PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 [222] 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. tiptronic??
  2. mccolluch HID's?
  3. 92 Prelude Si can't shift into gear(auto tranny)
  4. PIAA bulbs ?
  5. Detailed main relay help(searched)
  6. fuel cutoff at 6,700 rpms?
  7. Tein Suspension
  8. Cylinder Position Sensor
  9. greddy emanage?
  10. tranny code
  11. B21A1 Cylinder Head
  12. 5th gen smog check passed (California) .. Questions
  13. Security Alarm
  14. Brake Booster removal! HELP!!
  15. used vafc question
  16. Anyone tried to put satan_srv 4th gen spoon lip on a 5th gen ?
  17. I need to buy a Tach Mount.. WHERE TO GET?
  18. memory button
  19. dohc f22 in 92 si lude
  20. Prelude/Accord Suspension Question. NEED ANSWERS ASAP!!!
  21. Cat Back system
  22. What camber kits do you run?
  23. pulley probem need help!
  24. shifting into first
  25. 1997 Prelude Secrety Emission Cutoff date?
  26. shifting problems...
  27. troubles with code 9
  28. Buying my first prelude
  29. Speed range for the Sequential Sport Shift?
  30. Main Relay??
  31. JDM Headlight doesnt quite fit
  32. OBDI distributor that bolts onto 97+ h22a4?
  33. thermal exhaust? w/pic
  34. Idle screw, where is it?!
  35. 86-90 prelude engine swaps???
  36. 2GEN pgmfi SI 86 Lude injector issue
  37. h22 stroker kits?
  38. what is a resistor box and how do you install one?
  39. electrical problem...
  40. need help reeeeeeeeaaaaaallllllll badddddlyyyyyyyy~!!!!
  41. stuttering?
  42. 4th Gen Prelude Interior
  43. problems off the line (5th gen)
  44. another h22 swap problem for u guys to help me with....fuel
  45. Leaking Mysterious Fluid
  46. clutch alignment tool where to get one
  47. witch one
  48. h22a redline
  49. Turbo prelude wont idle!
  50. how much would this cost to fix?
  51. h22 skunk2 manifold...for you vtec guys..
  52. 4th and 5th gen prelude seat rails
  53. Pre-Loading Coilovers (Tanabe's)
  54. can you smog jdm engine in california ??
  55. best way to refill transmisson fluid on a manuel
  56. Catalytic Converter advice please...
  57. type s block able to be bored out?
  58. H22A H22A Dyno Hondata 208WHP
  59. how much $ would you pay for 94-96 sawblade rims?
  60. anyone in here located in Upstate NY....???
  61. VTEC CONTROLLER
  62. help with p14 ecu pinouts
  63. 5th gen prelude o2 censor problem
  64. idle question
  65. uberdata vs hondata.
  66. Clutch Problems
  67. what should i do with my car?
  68. my 5th gen sounds like a little truck!!
  69. Difference between 1998 & 1999 engines?
  70. oil pump installin a 1995 JDM H22 anybody have luck with this ????
  71. Mugen Question
  72. Automatic to manual conversion
  73. Lowering springs for JDM 1998 Prelude ?
  74. crazy idle
  75. abs pump overrun error
  76. SPARE TIRE???
  77. About to replace Timing belt. Should i keep the AUTO or go Manual tensior?
  78. Bent valve??????????
  79. CF Hood Question (searched)
  80. coilover decision help
  81. removing sound deadening material?
  82. Bizarre Problem: MAP sensor keeps falling off
  83. A/C Removal Q's
  84. upgrade plugs and wire difference
  85. weird sound coming from i don't know where
  86. aftermarket bulbs
  87. trouble holding idle
  88. would it be worth getting Vtec model brakes?
  89. 2000 grill insert
  90. Newbie, VTEC engagement
  91. how to tell between type s cams and stock
  92. who make the best hood for the 5th gen
  93. I need a pic of a H22a Flywheel Bolted onto the tranny please.
  94. Sqeaky suspension & Tire Rub
  95. Last questions... yeah, right.
  96. front lower ball joint
  97. crank oil
  98. Spak Pugs?
  99. radio problem
  100. turbo
  101. looking for h22 tranny rebuild
  102. 5th Gen - Strut Bar and Tie Bar questions.
  103. how to install the alt/ac belts to a 93' lude
  104. Can a compression test have off numbers due to a hole in a line to the intakeman
  105. do i need a new idle air controller (IAC) CEL 14??
  106. JDM Headlights?
  107. HeaderS?!?
  108. How much does H23 weigh?
  109. i want a/c back in my car, how?
  110. Car want start
  111. 92 Prelude S
  112. h22 swap perf problems
  113. start up question
  114. Strange hick-up
  115. Carbon Creations CF Hood
  116. Spun rod bearing?
  117. 3rd gen engine swap question
  118. sea foam though my brake booster...
  119. pcv valve question?
  120. jdm h22a versus usdm h22a.....how much is jdm faster ??
  121. Oil question
  122. *stupid question*
  123. Installed head unit, now factory alarm and clock aren't working.
  124. whats the best vtec controller
  125. how do i get my shift knob off
  126. turbo parts
  127. prelude wont start
  128. Brakes wont depress when car is hot!
  129. F20A/B
  130. h22a7 (euro R) into 4th gen.
