2 limp mode
Old Oct 23, 2003 | 04:32 AM
fastludeh22's Avatar
Default Re: turbo probs need help (h22acclude)
what kind of fuel mgmt, ie ecu, and how many psi ar eyou pushing? be more spicfic and we can help you better.
Old Oct 23, 2003 | 10:55 AM
blackssvtex's Avatar
Default Re: turbo probs need help (fastludeh22)
get a missing link
Old Oct 23, 2003 | 11:16 AM
prelittlelude's Avatar
i ahve no idea what kinf of fuel setup you currently have, but a little info may help you. the stock lude map sensor is a 2bar map sensor, -14.7 to 14.7 psi, however, ususally the map reached its limit at something b4 14.7, the max map output voltage is 5v when you reach 5 v thats you max. but you have to have a standalone for any of this to matter to you
edit: and if you want more boost support over the 12 or 13 the stock will handle you need to get e GM 3 bar map sensor
Old Oct 23, 2003 | 02:48 PM
SKDRCR's Avatar
Default Re: turbo probs need help (blackssvtex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackssvtex &raquo;</TD></TR><TR><TD CLASS="quote">get a missing link</TD></TR></TABLE>
w3rd, i think gudeh23 might have one 4 for sale
90Rexx
Jun 1, 2008 05:12 PM
TheOdd001
May 21, 2008 05:39 PM
SilverPanda
Oct 9, 2007 01:16 AM
BluntMan
Mar 4, 2004 07:05 AM
fast[R]
Jul 18, 2002 03:00 PM
