- 4th GEN CEL diagnosis issue
- p0335
- 1990 Honda Prelude SR Power Steering Lines
- ISO: Information/Suggestions regarding a 1989 Prelude 2.0 Si from any racers here?
- Prelude SH Speedometer problem
- Need Radiator
- h22a prelude
- introishh
- Introduction
- Homicide (SoCal)
- need help
- 92 prelude 2.2 v-tech NO HP NEED HELP!!!!!
- H22 vtec oil pressure switch
- Help
- can i use a b16 head
- Rear suspension noise (squeaking)
- f22 sohc swapd to h23a1
- balance shafts questions
- 1995 honda prelude question
- bad wiring please heeelp
- h22a vtec solenoid problem?
- 5g prelude emanage ultimate help
- 1988 - 1991
- what will do this?
- Looking for an Adaptor Bracket or Dimensions to Eliminate ATTS Unit on Type S
- What suspension bushings are crucial to replace?
- Need help on buying the right turbo!!!
- Wiring Vtec to a Non Vtec 92 si prelude
- 2000 Prelude auto tranny problems
- need a rear window visor
- 89 sunroof visor ?
- INTRO: got a prelude....
- electrical problem
- tach install tips for 97/01 prelude
- 1996 prelude 2.2 vtec turbo
- f22 93 prelude
- Key fob problem
- H23 engine swap
- need help!
- Going to turbo 92 prelude
- help with factory keyless entry!!
- Throttle body choices....
- Resistor box
- accord springs fit prelude 99
- fifth gen prelude type S
- WTF? CAR STILL ACTING UP
- Please help me identify this part
- H22 Euro R block vs JDM H22 block
- 93 Si High idle (2K rpm) on cold start
- bb6 pursuit of weight reduction= sunroof plug?
- thermal insulation
- best modyfications for h22a jdm for street use
- Best throttle body for n/a h22a type-s
- Type-S cams in h22a OBD2b JDM 200
- 95 lude h22a1 turbo question
- Skunk2 exhaust...
- Radiator and ac fan problems
- who is using the OT-2
- can you put a b16a2 intake manifold on to a h22a
- JDM Climate control
- Greddy trust
- **Brand New!!** 4th Gen Prelude Seibon Carbon Fiber Hood
- fuel hard line size?
- Passenger side Quarter
- what happened to the socalprelude website?!
- Starting to hear ticking noise in my '97 prelude?
- boost stock motor
- what does you fuel psi pressure read at during vtec
- 88 Prelude Si EGR Removal
- 96 prelude SI clutch problems PLEASE HELP!!!
- New Rims, Susp, Exhaust, Lip Kit NEED HELP wheel size
- D2 coilover install - issues with front set
- honda prelude electrical problems
- wtb 88-89 prelude fog lights!
- HELP oil leak on right side of engine???
- H23A1 to F22A6
- H22 TB H23 Intake Mani Help. URGENT!
- Jdm h22a into 97 lude
- h22a moroso oil pan help
- h22a oil pump sympthoms???
- d15b into odb1 prelude 92-97
- part idea
- Drilling Intake Runners (EGR Ports)
- h22 sk2 im/stock/euro-r????
- 1992 Prelude S H22a4 swap pictures and a couple of questions! No noobs!
- need engine connector pinouts
- h22a NO compression ?
- oil?
- JDM H22A Head
- 91 prelude si help
- tanabe gf210's
- 4th gen spark plug
- cant adjust ignition timing!
- 94 Honda prelude Vtec door lock/unlock wires
- hazards & signals don't work! please help
- is 3in exhaust to big for a stock h22
- Need help dcc
- What manual transmission oil do YOU use on your 5th gen?
- need help front 2 tires are not centered
- IAB vacume line question.
- Is it possible to remove pistons without removing engine block on a H23A1?
- Car stalling under heavy breaking
- Transmission help H22- Cant shift
- 2nd gen Honda Prelude 2.0 si
- intake control solenoid vavle???
- need distributor advice: jdm h22
- ECU Question
- So what can i do about the 5th/reverse syncro grind? =/
- H22a swap redline problem
- 2001type sh swap into 93 si
- 90 prelude s, axle nut will not budge!
- 01 5th gen Turbo Info plz
- h22a wont start
- Oily Connection
- SH and Base Prelude Question
- 4 th gen prelude problem gurus help
- NEED ADVICe for 91 prelude
- mount problem h22 to f22
- JDM H22a
- water in trunk...need answers
- B21a1
- need help for EGR..
