PDA
View Full Version : Honda Prelude
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 1988 honda prelude fuel supply problems
  2. power steering hoses
  3. Timing belt
  4. Dirt track my prelude
  5. Purchase possibility
  6. Thump/squeak noise while shifting
  7. Brake lights always on
  8. 4th gen lude i built a while back
  9. Should i buy a 2001 honda prelude for 800
  10. H trans hp
  11. Not fully heating
  12. Brake fluid leak
  13. Power door locks not working
  14. Is H22a1 to H23 vtec a direct swap
  15. ‘97 2.2 Prelude vti auto box problems
  16. M2a5 5th gear in m2b4 compatability.
  17. what are the common issues with 1990 prelude S with carb?
  18. Won't go into gear in the A.M
  19. 88-91 rear ash tray
  20. 2001 H22a overheating issue
  21. h22A In 97 Prelude What Harness And what to do about CPS
  22. Interchangeable parts
  23. 4th gen f20b swap help
  24. Tire and wheel sizing questions.
  25. H22A Crank But No Start
  26. 92 prelude with h22a swap ECU QUESTIONS
  27. idle issues and stallling out after cleaning the iac and doing a coolant bleed
  28. H23 Valve Seals
  29. help cel throwing 5 diff codes
  30. No power after starter install 95 lude
  31. RPM throttle body
  32. Speedo Needle EL cluster
  33. New to Honda Prelude, Could Use Some Serious Help
  34. Wheel bearing help
  35. wheel alignment
  36. 1989 Prelude Compressor
  37. H23a Dohc vtec. Help me!
  38. 92 prelude build
  39. 98 Prelude SH - HELP!!!
  40. I have a 5th gen lude with h22a1 engine broke timing belt while driving.
  41. 4th gen prelude “overheating problems”
  42. high rpms low power 97 honda prelude
  43. What happens when I install skunk2 tuner camshafts?
  44. 89 Prelude engine oil cooling hoses?
  45. I have a 95 prelude with a warped head need help
  46. Can't find JDM H22A Vehicle Speed Sensor location
  47. 98 Prelude Type SH
  48. 4th/5th Rear Suspension Compatibility?
  49. Want to Turbo JDM H22A
  50. Questions about engine swap... Pros and cons of Euro R or JDM 4th gen engine swap
  51. abs diagnosis port location
  52. Honda prelude is it rare to have a h22A4 in the 97
  53. Master Cylinder Replacement
  54. Howdy and first question . .
  55. Not getting spark
  56. throttle adjustment
  57. F22A1 head swap
  58. Prelude sh and LSD?
  59. Help with CEL code 43 "Fuel supply system"?
  60. H22a4 turbo install?
  61. 2000 Honda prelude signals and wipers stopped working
  62. Jdm F22b DOHC Timing too advanced Need help trouble shooting
  63. Alarm install - Where is passenger side door harness located on 93 vtec?
  64. Can u add vtec to a h23a1 from a prelude si.
  65. 5th Gen 2000 SH WHEEL AND TIRE UPGRADE
  66. Dog box help
  67. hey guys...I recently bought a 2001 Honda prelude with apparently a H22z1 engine.
  68. 1988 Honda Prelude (4WS) electric conversion
  69. 2001 prelude misfire/backfire, rough idle, decreased power etc
  70. Power window wiring, and blower resistor
  71. Thread closed.
  72. B series head on H series block
  73. Help? loss of power at freeway speeds
  74. Swapping JDM H22a into my JDM F22b 4th gen Prelude
  75. Shifter problem, any help.?
  76. for sale
  77. H23a Bluetop
  78. Engine will not start after replacing head
  79. Shifter gets sticky when warm?
  80. 00 automatic misfiring mystery, Please help!
