PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 [302] 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. new rods, stock sleeves and pistons, how much boost? h22a1
  2. to turbo or not?? need some opinions
  3. car sitting crooked!! but WHY?!?!
  4. h22, stock pistons aftermakket rods, what needs to be done?
  5. 89 prelude 4WS replacing water pump...
  6. P5M trouble (99 H22)
  7. Is it possible to use a '92 Canadian prelude SR tranny with a 2001 H22A longblock
  8. Anyone know the diameter of Euro R throttle body?
  9. FS: JDM Integra Type R
  10. question about type s
  11. Steering Wheels
  12. What the hell is this (engine part)
  13. Went to the track..my times!
  14. Type S pistons
  15. Oversized Piston (friend needs help he's going all motor H22)
  16. Engine Vibration
  17. Compression test results and question
  18. Overseas engine install
  19. code 3... MAP SENSOR HELP!!!!
  20. is this normal?
  21. THought this might interest someone!
  22. 98 Vtce head on a 93 block
  23. need swap for 84 prelude
  24. Lug nut size
  25. Anyone seen a s15 front end on a ...
  26. check engine light is on... wont rev past 6500 rpm...
  27. where do i connect the vtec oil pressure to???
  28. Buying a prelude
  29. VTEC head
  30. Better for Boost-H22a or H23a?
  31. Should I swap in a JDM LSD tranny?
  32. Please help the NEWBIE!!
  33. o2 wire for a/f guage
  34. Need help finding parts.
  35. Can ATTS be removed
  36. Any of you have the Apex-i Vsafc
  37. FS: AEM/Brembo 4 piston brake caliper kit for 97-up Prelude
  38. Black carbon deposits on the inside of exhaust tip; a sign of a rich condition???
  39. OEM Head Unit Changer pinouts?
  40. Sway Bars
  41. 90 JDM B20A i/m and coolent q's! help.
  42. ---->question bout sprint camber kit<-----
  43. Hey Corey, how 'bout a race report?
  44. Chicagoland H-T meet...
  45. What are you riding on? Suspension Question
  46. check out this video
  47. It's ALIVE!!!! H23vtec!!!!! MUAHAHAHA
  48. Need to ask some questions for a friends
  49. Prelude VS Prelude Si
  50. Prelude leather seats
  51. Euro-R mani on a JDM H22
  52. H23 Intake Manifold question......involving intake runners
  53. 94 prelude
  54. Any power Gain on this mod??
  55. 3rd Gen Prelude...
  56. I got killed...but now I'm curious
  57. JDM Honda H22A Type S Engine
  58. Should I buy? '92 Prelude Sr
  59. here's a nice prelude for ya
  60. Will TAKING off My Heat Shield affect my engine at all?...
  61. Sunroof vs. moonroof
  62. Still dying - please help!
  63. JDM H23 VTEC?!?!?!?!?!
  64. MSD 6AL and blaster 2 coil HELP
  65. New Project Car
  66. HydroLock
  67. Can I use a p13 ecu on a 92 prelude????
  68. Anyone do a Euro-R intake manifold installation into their H22?
  69. Exhaust Questions
  70. need help with my h22a4
  71. How do I get the stock cd player out of my 98 prelude?
  72. Looking for a crashed prelude (WTB)
  73. b20a3
  74. rear speaker help
  75. Fuel rail fitting?
  76. Does anyone know where I can find cheap ROTAS???
  77. 88-91 prelude mod's?
  78. eibach springs
  79. JDM Auto Tranny help?????
  80. Change Tranny Fluid, Help Quick!!
  81. Prelude or ITR?
  82. Prelude Type R
  83. MAP sensor..........
  84. HOT Import Nights
  85. Looking for Cam Seals for H22
  86. what distributors will fit the h22?
  87. Anyone in here have a GReddy turbo kit???
  88. JDM headlight problem
  89. greddy evo avail for 4th gen
  90. VTEC Tranny and more
  91. What do you think about Greddy E-management For Turbo setup?
  92. 14' steelies
  93. H3 Conversion for JDM Fogs
  94. installed A/F gauge questions though?
  95. help... battery might be dying?
  96. attn. toronto people
  97. Socal HT canyon run Aug 17th
  98. new time
  99. Any word on the 4-2-1 SMSP header????
  100. timmig belt slippage?
  101. apexi vafc
  102. lude is hesitating from stop
  103. n2o cams while n/a VS n/a cams while on n2o
  104. Does anyone know where I can find spoon replica front lip?
  105. all motor H22a parts???
  106. Another Prelude Question...
  107. Tell me what you think
  108. ZEX Nitrous; why retard ignition when it's electronically controlled?
  109. Anybody with a black 4th gen on black 16s?
  110. Crane Cams Roller Rockers???
  111. Aasco flywheel versus JUN flywheel *ding*
  112. Purge cut solenoid
  113. RPT p13 specs -- any one know or have this on their h22
  114. hydrolocked motor
  115. Do Cam Gears and New cams Make a difference in Turbo?
  116. headlight adjustment... how?
  117. i just milled my head do i need change my cam timing
  118. Anyone here from Minnesota?
  119. After months of waiting it finally came
  120. Wiring harness question??!!
  121. what exhaust should i get?
  122. color codes?
