PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. CV Shaft Problem?
  2. Girl needs help with H22A - wiring harness
  3. Best place to test fuel pressure on a 92 Si?
  4. love to go fast
  5. Prelude < / > / = CRX?
  6. new rims on the lude!
  7. Simple Intake question
  8. Removing boot off the half-shaft
  9. rear bumper
  10. just put in a f22b6 in a 95 lude
  11. h23swap in 1998 prelude?
  12. 93 h22 gettin hot on the HWY
  13. h22a swap
  14. Intake Mani Sensors
  15. automatic 5th gen preludes
  16. Catalytic Converters in California
  17. cat. converter
  18. USDM Optional trim kit....
  19. weird engine sound in 5th gen
  20. is it worth to tune stock motor ??
  21. ?? Part number ??
  22. Aftermarket springs on OEM type SH shocks?
  23. JDM Type S Rear seats
  24. 4ws question
  25. 1992 Prelude with 200,000+ miles for $800. Should I buy?
  26. shifting problem
  27. h23 swap with f22b need ecu help!!!
  28. Frustated with my Prelude.
  29. tps maybe?
  30. 1989 Honda Prelude 2.0 S dies intermittently
  31. 5th Gen Digital Climate Control
  32. Need a link or direction to h23vtec. H23a1 motor, swapping in vtec head.
  33. 2000 prelude - abs light - 6 long 1 fast.
  34. sunroof on 92???
  35. Question
  36. Will P0B ecu run my F22b?
  37. New build, decided to keep some of my stuff.
  38. Question on my H22A's dyno run
  39. cv shaft removal
  40. 01 prelude electrical problem. Ideas?
  41. manual trans question.
  42. preludepower down for the count :(
  43. broken 91 lude
  44. Totally awesome problem, need a part number please :)
  45. transaxle removal
  46. Brake Problem with JDM Honda Prelude BB4
  47. Pulling hard to the right...?
  48. problem guessing quarter mile time
  49. 4th gen HVAC and exhaust questions
  50. m2f4 vs m2a4 tranny
  51. is anyone running function form types 1 or 2
  52. Koni settings for drag racing
  53. if i bored my h22 out to 89mm
  54. installing jdm h23a blue top in a 93 prelude
  55. does anyone make aftermarket lower control arms for a 4th gen
  56. WTB Wanted To Buy thread September 2009
  57. FS For Sale thread September 2009
  58. Interesting ABS Light issue
  59. Distributor H22 INTERNAL--->>EXTERNAL Conversion
  60. Car not accelerating past 3k rpms.
  61. Passanger Air bag
  62. AP1 stuff
  63. have a ? about a dizzy
  64. 88.5 pistons needed
  65. Engine Swapped - Started a couple times now it will not crank
  66. H22 valve locknut size? 10mm or 12mm?
  67. H22 temerature sending unit -->
  68. Balance Shaft Removel
  69. oem 92-96 vtec radiator size?
  70. n/a vtec Q
  71. Warm idle speed low
  72. Bump Stops
  73. Wrong Coolant
  74. "new here need help with flashing oil light"
  75. for the turbo guys running hondata
  76. Electronic VSS plumbing
  77. 1992 HONDA PRELUDE VTEC SWAP
  78. clutch replacement
  79. Got my FCPGroton Kit!
  80. New to Honda's, Come from DSM Background, Couple ???'s.
  81. Engine Oil
  82. H22A timing belt procedure
  83. H22 Knock Sensor
  84. bad problem
  85. how to pull crank?
  86. Swapping passenger to driver seat base?
  87. Hi - New here AND blew up my Prelude!
  88. Plz Help car wont crank wont start!
  89. swapping obdI '94 h22a into obdII 98 prelude...want to keep car obdII
  90. f20b in 97 prelude
  91. 94 prelude turns but doesnt start until many tries
  92. Accident pictures & stories - Post 'em. -PRELUDE specific.
  93. Famous T-belt tensioner failure
  94. driver side headlight has no power
  95. sad day.....
  96. 89.5x97mm11.5cr dyno inside
  97. electrical problem
  98. loose fuse socket
  99. SRS light
  100. Does OBD1 have the immobilizer unit?
  101. 92Lude Radio and dash clock out - what up?
  102. how to know?
  103. is it possible to replace a damaged sleeve ?
  104. H23/Vtec Piston Choice
  105. Hello everyone! 1982 Prelude
  106. Radius Rod INSTALL <--------
  107. Vtec Solenoid
  108. radiator
  109. H22a4 swap issues
  110. 1st gen Prelude struts
  111. H22 in 92 civic hatchback
  112. Prelude stalling and rough idle..help please
  113. tuning ecu
  114. h22 build
  115. weird noise from valvecover
  116. Need help with wiring from auto to manual
  117. h22a head
  118. has anyone ran the ebay intake manifold?
  119. **Transmission shop recommendation needed**
  120. Real deal mugen?
  121. Ticking Noise After An Oil Change
  122. when are all the meet
  123. OBD2 P13 vs. P5M
  124. Boost Controller Issues (Greddy Prospec B Type II)
  125. lets talk heads.....
