PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 [158] 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Is this true?
  2. Are 4th gen VTEC and Si Brake Pads the same?
  3. f22/h23 heads help
  4. How much life is left....
  5. f20b head
  6. N/A forum sucks: Prelude : h22a1 rebuild ?'s
  7. Shredding power steering belts
  8. H22/H23 crank pulley
  9. Question about H23VTEC (i have searched)
  10. whitch clutch
  11. 5th gen aluminum drain bolt starting to strip!!!!! HELPP!!!!!
  12. Help getting oil pan off a 89 Prelude
  13. Dropped about 2 inches...
  14. 4ws and fast/sharp turns
  15. 88-89 Lude owners..help me out here..
  16. CEL code 36
  17. 4th gen Prelude trunk dimensions
  18. cams
  19. clutch
  20. Will my car lose power if I unplug my O2 sensor?
  21. swap question
  22. my vtec is actin strange
  23. Most Comfortable Springs
  24. JDM H22 swap or H23 Turbo w/ stock internals
  25. 97+ back seat room?
  26. Weird sound coming down from my 5th gen..HELP
  27. H22A All-Motor 233 HP 175 FT-LBS Dyno on OEM Bottom End
  28. Swapping JDM H22 into SH questions
  29. window stopped working.....
  30. Del Sol radiator swap completed.
  31. need help new to prelude scene and modifications scene..!!!
  32. help!
  33. 5th base model center caps
  34. Oversized Valves
  35. unorthodox pulley won't fit in !!!!!
  36. turbo prelude???
  37. Transmission
  38. To 4 wheel steer, or not to 4 wheel steer?
  39. 92 Prelude Tranny Swap=dissipointed
  40. F22A
  41. some help please
  42. external or internal coil?
  43. Engine hum?
  44. Engine hum/buzz/click?
  45. b20a6 with b18 head?
  46. Auto Tranny Went Out Already?
  47. Getting my 92 si this week.....Got a couple questions..
  48. all motor or turbo
  49. Ground Control spring rate question
  50. my throttle is sticky.
  51. Front and Rear Strut Bar
  52. car cuts off while driving..what could problem be???
  53. v-tec and i-tec what is the difference?
  54. prelude exhaust?
  55. VAFC fuel question...lean?
  56. Enjo Dealer?
  57. Oil: That time of year again
  58. Map sensor problems
  59. 5" silver autometer tach in 93 prelude Si help plz :P
  60. prelude vt?
  61. h22 question
  62. New Front Suspension?
  63. tranny?
  64. anyone know what color is the knock sensor wire for h23????
  65. should I?
  66. Damn check engine light
  67. Hesitation
  68. 5th GEN STEREO/UPGRADE to DVD in DASH?
  69. how do I know that my vtec is kicking in
  70. srs light
  71. JDM Fog lights on the 92 lude si
  72. Ticket ?
  73. which year prelude to get
  74. need help with a aftermarket pulley
  75. ing for someone to purchase and take care of FOR SALE......
  76. LIGHTS OUT!!!
  77. WHICH ECU 92 prelude w/ H22A
  78. im finaly changeing my struts need some advice
  79. Sellling your exhaust?
  80. BRAKE LAMP ON on dash, everything fine.....
  81. i got my car dyno'd 130hp/140tq
  82. spark plug wires. Do I go with 7mm or 9mm?
  83. prelude swap need help
  84. Erebuni Body Kits
  85. Prelude Spring Rates???
  86. Need some info on a radiator swap
  87. Compression
  88. Need help with VAFC2 setup on 5th gen!
  89. Week old paint
  90. 140$ worth for koni/gc install?
  91. b18b1 into a 95 lude?
  92. timing belt gear
  93. 95 jdm h22 redline
  94. Camber Kits
  95. intake for skunk2 manifold
  96. Engine Type?
  97. just need STOCK 1/4 time for a 95 plz.
  98. Looking at buying a lude SH, need some advice.
  99. Is this worth it?
  100. automatic speed sensor
  101. JUN Racing ECU?
  102. H22 Engine Overhaul Kit
  103. oil burning up too fast
  104. wheel hop
  105. 96 automatic tranny problems
  106. New master brake cylinder
  107. PLEASE REMEMBER!!
  108. sunroof/moonroof question???
  109. im parting out a prelude!
  110. OBD2 to OBD1 conversion? Is it Possible? HELP!
  111. fuel injector question
  112. Iron sleeves?
  113. Exhaust Options...Sizes...Tones...
  114. prelude fog lights
  115. how much you guys willing to pay for......
  116. 94 lude
  117. For the show guys, AutoFashion is looking for the following cars to partial sponsor for AirRunner Su
  118. Where to buy RevHard Manifold?
  119. Remove Headlight and Taking it apart
  120. Ignition Problem?
  121. Stripped
  122. bump
  123. Need to know parts number for valve cover screws
  124. USDM H22 OBD2???
  125. DESPERATE FOR HELP.....88 prelude swaps..
  126. 88 Prelude compatibility
  127. kamakaze headers
  128. Clutch Pedal Pressure problem - urgent Need help ASAP
  129. Spring compressor shot off
  130. Front Strut Bar
  131. TPS Problem!!!!
  132. I'm about to tear down a manual tranny, any advice?
  133. Whoever designed the bolt layout of the IM should be SHOT.
  134. Cylinder 1 Misfire - Code 71
  135. problem with wiring putting jdm fog lights on! help!