- SOHC to a 350 small block
- What color rims?????
- H23 Transmission question.
- Looking for OEM Shift Knob
- I think my timinb belt is too loose?
- wtb 4th gen prelude interior
- Help with sideskirt removal.
- h23 block or jdm h22a?
- 1992 Prelude SiR F22b needs Camber kit??
- Prelude burning oil?
- bamboozled buy.
- 1987 Honda Prelude Si... HELP!
- rear speakers
- 93 prelude tachometer limitations
- Timing belt installation
- Need Some Help First Swap
- 93 Prelude f20a dohc trans question
- Need help with prelude.
- Rebuild Guide????
- TDC marks on CRNK and Flyweel dont go together!!?
- 97 prelude sh.... no /start
- Honda Prelude Vtec Check engine light!
- 93 Prelude
- Prelude Problems
- are my sleeves fubar???
- Where do I start?
- H22 Crankshaft
- noobish question about wheel fitment
- h23 to f22 need help
- Looking for 4th gen. owners in Cincinnati, Ohio
- Looking for Engine
- Looking for 4WS
- a few questions about my h22 civic swap
- For Sale
- need a picture of a 5th gen with xxr 522s
- suggestions on power chip for my 5th gen?
- honda prelude tranny mount?
- need help on auto tensioner!!
- i need a great reputation shop to work on my '01 sh tranny..any suggestions?
- Prelude Engines
- Frankenstein build.
- Oil for '94 Prelude?
- Good Website for Aftermarket rims?
- turbo questions
- oil filter relocation kit
- Driver side window not tracking properly
- 4th gen fog light project...not JDM!
- slim lug nuts
- looking to buy honda prelude si H22a 92-96
- 5th Gen rotors
- Just bought a new car. Help identify?
- 2nd gen Trans questions
- Done my homework now need help.from the pro's
- Shifting at 8500 almost 9000 realy?
- WTB stock H22a injectors
- 5th gen headlights flickering
- Motegi (i know... rare)
- Duel 77mm Throttle Bodies ????????
- 92 lude need help wit a few little things
- What Sensor Is This?
- Buying a Prelude question.
- F22/H23 interchangable parts?
- clutch, cv or cylinders???
- need random parts for 99 prelude
- 2001 Prelude Motor Replacement Question
- swap H23A1 to a JDM H22A( motor mounts)???
- Vac Lines Q
- Swap H22A1to H23A
- 1500 for this? (worth it or not)
- New proud owner of a 3rd gen prelude.
- light wieght crank pulleys?
- G23 build help
- h22 sputters and alt belt rubbing?
- H23A1 crankshaft pulley bolt!
- Can't pass smog!
- Ignition Control Module Question
- 2001 JDM H22 Crank/TDC Sensor Question
- In dire need! Please help!
- built manual trans
- Rotor width question
- Phearable ecu's
- Getting started
- H22 stroker
- Jdm F22a swap into USDM F22a1 92 prelude help
- h22a4 turbo help!!!
- That JDMH22A Black Prelude w/the XXR Rims..Specs inside!
- quick question
- Just did an h22 swap cant get the car to run right on the p13
- Need help findimg this writeup
- question re cylinder head removal h23a1!
- What cel code is this ? I'm running P28...pls help
- Alternative way to fill mtf other than through the fill bolt?
- 6 spd h22
- what size throtle body
- what parts from f22a4 manual tensioner can be swapped to h22a?
- 4th gen overhaul
- New Honda owner
- T2W4 lsd in M2A4 case
- usdm head vs. jdm head
- Removing Shift Cables
- Prelude Cover
- Looking for a Temp gauge
- 98 Honda prelude having a weird dying problem
- Car turned off while driving code P1382!
- D2 coilovers
- manual tensioner
- H22a top dead center
- Sleeve Help
- a video of my dyno
- will a h2b header fit on a standard h22a prelude
- Has anyone eve used h22 pistons, with h23 rods, and crank???
- h22a timing belt???
- h22a question
- 86 Prelude Parts
- wtf really
- 93 Prelude VTEC mild sputtering after heavy rain
- h22 wiring.. help a brotha out
- oil on spark plug wires
- Oil vapor condensation-plugs/PCV valve/hose
- 5th Gen Interior Swap
- Dumping fuel through exhaust
- Please help
- High flow cat/ no cat.
- 91 Prelude Won't start
- whats the best swap for a 93 prelude si?
- New 1998 Prelude Owner
- Looking for 96 JDM Auto Prelude ECU
- alternator problem help!!!
