View Full Version : Honda Prelude
- cel 1456 any info?
- h22a
- Flooded engine.. Is this an option?
- idle scree adjust
- roadracing a 5thgen
- H22 confussion, searches, got even more confussed
- do my motor mounts need to be replaced?
- How much can my lude take?
- 2001 prelude - firing order
- F22/H23 Intake Manifold
- Emergency Brake Light
- atts oil whats kind ?
- Is my prelude equipped with LSD or am I an idiot?
- Wheel bearing possibly going, unsure. Help me prove/disprove.
- speedo cuts off after 4800rpm??
- Valve cover nuts
- h22a????
- E-Brake light stays on
- axles
- Seibon Carbon Fiber Spoiler
- Really urgent guys i broke something in the throttle
- 5th gen carbon fiber lip / lip kit? Where....?
- flywheel n crank problem???
- Supercharger
- recoating cams?? is it possible?
- H23/VTEC question. Rods
- No luck with Trannys
- ehh necessary parts?
- h22 distributor
- Buying a New Transmission Straight from honda
- Possible Leak? My trunk is always wet
- auto gear shifter light bulb replacement???
- 1994 Prelude VTEC, Towing Capacity?
- 01 prelude amount of r134 to inject into empty system
- lets start a video thread
- wheel alignment........
- anyone hear run 185/65/15 tires? Or around that size
- SH h22a4 and base h22a4
- losing power in my prelude
- h22 starts but then shuts off
- weirdish noise when i push in the clutch
- car EXTREMELY hard to start when cold
- H22 Beather Tank
- Horn goes on when reconnect the battery??? Why is this happening???
- Oh ya, got my Greddy Header!
- h23 and f22
- HELP! Need quick answer!!
- WWRS Side Skirts installation
- Question about h22 Prelude
- who had the M2F4 transmission gears for sale?
- VSS dies briefly in cold weather. Bad VSS? Bad connection?
- Fog light help
- New Header New Problem?
- going price for a 98 prelude
- Bad Timing Light?
- Crank pulley is "shaking" a little, normal?
- What prelude engine will fit my chassis?
- Looking for second opinions on upcoming project...
- 1997 tranny same as 2001 tranny???
- Clutch Woes... Has pressure but won't disengauge
- Which exhaust for best performance?
- TPS voltage reading jdm h22a
- Problem with Radiator and ATTS
- coolant leak
- Need new syncros
- Has anyone ever thrown a EGR Code on there Turbo H22?
- do h23 rods fit h22 pistons?
- Brake grind feeling
- throttle body torque specs
- VTEC or a non-VTEC with a turbo.
- USDM VTEC Solenoid vs. JDM
- cam shafts
- oil leak
- anti coolant bleeding screw?
- Stacking?
- heater hose
- Hondata Opinion
- tokico springs and shocks
- Dash Removal on 5th Gen
- what is shot peening?
- check engine light came on
- 16x7 +33offset will i rub?
- where to find h23 rods and type s pistons
- Car slightly jaults/jerks when letting go of the gas
- My foglights are buzzing (?)
- Prelude stuttering (vtec only)
- 1995 Prelude Automatic Wont start
- 5th gen gauge pod
- Fuel Filter Related Problem?
- Oem HG Thickness
- Garrett or Precision Turbo for H22a4
- all usdm h22a manifolds the same?
- Whats the real deal w/ Skunk2 pro 1 cams and idle?
- h23 tranny vs. h22 tranny
- Intake manifold question? Searched.
- nitrous help
- vtec works then does not
- replacement cost?
- f22 v tec selenoid on an h22
- 92-96 F22 Fuel Pump the Same as H22 Fuel pump?
- H22 SH intermediate shaft adapter plate to base model tranny.
- Civic Alternator and Underdrive Pulleys
- When Installing New pads and rotors
- stage 1 and 2
- exhaust ? regarding 92' H23 to JDM H22 swap
- My sweet winter beater, but with an issue.
- Meziere Electric WaterPumps
- What's wrong with the 5th gen gallery....
- Brake Lamp Problem! HELP!
- With all the velocity stack hype... does this do anything?
- Re: CAR Shaking at 110mph....
- is it possilbe to swap in a non-SH motor into a type-SH prelude?
- Tail light bolt/screw problem......
- Lowered - Can NOT fix toe...
- f20b connecting rods?
- Surging idle...tried everything and have read every search related topic
- jdm trans will it work?
- switching motors to h22 from h23
- No SPark need help
- Odd idle problems
- Immobilizer & P28 functionality?
- quick question about h22 block?
- IS300/Altezza Tail Conversion on a 4th Gen?
- LSD & Final Drive Conversion
- Water and black gas from muffler
- F20A Transmission
- General Question *no flaming, searched* Why do Hondas have low Torque numbers compared to some other
- 4th gens with the passenger side airbag, is there any way to just get a dummy cover?
