PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 [189] 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 4G LCA question...differences
  2. differences among h22 heads throughout the years?
  3. Transmission Drain Plug Rounded out....
  4. Engine break in? Tuning?
  5. which screw is the idle screw on the 5th gen prelude?
  6. TPS voltage H22 & H23
  7. prelude injector sizes
  8. OBD II conversion to OBD I
  9. Would this be a good deal?
  10. USDM vs JDM h22 Intake Mani?
  11. Rattling noise coming from underneath the car..
  12. Discharging r-134a ac sytem???
  13. Coilovers and suspension
  14. need help on finding iac valve on 98 prelude
  15. can 14 inch steelies fit on a 93 prelude si?
  16. '94+ Integra Rear Wiper Assembly... into a '92 Prelude??
  17. Jdm h22 question
  18. Removing Intake Manifold
  19. Too Much Oil
  20. Alarm wiring problem, Need help, no start.
  21. bent shifter cables on 89' 2.0Si
  22. MICORFICHE!!!!!!!!!
  23. H22 swap done but not working please HELP
  24. 5th Honda Service Manual
  25. forbidden shortshifter= amazing
  26. Tranny hard to shift into gear
  27. Interior Lighting Problem
  28. Various problems with 91 SI
  29. Building a new motor - OaksRacing
  30. Prelude p13 ECU question
  31. VAFC Wiring -Searched-
  32. broken timing belt
  33. Error code on tranny?
  34. Balancing Turbo and Cams....
  35. aftermarket support for preludes?
  36. my steering wheel is falling apart
  37. Great guy to do business with, Aludew5
  38. Looking at titanium retainers and came accross this....
  39. Thursday March 24th Irwindale anyone going?
  40. Redesigned H22 Skunk2 manifild????
  41. wiring color to check CEL codes
  42. shocks for prelude sh
  43. search mang
  44. 5th gen strut bars
  45. Going about modding my 5th gen Lude
  46. Major Water Leaking Problem
  47. prelude and civic radiators
  48. What kind of numbers will it put down?
  49. Clutch dampner assembly
  50. Getting a 93' Prelude with a H23A engine...
  51. prelude injector ...need help fast
  52. Driving at night - headlights go out - not normal
  53. Fuel injectors foir an OBD-I car, but OBD-II block/head
  54. Spring Mounting Rubber
  55. ECU help....
  56. Good News: CP releases their H23a Forged Pistons
  57. 90 Prelude Si HELP PLEASE
  58. cam question for the b20a5
  59. turbo recomendations needed badly for prelude engine f22
  60. PrecisionH23a I want to buy some parts but I am restricted.
  61. odd electrical occurances?
  62. Thinking of buying a prelude...need help
  63. Tail light/gauge light fuse blown
  64. H23a ands H22 frankenstein anyone?
  65. Need info: H22 2.5L Stroker kit !!??
  66. Passing Ca smog with fuel hondata;1:1 reg
  67. My new prelude
  68. prelude starts and then all power goes out ??????
  69. Tps sensor recalibration?
  70. 99-2001 transmission.
  71. RPM stuck?
  72. SH clutch
  73. what is the m.p.g. for a 94 lude?
  74. smoke coming from engine bay
  75. Dead Speedo after hitting milk jug
  76. LIP part number
  77. Random stalling, car bucks, engine revs by itself
  78. does anyone have an h22a4 sh crank???
  79. Auto > Manual Tensior swap.. How many washers?
  80. Auto > Manual Tensior swap.. How many washers?
  81. Auto > Manual Tensior swap.. How many washers?
  82. h22 crank in h23
  83. How to check to see if injectors are working properly??
  84. Clutch Fork Bent? Tranny is clicking...
  85. 2.2 VTEC type S active torque transfer system
  86. disconnected battery and car wont start
  87. Transmission Problems
  88. why is there a window at the bottom of Prelude cupholders?
  89. knock off or real thing
  90. Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic
  91. JDM H22 Wiring Schematic Needed
  92. H23 wire harness on H22
  93. engine stalling on me when I'm in neutral
  94. Cargo Capacity
  95. Prelude chip
  96. Mixing Oil
  97. Q: Valve cover washer's... and Profab IM gaskets
  98. Compression ?
  99. which camber kit?
  100. number on crank
  101. AT - 5sp. Transmission Swap
  102. clevite77 and acl bearings
  103. 2001 h22 in a 1998 integra???????
  104. Feedback from engine through speakers?
  105. *HELP* need pics of drag wastegate tube
  106. Random Misfires
  107. Will this head fit an H23?
  108. Running p28 on 1997 obd2 h22? car dieing when i stop??????????
  109. Will an F22A1 (S model) intake manifold fit an H23A1 (Si model)??
  110. Sensor scam or no?
  111. type sh vs base/4th knob height
  112. H23 piston in H22?
  113. Need Some Help With Coil Overs
  114. timming belt riding wierd after manual conversion
  115. dont mess with cam gears...while engine is running,,,or come out fingerless...like me
  116. urgent: atts question
  117. Car won't start..cranks fine..electrical problem???
  118. 5th gen Strut bar installation
  119. Anyone rebuild their starter?
  120. *Searched* o2 sim & test pipe
  121. i want to make my gf's 4th gen prelude more "efficient, safe, reliable, faster" help.
  122. wtb rims
  123. who owns a VAFC?
  124. Kteller exhaust components questions
  125. What kind of flange do I need?
  126. camber and caster
  127. any ideas on engine mods
  128. H22 Oil Pressure gauge question. Electrical or Mechanical???
  129. h22 tranny for an h23...
