View Full Version : Honda Prelude
- I guess I got too much torque.. bummer.
- CEL 4/8/9
- Random Idea...
- 4th gen edm dimmer switch? Wiring to dome light.
- HELP! Need 4th gen cam shaft and crank shaft info!
- radiator cap (searched)
- P0112 (IAT) 2001 5th gen Prelude Help needed.
- How to Install Short-Ram Air Intake? (I've used the search already)
- Solid CEL drove fine then wouldnt start
- Which is better?
- tuning
- Need Help! Tools required to pull a H23 shortblock by Monday
- 5th gen remote keyless entry question
- help with my first engine swap
- Wicked Transmission leak... help wanted!!
- Cat?
- brake lines to prop vlave
- Think i might have found the next whip!
- 5th gen: WWRS front lip black primer, apexi N1 back bolt on tilted for base maybe SH also dont know
- oil burning smell at the rear of the car. No white smoke
- replacing a break caliper on a honda prelude
- LED Projector Headlights - Opinions
- ITR wheels on 4th gen pic request
- Brake Fade Question
- Tanabe Rear Underbrace + 4ws
- Oil on timing belt side = bad cam seals?
- What is "Sports mode" on my auto '91 ??
- Fuel Tank Leaking
- prelude brakes and accord brakes
- Replacing balljoints on front knuckle
- jdm front clip worth it?
- Will obd1 h22 dizzy's work on a...
- .koni yellows for type-sh
- wat kind of aftermarket steering wheel should i buy??
- Bought a Koyo radiator...need a little help though
- momo steering wheel
- Integra Front on lude on bodykit website *pic*
- HELP ME TURBO MY 3RD GEN LUDE!!
- WTB: KONI YELLOWS!!
- Electrical problem "Horn/Stop" fuse
- possible piston damage, or bent valve?
- is anyone running this set up
- check engine light
- What size is it??
- H22a Accord - Questions
- i was wondering if this site is a good site to order from??
- h22a motor/h23a1 tranny CLUTCH question.
- How do you know you've gotten water in the cylinders?
- b and h knock sensors interchangable?
- atts control unit
- NEED SERIOUS HELP
- 97-98 threw 99-01 engine motor harness same?
- H22 installation cost
- 16" KONIG TRAFFIK on 95 prelude
- HELP! Do I have a H22 transmission????
- Who can tell me the average oil pressure readings?
- Took a 97 prelude im thinking about getting to mechanic....
- Timing & balancer belt....
- Alternator Pinouts
- How many 5th Gen owners have PF Mirrors?
- Can I use this oil pressure gauge?
- Help please. Cant get into gear first thing in the morning
- VTEC not working any more??
- h22 swap
- Honda prelude ignition barrel steering lock and 2 keysbrand new
- mainfold
- Engine wont start, H23 swap
- Timing Light Help
- Problem with my Prelude 1999 -- Please help...
- Tools for TB<->Manifold Portmatching?
- Sticky throttle issue
- Boosted h23 question
- Any tuning and parts shops in LA ?
- +50 Offset rims - Pic request
- Seatbelt Bar for 4th and 5th gen - same or different???
- disassembling a tranny
- h22 ITB's
- k24/k20 swap into jdm prelude... need help.
- Lookin for a clutch
- Before I do Clutch work (advice)
- Apexi VAFC or VAFCII HELP!!!!!!
- h22 torque specs
- Internally balanced or Externally balanced?????
- need a 5thgen 98 factory service manual...
- Finished my hmotorsonline replacement H23A3 swap...
- Weird Idle Drop!!!
- weapon r header
- Suspension Problems 2!!!
- Suspension Problems!!!
- 4th Gen VTEC install question
- not boosting leaky boost controller?
- will 5g springs and shocks fit 4g 4ws?
- Elite Summer Nationals.
- is this even possible?
- SH struts
- what is this thing that came off my car?
- Car won't start, no fuel no spark, CEL is there but unable to check it.
- Need To Know Pipe Size for 6'' exhaust
- how can you tell if you have a messed up gasket or not
- transmision removal from the engine
- Strange noise while accelerating
- WTB 1996 Prelude OBD2 ECU or 1998-2001 Prelude ECU with key
- Repair or Replace IAC
- Need confirmation that Spoon strut tower bar fits both 4th & 5th Gen
- a/c acting up
- base or SH camber kits
- H22.
- 96 H22 VTEC Prelude!
- Linkage Bushing
- Good Deal?
- Unplugging Knock Sensor.
- 96 Prelude OBD2 to OBD1 AUTOMATIC swap help
- 99 prelude v-tec engagement???? vtec solenoid
- Eagle Type s rods
- ITR exhaust
- where is the IACV on 97 prelude?
- Lifters need replacement?
- dropping transmission w/ jack stands...
- Question about a 3rd gen???
