View Full Version : Honda Prelude
- Air Condition problem 98 Prelude.
- I have no idea what has happened
- FAV6052 build thread
- quick cooling question.
- any 4th gens with oem fogs and intercooler piping or try the accord fogs?
- expansion valve for 92 prelude
- SH w/ chipped p28 ECU
- Interior Lighting: Guages, climate control and clock
- Help: Idle too low
- 4g 4ws rear suspension ?
- very low idle at start up, any ideas???
- can a power steering hose for a h23 fit on a h22 engine
- rear lower tie bar
- H22 question
- Coilovers
- drag wheels offset: need help
- EVAP Purge Control Solenoid
- Discussion: h23 crank
- o2/fuel code after rebuild. Need help
- h23a vtec valve lash?
- oil pressure right??? maybe air in the lines???
- where is the coolant bleeder nut?
- Post Some Pics Of Your 4th Gen Ludes On Offset Wheels Plz!!!
- Ebay h23 header pipe 65 dollars
- serious problem
- 5th-Gen Prelude
- Need a new engine...
- Help on H22 fuel rail n injector
- will a stock 5th gen prelude radio plug in to a 95 accord
- Rear Veiw Mirror
- H22A engine oil cooler, nut size??
- Drained block and rad of coolant. How do I refill block?
- im a newbe to hondas just bought a93 prelude and need some info.
- Idle problem/ open loop
- how to recognize a H22a ??
- tranny problem
- 01 sh tranny question
- h22 not running properly
- HELP - cel knock sensor
- JDM P13 ECU: How to eliminate the top speed limiter?
- Weird Idle...
- no 1 cyl tdc
- It's hot here and my prelude is doing weird things...
- IAT Sensor location?
- spark plug cover?
- Headlight woes, low-beams not working but when hi-beams are on they work. [urgent]
- Heater hose problems on a 1998 Prelude Base
- h23 ac compressor?
- H23 crank / turbo basics question?
- weird lag and low idle
- Stock or Catback
- Belt squeal / squeak at startup
- cooling issues after new paint..lol weird
- trying to find foglights and radiator cover for my prelude
- best crank for n/a h22
- Tail Pipe Smoken
- need help code 6
- alternator question.
- Deleting secondaries on jdm h22a.
- USDM OBD1 H23 into a 96(OBD2) Prelude swap help!!
- check engine light not on?
- 88 prelude si auto tranny
- trouble starting now after hondata s200
- h22 having trouble flooring it
- 1999 Honda Prelude(base)
- 93 SI Dies Randomly - Sometimes Days Between Incidents
- 5th Gen Rim offset?
- 1992 PRELUDE SI WONT START
- EGR problem on a 1993 Prelude w JDM H22A swap..which part??
- h23 vtec
- ECU not getting power
- 5 speed swap and jdm head swap. rpm wont work
- Eliminater chip???
- anyone know vtec wiring for obd1 h22?
- can I increase my idle by adjusting the 2 screws on the throttle wire?
- No reverse, how do you ADD transmission fluid?!
- Dead wheel bearings?
- on warm days my car idles real bad and shuts off. What are my options to increase idle?
- Good oem parts dealer
- ATTS Delete a unique question
- Bad Alternator = Misfiring?
- New electrical problem
- cams dohc
- 89 B21A1 rough acceleration
- clutch master cylinder
- LS swap?
- 93 prelude, JDM H22A, No spark??
- alternator connection pops off..also right headlight dimmed.
- any thoughts on F1 Racing
- Prosport gauges help! (pictures provided)
- Exhuast help
- Turbo H22?
- How To Get Started?
- new project
- 96 prelude cranks starts and stubles off
- h22a swap recently started killing starter solenoid
- electrical problem with h22 but good battery and alternator?????
- I can push the brake pedal to the floor??
- Is it possible to switch a SH to all base model suspension arms in the front?
- Powerband
- need help ans suggestions w/ my A/T tranny please
- 87 octane in H22
- Kteller oval or round?
- lightweight preludes
- Suspension Question (Tein/Megan)
- h22 wont fired up.
- bad or good mechanic? how much to get rotors fixed?
- driving a stage 2 clutch
- Aluminum Radiator...
- I need Help With Auto To Manual Conversion??
- h22 or f20b jdm
- Headers question
- AEM CAI Question!!!
- Accord Side Skirts
- Smoke coming from H22 tranny?
- Cooling problem
- Wipers not working on '93 Si.
- 1990 4ws..good price?
- boosted h23a1
- H22 buildup questions
- DOHC ON A F20A4
- how to eliminate ATTS on SH prelude
- H22a7 Head on to H22A1 Block
- 4th Generation Clutch Slave Cylinder
- misfiring problems
- KC Prelude Club...