  81. Possibly buying a 2001 Honda Prelude
  82. F20b timing
  83. Shaft seal for distributor H23A1?
  84. NO BRAKES, NEED HELP!!!
  85. Injector tick?
  86. VSS and EL cluster. Speedo is now off.
  87. Surprising Compression Numbers
  88. H22 gearsets/ solutions for the big power guys
  89. Temp gauge always reads cold.
  90. 1993 prelude no power fuel temp gauge
  91. Circle track 98/01 5sp idle is 4500 it was a surge issue my dad replaced the antifree
  92. I have a 2000 honda prelude and I need some help on wiring my new msd igniting coil?
  93. 94 Prelude Issues?
  94. H22 swaped 92 si won't start. Cooling fan comes on and stays on.
  95. Honda Prelude 2001
  96. 1995 prelude dies after warm up help
  97. 93 Prelude SI distributer noise? (video)
  98. Running super rich
  99. Can someone help
  100. My Honda Prelude N/A build
  101. paint
  102. 93 prelude si h23 docs lower timing belt cover
  103. Cruise Light on Cluster question
  104. My 2000 Honda prelude bogs and dies on acceleration
  105. sticky steering
  106. Will this turbo fit my 95 Life
  107. VSS Power Steering Hoses
  108. D4 light started blinking while driving
  109. What injectors and TB for h22 build
  110. My atts light is on where can i buy a new atts?
  111. 99 Prelude SH with 04 Accord Engine and Tranny Swap Axle Popping out Issues
  112. H22a4 Anyone know where this part goes?
  113. 5Th gen key fob?
  114. how do i tune 98 base prelude
  115. Should I buy and is what should I look out for? (4th Gen Prelude)
  116. 96 honda prelude si h23a1
  117. Anyone recognize this connecting rod?
  118. 94 Eg H22A1 Swap looking for turbo advice.
  119. Constant power to windows and roof help???? 98 prelude
  120. Anyone happen to swap a jdm dohc F20A into a 95 prelude to replace the H23?
  121. H22 11.5:1 compression. Injector size?
  122. New rods/pistons. Engine Starts then immediately dies?
  123. Pros of Putting an H22A in an SH
  124. 03 honda will crank but wont start...
  125. H22a4 Head On H22a block
  126. Super tech springs with Brian Crower steel retainers on h22?
  127. 93 Locking/Unlock Door Problem
  128. 1998 Honda Prelude OBD2 Fuse?
  129. 95 Prelude race only ECU wiring
  130. Can I ask for help on 4th gen. Prelude part prices?
  131. 92-93 Prelude Si Center Caps
  132. Head variation questions - P13 vs PDE
  133. Prelude Alternator: 3rd Gen How To
  134. Prelude marketplace dead?
  135. 2001 Prelude Type SH: Inner Tire Rod Torque Specifications
  136. Reusing h22a stock valves?
  137. Pad Recommendations
  138. H23 pistons with h22a1 crank and rods to lower compression for boost
  139. F22a1 Turbo Build
  140. Intermittent loss of spark
  141. Clutch
  142. Oil wheres it all going?????
  143. Need help installing the bell housing. Just finished installing a new clutch kit.
  144. 4 wheel steering
  145. H22a Euro R swap DYNO TUNE
  146. Where can I get a h22a4.
  147. Need some questions answered about 5 lug conversion
  148. 1992 Prelude manual H-series trans won't shift into 3rd or 4th
  149. 4G Prelude Window Stuck Down
  150. H22 Swap No Start
  151. leaking coolant behind engine block in straight beam!?
  152. 91 prelude no start mystery
  153. tranny question
  154. Power steering pump making a wild noise?
  155. 1999 Prelude Base no start
  156. H22a4 skunk2 intake manifold problems
  157. 97 Honda Prelude Knock Sensor
  158. 1986 honda prelude rough idle and intermittent poor driveability
  159. h22a4 problem
  160. H22a4 valve springs
  161. 1997 Prelude dies only on the freeway
  162. Alternator rotor still salvageable?
  163. Cheap power b21a1
  164. Dashboard lights and low lights went out
  165. Oil pump won't spin by hand
  166. H2u5 worth it?
  167. 93 prelude high idle problem
  168. h22a4 possible bent rod
  169. Cleaning MAP sensor on 87 Prelude
  170. h22a oil pan
  171. My prelude stalls when I come to a stop, whats wrong with it?
  172. Is a 4th gen preludes hub assembly the same size as a 5th gen?
  173. 1994 Prelude Advice/Options
  174. 98 Prelude h22 turbo shutoff sometimes?
