View Full Version : Honda Prelude
- 88 prelude si
- Pacesetter
- Starter Relay Help!
- Strut Bar prices (ebay deal?)
- Changing Your Antifreeze
- quick question, jdm h22a type s
- What ECU to use in my Prelude?
- Tokico Suspension Kit
- installing a 3 bar map sensor on a 1997-01 Prelude SH
- Traction Control problems
- basic timing question
- Helms.
- Question about Helms (4th Gen)
- FS 5th gen lude + exhasut + audiobahn audio
- wanted:"diagram ecu" and wires for h22a5
- h22a problems
- dual exhaust
- H23 VTEC or H22 TURBO
- does any obd1 prelude with atts exist?
- Air/Fuel ratio
- Trade headlights?
- cylinder/crankshaft condition, opinions needed
- Momo pedals
- ES Oval - Quality?
- black 5th gen wheel pics......
- ticking sound when i turn on the heat fan?
- obx oil pan
- AEM dry air filter
- tranny swap
- h22 oil capicity
- My 4th gen only has 2nd gear :(
- Turbo install first or normal N/A first?
- wire question
- 97 oem head unit into 01
- Question about the JDM H22 and the sated 200 HP
- wtb:: PRELUDE SHIFT KNOB
- DOHC Vtech system not kickin in anymore!!!
- emracig c pillar bar
- enjo...
- Syncromesh vs. Honda oem fluid vs. Red line synthetic tranny fluid
- 1980 prelude problem
- engine swap help
- Need a Starter
- tweeter replacement
- How do it check the ignition timing on my H22
- H22 running badly :(
- HOW TO:Balance Shaft Removal
- Stock air Intake for 97-01
- Fuel Line Extension Question
- WTB: Power Steering Pump 97-01
- jdm Si valve train issues...
- Good websites for prelude ups/acces.
- intercooler piping for 93 prelude
- Programing new keys for 2001 prelude (immobilizer)
- knock sensor problem
- Basic Tune Up
- water spots on window
- Compression Testing?
- If you could buy a 99 SH, 79K for $9000...
- what is this code?
- To the still is Glass Roof lovers!
- hardcore bogging?
- H22 Stock motor redline...
- How hard is it to relocate the dome light to the front?
- Which Setup?
- 4th Gen JDM Amber Front Signals
- if you are looking for cheap, replacement rotors...
- Where to Find...Carbon Lip and Stock Fog Lights
- Another "rebuild H22" thread- some questions too
- what vtec type do i set my VAFC2 when i am running h22 with p28?
- ECU Question, Please help!
- air con removal
- prelude with 190k miles
- FU Strut bar question
- Over heating exhaust problem
- 97 prelude CEL 23...oil pressure switch or knock sensor?
- My engine in my 98 Prelude SH gets hot too fast. why?
- What to get for my 01 lude
- I want RWD!
- Oil Dipstick pipe on my block. Radiator hose?
- wanted 3 gen prelude
- Please Confirm: Timing Belt Auto Tensioner problem?
- New here - pics of my car
- Is it worth it?
- weird noises on a 5th gen
- Can you tell me what this is??????
- Prelude OBD1 ECU help
- WTB: Prelude front lip
- Invidia Carbon Fiber Lip Honda Prelude 1997- 2001
- Killer Deal
- All motor H22 build complete!!!
- Is it possible to mount a sub under the rear seat?
- located in socal!
- Cigarette Lighter Thing...
- My motor mounts...
- parts parts parts
- My stage 2 racing clutch is making a screeching noise? what is it?
- I need HELP....i need information on my 98 Prelude ASAP
- The INFAMOUS tranny whine, ok well its infamous to me.....
- wats the best top end for h22
- Bunch of MINT H22 parts FOR SALE
- Rear wheel bearings - disc brakes quick question
- Best prep for the harsh winter months ahead.
- Tryed searching... could not find.... Offset grinding crank thread by innovation?
- Differences between usdm & jdm 92-96 4th gen fog lights?
- No Heat-help plz-SEARCHED
- h22 compatible tranny cases
- Buy my stuff
- 5th Generation Retrofit Headlight
- Timing Belt Issue
- What do I need for silver Auto Lock switch to work?
- Valve Adjustment
- very low idle
- ATTS Fluid and tranny fluid
- Snow tires for the lude
- Tips on driving a Stage 2 Racing Clutch....1998 Honda Prelude SH
- RMF'ed Lude too slow
- JDM DOHC F22B Dyno?
- ATTS issues when doing a radiator swap? ( searched )
- Honda check engine light codes
- For Port and Polish...???
- Anyone tried to use an accord tranny on 4th gen
- to heavy???
