PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 [262] 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. My new Brembo blanks just warped!!
  2. Removing ABS?
  3. HPOA Closed down
  4. Can anyone fax me the couple of pages out of the helms manual for...
  5. What is the best camber kit for my 2001 Prelude ?
  6. how do i take out the cruise control?
  7. STOCK BLOCK RPMS!
  8. Aftermarket Tach...
  9. Rear upper tie/strut bar
  10. How much power can stock internals handle
  11. how much is it to detail a car??? DAMNIT IM STUPID
  12. Question about putting my car in reverse
  13. 4th gen wiring... window/lock
  14. HELP! GAUGES..
  15. 1990 honda prelude si
  16. 4th gen prelude body kit 4 sale
  17. motor will not bolt up for nothing!!! h23a! grrr
  18. help...
  19. 94 Lude...brakes feels very mushy???why?
  20. help identifying this TB!!!!!
  21. Which coilovers are Better?
  22. Upgrading brakes... AEM Brake Kit wont fit???
  23. Will 92-96 ground control coilover and tokico shocks fit 97 and up?
  24. need help with jdm f22b dohc
  25. Searched: Ingalls Camber kit question
  26. This is why I hate some mechanics
  27. slight running problem
  28. fast idle thermo valve question?
  29. AEM v2 cold air intake
  30. Poor mileage caused by coolant temperature sensor?
  31. I have searched the search, and need a diy for install on power steering.
  32. Thrust Washers/Bearings
  33. Dyno results H22A with Crower Stage 2 cams
  34. Need torque specs rod bernings an main bernings???
  35. what brand of oil?
  36. OK suspension question (again)
  37. Will Koni or KYB fit SH?
  38. What size is my throttle body?
  39. The Euro Intake Manifold?!
  40. no vtec ecu will work but a non vtec will
  41. Project RWD Prelude
  42. Cold Cranking amps of 92 Lude Battery?
  43. Spoon Replica Lip
  44. H22A how many miles before they die?
  45. dyno/track numbers
  46. Need Insight
  47. WTB: 5th gen OEM kit
  48. Anyone use 85 /15 fuel?
  49. Help need 5th gen pics!!
  50. Fuel Filter question
  51. **need help with sunroof removal**
  52. venom 400
  53. Kteller8's Mandrel Bent setups....anyone have pictures of installed setups?
  54. quick question - is there a 4th gen vtec lude?
  55. Companies that make custom fit prelude floormats?
  56. Weight Loss
  57. JDM H22 intake manifold and EGR experts needed!!!
  58. where is this?? i can't find it..
  59. valve adjustment, now white smoke!
  60. 24.5x8x15 slicks fit on a 4th gen thats lowered
  61. Tranny Fluid
  62. what other wears old cars have
  63. Prelude Forum users, update on Mods other stuff..
  64. Stock h23a1 injector size
  65. 94 VTEC - ABS system on and off
  66. Cylinder Head
  67. 1992 Airbags!!!!
  68. How To: Cleaning Air Filter
  69. Need help with stereo wire diagram for 92 Prelude
  70. dc sports short shift adapter vs obx short shifter
  71. 92 Prelude Master Cylinder vs. 93 VTEC?
  72. bad idle problem, stalls when at stop or cruising
  73. need engine!!!!!!!!!!!!! for 91 prelude si b21a1
  74. the groves on a thrust berings face tords the rod or face out on the crank sharft? H23a
  75. Help! I just got into an accident and I need some help with parts.
  76. Tires....Best?
  77. clutch recommendation???
  78. MODERATOR APPROVED - FS: 2.5in stainless steel exhaust for 97 and up prelude.
  79. simple yes or no...H22 crank compatible with H23 block
  80. NEED header/manifold
  81. What works w/ what?
  82. Spring Install
  83. 12:1 Pistons in a h22a. Good idea?
  84. When swapping cams what seals are needed to be replaced.
  85. has anyone brought the turbonator for extra hp
  86. Do 97 ludes have interior cabin A/C filters?
  87. What tranny code is this?
  88. exhaust question?
  89. b21a1 vtec head swap
  90. secondary runner & JRSC?
  91. help please ecu code problems..............
  92. Infamous Fuel Relay on 92 Si
  93. T-shirts - you decide.
  94. Question about stock brake rotors
  95. fried ecu's.. who can fix them??
  96. I fried my ecu.. AGAIN!
  97. prelude auto tranny's
  98. New Clutch Installed Help
  99. vrd racing wheels
  100. Hello!! im new
  101. throttle bodies are they any good
  102. TEIN SS COILOVER INSTALL. ANYONE HAVE HOW TO on this??????
  103. [WTB]Knock Sensor for h23 block
  104. Bent Valves
  105. JUN H22A CAMS FOR SALE
  106. EXEDY RACING CLUTCH? YES...NO?
  107. Espelir exhaust
  108. Aftermarket Catalytic Converters for OBDII Preludes???
  109. Fuel Rail/Air Intake
  110. Wobbling sound coming from up front?
  111. NEED HELP NOW!
  112. quick question
  113. Vtec controller???
  114. Found a quick and easy solution to rough idle caused by the EACV.
  115. engine theory question - longer stroke (h23 block) resists detonation more?
  116. 92-96 Prelude full Combat body kit 4SALE
  117. suspension problem
  118. yes, my nose is huge...
