View Full Version : Honda Prelude
- dizzy guestion
- 92 prelude idle problem
- OBD2 to OBD1 harness
- Need help!! external and internal coil/dizzy problems =(
- Sensor on cylinder head
- Tips on getting my car ready for autocross.
- Problem or ?
- couple of questions about ATTS to help me out
- Car cranks, but no start. Help. 93 Si-VTEC.
- energy suspension mount inserts...
- does an aftermarket header replace the braided pipe on a 1994 si?
- Tunning?
- No starts after head install
- mayeb i fixed my smoken problem?? NO WAY
- PCV Valve stuck on tube
- CF Hood?
- Need Help ?Clutch?
- Rear Sway Bar Problem
- OEM CD player problems
- does the megan header for the H23 extend all the way to the cat??
- Timing Belt Installation Question
- cosmetic problem, sry no one answer in the cosmetic threa section
- Prelude Throttle Question
- I was on the dyno then...
- 86 prelude left driveshaft out boot replacement
- h22/h22 oil pump
- exhaust for my prelude
- random 4ws factoid of the day!
- Problem w/Tail Lights.....please HELP!
- Jdm honda prelude rear lip
- type s cam problem
- No brake pressure..sometimes
- H22a4 crankshaft bad !!!!!!!
- Super Hard Time Getting Timing Belt On H22a
- h22a head torque
- 92 Prelude Si, Hesistating/backfiring.
- peice of $h!t-vent
- h22a4 or h22a
- Is there anything we can do to help this forum get back to where it was a couple years ago?
- powerslot plus big brake kit???
- transmission problem in 99 prelude base... next day
- JDM fogs with HIDS
- Clutch Fluid
- Wut ecu to run with Hondata s300 ?
- weird tranny/clutch problem... please help grinding all gears etc.
- is AEM pully kit worth gettin
- dirty injectors???
- no clutch pedal pressure/pedal sink to floor all of the sudden
- How much Tranny Fluid? 5th gen Auto
- Exhaust leak anyone?
- 2000 Honda Prelude's OEM Anti-Theft & Immobilizer
- Correct shift cables for an F22 trans going into a 97 prelude?
- 97 H22a4 + 94 H23 Tranny - Which Throw-out Bearing?
- '92 Prelude Sub installation problem
- brake fluid flush and fill?
- My oil drain plug is stripped and can't get it off
- H22 ecu vtec engagement point.
- h22a vs h22a4
- smoking on startup
- How to get mil codes after installing OBD2 > 1 conversion harness
- slim fit radiator fan...
- Moving to Arizona + Greddy header. = worried about my paint.
- vacum leak
- Best Exhaust??
- hondata installed, need some clarification
- Hybrid options for H22A4
- Suspension Advice
- have h22a4 using jdm h22a obd1 345cc injector, what fuel psi should i have?
- 88 prelude si must sell
- Abs light and cel.
- Best Preformance part!!!!!
- HKS sport exhaust
- easiest way to take off 02 sensor?
- higher compression then better gas mileage?
- Any way of telling if timing belt work was done?
- Intake and gas mileage
- Koni shock lower clip keep on poping out.
- Difference in Hoods?
- OEM "Optional" lip kit
- witch is power???
- GARAGE SALE!! Everything Needs to Go. H23/H22 Parts
- does any1 have pics of what fog switch will fit in a 95 console, next to the hazard.
- header & exhaust
- airmass header
- ''whining'' noise coming from front of car...
- How to remove outer door molding (5th gen)
- knock sensor...searched
- Turbo on h22 with s300
- s2000 steering wheel on 4th gen.
- "vacuum box" Is it really necessary?
- What Exhaust?
- Quick question about my headgasket
- Spoon ECU
- 96 vtec lude no lsd right??
- transmission fluid/oil
- Greddy Evo Exhaust
- Wierd Problem... If you can help, I will love you long time! PLEASE!!!
- new lude-best exhaust???
- Idle problems, Diagnosis help!
- custom motor mounts for a 3g
- How to tell what tranny?
- How much is too much
- Preludes "burn oil in VTEC" ?
- 5th gen lude... Motor replacement... What do i need
- stock 5th gen prelude tranny?
- what is the best coilover set up for a 4th gen?
- any have problems with their dc headers?
- transmission question
- HYTECH header
- Need help installing my air/fuel gauge! (which wire?)
- cant get 5thgen slammed:( help
- anyone here who has a tein basic damper?
- geneuine spoon ecu
- swap problem??
- Car won't start after motor build, bad ecu?
- ecu tuning conversion problems
- Jet Performance Chips
- Turboing a built high compression H22
- Buying A Prelude (Need Advice)
- h22 turbo accord project
- H22A1 Valve Adjustment (searched)
- rocket motorsports cams
- Skunk 2 IM
- Replacing JDM H22A long block into my H22A1; What do i need to know?