  175. H22 JDM Internal Coil Distributor, where to buy?
  176. should i rebuild my b21a1 engine?
  177. M2L5 Transmission Fitment?
  178. Where do I even start this project..
  179. Gap in ball joint
  180. Sideview Mirror Glass
  181. paint chips showing up everywhere??
  182. F22b2 crank H22a1 block
  183. 01 Prelude ecu/smog issues - CALIFORNIA
  184. need help about 1991 prelude headlight
  185. Compression test?
  186. Would you take a chance on this '97 rebuilt auto?
  187. H23a vtec blue top and stock p5m ecu
  188. car recommendation (involves high miles prelude and a prius)
  189. H22 11:5.1 CR What spark plug gap?
  190. H22 Rebuild, No Fuel Pressure = Frustration!
  191. Alternator question
  192. 1996 Prelude VTEC Rescue/Revival
  193. Advice Needed: 5th Gen Lowering Springs/Coilovers
  194. Help!! H23a3
  195. H23A3 honda prelude
  196. Weber for 89 prelude?
  197. 01' prelude SH drivers side axle seal part #?
  198. 98 prelude sticky clutch
  199. prelude 5th gen windows wont roll down
  200. Please help with prelude, clueless on issue.
  201. 99 Prelude no start
  202. 96 4gen prelude timing belt snaps So new motor
  203. 3rd gen prelude b20a5 moddable?
  204. Looking for Hytech Replica header
  205. 1994 prelude with 1998 h23a motor
  206. Good distributor for 194 Prelude SI H23A1?
  207. Rebuild my 2000sh motor or swap in a jdm version ??
  208. Honda Prelude H22a1 rough Idle and misfiring
  209. Fuel gauge and temp gauge not working
  210. Hondata CPR Kits
  211. P/S cooler removal
  212. 1982 Needs a Nudge
  213. Lowering a 5th Gen, Camber Specs/Kits
  214. Where is ECT Switch A blue/red wire on prelude 93
  215. H23A1 possibly dead?
  216. 5th gen build question
  217. Key chime
  218. Locking rods
  219. Save my transmission
  220. K swapping Honda Prelude BA8
  221. Prelude SH rear struts
  222. 94 lude si seized?
  223. 1990 Honda Prelude stall only while driving
  224. Is anyone else rollin a lowered 5th gen?
  225. Vtec dosent what to engage after head swap
  226. Distributor Compatibility
  227. 98 Prelude turbo installation question
  228. 4th Gen. JDM half antenna mast replacement?? Help..
  229. 1997 Prelude Auto Tranmission Tough to get into gear when Cold
  230. Fastest prelude 5g stock chassis
  231. 94 preludes no spark need help
  232. Bad smell from exhaust 1990 Prelude
  233. 2000 Prelude double din + speaker options
  234. H22/H23 build w mahles still going!
  235. BB6 Prelude Turbo Manifolds
  236. Pic Request: 4th gen stock catalytic converter
  237. Honda Prelude 4th gen 2.0 l. upgrade help?
  238. 4w
  239. 99 Prelude SH Power Steering Cooler
  240. '98 Prelude - Distributor Leak
  241. H22A4 aluminum oil pan into H22A
  242. Car lights intermittently come on
  243. sign of a dying alternator?
  244. 89 prelude si
  245. USDM Honda Prelude Type S?????
  246. Honda Prelude Charge light problem
  247. 1993 prelude s
  248. Honda prelud twincharged build.
  249. honda prelude 2.0 ex
  250. Project Prelute
