PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Need help with 1989 prelude si
  2. 4th gen lude pulled CELs. need advice...
  3. help cold weather possible serous problems
  4. Need engine rebuild kits
  5. gas is getting stuck
  6. need a motor for my 95 si
  7. Who here thinks that the Prelude SH, should be sold at OR above what Type R's go For?
  8. having problems at 3000 rpms
  9. Car bogs at 4k at full throttle.
  10. f22a1
  11. Overheating, where to start
  12. Megan header exhaust leak?
  13. help with buying new car
  14. Prelude Clock
  15. Need to raise idle + retard the timing
  16. gc spring rates
  17. losing power up hills
  18. Very Rough Idle (RPM steady).
  19. Check Engine Light
  20. Taillight fuse blows
  21. h22 m2b4 lsd tranny 5th gear
  22. are mahle pistons good to turbo with stock sleeves
  23. 94 Prelude VTEC AC compressor and both radiator fans not working
  24. POST PICS OF PROFILE SHOTS OF UR LUDE & ITS RIMS
  25. my prelude wont start
  26. finally making the car i want but need advice and help
  27. RIP 1995 PRELUDE H22A1 :( ATTN COLORADO LUDE OWNERS!!!
  28. 1995 Prelude ABS
  29. prelude and Civic Si wheelss
  30. need help... car want turn over
  31. motor swap questions???
  32. shitttt...help plz
  33. H22A1 performance internals
  34. Looking for a tune shop...
  35. wheel opinions?
  36. can we run a staggered wheel fitment on 4th gens??
  37. Rear brakes clunk when first applying brake
  38. Emissions Failure !
  39. And so my 89x95 Build Starts
  40. 2 things Disabling EGR Valve and Vaccum line for intake control solenoid
  41. Snow tire/wheel size for 97 SH...
  42. EGR
  43. Hi from Spain! we want to Join the BBSquad!
  44. Timing belt replacement and now idle problems
  45. h22a help plz help
  46. wheres the post from removing the amber from stock 4th gen tail lights
  47. GLOW GAUGES ? and INSTALL ?
  48. skunk 2 intake manifold
  49. Clutch Pedal Problem.. Help Please!!!
  50. 92 Lude automatic, electrical probs
  51. V Tec Wiring.
  52. what the difference between h22 long block and short block
  53. h22a jdm need headers
  54. whats faster and hp stock???
  55. Rice Prelude
  56. speedometer not working
  57. need help finding were i can buy CROME
  58. High Mileage Prelude should I supercharge it?
  59. Will these headers fit?
  60. Intermittent Oil pressure light problems - tried everything....
  61. Ecu error code problem.....
  62. altenator wiring
  63. Thought you guys might find this video cool..
  64. Another p5p but no injector ground
  65. car keeps dieing
  66. Overhating and no blower heat
  67. What oil to run? (searched)
  68. f22a1 t-belt broke
  69. proping up a hood?
  70. what pistons are good to use with stock sleeves?
  71. Painted gauge bezels..
  72. help with vtec wont engage
  73. cam wear
  74. New OEM Exhaust
  75. Acord-Prelude Engine Swap
  76. Removing the ball joints....
  77. 1992 Honda Prelude F/T
  78. H22 compression testing...with engine running
  79. h23 transmission
  80. How much Hp do the H23 rods hold?
  81. Honda ATF a good cleaner for the motor??
  82. Car Over Heating. Need Help!!!!
  83. wire harness???
  84. Will an auto diff work in a manual trans?
  85. Radiator drain plug broke
  86. can some one take a picture for me?
  87. HID headlights?
  88. H23 pistons questions
  89. h22 cylinder head
  90. can a 97-01 exhaust fit a 92-96 prelude
  91. Best option for H22 swap into OBDII 96 prelude ?
  92. can I use a Obd 2 scaner to delete a cel
  93. jdm h22a vtec..m2s4 or m2j5..?????
  94. HP headers
  95. 5th gen cluster dial UKDM spec
  96. 5th gen oem euro spec cluster dial
  97. 93 prelude no start
  98. HIDs
  99. JDM F22B valvecover vacuum
  100. check engine light reset by mech.??????
  101. widebody kit?
  102. Where can I find a manual Tensioner and Idler for my H22A?
  103. swapped motor... now no gas/temp gauge and no heat??
  104. Fog Lights
  105. H23 NA Cams???
  106. Urgent! Need ECU help with an OBD1 H22a
  107. new h22 project..
  108. 92-95 h22 and 96-00 h22 is same??
  109. need help h22 swap on my 93 prelude
  110. Timing belt install
  111. D4 Light Flashing
  112. One Last Prelude H23 SE header question
  113. 98 jdm h22a won't crank over?? why?, how?? can it be fixed?,
  114. Oil cap leak?
  115. Help! Car Died after it was making a "whirring" noise.
  116. What intake are you running with your BPi stack(4th gen)?
  117. could a coolent temp sensor cel = vtec not working?
  118. couple questoins about honda prelude
  119. best motor for honda prelude
  120. Dash Lighting
  121. 92 Prelude F22a1 Swap to F22B2
  122. Sorry for this stupid question...
  123. having trouble finding the right thermostat for my motor need help asap
  124. 92 lude H23si 2.3 swap H22vtec?