  136. synchro for 1st gear questions
  137. Omni Power - Quick Clutch Master Cylinder - Reviews
  138. electronic wiring question
  139. Tire size
  140. attn: whoever offered me a set of vtec calipers!!
  141. THE OFFICIAL 4th Generation Prelude Auto To Manual Swap Thread
  142. radio code?
  143. where to find type S parts?
  144. Skunk2 Stage 1 vs H22 Type S Camshafts
  145. Coustom backseat enclosure
  146. new guy. weird probelm.
  147. H22 water pump fitment?
  148. Brakes
  149. TIN WORK TABLES TO PRELUDE 5G, 97
  150. Fogged or Clouded Head lights?
  151. what do i need for an h 23 auto to manual
  152. surface rust and what to do
  153. Heater core
  154. front strut bar clearance problems
  155. Sad, I only had vtec for 19hrs
  156. Auto to 5 spd 93 lude Q'S
  157. Looking for a new downpipe-my flexpipe exploded
  158. H23 to a H22
  159. where is the oxygen sensor #1 located at?
  160. Gauge problems on '00 Lude
  161. ABS Code 53: Motor stuck on ?!???!??!?!?
  162. What you guys think of souping up 88 prelude si
  163. Ideas for an All Motor Setup..
  164. Fuel system questions
  165. 88 SI Performance parts?
  166. Swap a 5th gen auto tranny for a 5 speed???
  167. Whos got a CF trunk on their 4thgen!?!
  168. h22 with a Turbonetics T3/T04B???
  169. converting to ethanol...
  170. 4ws removal
  171. sleeve walls scratched. are they still good?
  172. RMF pics and pics of my lude
  173. Gas Gauge
  174. Headlight washer -> does it exists in US on hondas ?
  175. How many miles did your auto-tensioner hold before it failed?
  176. Compression ratio from compression test results?
  177. What to do next???
  178. DC Sports Lower Tie Bar
  179. Skunk 2 Stage 2 Camshaft Question
  180. H22 sleeves- kinda confusion
  181. Help me decide on tires...
  182. Any safety option for carbon fiber hood other than Hood Pin?
  183. need help ASAP
  184. pic request:: Rota GT3's on a 5th gen lude...
  185. How to make such tail lights ???
  186. 92 h23 auto to manual
  187. Which shifter cables fit 91 prelude?
  188. compression test
  189. JDM BB6 front clip
  190. tell me what u guys think???
  191. problem with camber...premature wearing of tires..
  192. where can i buy a final drive?
  193. crank pulley bolt... WTF
  194. Supercharger
  195. WTB 90 si automatic transmission/parts
  196. Silencer mod-- effect on horsepower, and torque?
  197. 01 prelude non-sh 5spd VS 04 accord coupe V6 auto
  198. Cold air brings surging Idle (I searched)
  199. BB4 liscense plate relocation?
  200. New Prelude ENgine Owner: What kind of Gas do i use?
  201. Quick question
  202. Valve Seals...
  203. h23 or h22?
  204. What else do I need?
  205. Making the H23VTEC
  206. HOW TO DO A Coil On Plug CONVERSION
  207. h22a VTEC trouble shoot MY VTEC WORKS!!
  208. Spark plug installation
  209. whys skunk2 only 94 up
  210. if u build a h22 up what the max rpms it can take
  211. Rotas on 4th gens please?
  212. need help please
  213. h22 header gasket
  214. automatic throttle body different?
  215. What ECUs are Ok for my H23A1?
  216. i have a 92 lude but i putting a h22 i want to get a aem ems what model do i need
  217. wwrs front lip dilemma
  218. Bolt from camber kit hitting when bottoming out
  219. Ignition Recall part #
  220. What ECU would u get?
  221. Check engine light/ Gas smell
  222. Oil piston squirters and oil pressure
  223. $$$ HeLP ME OuT Guys $$$
  224. I guess my gas light is broken?
  225. need help with an apexi afc2
  226. h22 crank
  227. Help!!! need to replace my pulley in 97 lude
  228. Prelude exhaust...is there a differance?
  229. ECU reset 5th gen
  230. Xenon bulbs (HIDs)
  231. jdm h22
  232. Will 4th Gen 5spd swap parts fit on 5th Gen ludes?
  233. Imagine Engineering header....
  234. H2L5 tranny!!!????
  235. Euro-R IM.....H22A fuel rail
  236. problems with lighting...suggestions?
  237. 97-01 Moonroof on 92-96
  238. eating timing belts again
  239. supercharger or tubo?
  240. Torque specs for clutch and waterpump
  241. were can i get an ARC front splitter?
  242. h22 type-s cams
  243. I wanna get in the 14''s :D
  244. problems getting onto preludeonline.com??
  245. h22a1 to h22a
  246. Would a D-Series distributer cap work on a H-Series?
  247. special tools for putting in camshafts, springs and retainers?
  248. Missing a Distributer Cap Bolt
  249. wiring up the reverse light on 5th gen prelude after auto to manual conversion
  250. h22 lude with GSR ecu?
