View Full Version : Honda Prelude
- did u know? the bottom ends are different on 4th gen & 5th gen. HELP
- anyone here has pics of drag turbo kit installed on lude 4g vtec???
- 88-91 stock lude engine , hp torque specs
- What is required for fitting a B20A into a 1990 prelude?
- So i'm thinking about a 92-96 SR-V
- 94 prelude head rebuild
- No Power No VTEC ? Lots of Water !
- Bent Valves?
- got my 1 piece jdm headlights and very upset. what should i do?
- Jack Points
- rear brakes
- piston crack
- abs is coming out how much of a pain?
- how many hp
- boost leak after removal of butterfly valves
- Fuel Gauge!!
- a possible lude in sight
- 2003 BMW 330ci HID Projector housings into 4th gen headlights
- Engine mounts?
- wanted- intakes for 5th gen. prelude. preferably injen or aem cai.
- Injector size
- which injectors do i have and what cc?
- help cant start!
- H22 heads weakest link?
- knock sensor after swap
- JDM front bumper... 5gen
- 4th gen jdm fog light switch and usdm connector
- Where to find right axles
- automatic H22?
- 4th gen radiator fan upgrade???
- jdm climate control sensor question
- Request For 92-96 Prelude Photos
- Anyone know where to find 89' Lude performance parts on the web
- srs light still on (now i have tried everything)
- A little tranny help please!!!
- Pic Request: '98 JDM ITR wheels on a 5th gen lude
- car won't start, please help
- check engine light??
- How the hell does these JDM gen 4 headlights work?
- Is my head gasket blown/cracked??
- jdm h22 or h23a1 vtec
- exhaust leak found - what to do?
- Auto to Manual Swap, Speedometer Wiring, 92-95 Prelude
- 4th gen taillights!!!!
- Brazilian Implant Theft
- Need some help on pricing...
- Hub adaptor on type SH
- what rear lip is this?
- Difference between SH and base model aside from atts?
- cooling system
- Waterpump leak
- JDM 1-piece problem!!
- Coolant Leak
- timing question
- Losing Weight!!!!!!
- Losing weight!!!!!
- Skunk2 Universal Muffler/Exhaust
- Lomandi Brakes?
- $900 Prelude. Help
- Problem on automatic tranny 5gen 2.2L VTEC
- Looking for,
- Omni Power???
- Can a DOHC H22 V-TEC fit in a 89' prelude
- How many people have a 4WS Prelude
- srs light on (tried everything)
- Wrecked 95... What to do?
- wut should i use
- Dyno: 200whp/159tq
- what to check for? cooling fan help
- help please
- 1992 Honda Prelude
- 99 lude suspension
- Bleeder T-Wrench
- Bleeding the brakes
- Speedometer not working, simultaneous CEL...VSS?
- Best Springs for Preludes
- Sway Bar
- Prelude suspension question
- ABS and SRS lights are on. What to do?
- MSD + VAFC II vs. Hondata
- Cooling fan won't come on...any ideas?
- rear struts are b!tches
- A/C questions.. need help/advice
- Were is the Main fuel pump relay located on a 90 lude??
- any auto prelude owners?
- 97up left(drivers side)fender.
- switching open/closed loop
- 4th Gen Headlight Problem...
- want to put h23 crank, rods, and pistons in my h22 block
- H22 Missfire
- looking for a place that can tune my vafc2 in va.
- Blown Motor please help
- Fuel injector sizing and application (yup, searched)
- JDM 95 Head
- JR Supercharger 97-01 Prelude
- ECU pinouts diagram help?
- part numbers for...
- Remote for Keyless Entry not working!
- 4WS 2.0Si
- No Clutch Pedal Pressure
- retrofit g35 hid into 5th gen??
- Cluster conversion help plez
- H22 Turbo Oil Pressure
- h23 14.8 @ 92
- Air Conditioning Problems...at the end of my rope
- Will a h22 block fit a h23 head?
- Weird noise, engine/belt area
- anyone have check engine codes?
- though some of you guys might want to see this (f20bcrank on ebay)
- 5th gen NOT going into gear properly
- turbo owners please help (code 22)
- auto to manual help
- how to remove piston and rods?
- Oil and radiator?
- problem starting car
- I want to buy some hood pins but i'm scared
- Engine rebuild
- Vision mirrors
- Camber Correction Kit needed/ Neuspeed Sport Springs and 17" Rims
- 89 prelude a/c compressor not kicking in please help
- 89 prelude a/c condensor not kicking in, please help
- prelude loud start up
- Some stuff for 4th gen
- Tightening the Transmission Cables
- Porting and Polishing
- 91 prelude Si speaker install, door, please help!
