PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 [151] 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Bhp? SAE Net HP? Difference?
  2. Alternator belt
  3. Underground Racing Cams
  4. qui question...
  5. OEM Style CArbon Fiber hoods.
  6. OEM Honda Parts
  7. head gasket maybe?? help??
  8. pics of 92-96 stock radio stereo cd charger please
  9. IACV removal
  10. trans removal
  11. Anybody using the Apexi PowerFC and Commander?
  12. tranny compatiability between h23 and h22's
  13. horsepower enhancer??
  14. How soon till you get rights??
  15. Alarm Siren Placemenet
  16. When coming to a stop My car rattles.... Help
  17. Dension Icelink
  18. bad injector leading to clogged egr?
  19. DESPERATE FOR HELP...[H22]
  20. Tranny flush
  21. Bad Ass Exhaust Header for H22A ?
  22. removal of 4ws system??
  23. PLEASE HELP ASAP b18c to H22a throttle body ???????????
  24. Oxygen Sensor questions
  25. could my idle problem be the EGR Valve?
  26. Heat/blower problem!
  27. pic request jrsc of 4thgen
  28. AEM Tru Power Pulley Kit vs. Unorthodox Racing Ultra-SS Underdrive Pulley Set
  29. honda prelude transmission
  30. 98 Lude won't hit VTEC or past 6K RPM
  31. sparco seat brackets for 5th gen??
  32. 93to 2000
  33. Remove of Spolier?
  34. Best Motor Oil?
  35. Wetsanded my turnsignals!!!!!!!
  36. 5h gen prelude question
  37. Steering wheels
  38. Black prelude 4gen HQ photos ...
  39. 88 Prelude.....
  40. Need Help Of Tranny Mount For 5Gen Swap
  41. help a prelude out!!!
  42. h22a lude
  43. 92 prelude oxygen sensor wiring
  44. anyone selling any headers for a 98 Honda Prelude SH. Stock or Racing Headers. Used or New. thanks..
  45. Prelude Engine hoisting points.
  46. Best springs for comfort.
  47. Need your help..
  48. ATTS and Hondata are not friends! Help please!
  49. Best way to get some power
  50. my compression results
  51. Where can I buy after market axels?
  52. password jdm CF J's replica intake
  53. HotShot heaers??????
  54. Type-S Intake
  55. Possible turbo project question
  56. Idle? Not for me...
  57. no spark and fuel!
  58. Car won't start. Bad ignition switch?
  59. Header heat shield
  60. Finally got car started but more problems.
  61. knock sensor question?
  62. Possible Timing problem
  63. what are the correct tire size for 17" rims?
  64. will a 98 prelude Non-SH header fit into a 98 prelude SH?
  65. someone help please...
  66. H23 Vtec with H23 injectors
  67. 5th Gen JDM Sidemarkers....
  68. Aftermarket Stereo Help SPEAKER MOUNTING
  69. i need help w/my 98 Prelude SH
  70. Import Tuner: March 06
  71. Headers..
  72. socket size for 97 prelude knock sensor?
  73. will this fit my 4th gen???
  74. Frankenstein possibility? h23a1 block with h23a4 head
  75. 1992 Prelude SI trim...opinions
  76. is there a law for massachusetts....
  77. Tranny question
  78. difference between Non-SH headers and SH headers?
  79. front balance shaft oil plug
  80. JDM climate installation quastion ...
  81. EL gauges
  82. How does ELD communicate to ECU
  83. Jdm one piece wiring schematic
  84. headunit losing memory after each start
  85. does JDM prelude have heated wing mirrors???
  86. ***94 prelude si*** MAIN RELAY LOCATION??????
  87. 3rd gen: fault code 11?
  88. JDM H23a vs. USDM H23a...any differences?
  89. 5th Gen Jdm Fog Lights
  90. 92 Prelude SI motor swap info.
  91. ATTS sensor
  92. Broadway mirrors
  93. F22a1 swap to JDM F22B
  94. need price quote for 97-2002 prelude
  95. My Prelude build....old-schoolness!!
  96. prelude muffler pics! POST UP
  97. h22 in 4th gen
  98. ????motor swap???????
  99. very strange idle with "check engine" light
  100. Problems With My ECU
  101. Red Altezza or OEM Conversion
  102. Where to focus money for the turbo build?
  103. moisture in headlightS
  104. picture request please
  105. where to get a lighting relay online
  106. SRS Reset Sequence needed
  107. Did your prelude come with a 6x9 speaker in the middle of the back seat..help i gotta question.
  108. compressing rear brake caliper pistons on a 4th gen...
  109. 5th Gen Prelude Tranny Issue
  110. Coil Overs in the $300-$600 range: Suggestions?
  111. can nebody help rev counter bounces uncontrollabley
  112. (sos) can ne body help with 93 2.2 vtec si engine diagram need to replace oilseals
  113. 180 to the wheels?
  114. Piston question ???
  115. auto prelude
  116. pspec vs. lean (searched)
  117. Radiator Fan Control Module
  118. HELP me: I find the invertor for EL gauges cluster(prelude 94-96) ...
  119. MSD distibutor cap? CRX and Prelude, same fitment?
  120. my lude has a mind of its own...HELP!!!
  121. Built H22 running STOCK MUFFLER?????????
  122. H22A JDM P5P ECU Help!
  123. sleeves
  124. questions about FRM compatible pistons and FRM sleeves
  125. silverstars sucks! Recommend any others?