  126. car leans all the way and sputters badly after 20+ min driving
  127. stock prelude injectors
  128. VTEC EL CLUSTER 10-15mph slow!
  129. sudden poor gas mileage, help!!!
  130. h22a head on a f22a block
  131. H23 burning oil
  132. how much should I sell my Lude for
  133. prelude h22a auto
  134. no vtec
  135. 96 Prelude Book
  136. obx short shifter
  137. 4th gen energy suspention bushing kit will fit on 5th gen ?
  138. H22A really ticky and lack of power...
  139. interior fuses
  140. Sunroof Question
  141. Short shifter
  142. INFO: Ground Control (GC) Coilover Installation
  143. help battery being drained by something
  144. CAR BATTERY BEING DRAINED BY SOMETHING......???
  145. Best Place to Score an INX
  146. hey whats up
  147. This lude worth 4200?
  148. 92-96 lude pics
  149. H22 BUILD!!!*** Need some help and opinions
  150. bb6's ludes with wheels pics please
  151. aftermarket end links
  152. Drop the exhaust?
  153. Couple Problems 1 thread
  154. What color are your stock FRM cylinder walls?
  155. dream or possible reality??
  156. good websites
  157. ordering new engine
  158. headlight fit
  159. Thoughts on what might have happened here? vid inside
  160. Aem v2 intake same for 4th and 5th gen?
  161. blowing battery fuses
  162. Half size radiator ok with AC?
  163. hondata,crome,eztune
  164. K&N Filter Size
  165. Cruise Control Removal
  166. Timing: Is my oil pump gear in sync with my cams? *pics*
  167. 94-96 EL gauge harness swap = no more JDM fogs
  168. IM swap
  169. Alternator assembly help
  170. wierd idle
  171. 4th Gen H22 Swap Help ...
  172. Old Gas
  173. Leaky Tailights
  174. Vtec only engages when cold,wants warm it doesn't engage at all
  175. New H22, broken sensors!!
  176. fuel injectors
  177. euro R h22....help to make pass smog
  178. What would cause car to shake while accelerating. (doesnt shake in vtec)
  179. running rich and need help
  180. aftermarket fuel rail questions......
  181. Instrument Cluster Issue, 89 2.0 Si 4WS
  182. Oil In Distributer Problem
  183. 92 prelude help. (shifting) auto.
  184. Unusual Random CK Engine Light
  185. (Newbie here) Prelude h23 motor heats up quick
  186. running on bad axle
  187. lude dies while driving
  188. no start problem.....
  189. Anyone know where to get T2W4 by itself?
  190. turbo f22a1 92 prelude s bulid
  191. Knock sensor help
  192. Side Skirt Removal
  193. lude meet
  194. 92 Prelude JDM CLIMATE CONTROL WIRING DIAGRAM
  195. Alignment in the OC area (socal)
  196. Idling Problem
  197. Bumper Lights
  198. Problem solved
  199. jdm p13
  200. Gauge says i'm running hot?
  201. newbie lookin to boost h22
  202. Need help with some codes!!
  203. Taking off from a stop, engine bogging/hesitating.
  204. H Series Engines
  205. 94 prelude stumbling and not accelerating
  206. sheered flywheel bolts (H22A) damaged crank
  207. rust in quarter on 4 gen
  208. Car won't start when it hot.....
  209. turbo
  210. h22 shifter cables
  211. Can't Find Timing Mark....
  212. Bring a Prelude meet to western/Northern MD!!
  213. Decoding VIN (All Models 1983+)
  214. Where is my main relay?
  215. turbo f22 hatch
  216. Injector Size
  217. 92 jdm prelude issues
  218. BBS RS wheels
  219. What do you think
  220. another projector question
  221. turbo f22a1
  222. 1992 Prelude "HELP" where is the vtec solenoid at?
  223. 92' Prelude Si, Digital Fuel/Temp Gauge and more..
  224. oil on tps sensor???
  225. Alignment Issues after hitting manhole?
  226. tailights and dash dont work!!!!NEED HELP
  227. Best Way To Save Gas On The Highway
  228. Does H22A1 Have Crankshaft sensor.....?
  229. Prolems With ICM
  230. Need Help!: Swapping H22A4 into 94 Prelude
  231. Low Brake Pedal problems 4th gen vtec
  232. Quick 4th Gen Question
  233. how to modify oem air box
  234. Help! Problems with 97 Lude
  235. Idle/Start Problems
  236. 92 SI H23 heat issue
  237. h23 trans counter shaft removal question
  238. h22 auto tensioner unsolved mystery?
  239. k20 in 4th gen lude
  240. header install question
  241. exhaust manifold length
  242. VA Prelude Mini Meet/Cruise/Photoshoot !
  243. IACV need one....
  244. HELP ABS light just popped on
  245. A/C Altenator belt install??
  246. F22B DOHC Valve Clearance
  247. How to run lines ? .. Aeromotive FPR + stock fuel rail
  248. 92 prelude no start
  249. h23 axels on a f22?
  250. Get to the bottom of the obd1 or obd2 injectors