- whats this? ebay adapter dealy
- Spark plug wires...Needs Insight
- ignition REcall
- PROBLEM!!! Just had my tranny rebuilt and its all wrong!
- xs power turbo?
- Help..
- Adjustnig valves and re-installing cylinder head
- anyone know the size of the short ram intake for the DC Sports Short Ram 92-96
- do they make a 5sp tranny w/ factory LSD for 5th gen.?
- JDM Prelude VTEC/Accord SiR Auto GEAR RATIOS??
- a sunroof visor
- water pump OEM or Aftermarket??
- pillar guage wiring... firewall wiring 98 prelude sh
- starting
- clutch adjustment help please
- how impoertant is ABS?? heres a stroy for all you who want to remove it
- Looking for passenger side headlight
- replacing rear hub
- IACV Code.
- clutch advise
- Another "weird noise" thread...
- I need Help ASAP! NEW BATTERY/STARTER STILL WONT START!!
- Check engine code 8. TDC sensor?
- for anyone debating afc or hondata
- engine rpm dropping - 2 questions
- emissions questions
- how much boost can stock h22a handle?
- Interior Lights and Radio - Too Dim?
- Does This Sound Like A Timing Issue?
- Tires on 5th gen
- B vs. H series
- Help!! oil leakin
- Which Aeromotive Fuel Pressure Regulator do I need?
- Attn: need help asap!
- a little help please...
- Prelude Exhaust THread
- hesitation after 4k please help
- Write-up for my awanabe JDM foggies.
- Short Shifter ?
- Low idling when ac and heater is on....HELP
- speedo wiring + broken power steering line
- stupid fan question
- fog light
- Need help finding out what kind of transmission i have
- prelude itr rims
- 98 Prelude 5 Speed Conversion
- Ingalls Engineering needs your input! 92-01 Prelude Control Arms
- anybody have CL wheels on a Prelude?
- what's the difference
- 5th Gen ABS removal ?
- Another Turbo Topic (help is needed)
- PLX M300 wideband install on SH
- Dyno Sheets Open Header
- L Brackets for Lip?
- help with skunk2 tb and intake manifold
- Oil pressure switch port turbo safe?
- MUGEN Headlight Covers....
- H23 vtec obd2 ?
- 92 prelude 1pc black projector head lights
- h22 pulley set are they good for h-series?
- 2000 honda prelude
- 512whp 14psi H22 Lude
- Are my foglights too bright???
- tiger motors
- which clutch
- removing door beams in a 5th gen
- how to remove brake and gas pedals from 4th gen
- motor, tranny swap/ shifter cables??? need help please
- 4gen fogs and yes i searched
- Where is that 4th gen squential shifter thread????
- speaker size in door???
- how to check tranny fluid on 5th gen
- Weird buzzing noise!!! Searched!!! Please help!!!
- Got pics of your OEM wheels sprayed? Post 'em up >>
- Info need'ed on prelude turbo 1999 SH
- 89' prelude performance help?
- how to: removing rusted rotor screws
- How does water get into the bottom of the trunk?
- ABS Removal?
- Car leaking oil like crazy from rear of motor. Need Help ASAP!!!
- h22 vtec solenoid hole?
- Knock Sensor Connector
- Need Advice: Timing Belt change while engine in bay, H23a1
- Need some turbo advice?
- Engine Upgrade
- Clutch overpressured?
- need 2 know wut ohm i need 2 hook up autometer fuel gauge
- suggested pistons n rods plz
- You know your car is too low when...
- Erratic Idle
- 5th Gen Spoon STB F&R
- What are some important things to check before buying a Prelude?
- 5th Gen: Clutch Damper? My fluid is leaking.....
- auto tranny, revs a little when shifting, dosnt seem normal
- DIY 5th gen Fogs
- Need a good Honda Tech on this one ???
- lil help on grease(sp?)
- Question for the TOP TECH guys only
- VAFC 2
- Wings West RS kit w/ mud guards???
- Cat SH vs. Base vs. 4th gen
- Ignition For supercharged BB6
- what size screw extractor for rotor screws?
- oil?
- How to do H22a4 timing??
- Anyone ever seen this front bumper?
- 5thg wheel compatibility
- Ignition Timming HELP ??
- H22,SH intalation?
- BB6 aftermarket front upper control arms...
- Where the heck can I install my NRG Oil Catch Can...5th gen.
- code 21
- White/Blacktop 5G
- Prelude Problems!
- Can an H23 trans bolt up to an H22 motor?
- how can you tell the ecu vtec
- Function/Form Type I Coilovers
- What is the part No. for AEM Fuel Regulator for a Lude?
- Prelude overheating, looks and sounds like a hose
- 2.2litre single cam and h23??
- HKS SUper Drager
- h22 tranny issues need help