- Shifting
- Koni Yellows and Eibach's...
- is an OIL leak in a 98 honda prelude SH a big deal?
- I have a question about my O2 sensor in my 98 prelude SH.
- Honda Badge removal
- h2a5 tranny fit prelude?
- Ignition Key Problem
- any tips/tricks for more power? basics installed alrdy.. i/h/e/p
- need help fixing my heater
- Instrument Panel Garnish
- Block broke can it be welded/repair
- where can i get a jdm parking pole
- Trouble starting up?...
- 1998 5th gen Prelude top speed. H22A 5-speed
- Code 43
- anybody replaced a 4th gen telescoping antenna w/ a fixed one?
- The Official Honda Prelude Header Thread H22A F20B
- How many Hangers for the Exhaust..?
- Suspension Setups
- whats that noise, coming from steering??
- JRSC 4th gen
- still can't figure which set up is the best
- can't find old post about oil leak and replacing some seal near the oil filter?
- any new stuff out
- KMS valve springs with crower retainers?
- JDM Black Housing Lights and HID's...
- timing belt
- 97-up aftermarket Frontlights
- suspension help
- swoosh vtec,a\f,rpm,torque controller
- distributor cathode wire????????
- need help installing v tec controller?92 lude
- No pull after 100mph.
- Clucth question Will not engage
- Dash Lights......OUT! Anyone have or had the same problem???!??!!
- what year prelude do i order o2 sensor for? when i have a jdmh22a.
- Fried ECU
- Balance Shafts
- I have a short somewhere, need help locating
- help with removing panel
- Remote starter?
- 3rd gen lude dohc vtec?
- Help -- possibly buying a 5th gen
- Fast Idle Thermo Valve (FIT) or idle air control valve (IAC) ?
- All Aluminum Radiator
- Balancing Shaft Removal
- Heat Plastic Piping Problems
- top speed
- GT28RS?
- breather filters
- problems with pspect
- Options on 97 jdm h22a header
- need some help with my fuel pump
- looked in FAQ. couldnt find.
- turbo manifold for a 97 prelude sh
- Where did you get you work done?
- no heat. its getting cold out!
- h22a h23flywheel situation?...PLEASE HELPO....not a noob question
- Head up window RPM/Speed display
- canadian 5th gen seat warmers?
- dont know what year my car is?
- current turbo setup...
- Cracked my front bumper...
- short shifter fitted, gear changes still not so smooth
- quick CAI question
- JDM h22a LSD tranny keeps poppin out of 2nd gear??!?!?
- need help, car died
- dash conversion
- Dash Cluster - 96 4th Gen
- Sprung a coolant leak.
- anyone know what a good o2 sensor to replace? is bosch good?
- 5th Gen Tire Sizes
- Apex WS or WS2? or Greddy SP2? Which one?
- Rear Accord Lip, On a Prelude...
- h22 head on h23 block
- AEM Plug & Play Programmable EMS
- Top Speed limiter?
- JDM Headlights...
- 4th gen turbo ludes please help
- How high can i rev
- What Next?
- Air/Fuel Gauge and Oil Pressure gauge (autometer)
- High pitch "screaming" noise from my distributor cap.
- Turbo question
- My prelude Starts stallin when i press too hard on the throttle
- changing out combination switch wiring harness
- Immobilizer/ignition problem on Prelude.. after clutch job,no spark...
- Race axles, got them?
- Intermediate shaft question?
- performance tranny question
- emission parts removed, is it ok?
- Temp. Gauge?
- problem
- Headlight ID/difference
- Messed up my Lude...
- 95 JDM H22 vavle clearance needed!!!!!
- cam timing
- Changing 4th geb LEDs
- Wiring Diagram for JDM headlights
- F22/h22
- THANK YOU!!!
- can I put a h22 head on my f22a?
- Who install a climate in left power prelude 4???
- Factory LSD installation?
- 95 Vtec headers removal problems
- engine advice please
- A Few Good Questions
- TB Change and more F22A1
- 5G climate compat. w/ 4G?
- fuel pump
- Need help with 95 JDM h22 vtecValve Clearance specification!!!!
- power steering feed hose
- do prelude have 4ws??
- Si = Vtech?
- prelude axle differences?
- questions about my future setup
- will it fit
- Need 95 JDM H22 head valve clearance specification!!!!!
- Hytech twin loop muffler
- shocks part number
- h22 distibutor plug order
- need help with a parts number PLEASE
- balance shaft belt question.
- performance exhaust for 96 prelude
- Fun having JDM BB4 til you blow a fuse!!
- Skunk2 IM porting
- Im gettin some headers!