  126. foam air fliter vs. paper air filtervs. aem dryflow
  127. Turbo H22a problem????????????????
  128. lude sh would be the closest to the lude s right?
  129. vafc vtec crossover Q
  130. clutch master/slave both replaced. clutch loosing pressure. What's wrong?!?!
  131. throttle body help
  132. h22 cylinder head material
  133. turbo jdm h22!
  134. 5 year old springs, nothing to worry right???
  135. aem cold air intake interchangable between H23 and H22?
  136. Snapped rotor??
  137. will a 4th gen prelude smsp header fit on a 5th gen prelude?
  138. v-tec controller??
  139. Jdm digital climate control installation HELP !!!!
  140. cam seal replacement
  141. 1998 prelude vtec intake?
  142. Shifting too high?
  143. o2 sensor compatibilty
  144. worth buying this 92 si?
  145. 3 axles in 2 days please HELP
  146. brake light coming on
  147. Anr vs Prospeed vs Kteller headers
  148. H22 Clutch
  149. Zeal Function Xs Vs Tein SS
  150. What's the best Air/fuel ratio to shoot for on H22A motor?
  151. 1990 Prelude Si 2.1 ltr. Steering & Clutch
  152. Stainless Steel Lines ...BRand ??
  153. AEM Ems and ATTS
  154. h22a in eg, no spark
  155. need pics of rota cirucit 10 on 5th gen prelude
  156. 91 lude
  157. Headlight Questions
  158. Suggestions on replacements for the stock sub in Gen 4 Preludes.
  159. clutch churp???
  160. egr
  161. ::: HELP ME :::
  162. 95 Prelude electrical HELP
  163. Raising Oil Pressure?
  164. 94' prelude vtec
  165. shift cables broke!!!! help
  166. h23a3 engine swap and new clutch
  167. Oil Filter Relocation Kit
  168. how do you install jdm door visors?
  169. H22A1 -> H22A4
  170. Clutch, transmission, engine? (helppp)
  171. prelude
  172. H22-S
  173. H22 clucth on an 99 F20b which year is interchangable??
  174. 94 accord -- 94 lude ?
  175. f22 with a H22 tranny??
  176. JDM Climate Control Help
  177. h23 vtec turbo (searched)
  178. 5th gen prelude OEM Air intake question
  179. Quick question on the RSR Exhaust...
  180. Ticking noise comming from valves?? * Searched *
  181. 3rd gear horrible grind
  182. driver side cv boot
  183. Check engine light question
  184. Sir S-spec Vin
  185. h22a si 4ws vtec....TEMPERATURE situation...searched everywhere....please
  186. need help finding headlights
  187. Winter Driving
  188. 93 Si with JDM F22B - D4 Codes: 1L, 1S, 2S, 8S
  189. another starting question
  190. cutting out
  191. i need to install my quaife lsd in my tranny help
  192. F22 header and H23 header-same thing?
  193. Daily driver sold...........now what?
  194. 4bidden short shifter
  195. Assistance needed with Manual tensioner conversion
  196. one quick question please answer im in a predicament
  197. DC Sports Header Info Needed...
  198. Walbro 255 pump
  199. CAI Install
  200. clutch drops to floor?
  201. transmission probelms
  202. Vaccum control valve??????
  203. 93 prelude idle problems please help
  204. Perfect Install Instructions for MSD Ingition on 4th/5th Gen Lude
  205. ? for people who removed front sway bar
  206. 4th gen ecu
  207. installing a pspec short shifter..
  208. 93 honda prelude vtec problem please help
  209. missouri paint shops
  210. h22 type s tranny
  211. screeching
  212. Misc 5spd swap parts for 5gen
  213. quick question
  214. Could it posibly be my Throttle Possition sensor?
  215. In Debate: Skunk2 Proseries IM or Stock Ported H22 IM
  216. Euro-R Cams, Should I put it on?
  217. License Plate Lights
  218. Need 5spd swap parts for my 97
  219. Raising Idle via Idle Screw
  220. Help with 1991 SR fan issue
  221. 92 lude w/ h22a limp mode
  222. would this need machine work?
  223. Having Light bulb trouble
  224. Question About Rebuilt H22a Head!
  225. New to Crome need help
  226. obx high flow cat
  227. rebuilding h23
  228. High pressure in Valve cover? (Delete this admins, Search now working...)
  229. High pressure in Valve cover?
  230. 4th gen gas gauge sensor broken?!?!?
  231. apex n1 fitment
  232. which motor should i mod on my 3g
  233. 4th gen parts or shell for sale
  234. Crank sensor Questions....i searched!
  235. is the rear caliper locked? 5th gen
  236. vtec pops loud but doesnt pull
  237. hardcore burning oil
  238. OBX & JDM valve cover difference?????
  239. need advice on custom exhaust.
  240. Leaking H22 Transmission Case?
  241. Camber kit & suspension problem
  242. Planing to turbo a 94 si.
  243. Strut/spring installation writeup?
  244. Reputable Honda Repair Shops in LA (Southbay Preferred) - Already Searched
  245. What fuse blew?
  246. Fix It Ticket!
  247. pic request: 4th gen buddyclub front lip, low angle
  248. Lower Control Arm Bushings
  249. Some one fill me in
  250. would a cai work along with a jrsc?