  125. ..::: WANT TO BUY ONLY :::... NO TRIAL USERS, NO COMMENTS, NO PICTURES - November 2008
  126. ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - November 2008..:::
  127. '96 H23A prelude 4 CEL codes, is my ECU failing?
  128. How can i improve handling
  129. can anyone tell me why my car running like this what is wrong
  130. Speedometer doesnt work!!!!
  131. H22A wont start
  132. OEM or Aftermarket parts
  133. How do I remove the stock radio for '99 Prelude?
  134. Engine Fault Codes
  135. 4th gen clock not working.
  136. what are the head lights and high beam types??
  137. Broken spark plug wire cover bolt
  138. h22 in eg wont go into 5th gear
  139. 98 prelude CEL codes P0450 and P0453 how can i fix it??
  140. APEXi VTEC Controller and ECU swap?
  141. od2 motor swap in a odb1 car
  142. F22b block with H23 head
  143. torqued all down... Forgot something. need new bearings?
  144. Wanting a new motor...... need suggestions.
  145. disaapointed with my prelude...
  146. bad converter....
  147. 98 lude
  148. cooling system problems
  149. Just want to say Hello and have a question
  150. vtec wont kick in! redline 6500.
  151. check engine light
  152. 4WS Error Code: 74
  153. Header Help Please _,.-~`-`~-.,_ SMSP
  154. 92-95 jdm h22a motor and tran into 1998 SH whats needed, and how to keep it obdII
  155. Wheel hop elimination
  156. 1998 honda prelude cranks funny when i turn the key need help!
  157. Shoof's 4th gen
  158. Overheating, but I can't find the problem. (Searched and Searched again through 63 results)
  159. Please help 96 Prelude starts some times
  160. Gramlights 57s pro
  161. should i take my head to a machine shop
  162. Distributor seal leak
  163. idel... SEARCHEDD!
  164. useing the site.
  165. Changing Clutch on Type SH Walkthrough
  166. Changing the clutch in My SH
  167. tranny question HELP
  168. 4ws worth it?
  169. Overheating...
  170. HELP!!! Accord Euro R swap in 4th gen Prelude
  171. h22a head question!
  172. Vehicle history check?
  173. oil leaking from headgasket
  174. transmission problems?
  175. JDM Auto Shift RPM
  176. prelude h22a vss question
  177. Anyone have pics of 4thgen intercooler route with Lovefabsst?
  178. knock sensor for a 96 h22 swap
  179. Saw a 5 gen for sale today
  180. 98 prelude boging and surging when driving need help!
  181. Removing my oem intake manifold
  182. Get code P0335 Crankshaft position sensor
  183. 98 prelude Clutch Problems
  184. H22A swap...post complications
  185. Water pump and rear balancer belt pulley
  186. distributor for 1994 prelude h23 firing order
  187. rebuilt engine will not rev past 3000 rpm's
  188. sh to a base Brake lights
  189. Nippon racing pistons
  190. spring rate help
  191. Brake boosters
  192. anyone know what rims these are?
  193. dizzzzzzzzzzzy
  194. Plugz and wires
  195. DIY Intakes anyone?
  196. Oil leak...??
  197. bench bleeding
  198. no pressure on clutch pedal...
  199. looking to buy a 4th gen
  200. legend 2piston caliper in 4th gen
  201. 02 Sensor worth changing?
  202. Prelude Grills
  203. 2001 Lude burning oil...
  204. cel #6 coolent temp sensor
  205. 92 prelude no spark
  206. CEL
  207. paper clip cel on 97 prelude
  208. Honda Prelude SH
  209. Function Form 32way adjus. VS D2 RACING SPORTS RS 36 WAY adjus.
  210. JDM F22B, no spark
  211. disappearing coolant, head gasket?
  212. IAluder95s Build thread H23vtec Turbo
  213. wheel help !
  214. clutch bleeding
  215. starting problems in the mourning!!!!1
  216. Running rich?
  217. 90 Prelude VSS Problems
  218. 5th gen shocks fit on a 4th gen?
  219. How do I change 98' thermostate and temp sensor?
  220. Can some one explain why oversized valves are good?
  221. Those that have upgraded their brakes
  222. h23 4th gen problems. please help.
  223. No Heat!
  224. idle problem
  225. multiple suspention questions
  226. how to take off oil pan and exhaust
  227. Heater Problems-4th Gen
  228. Radio error after disconnecting/connecting the battery!
  229. cheap hp gains
  230. AC CONTROL PANEL LIGHTS NOT WORKING.
  231. High RPM's anybody??!
  232. H22A4 RUNNING RICH.....HELP!!!
  233. Looking for 1 OEM rim for 1997 Prelude SH model!!
  234. Help with G3 Prelude head swap B20A vs B20A5
  235. KYB Shocks For '97
  236. Cv axle gone wrong!...
  237. Alpine components or speakers
  238. H22 problem and vss question
  239. Change in exhaust tone / loss of power / Rough idle
  240. carbon fiber hood question
  241. FINALLY AFTER A YEAR IT RUNS!
  242. Cool Weather Starting Issues -- Sorting through issues
  243. tranns & atts drain plugs?
  244. 4th Gen Prelude, where to start.
  245. spring rates
  246. a bit of white smoke when Vtec kicks in
  247. spring question
  248. Is there such a thing called BBSquad?
  249. stock h22
  250. 96 h22 ecu
