PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 [238] 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. h22 thermostat
  2. intake question
  3. What would happen if you palt the IACV on the manifold?
  4. What is the diameter of stock exhaust????
  5. removing the atts package
  6. Drop-in gears for stock lude trannies
  7. h23 turbo manifold question
  8. best header design for the h23 (search friendly)...
  9. control arm
  10. General Questions Prelude H22 Swap and Mods
  11. Skunk2 Response on IM
  12. field sfc-vtec controller problems!! (searched no results)
  13. H&R race springs
  14. having trouble starting....
  15. 89 Prelude Help!! Mystery can't be solved by mechanics or Honda Class Instructor!
  16. xenons
  17. What Height?
  18. What roll cage/bar are you 4th gen Owners using?
  19. Jackson Racing SS Brake Lines
  20. Denso Iridium: IK16 or IK20 for 1996 H22A1?
  21. Please help all u H22A lovers please some advice on cam and ignition timings!
  22. Cracked oem rim??
  23. Look what I did :(
  24. i need confirmation: 5th gen rear strut bar fits in 4th gen
  25. Tires Scraping
  26. Front ST Sway Install
  27. Clutch Recommendation for All Motor and Nitrous Build
  28. loctite for pressure plate?
  29. Will 90 prelude starter fit on 95 prelude si?
  30. oil
  31. gasoline getting into my oil?!?
  32. Replaced Axle Shaft - New Vibration Now
  33. oil burning/rebuild questions
  34. oil burning ruins cat?
  35. Tanabe Suspension...
  36. auto-manual swap ...please help!!!!
  37. Car wont start, need help ASAP
  38. B21A1 rebuild
  39. ABS and TCS light on with ignition turned to on, Help!
  40. extra power for 4th and 5th gen preludes (rewirering intake tempreture sensor)
  41. Question about 4th gen front / rear knuckles & ball joints
  42. bumper lights? 4th gen
  43. s2k rims fit on 98 prelude SH?
  44. Can i use this radiator????
  45. JDM H22A wiring question....
  46. anyone running an HKS Sport Exhaust?
  47. Changing from external coil to internal problems!!
  48. h22 itb size
  49. Urgent: Need 3rd gen CEL code deciphered
  50. Is the prelude capable?
  51. hard to get in every gear!
  52. jdm h22a/ 93 civic swap
  53. broken knuckle?
  54. 5th Gen: Help me identify this part!
  55. going to look at a lude' what should I look for?
  56. Tips on removing window tint?
  57. How to hook up horn with Momo hub in a 92 Prelude?
  58. Corner light bulb replacement?
  59. cruise control question
  60. Fuel Filter problems...
  61. i think my 93vtec hates me :(
  62. 2001 sh cams?
  63. 5th gen getting lean error code
  64. IT'S ALIVE!!!! Fully buily H23 not H22 UP AND RUNNING
  65. clutch for 93 prelude si
  66. Broke off a a nut/part of bolt holding fuel rail down, please help!
  67. maillfunktion in Brake system
  68. VTEC Doesnt kick like it should?
  69. FINALLY HEAD IS PUT BACK TOGETHER!!started it up....
  70. ignition timing
  71. I want to purchase something in the For Sale Section
  72. 1988 Honda Prelude
  73. issues w/ removing ac?
  74. B series in a 3rd gen lude
  75. 4th gen OEM CD player
  76. anyone near orem utah that can help with timing belt?
  77. jacking up da motor?!?!?
  78. Euro r Intake manifold Question?????
  79. Turbo Retarding
  80. clutch problem (didn't find anything in search)
  81. Suspension Help...
  82. JDM Prelude Door sills
  83. got egr valve code, replaced new one but still throwing code.
  84. Upgrading header worth it for my setup??
  85. *** Question on Offset for 16" Wheels ***
  86. broken timing belt. need advice on mod that can be done along with the repairing
  87. how can you tell the difference between a h22 that has 200 hp and the one that has 220hp besides the
  88. Crower Stage 3 Cams and Nitrous?
  89. can't rev pass 6500....
  90. RSX Wheels on 5th Gen?
  91. Nitrous or Turbo?
  92. 4th gen front lip spoiler
  93. Spoiler full of water?
  94. type of tranny fluid for H22A LSD tranny?
  95. Tranny codes
  96. Differences between S2000 87mm pistons, and H22a 87mm pistons
  97. Gearbox and driveshaft VS HP
  98. 5th gen emissions
  99. Electronic problems, need HELP Please !!!!
  100. What engine do you rcomend for forced induction H23 or H22
  101. differance between LSD trans and non LSD
  102. Idle Problem?
  103. CANT TAKE OFF MY H22A4 OIL PAN!!
  104. supporting the motor while dropping tranny?
  105. Type S Pistons on old rods
  106. Exedy Cerametallic Installation Instructions
  107. Radiator?
  108. JDM climate controls in 4th gen.
  109. Free greddy exaust
  110. peak and hold vs saturated
  111. Need help guys and gals (optima battery)
  112. spindle nut size?
  113. h22 tranny problems.....grinding in every gear
  114. Turbo Misfire Question
  115. Replace Driver side Door Window, How Much???
  116. having trouble removing rear strut assy. 94 lude..HELP
  117. bad starter?
  118. 4th gen glove box
  119. turbo problem
  120. ECU code 20
  121. What is this?
  122. Prelude Bore Q?
  123. the top speed
  124. h23 vtec/pistons/rods/compression ratio???