  119. ANYONE USING AN EBAY HEADER? SERIOUS, IN A ROUGH SPOT.
  120. H22 Aftermarket? All motor options?
  121. how to: remove back seat
  122. Worn out brake pads??
  123. 1987 Prelude Question
  124. H22 EuroR Intake Manifold Single Runner? How about on a F20B?
  125. where to buy nitrous hose
  126. Wheel offset? what does it do?
  127. For those of you with after market ignition...
  128. Rear Main seal
  129. Need torque specs for h23a flywheel...an rod bernings???
  130. who's running h23 crank in h22?
  131. need help quick please...
  132. ISO OBD2 prelude injectors
  133. HELP!!!!! trying to change exhaust manifold gasket. (h23)
  134. Looking to buy used mugen exhaust and header. cash in hand
  135. Oil in distributor?
  136. Problem with lude... randomly turns off????
  137. Tranny fluid for 1992 Lude Si?
  138. H22A1 COOLANT AND EGT
  139. four speed sport shift vs. five speed
  140. How are KYB GR-2 shocks for 92-96 Preludes?
  141. 1986 prelude Si Auto trans/throttle cable?
  142. compresion test wows
  143. 130k miles on alternator.....should I replace it or rebuild it?
  144. Slid into a curb, need advise...
  145. Turn AC off when you turn your car off?
  146. SWEET! :: massive oil leak
  147. 13" wheels on a vtec prelude
  148. can anyone give me some suggestions?
  149. Internal/external wastegate question
  150. turbo cams
  151. vtec oil pressure code 22
  152. Auto-X'ing results for the day...
  153. 97+ vtec in 95?
  154. not tech related. front lip damage
  155. Found oil in spark plug holes...
  156. What exhaust is this on the halfway down the page silver prelude?
  157. Need help on car parts
  158. LSD tranny on JDM H22A?
  159. n e 1 use f22b1 crank in there h23?
  160. ATTS and mods
  161. Spoolin no more.... motor is fubar
  162. 1997+ pic thread?
  163. vtec head?????
  164. "maintenance required"
  165. Too much bad shit happens to my PRELUDE... Got into an ACCIDENT. Who's @ FAULT?
  166. Value Question
  167. a boosted H22 oil pump failure
  168. mugen cat back exhaust and headers anyone got them?
  169. valves possibly?
  170. 1989 Prelude Dual Carb Problem
  171. Rear rim damage
  172. wtb: h22a head
  173. clutch pros please help me ....
  174. Dumb question??
  175. jdm headlights
  176. Anybody knows where to get a Haltech E6k For a good price
  177. Mandrel Bent VS. Stock Piping.....
  178. 1985 Prelude
  179. turbo manifold for h23a
  180. Noise from my resonator
  181. I found a 97 prelude sir tranny. Could someone give me the specs and some info please/
  182. 4th gen shift linkage...
  183. The definitive Prelude ECU choice / Hondata Info Post
  184. 86Prelude SI....engine code BT???? pls lude experts help help!
  185. H22 or H23?
  186. Help me, for i drive like poop
  187. Anyone selling 97+ H22a injectors? Help me out
  188. Throwout bearing going?
  189. engine opinions
  190. anyone here succesfully done a Legend GS/NSX brake install???
  191. Need your help, experience, advice, opinion, etc
  192. H23 time to Re-Sleeve... or not? #2 & 3 rods snapped
  193. ECU code 20
  194. will the h22a4 block bolt up to my h23a tranny
  195. adjusting valves!!
  196. spoon replica??
  197. A good buy?
  198. Putting 3rd jdm 2.0 engine in a 97 prelude....
  199. Accord Euro R tranny?
  200. Camber Kit?
  201. Going all out on the ALL Motor Lude, opinions wanted..thanks
  202. Free AEM Intake
  203. GOOD Price?....$139 Front and $139 Rear....Koni Yellows
  204. When A/C isnt working, what might be the problem?
  205. getting out driveshaft from the ATTS unit????
  206. quick a/f gauge question-- nothing good in search
  207. thinking of dynoing....
  208. how many quarts?
  209. Cam Recommendations All Motor H22A
  210. Does Anyone Know
  211. Dyno Results -> 216whp/171wtq
  212. Dyno last weekend
  213. Fast Idle Valve write-up
  214. P28 ecu(tried a search)
  215. Clutch sticking and tranny popping out of gear
  216. side mirrors
  217. Used A/C compressor for 3rd gen
  218. H22A Distributor
  219. Carfax help
  220. 01 windshields
  221. do i got the sh lip?
  222. going past redline?
  223. H23 Help needed
  224. H22 or keep h23?
  225. People with AEM Fuel Pressure Regulators and big pumps......
  226. Knock Sensor Needed ASAP
  227. Adapter nut for mounting a fuel pressure gauge?
  228. Adjusting door hinge?
  229. NEED help.
  230. whats the deal with ecu swaps...
  231. Bad Camber - Need Suggestions?
  232. attn. 4bidden
  233. Suspension VS. Custom Exhaust System........what should I get
  234. JDM H22 ECU....will a auto ECU work for manual???
  235. Any interest in a Euro R Intake manifold installation kit?
  236. P13 vs P28
  237. how do I become a member
  238. Just messed up my Lude
  239. What Is This On The Back Of My Manifold?
  240. differnce between euro R tranny and jdm h22 tranny
  241. o/t:: JDM Climate Control
  242. 1st Time Brake Install
  243. What do you guys think about s2k seats in a fifth gen lude.
  244. High Flow Catalytic Converter
  245. Hey all, just got a Prelude!
  246. H23 Prelude vs. 2001 D17a2 CIVIC...who would win?
  247. where's a good place to buy...
  248. Anyone have a stock 94 fog light switch? relay?
  249. Does low Fuel Level in your tank effects your fuel pressure??
  250. I need to do a test fit on an ATTS Prelude