  123. Prelude stock hood question...
  124. greddy lip for lude's
  125. can you chip a obd1 prelude ecu? p13
  126. Engine Re-building! Bearings...Need help!!
  127. Who is going to NOPI 2002 plz post here (it can be a H-T meet too)
  128. jumpy/fluctuating RPM & shutting off
  129. H22 / F22 Swap??
  130. Another one bites the dust...
  131. Soanother one bites the dust...
  132. Yokohama Parada Spec 2
  133. my first dip into the prelude pool . . .
  134. Preludes...
  135. Main Bearing question
  136. Plans for NOPI September 20, 21 & 22 (Part 2)
  137. 93 Si non-vtec
  138. Problem with the 92 prelude
  139. quick question
  140. apc- red and clear...not altezza??
  141. advantages/disadvantages of turbo kits
  142. 5th gen dash in a 4th gen body
  143. 98 SH?
  144. rising temperature
  145. Is this the best price? Or have U seen better?
  146. h23a4 on what tranny
  147. Valve Lash adjustment
  148. 2 inch drop too much??
  149. MSD injectors fit fuel rail?
  150. yes you need to chip it.
  151. Brake upgrade
  152. Timing belt tension
  153. I made the side marker blink
  154. So did anyone buy the NOS plate kit?
  155. need 4 stock 205/50/16 tires only
  156. good exhaust system for supercharged lude
  157. Bored and Stroked H22A's?
  158. prelude question
  159. SS ECU -> 5-speed ECU wiring?
  160. Crower Rods in H22???
  161. Does a H22A use a pilot bearing?
  162. i have 7,000
  163. Are axles and intermediate shafts the same for a Sh and base model???
  164. What do i need to do a h23a vtec??
  165. Daily Driven Turbo
  166. What the Hell is Wrong?????Please
  167. What should I do to the H22a block to run a forged piston?
  168. 5th gen prelude
  169. Any F22/F23 for sale????
  170. Help! Need full cat-back exhaust for a '90 Prelude Si
  171. how much is too much for a f22 ?
  172. looking for a prelude 92-95
  173. balance shaft oil seal recall...
  174. does a 92 H23A clutch fit a 97 H22A???
  175. JDM H22a Auto ECU Diagram?
  176. What do you think about going Turbo In a SS tranny Prelude?
  177. Tell me if this is a good deal.........
  178. msd plugwires good?
  179. My ATTS took over and made my Lude go outta control! :(
  180. 91 Hybrid..need Htech members help here.
  181. 92-96 lude ques.???
  182. 93 lude s tach wiring
  183. How can i make a prelude . . .
  184. S/T sway bars install on a 4th gen
  185. longer geared tranny fo sale
  186. Anyone with Radiator problems?
  187. What would you guys use?
  188. Anyone know the tranny codes for every 92+ JDM/USDM h-series tranny?
  189. WTB forged h22/h23 pistons
  190. How can i make a prelude . . .
  191. V-AFC settings on Lude with i/e/h/pulleys
  192. Injen cai Vs. aem cai
  193. Todd is back, the trolls are gone... you may continue your regular scheduled Tech talk.
  194. Removing /Installing AC......
  195. lowring your ludes...
  196. JDM H22a people
  197. dyno prelude???
  198. Valve adjustment
  199. reviews of Pivot auto shift lamp
  200. warranty prob..help
  201. Anybody running a copper head gasket/0-rings on their H22a
  202. 27mm rear sway bar for 5th (possibly 4th too) gen
  203. Anyone got H23 VTEC dyno's?
  204. How heavy is the 5th gen prelude
  205. 5th Gen. Prelude
  206. SRS Light
  207. Anyone here have ground controls & koni yellows?
  208. weight of stock '00 prelude hood
  209. Anyone replace their antenna mast before?
  210. carbon fiber toilet seat
  211. jdm cluster
  212. need a JDM H22 trany
  213. does that spiral-max really work?
  214. vafc question. what is prs mean and is it bad if at full throttle it reads in the +s ? what is in 6
  215. Level 10 touqe converter????
  216. Advancing the Timing...
  217. 99 lude exhaust problems
  218. 13.6 wahooooo!
  219. 3rd. Gen Prelude wanting to make it faster!!
  220. WTB: H22 4th gen lude motor JDM
  221. Anyone have a speed sensor assembly for 92-96 Prelude MT (shaft/gear assembly that goes into tranny)
  222. 90 Si - Speed Sensor?
  223. i'm New to the site, oh and any Luders from DFW??
  224. got the engine out
  225. Houston People - $35 Dyno
  226. what are your agx's set at?
  227. Concern(s) for my '90!?
  228. Need help on a Wiring problem..
  229. question........
  230. What kind of oil do you guy's use in your lude??
  231. Hondata
  232. What do you think about the HKS dragger exhaust?
  233. ARP head studs for the h23a
  234. Screw Honda...
  235. can someone clarify the shock knock?
  236. Laughin2.2.... Cleaning Out my garage - some parts for sale.
  237. get new lude or build up old one?
  238. for you guys have turbo preludes
  239. Rice or Not?
  240. N E 1 have an oil cooler on 92 up prelude??
  241. 1st drag lude i see don't know if you guys see it yet
  242. my tranny problem *pic*
  243. coilovers vs springs which is better
  244. Where the Orlando Luders and Honda owners?
  245. who makes good intank fuel pumps for 4th gen Si??
  246. East Coast Meet!
  247. newbie here
  248. Fuel Lines and fittings from tank...
  249. Aftermarket fuel pumps......
  250. Forged Block for H22a?