- Smog? high HC.... Need some help
- my 97 prelude 2.2L vtec wont start. needs help figuring it out.
- Help Needed!!! Clutch, Transmission, Slave Cylinder Issue
- How do you get the headlights off?
- Exhausts???
- Turbo..need tune>
- tweeter speakers question on a prelude 96
- Good Method to compress valve springs
- Anyone know how to make this? Twin mounted door speaker design.
- Help PRELUDE USING WAY TOO MUCH FUEL
- UK Spec Prelude 2.0
- Mfactory h22 final drive gear
- need basemap
- honda prelude 2.3 needs head--what heads swap possibilities are there?
- engine dying when warmed up....
- H22a Problem
- rear speakers
- Interior help please!
- Transmission Gear Ratios ---- Which is correct ?
- Wheel Bearing Replacement
- Balljoints
- ESP traction bar vs stock
- Key stuck in ignition
- h22 in a previous h23 lude.external coil now internal?
- 18.49 volts at 7k+ rpm!!!!! 3 month old alternator....
- Clutch Kit....
- crank hp vs. whp
- Lowering springs
- What is this?
- help,left turn signal,parking lights and tail lights won't turn off!!
- Euro r bore and Tb size conjunction
- jdm h22a confusion
- 94 prelude idle problem
- what radiator hoses should i use?
- 1997 prelude ac fan and cool fan help!!!
- lowest offset
- JDM headlight installation.
- 25psi clutch?
- 3" exhaust where?
- hydro lock
- 2 types of injectors?
- BEST Headers and Exhaust for 98 lude?
- Grinding when car is in gear
- Need Stuff for my 5th Gen Lude
- Bad TPS sensor??
- 3" exhaust or 2.5"
- DRY or WET nitrous
- code 6 diagnosing help!
- Best place to get vaccum for turbo setup?
- Newb needs some help....just found a problem.
- Lightweight rims for a 3rd gen?
- start to flywheel whine on start up
- Clutch issue
- crud on my jdm headlights how to get off? HELP
- MUGEN HEAD GASKET???
- 1991 Honda Prelude Si is stuck in park.
- mishimoto radiator with OEM FAN?
- crazy problems i need help quick!!
- intermediate shaft
- whats some quick ways to get my lude to accelerate quicker? Like get out of the hole.
- prelude what modss ???
- will a 96-98 auto civic ecu work on a 97 auto prelude?
- overheating
- New Prelude Dyno!! Vid inside!! 872 WHP on 35psi!!!!
- Headers for all motor
- Looking for 1994 h22 engine harness
- H22A resistor box HELP!!
- 1990 honda prelude w/ VTEC
- 1990 Prelude w/ VTEC
- flywheel and pressure plate bolts
- prelude seat sliders, rails?
- Sagging 5thgen front bumper
- AND THE PROBLEMS CONTINUE...JUST GETTING BIGGER...HELP APRECIATED
- WTB: BLOWN 4th gen pass. airbag top cover
- A/C Problems...Please help....
- Wheel size and offset questions HELP for 97-01 prelude
- RPM droppae when turning on accessories?
- ENGINES!!!
- AC TROubleshooting.
- another PITA CKF CRANK sensor problem
- WHATS BETTER ADDING A B HEAD OR CHANGING THE ENGINE???
- WHATS BETTER ADDING A BHEAD OR CHANGING THE ENGINE???
- CTR steering wheel?
- Nasty rice sound
- Jdm H23a Vtec.
- H22a Thrust washer clearance
- JDM type S questions......
- Parts Compatability
- Euro r fitment
- need some info about 99 prelude auto
- Reverse light wont work on a auto to manual conversion lude
- clutch squeaking
- S2K Oil Filter on BB6
- Rough idle
- Baffle for Catch Can
- OBD II to OBD I conversion...
- 15's on a 5th gen
- 2001 Prelude Idle Problems
- H23 help. need help with vtec
- boosting- usdm over jdm h22a1
- code 12? HELP PLEASE!!!!!!
- 93 Prelude, i need help iding the head
- 92-96 prelude jdm gauge cluster wiring help
- need help on FITV and IACV hoses...searched!!
- ball joints
- soon to be 4th gen owner
- JDM h22a dry 60 shot traction issues... vids included
- what offset?
- ECU Computer 92-96 4th Gen Prelude, VTEC, Auto
- Engine Swap Questions
- is it compression?
- prelude questions
- f20b........ help
- MFactory Oil Block Adapter
- Balance shaft eliminator kits [Kaizenspeed.com]
- Prelude- H22a and H23 Distributors, Car won't start!!
- HID Headlight Conversion
- SRS Light Wont Turn Off...
- rear brake problems
- Header question!
- 93 prelude no a/c
- R12 to R134 Conversion?
- Engine knock when hot