- 5th gen intake on a 4th gen install question.
- H22a tranny
- Good vendors
- Question about Tires for Prelude
- fog light harness and wtf is this?? pics
- aem twin fire c2di
- si/vtec pulley situation....
- Help... need quick tips/tricks to replace rear shock (first time on Prelude)
- Check engine light when "getting on it"...
- Timining belt crank pulley
- Built h22a head on a stock block
- difference between 4th and 5th gen starters? (searched)
- Need help. About to buy h23a1 shortblock...
- coolant issues.
- Coolant leak in (2) places...
- Opinions on this Lude? May buy.
- oil burn problem with a 00 prelude
- external clank when engine starts or when it lugs
- hmm wth is wrong??
- ebay megan header
- checking power to ECU. how do i check this?
- CF Hoods and trunk lids
- Long live the Prelude...
- act clutch bearing?
- my h22 build
- AC Compressor Compatability for Prelude
- New Sound System Setup
- 94 Honda Prelude Camber Adjustment
- revalving Konis for free???
- Hesitation Back after Resetting ECU?
- i need hlp with my 91 lude..
- 4th Gen. Factory Front Lip/Air Valence.
- h23 head work
- Fuel injectors on h22a, saturated or peak and hold?
- h23 rod capeability
- JDM H22A on 96 Accord VTEC CUT OFF!?
- Small Video Draveby of my car...
- Important Information 2006 National Prelude Meet
- Work RS-Delta 16x8 45+mm offset on slammed 5th gen..what tires???
- Tuned...not happy./..
- Center beam Q's
- O2 sensor ?
- Leak on the passengerside flooring ??
- h23 CAI
- Where can I find gearbox and shifter?
- e-brake handle
- Any 4WS gurus here?
- Reverse lights stuck on and leak inside trunk
- Power Steering and ABS Removal in SH
- Funny Shake @ 70-80 mph?.....
- Oil smell from inside cabin??
- JE pistons question
- Emissions and P28
- Sourcing out manual conversion parts
- Zero Play LCA inner bushing kits (I had a few extra made)
- Evaporative Emission (EVAP) Control Canister Removal
- Where'd my oil go?
- 2,2 VTEC Digital Cluster
- What type of oil...
- Auto or 5 Speed?
- Failed Smog, help me locate parts.
- CEL light
- Bogging...
- Please help, my lights not working
- shimming the tranny / special tool. uh oh.
- Does anyone own the new DC header with 2.5 collector for the 92-96 Prelude?
- skunk2 shifter?
- Whats better than a h22 to swap into a prelude?
- j-spec f22b?
- parts car help
- Strange idle in cousins 96 Lude h22a swapped
- Pads/Rotor installation on 5th Gen. Simple?
- carfax
- putting a h22a in a1988 perlude
- How to recalibrate gauges??
- DIY : How to adjust JDM headlights - directly from Honda :)
- How to fix cut antenna wire?
- will this harness work with the jdm headlights?
- 99' 5th gen 5sp Transmission Leak?
- oil seals
- km question
- H23a1 white smoke
- knock sensor question
- new rear pads!!
- S2000 power trunk release on prelude
- The Envious Fuel Lines.....(searched)
- blew bottom block...
- how often do they send you a Test Only smog check
- help me plz . . .
- Car Trouble - Keeps dying when I stop giving it gas
- found one TYpe-s
- searched, detailed egr cleaning..
- quick question
- anyone have a thread of how to take out and install jdm headlights, 94'?
- dc ceramic
- h22a in 2000 prelude wiring
- tranny slippen
- cel code help
- How to clean foggy headlights *searched*
- header from an another car
- Quick question on anti-roll bars
- vafc or hondata
- will an exhaust for the vtec model fit the si model??
- still not starting? WTF mate
- Prelude with a CRV motor?
- Cornerlamp has me baffled....
- question for those who have done hids in 5th gen
- What does this plug do? PIC included
- cat converter
- Jdm Side Markers both have 3 wires L(Blk,Blu<Gre) R(Blk,Gre,Gre)
- H22 Type S in a USDM car?
- Front License Plate bracket for 93 Prelude
- clutch adjustment?
- Who makes a H22A Thicker Head gasket?
- oil light on, but no oil is leaking and oil is full *more questions about H22 inside* plz HELP
- I need 4ws error codes... (already searched)
- optima battery
- 1/8 Mile times?
- Hey all, n00b prelude owner joining you. Any suggestions on securing my car?
- vtec exhaust!
- h23 with h22 head??
- New to Preludes: Regular gas in my Prelude? CEL? (my bad)
- n00b prelude
- 4WS ECU
- Car Trouble... What's a shift solenoid?? Help appreciated!
- Link Request: h22 allmotor build swaped in h23 crank at dyno
