Vibrations on steering wheel, brake, gas pedals.
Old Oct 24, 2003 | 08:28 AM
oes's Avatar
oes
Default Vibrations on steering wheel, brake, gas pedals.
It is not an all the time thing, but lately my steering wheel, gas and brake pedal has been vibrating. It only happens when im doing around 50+mph and when I start to hit the brakes it also occurs. It could be alignment, but I dont want to have to take it to a shop and have them look at it and tell me its not that. What are some possible causes of the vibrations?
Old Oct 24, 2003 | 08:32 AM
Behan's Avatar
Default Re: Vibrations on steering wheel, brake, gas pedals. (oes)
if it only happens at speed then i would check to see if your tires are balanced.
Old Oct 24, 2003 | 08:46 AM
AndyD's Avatar
Default Re: Vibrations on steering wheel, brake, gas pedals. (93preludevtec)
Check your CV Joints. See if they are leaking.
Old Oct 24, 2003 | 08:50 AM
4glude's Avatar
Default Re: Vibrations on steering wheel, brake, gas pedals. (AndyD)
yes i would also say that the tires probably need balancing.. its totally the same with what's happening to my lude right now..
anyone knows if its not safe driving with unbalance tires?
coz im saving up for new rotas
Old Oct 24, 2003 | 08:53 AM
Behan's Avatar
Default Re: Vibrations on steering wheel, brake, gas pedals. (4glude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4glude &raquo;</TD></TR><TR><TD CLASS="quote">
coz im saving up for new rotas</TD></TR></TABLE>
a tire shop will balance you tires for a few dollars
Daboi630's Avatar
same thing with me.
steering wheel would shake when i apply the brakes around highway speeds. but that went away when i purchased new rotors for my car.
could be tires unbalanced, could be alignment. but mine was in need of new rotors.
Old Oct 24, 2003 | 09:17 AM
oes's Avatar
oes
I just got some new wheels and tires a couple weeks ago, and they came balanced but it would probably be a good idea and get them rebalanced now that ive ran on them for many miles. I did drive all the way to TN from NC not too long after I got the wheels on.
Old Oct 24, 2003 | 09:20 AM
4glude's Avatar
Default Re: Vibrations on steering wheel, brake, gas pedals. (Daboi630)
mine vibrates all the time but mostly low speed at around 30-60. anyone knows where i can get 16" slipstream for less than 500? i only got 250 right now..
Old Oct 25, 2003 | 09:39 AM
sambam27's Avatar
it would either be balance, or CV boots. but if you say your slowing down, you need to get new rotors...becaus i had the same problem
whiteformula98
11
Nov 9, 2015 06:58 AM
sprtbiker
19
Jul 24, 2006 07:11 AM
upwind
May 12, 2005 06:10 PM
SoCal ITR
Feb 22, 2005 01:01 AM
kingseth2
Jul 2, 2003 04:22 AM