- tranny problem
- Aircraft Remover FTW....no seriously.
- Worth It or Not Worth It
- What is the MOST PSI i can push and what do i need.
- Headlights randomly go out
- CEL help 71, 72, 72, AND 74?!
- crack...
- 2 choices
- control arms
- Squeaking sound when car is on
- 1999 Honda Prelude SH - Manual Transmission or Clutch Problems/Questions
- 5th gear noise
- any one running this combo?
- back seat metal plating, does it serve as a sway bar?
- HELP! FUEL INJECTOR/PUMP QUESTION!!!
- IACV problems
- Need help with Offsets for 97-01 ludes.
- noob needs help.
- ABS connectors/ computer
- F20B motor, Comes in auto format and with no Euro R manifold/ no euro R cams/ Type S cams?
- ESP header
- *Rosko's H23vtec build* N/A 12.0:1, Sk2 Pro2, Euro R, RDX Injectors, Alaniz ported, Camp1320 header
- where can i find a .02 oversized head gasket for the h22
- 97-01 prelude lost or duplicate keys
- h23 timing belt
- crower cams
- Need a DC Sport Downpipe header
- cruise control removal
- ummm dont know much about cars..
- Timing belt install HELP
- Prelude sluggish from the start...
- H23 to H22 swap in 4th gen. need help please
- Still searching for info...
- CEL code?
- dude, wheres my car?
- EL dimmer wiring
- Does 94-96 performance springs fit on 97-01??
- Driver's side axle shaft re-installation
- prelude transmisions
- Drove with one sparkplug wire out!
- Need help removing 5th gen trunk!
- Head Gasket Help
- H23 compression problem, looking for ideas
- replacing clutch- how to/where to
- Timing Belt Problems...
- skunk2 on 96 prelude
- ---- Steering Wheel Shakes When Braking ???? ------
- installed new Ti-C exhaust
- cold air intake vs short ram
- twincharged lude?
- h23a1 transmission/h22a motor
- 1st gear / REVERSE on h22 5spd?
- 5th gen CF Hood...help!
- EM racing C-pillar bar question!!!!
- anybody have a 92-96 prelude shift lever
- prelude SH swap options ?
- Can't Pass Smog at 15MPH --> HCs and NOx too high
- ABS code and CEL code
- H22 Exhaust Manifold "searched"
- NOS on 4th gen
- so my clutch pedal wont spring back
- SWAP QUESTION(H23 2 H22)
- ideas for my stock cx?
- h22 compression test??? GOOD or BAD??
- H22a Misfire issues, got a vid too!
- sway/stabilizer bar end links & bushing ?'s
- wondering if any web sites sell dart blocks for H series??
- 97 Lude Body Kits?
- moving miles on cluster.
- best compression to turbo
- JDM H22a into a 97 lude weird drivability problems
- Tuning for a new intake manifold. Necessary for euro R?
- Video Review: Greddy Ti-C
- There goes my Prelude You BLoody Trucks!
- weird wooshing sound
- what the hell is wrong with my dam clutch
- recommend a cai for 99 prelude
- h22 and h23 questions.
- External Coil H23A engine ... Can I use internal coiling distributor ?
- 89 prelude idles rough,
- F20B bore limits
- Yet another sputtering problem...Bad ECU or TPS?
- swapping parts on heads
- transmission problem
- struts for SH
- h22 clearances
- Flywheel inspection plug needed ASAP!!
- WTB: Wings West RS for 4th gen
- spare tire
- Clutch And Flywheel Question!
- Help looking for a clutch!
- I've been a traitor for almost a year now. What I've been up to.
- Grinding noise coming from driver's side rear wheel
- lost keys
- 4th gen Vtec Rear Speaker
- HELP!!!! BELT QUESTION?????!!!??????
- Idle air control question.
- Angel Eyes Headlights! Where to get em!
- Catalytic pressure
- 3rd Gen coolant leak
- Mahle Gold Series Pistons
- 92 prelude with p13 ecu
- Gear Box problem.
- CEL and ATTS Light
- Integra pedals ?
- Just purchased my prelude....
- recommendation
- Exedy clutch and flywheel part numbers (stage 1) nEeded!
- 4th gen crossbeam question
- What do you recommend?
- Which headgasket to use? H22A1 vs H22A4
- Noob question..... don't rip me a new one!
- JDM H22A header question
- ead about this but
- Hyperfest Weekend Race report & pictures
- 1 layer oem Headgasket
- H22A motor- any difference in auto or manual ?
- H22A Distributor Question
- checking for bent valves
- manual.v.auto
- gold honda symbols
- ABS code
- just got my head rebuild questions
- FS: 2 sets of JDM Headlights for 4th gen *Weekend Special*
- f22b dohc ??? worried
- engine bay diagram
- s2000 motor swap
- chrome pro
- catback
- lowering the BB6
- Question about some parts?
