View Full Version : Honda Prelude
- lowering an SH
- Oil consumption
- 2 CELs & Limp Mode...
- What oil do you guys use?
- non starter no spark 2.2 Vtec gen 4
- H23/F22 Rod Bolt Size??? ARP Rod Bolt Available?
- P13 Knock Sensor Error
- engine swap questions.
- Transmission hose?
- h23 pistons
- front calipers problems
- honing an H23 block
- ESP BB6 strut bar!!!
- distributor question
- Attracting cops with a loud exhaust
- Need Some HELP... Car Shut Off After a Missed Gear
- 390cc or 450cc
- ebay steering wheel
- Huston, We have a problem ( timing belt tentioner and block)
- Adjust the parking break?
- can we use +38mm offset on a 5th gen or will we need spacers
- Best Electronic Boost Controller?
- please help!!!!
- electronic cutouts
- Who knows of legit engine shops in Vancouver, WA?
- H23 to H22A Swap Please help
- new shifter bushings?
- cluster problem??? help!
- f22a1 to jdm h22 swap, oil pressure switch..
- Tranny wont go in any gear?
- Possible Oil Pump Problem ???
- changed oil pan gasket now oil light?!?
- my prelude helppp
- Got a Ticket
- SRS Light & VTEC Failure?
- Clutch pedal falling to the floor
- parking brake
- Odometer and tripmeter not working...
- Worth the purchase?
- question? H22-H23 header
- custom body kit
- EL Cluster
- Want to know if these rims would work on my 01 prelude (want to stagger)
- stroker kit
- need suggestion on tire size
- H22a swap...what to do with the left over money?
- car won't warm up
- Price Check - 2001 Type SH
- 546whp low boost dyno
- do you put reg gas in your 4th gen lude(vtec)?
- f22b dohc valve train help
- 13 sec prelude
- Car shut off when missed gear
- Best gearing for f20b?
- type s or base
- fuel problem.....
- stock parts
- Been having a strange overheating issue... gah!
- How to repair 5th gen 'blades?'
- Car shuts off when i let out clutch
- Need help with vibrant performance ehaust
- firing advancement
- golden eagle fuel rail
- Problem with JDM P13 ECU
- Rebuilt head, Now wont start, HELP!! H23
- pulstar spark plaugs???
- would a....
- ATTS light is on after base swap...
- h23a1 w/ f22b Head?
- 4th gen pics thread just like the "Official 5th"
- BRAKES OR ABS PROBLEM
- 4-2-1 !?
- horsepower help
- Best paint to match B-83M? Touch up paint not smooth enough.
- Climate Control problem and overheating
- dyno numbers from today, on and off the nitrous
- can i use hondata on a h23a blue top vtec?
- prelude shocks
- SOME SWAP PROBLEMS... :( JDM h22a
- trans
- Fuel Pump
- how to install timing belt on h22
- where can i get the gauge rings?
- vfac2 wireing
- p72 ecu
- HELP!
- Gas Guage
- i have a real big problem
- anyone have Tenzo DC-5 or Type-M rims on their car?
- What size injectors in h23a vtec (blue top) Sir Wagon???
- Help! Hard to get in gear...
- Help on 1000cc Delphi
- h22a1 into h23a1 si swap (93')
- H22A FRM cylinders compatibility with .25mm (oversized OEM or Mahle pistons)
- OIL FILTER LOCATION : Help Please
- h22a Speedometer not working
- needed 92-94 engine wiring harness h22 or h23
- skunk2 pro3
- alternator!!
- how much would this cost????????
- Good deal?
- curious about supercharged track times
- Possible Alternator or Wiring Problem
- About to buy a 97 prelude
- How to wire IAT Sensor
- balancer belt
- best rpm for vtec?
- skunk2 lowering springs
- 95 A/C Removal
- 2000 PRELUDE DASH LIGHTS QUESTION...ANY INPUT WOULD BE APPRECIATED!!
- h23A1 TURBO??
- Those that have turbos
- Socal Preludes Needed for a Movie Shoot
- How to Wire Vtec
- i have a couple of questions that need to be answered
- Bolt Sizes
- head question
- honda prelude sh exhaust pipes to fit honda prelude base
- need help
- 2 CELs w/ chipped p28 in '93 Si(jdm h22a swap)
- Frankinstein motor???
- passenger axle poppin out.