  131. f22a header?
  132. what is the differents between si/vtech/s models... other than just motor...
  133. 88 prelude 2.0 S carb questions
  134. Wire colors on your h22a IACV?
  135. switch for fans
  136. H22 Header Comparison *teaser*
  137. how hard would it be...
  138. cat back exhaust question
  139. interchanging parts??? need a website???
  140. h22 type s head swap
  141. 97 + projector headlite look
  142. Thinking about buying H&R Race Springs...Good idea?
  143. TIPTRONIC VTEC HELP!!!
  144. 94Si leaking/burning invisible oil
  145. racing medallion
  146. What is the best ECU to run a Hondata with boost on a 5th gen
  147. 99 Accord/ Prelude type S Hybrid won't get past 3500 rpm?
  148. HIDs
  149. h22 del sol axle question?
  150. Pulling codes from the 4ws computer
  151. Question for the wise
  152. MSD Boost Timing Problems
  153. I need Direction!!!
  154. Please, I need piston/displacement answers
  155. F22 Throttle Body?
  156. Motor Swap SHops?
  157. Accord SIR H23 DOHC Vtec
  158. Rally Kit?
  159. PSI??? I have some questions about turbos and psi. I hope I can get some answered.
  160. cf
  161. Contest- Help Me Out
  162. 2000 integra type r for sale
  163. Stock cams oversized valves....?
  164. My center air vents won't blow any air, but the rest do
  165. H22 / H23 Crank
  166. Radius rod, How much torque?
  167. 98 Prelude Bumper removal
  168. '01 prelude obd2 to obd1 conversion
  169. h23 rods/crank in my h22.... suggestions for my setup?
  170. Ecu and boost related question.
  171. H22 tranny oil capacity
  172. i need help with a ECU WHAT IS COMPATIABLE ?????????
  173. Exhaust question?
  174. 5th Gen Turn Signal Running Lights
  175. VTEC pressure switch wire(s?)
  176. 1993 h22 oil capacity?
  177. what is a hayabusa itbs?
  178. turbo tuning problems, help please
  179. Location of engine temp. sensor?
  180. body damage how hard or much u think to fix
  181. timing my h23 in sacramento,ca
  182. ECU help!!!!
  183. 2nd official prelude exhaust picture thread
  184. 3k RPM knocking noise? (help)
  185. good paint store in NJ
  186. Cam seals: Putting in new STRs
  187. prelude newbie!! why does my vtec kick in intermitently???
  188. Clutch Fluid?
  189. ecu match up>?????
  190. How much difference will a V-Tec Controler make?
  191. What is a stock H23 compression psi supposed to be.
  192. timing belt reuse?
  193. Turbo kit question pls help...!
  194. New to the forums...
  195. System Charging Issues...
  196. Custom H Series Crank
  197. STOCK question...
  198. Throttle Body 5th Gen???
  199. .......dsm injectors....??
  200. rear big rotor break kit for 93 prelude?
  201. anyone turbo, h22, uberdata like me?
  202. H23 Head.. How bad does it flow??
  203. ABS code. Three blinks, 5 seconds apart. ??
  204. Need help on finding a downpipe
  205. question about h22a cylinder wall...
  206. who has an extra clutch alignment tool?
  207. power steering question....
  208. ****Need JDM tranny info ASAP!! not in the Prelude FAQ, or on HT*****
  209. Balljoint question
  210. golden eagle intake manifold
  211. ECU fault 43 "error fuel supply"
  212. Brake pad clips to stop the clattering
  213. new to forum, got a question
  214. Squeeking clutch fork?
  215. prelude turbo
  216. Acoustic feedback system and another question
  217. head gasket h22a
  218. The dealership is finally taking my oil consumption issue seriously...
  219. VAFC sensor voltages check....
  220. Power Mirrors Don't Work
  221. OEM 2 pot brakes? Which Model?
  222. Warranty question..
  223. Need Pro Advice
  224. Front end troubles:(
  225. Need help with a bouncy idle.........
  226. h23->h22 Worth the upgrade?
  227. valves
  228. Official Prelude Nitrous Thread
  229. Quick Headlight Q
  230. Main Relay?
  231. Diagnostic Socket Terminals???
  232. best clutch/lightwieght flywheel for street and strip?
  233. preparing the bottom end of an H22
  234. got as question about the skunk2 obd2-obd2 harness
  235. best turbo kit for 97+ prelude?
  236. H&R springs creaking?
  237. msd wires
  238. F22 Nitrous. I Bought : Nos dry kit,remote opener,purge, etc...
  239. wheres the "official exhaust picture" thread? (searched)
  240. 3in prelude exhaust
  241. SEA FOAM QUESTION....
  242. Back out plate on H22?
  243. MSD ignition problems!
  244. 'Lude radiator size?
  245. VAFC affects Timing?
  246. Type SH headers on a NON-SH
  247. Whats the best strut bar for a prelude?
  248. how are the skunk 2 exaust for an h23
  249. what is the best exaust for a h23 lude
  250. Hondata