- symptoms = clutch?? clutch master/slave cylinder??
- `````need info on abs light.`````
- folding mirrors, cd player
- Replacing my engine...HELP! :)
- 4th gen fog light relay
- OEM vs. Aftermarket...what do you use?
- Individual Throttle Bodies
- ecu wireing harness
- 60% water and 40% coolant ok?
- Vtec on and off...
- body help
- 5gen JDM foglight bulb
- question about the automanual
- what kinda clutch
- Cluch just keeps revving
- h22 back fireing, hondata
- engine light comes on time to time, 91 si
- driver seatbelt light wont go off, 91 si
- driver door indicator light on 91 si
- 91 si headlights wont close/open, help!
- Coilovers. Its SOOO ANNOYING PLEASE HELP MEEH !
- auto to manual conversion.. is it worth it?? (searched)
- Port and polish question
- I need an AC evaporator...
- F1 Racing and XTD clutches?
- I have problems Shifting gears...
- BRAKES!!!
- sport tranny or manual
- help looking for motor
- Steering rack question
- motor ticks
- Japan manufactured ludes
- prelude oil cooler
- carbon fiber trunk
- Valve cover part number(s)
- Which Clutch Slave Cylinder Prelude H22A H22
- cooling fan in 94 lude continues to run after turn off
- 95 lude
- should i buy a 91 si for $1200?
- break pads
- i think this is parts for tranny swap too anyone?
- Timing belt installed, now car bogs under load
- Water Cooled Turbo?
- was there ever a recall for 5th gen lude transmission's?
- 89 prelude 2.0si 4speed a/c compressor not kicking in please help!
- FINALLY, The money for the h22 SWAP anyone knowledgeable PLEASE its a quick one.
- 92-96 prelude axle back muffler
- Turbo questions
- Coilover Installation
- radiator fan help !!
- H22a rebuild.. concerns? new mahle pistons? Help
- H22a1 pistons in H23a1
- bad idle after JDM P13 ecu
- Exhaust for a 97 Type SH
- what can i do with a f22a?
- NEED HELP FINDING SOMETHING
- Bent Suspension???
- turbo ludes : injector q's
- Clutch Issue: play in clutch?
- i want speed in my 1990 prelude
- atts problem
- Clutch installation question
- F23 crank modification (write up and pictorial)
- actual "cold air" intake question
- Metal sound when braking and sometimes turning?
- what are these wheels, rear bumper? find a decent lip
- Jdm BB1 h22a information??
- Lower rear ball joint question
- does p13 work with usdm mani egr
- vtec wont engage
- Factory Freak or not?????
- helms manual
- Ticking in head, white smoke, low coolant in a JDM h22a
- vafc II
- Spongey Feeling But Clutch Still Works Fine?
- 92-96 Interior
- Clutch squeeking after bleeding it
- Power Steering problem
- for the turbo prelude people (oil feed converter)
- 90 SI 2.0 5spd elec / engine problemsSSSSSS......
- Parting out 1991 Prelude Si
- Steering and clutch prob, realated??
- 89 prelude 2.0 si 4spd a/c compressor wont kick in please help!
- A/C problem
- harnesses on a 5th gen?
- Center console arm rest latch
- part number
- -Rebuilding my h22-???
- 89 si oil pan
- Whats the difference between h22a and h22a1 engines?
- vafc II for sale
- anyone have experience with greddy turbo kit on sh?
- busted tranny... not busted something
- whats UR fav. plug??
- In desprite need of help, SOCAL ONLY!
- thermostat replacement
- The collectiveracing site was hacked.
- Stroker Engine Update.... 2point6
- zex spark plugs
- subframe center beam cracked
- Exhaust Tip outlet diameter
- A/T & M/T cams different?
- Hood Latch Jammed
- intalling gc's and koni yellows (searched)...
- heating the springs
- Replacing SH Radiator with KOYO, can I install transmission cooler for ATTS
- Cousin got his Lude, problems already
- better axles
- Anyone ever try this?
- Exhaust Tips
- i need wirind diagram for a 93 lude to hook up cd player
- front bumper suggestions
- Master Cylinder Question
- OBDI H22A EGR, what can i dump?
- Clutch Adjustment
- Does 4th gen prelude si stock shocks/springs fit on 5th gen non-sh prelude?
- one pothole, one bent rim.....
- Suggestions on finding source of vaccum leak
- H22 Forged Pistons???
- What top mounts to buy???
- h23 pistons
- hard to shift when car is on, clutch has alot of slack.
- 92-96 Nose Vents