- VAFC Wiring
- 89 Prelude, trouble starting cold
- 4th gen 2.0i prelude non vtec
- 16x7 225/50R16 will they fit
- need new half shafts...
- My 94 vtec header and exhaust installation Pics and vid
- idle bounces swapped obd2 h22 in a obd1 h23 car
- is there a plug to check the codes for engine light
- fan turns on when key turns to off
- h22a losing allot of power help
- Help please carbs/wiring
- lug nug bolt broke off :S
- Please help..98' Prelude is dead in the water
- Shift Fork Issues
- 4th gen prelude build, History or failure, we'll have to see.....
- H22A potential turbo build
- O2 sensor simulator
- Idle problem
- i think i have ignition problems on my 93 h23
- Subs in a Prelude???
- 95 Prelude trunk
- How do I know which MAP sensor to use?
- problems with sunroof seal
- exedy stage one clutch
- can i lower the clutch pedal so it grips faster???
- 5th gen stock front seat weight
- obd 1 conversion
- Jdm H22a Coolant Temp Sensor HELP!!!
- Just bought a 70mm throttle body? just wanna discuss about issues.
- 1990 Prelude Question
- Another question
- short shifter
- hopeless vtec?? UPDATE
- tune
- Help with finding trim piece for 94 prelude
- cel code #9 2nd dizzy what going on?!?!
- 4point harness
- F23V????
- NA Dyno 230whp/185wtq Neptune tune by Zeeman
- I need pictures of...
- 90 prelude ac
- Replace broken stud on tail light.
- Rear caliper bolt stripped.
- What paths to take when modding an h22a?
- 400 bucks worth a H22a4?
- ok wtf
- allmost there
- e85
- d4 light
- torque
- torque
- engine idle problem
- Honda-challenge race report (Hyperfest weekend), with pics and vids!
- I heard something.
- Loose Door Handles
- difference between type sh & BB6
- H22 smoking
- High pitched squeeking noise during right blinker
- Power steering
- please help with ignition on an 01 prelude
- 4th gen Center console
- Replacing the small tweeters by door handle? (5th gen)
- H22a intermittent power loss
- timming information
- speedometer/odometer not working.
- s2000 seats in 4th gen
- oil light problem...need a miracle worker
- Car won't start
- Need help. misfire on #1 have read all posts!!
- radiator changed. oil hose mix up!
- Please what can I do to fix....
- Installing a gauge in the tweeter panel.
- 97-01 Prelude full coilovers
- R12 to R134a conversion
- climate controller replacement - new, used or rebuilt?
- $600 what can i do...
- need some help
- h22 knife edged
- Cold air intake
- bb6 rims
- Gutted cat convertor or Test pipe?
- Blow Motor, need help with replacement.
- How can I get this screw out?
- 86 honda prelude 2.0 timing
- Give me thoughts...
- Fuel filter options with Skunk manifold.
- 97 Prelude High Beam Problem
- Climate control + Cruise Issue
- Airaid throttle body spacers from Summit ??
- who makes 3" catback exhaust
- CEL & low idle
- Fixing dented header?
- came into some money need some opinions.
- 300WHP Achieved!
- Want to buy: NEED!!! 92-96 center console and seat frame!!!!
- Energy Suspension For 5th gen Base Model?!?
- HOW TO: Ignition Key Light
- Help with brakes 92 Prelude SR
- Cam identification
- h22 swap need help
- MY CEL came on at 108k
- ecu
- fuel air meter code plz help
- Hondata or crome?
- 1999 Honda prelude H22a4 wont start
- Lude problem!
- Brake roto screws rusted away! Can't get them out to replace rotors!
- Spring Rate
- h22 type s pistons with eagle rods
- hmm having some trouble finding a new trans
- S2K Wheels
- h22 alternator belt different than h23?
- 1992 SR 4WS Prelude-swapping in H22A question.
- wheel spacer
- "Battery" light on???
- 5th Gen Oem lip kit
- H22A low power
- oil pan
- quick question
- optima battery life
- car doesn't start right up
- H22 for sale
- Quick question about charge pipe routing and downpipe clearance.
- Best brand of synchros?
- HELP!!! with a 96 honda prelude won't spark!!!!!!!
- When lowering compression on the H22........
- 93 prelude for sale 6500 or fully built motor only for 3500
- 98 prelude that sounds like a WRX with An exhaust on it