  130. 0bd1/0bd2 injectors
  131. H22 piston choice
  132. exhaust by-pass valve thingy
  133. Tell me about Dizzy replacement
  134. Ever-popular Camber Issues + Balljoint Worn?
  135. what to do with 93 si lude?
  136. where can i get JDM foglights for a 2000 prelude?
  137. 4th gen sturt rod
  138. Carbon Fiber Hoods...Which one fits properly?
  139. what cams for h22 turbo?
  140. Big problem with VTEC...NEED HELP PLEASSEE
  141. o2 sensor
  142. 97 ecu chip
  143. Turbo Timer install question
  144. How would you spend $5000 on a h22a motor ?
  145. Not So Healthy Prelude! Torque Converter?!
  146. ¿Head Gasket?
  147. alternator problem
  148. Engine reinstallation torque specs for the JDM H23A?
  149. Honda prelude '84 engine can't start
  150. h22a fuel problems......
  151. question in difference between JDM H22 and US H22A4
  152. Exhaust on a Prelude
  153. f22a1 to h23
  154. jdm f22b dual cam 2.2 . Lookin to purchase a turbo setup...could anyone tell me if this has been don
  155. so Im getting the car tuned in 2 days!
  156. code 4
  157. h23a 220hp?,h22
  158. oil pressure sensor
  159. H22A4 Wiring: Pins?
  160. Exhaust Question
  161. Side mirror hanging by a wire
  162. stock specs on 92 prelude si?
  163. injectors!!!! help fast plz!
  164. prelude vti r coupe
  165. Im confused about Exhaust pieces.
  166. 4th gen prelude nostrils. anyone have part number?
  167. 4th gen prelude died now its not getting spark
  168. ac compressor
  169. Increasing Rev Limiter - options
  170. anyone running 215/XX/16 on stock 5th gen wheels?
  171. Skunk2 throttle body idle problem
  172. 1999 Prelude SH need advice going turbo and ATTS
  173. preludSR help? !!
  174. Dyno'ed my lude today
  175. parts.
  176. Which wire on 97 prelude o2 sensor is A/F
  177. NEED HELP FAST!!!!!!!!! a/f HOOK UP
  178. Woodruff/Crank Key broke
  179. Stock fuel pressure and injectors on h22a4
  180. noob tranny question i know =((
  181. head swap from a B20A5 to B21A1 block and intake manifold???
  182. obx cams installed something wrong?
  183. After turbo install getting check engine light
  184. parking light and tach wires
  185. ?honing H22?
  186. 87 prelude si (PGM-FI light comes on) why? HELP!!!!!!!!!!!!!!
  187. limiter and vtec problem .
  188. Whhhirrrring sound after timing belt replacement *help*
  189. quick JDM H22A question....
  190. Describe engine ping to me.
  191. h22 vs. h23a
  192. 14.5 seconds in 1/4 mile?
  193. 5th gen immoblizer bypass?
  194. OBD 2 ECU swap now wont start
  195. 2000 Prelude Service Question?
  196. motor mount where they go???
  197. electrical problem
  198. battery relocation
  199. Silverstar, 4100k, 8000k HID comparison (pix inside)56K eat my xenons
  200. s2a4 tranny code
  201. h23 Head
  202. what injector size for h23 with 7psi?
  203. Distro cap with external coil ?'s
  204. prelude sites
  205. Tranny Problem
  206. RETHREDING h23 block
  207. matching ecu, trans, and motor
  208. window motor install?
  209. Help!!!!!!!!!i need flywheel bolts
  210. 92-96 SR-V rear rotor size??
  211. Engine Swap 97 prelude
  212. H22 header surprise
  213. Valve Installation Problems
  214. 93' Prelude starting problem, need help!!!!!
  215. Help installing amp on my 89 prelude...
  216. H22 Nitrous?
  217. climate control cable problems
  218. valve cover gasket install...tips for no leaks
  219. EURO-R IACV problems.
  220. 97-99 greddy turbo kit pics
  221. Spun bearing?
  222. Electrical problems
  223. No compression in cylinder #1
  224. Turbo piping? is the enough?
  225. PRELUDES NEED A 6th GEAR!!!
  226. 5th Gen - 17x7.5 +43 Volks - Fitment Issues?
  227. Turbo Prelude's, stock internal dyno ##'s
  228. New setup makes 377whp, 333wtq!!
  229. h22 M2A4 trans gears??
  230. Obd2 to Obd1 conversion... one specific question
  231. Swapping seats
  232. Blocks ?
  233. rear lower tie bar " help "
  234. what is this rattling sound?
  235. Parting out COMPLETE 95 Si - mod approved and new pics added
  236. my headlight refuses to come out
  237. h22 and f22 injectors ???
  238. The drag strip.....?
  239. Clutchmasters Stage 3 torque capacity?
  240. JDM H22 IDLE PROBLEM?
  241. Flush coolant when changing oil cooler?
  242. What size are these in the 4th gen?
  243. Prelude Spoon Exhaust
  244. Wanting to building a h22a for fi and spray on a 10 grand budget needing advice...
  245. Valve Replacement: Oversize to Stock Size
  246. wheel options
  247. is a f22 alternator compatible with h22a braket?
  248. r-spec vtec controller help
  249. Photoshoot CAR needed >> Chitown AREA
  250. OBD1 dizzy got 2 connectors? h22