  125. Will old legend wheels clear prelude calipers?
  126. MSD coil help
  127. Degree's On My Timing Gears?
  128. 96 jdm H22a injectors
  129. 92-96 Prelude Si NON-VTEC ECU chip?????
  130. 92-93 lude si motor crank question
  131. i need some honest advice - keep the prelude?
  132. Temperature Question
  133. 88 Prelude 2.0Si?????help
  134. HEADLIGHT PROBLEMS...
  135. Is Pillowball worth it?
  136. Prelude, 4th gen 95..FOG LIGHTS-install!! RELAY IS GOING CRAZY!!!help
  137. how would you know if you have a bent valve?
  138. torque specs for oem flywheel on h23 tranny?
  139. Engine Management.
  140. CM clutches & Flywheel
  141. clicking noise coming from front suspension... more info inside
  142. How much does the JUN titanium muffler go for that the JUN prelude has?
  143. How much was your 5th gen Prelude?
  144. Exhaust header studs x3 for lower header section
  145. People with 92-93 Preludes: Cupholder question
  146. is the VSS in the 4th gen the same as the 5th gen?
  147. IS JDM P72 GSR ECU Compatible w/H22A
  148. what will my comression be?
  149. Timing Belt ?'s
  150. F20 QUESTION
  151. Valve Tick from over Rev. 11000+
  152. Bellhousing Indentification
  153. Help asap..do i need a resistor box
  154. Just got the motor back in the car, and it wont rev over 1500.
  155. PIC REQUEST: 5th gen Front and Rear strut tower bar pics installed
  156. Prelude '98 oil consumption
  157. 1990 Prelude SI B21A1 motor- O2 sensor problems?
  158. H22 type-R Motor valve train question
  159. Prulude Type SH rear stock amp.
  160. hearing some weird noise, anything to be worried about?
  161. electrical problems...please help.
  162. CPS?? CPK?? H22a
  163. Igniter/ECU
  164. Primary O2 Sensor Heater- Circuit Malfunction
  165. Short ram or CAI intake
  166. b20a4
  167. Prelude and autox?
  168. accord injectors in h23 vtec?
  169. supercharger question
  170. Overdecked/milled block question???
  171. S2000 Damper Pulley on H22
  172. Hytech vs. SMP review
  173. A testament to the Lude's Gas Mileage
  174. how to tell what type-s cams to get
  175. Crower 2.5L Stroker Kit
  176. Type S intake where to buy one
  177. question about TSB and hondacare
  178. good rod and piston combo?
  179. question about auto to manual differences
  180. 94+ console conversion complete
  181. What Dont I need? Cleaning up the engine bay.
  182. Mugen twin loop for 4th gen?
  183. got my helms but i still have a few ?s...
  184. what h22 parts do people want tested?
  185. Strange noises needing some Lov'n
  186. 1989 Honda prelude engine stroke *help*
  187. Recall item
  188. Typical max oil pressure for 5th gens??
  189. HELP!!!!!! PLEASE!!!!!!!!?????
  190. JDM H22a swap, motor won't fire up!!??
  191. 5 GEN RADIATOR SHROUD - pics inside 56k BEWARE
  192. high whp h22 turbo's...whos head gasket you run?
  193. F22 oil pan
  194. sparkplugs
  195. Need some help: Setting timing on H22a
  196. 37820-P75-A02 obdI or II
  197. what is the type s cams valve adjustment specs and can the cams be used with stock valve springs on
  198. milled head with auto tensioner
  199. Clutch Choice?
  200. Eibach Pro-Kit or H & R Sport?...
  201. How fast for 14,000?
  202. JDM F22B HP
  203. Buying Salvaged 2000 Prelude?
  204. prelude/accord swap
  205. help with crazy idle....
  206. re-locating battery to trunk
  207. Dynoed my car today
  208. Buying A H22a4 Head...Does It Look Good?
  209. compresion psi on a f22 prelude
  210. Spring Install
  211. did swap, but having starting problems
  212. can you strip paint from CF hood
  213. AEM CAI junk?
  214. Energy Suspension
  215. Greddy Turbo for 5th gen lude
  216. tps 1990 2.0 si
  217. ripped lower arm ball joints
  218. need H22 height
  219. TSB list for 2001 SH.
  220. Quick question about a turbo
  221. Displacement
  222. TB install/uninstall
  223. check engine light..
  224. H22 Break In Period (New block)
  225. fuel/tuning vafc
  226. 91 prelude header
  227. need help identifying tming components.
  228. Specs please asap~!
  229. i was thinkin of buyin a 98 turbo lude
  230. necessary to set tdc on oil and water pump??
  231. i think i screwed up again!
  232. reving up
  233. Pin out
  234. h23 tensioner install, i got a question
  235. H3c to H3 conversion?
  236. Need advice buying '97 - '98 Prelude
  237. Doin a major tune-up on 00 Prelude - help with plug choice!
  238. H22 N/A,Turbo,Nitros BUILD UP list
  239. Same size headers on 2000 /2001
  240. build my blown motor or buy a JDM h22?
  241. 2nd and 3rd gen prelude owners
  242. prelude sh aem intake for h23
  243. skunk2 cam problem..please help asap...
  244. Cam Gears on Turbo H23?
  245. checking codes
  246. gear box again.
  247. Torque & Horse power an AT tranny can handle ?
  248. 1990 2.0 Si
  249. ignition/computer problems
  250. nitrous for 2000 honda prelude auto
