View Full Version : Honda Prelude
- motorized folder 5th mirrors
- H22 Complete Swap
- Kamikaze Header...
- Direct Nitrous Injection
- Driving with oil leak?
- Dynamik 4-2-1 header (searched)
- Under Ground Racing Coilovers?
- What Steering Hub to use, NRG slim hub doesn't fit, sent one for 97-01
- Component speaker crossover without an amp
- Intake Manifold for H22's
- Really Quick Question - 120K alot?
- fidanza flywheel??
- rebuild engine
- to all you h22-ers
- Thunderbolt high flow cat any good?
- Mugen Dead Pedal!!
- Best prices for VIS products? (CF hood, Mugen kit)
- where does the lower rear tie bar go on a 93 prelude si?
- Need help passing emissions? (big pics)
- Dyno'd my brother's car tonight (JDM H22 in 95 Civic Coupe)
- crankshaft position sensor
- engine running weird and throwing codes
- Our FRM Cylinder lined blocks don't need to be honed afterall...
- OBD II motor in OBD I prelude
- JDM car boy twin loop exhaust. Whats your input?
- axle help!
- Electrical malfunction
- Tanabe Strut Bars
- JDM Fog lights. Everything done right. Fogs work. But the buz is still there. Please Help?
- Urathane bushing crunch?
- Intake Manifold Sensor(?) Question
- Help with Grounding Points for a 4g
- 225/40/18's rubbing... big surprise, now what?
- BIG hub bearing problem!
- installing jdm fenders got a question
- Experience with skunk2 coilovers??
- prelude springs
- No heat in the cabin...
- Stock wheels coating
- ACT or EXEDY?
- Still running rich
- Carrillo Rods ?
- Pistons
- Question about 92 prelude h22 swap
- 1996 prelude turns off after 60 mph
- getting the timing belt back on my h23 manuel tensioner swap!!!
- Inner tie-rod end replacement
- Questions about tires
- Q for all swapped H22a HP4s (engine cover temp)
- Simple question: 1996 JDM H22A -- OBD1 or 2 ?
- offset fitment for 4th gen.
- avoid ebay seller "firstchoiceautoparts.com" on ebay
- rota slipstreams?(pic request)
- 5th gen mirrors on 4th gen
- H22A Swap - Please Troubleshoot
- fuel line goes to...nowhere? is there something missing?
- Overheating problem
- Wanna run 88mm H23a Wiseco pistons? Think again.
- oil pressure sensor removal
- ATTS question *searched*
- Kinda funny
- does anyone know about the carsponsorship.com place
- Transmission Difficulty...
- Nitrous
- questions for the G23 swap
- Everything on my engine is really messed up.
- Header help
- what is this? please help
- Sunroof having trouble going "up" but not back?!
- help!
- rear defrosters and headlights
- Do all 98 - 01 Preludes have a LSD or just the SH?
- need both headlights for a 5th generation prelude
- Smoking Engine
- 4th gen aftermarket steering wheel install
- pspec-searched
- carbon fiber trunk on 4th gen
- For JDM radio owners -> frequency shifter - useful information
- how much boost is safe????
- WTF!! rear brake piston boot...
- After swap H23a2 to H22a error ECU code 20 (ELD)
- blocks
- Does Factory CD Player take Burnt CDs?
- Anyone on Neuspeed Race springs?
- apc harness
- Crippled by an SUV
- Helms: refinishing rotors during brake job
- Side skirts/ rear under spoiler
- whats up with my torque curve?
- compression for jdm h22a?
- 'Lude hard Cold Start
- idle problems h22a4 obd1
- h22 is hesistating at mid range rpm
- jus got a chipped p13....whats next???????
- '97-'98 intake fit on '00 prelude?
- cv shafts
- stupid battery light
- just did an auto to manual conversion for a 5th gen got cel code 31
- Please help, need tranny code(I searched)
- transmissoin swap done today have a quick ??????
- 1998 prelude for sale!!
- Ate Super BLue fluid
- Lightweight crank ?
- 2 low?
- new manifold...car runs liek pooh
- Can I pay anyone here to swap my engine?
- FYI: 92-93 Prelude fog switch still available..
- tanabe DTM
- Valve Cover
- Shift Cables Install
- 89 no a/c belt size
- steering wheel vibration/shimmy
- transmission interchangeability, 01 into a 97?
- my plug wires??
- Does anybody have a write up on how to chage water pump on 4th gen h22? -searched-
- 4th gen qustion?
- Type S parts in H22A4?
- Prelude SH Turbo????
- distributor question for h22 swap
- Middle splitters
- Tilton twin disc for the H22
- ACL H22 bearing question
- Valve Adjustment Matainence??
- Any good, honest, reliable honda tech's in/around Portland, Oregon?
- My heater is weak...
- b-series tranny w/h22 in a prelude?
- Prelude-powered Mini test drive video
- evap purge controll valve what is do i need to use it?
- Motor Mounts
- EGR BLockoff. A different approach.
- Knock sensor and Iab location on h22
- SH wheels, hard to come-a-cross?
- Would the h23 crank fit the h22 using the h22 eagle rods?
- Emmisions
- need help with distributor and ecu question
- AEM Fuel Rail Leaking
- H23/H22 Motor Mounts...
- Greddy E-Manage-searched
- Gear Indicator Light?
- motor flex
- High flow cat
- tech Q about engine light
- help buying a prelude
- clutch install not sitting right whats the deal??
- Installing Strut Bar
- 'eat ecu'
- question on tweeters on 98 sh
- fluid for atts ?????????
- speedo doesnt work when cold
- eletronic oil pressure gauge question
- 4th gen vtec upper balljoint
- obd2a ECU pinout for OPSU and o2 sensor signal wire?
- d2 coilover owners check in
- Steering Wheel????
- what engine?
- Removing the rotor, tune up (????????)
- Replacing the rear struts... Again
- Ram Hood
- 01 EBP Color and Tranies
- need a factory prelude cd player asap
- fuel injectors?
- H22a dyno @ 10 psi
- Remove 4ws 5gen
- TDC help
- H22A valve springs - egg shape, lemon shape
- what is a safe way to lower my 5th generation prelude
- Weird idle/throttle problem on '93 SI
- I think i have the accord tranny
- Brakes feel sloppy after brake job, need help!
- Engine swaps
- 97+ Prelude 02 Sensors
- Break in and used some Sysntehtic oil
- Need Clutch recomendations
- sensor bolted on to fuel rail what is it thanx???????
- JDM Foglight blub help..
- supercharger vs turbo
- Online diagnosis?
- Sleeve to Piston Clearance
- JDM Pricing
- obd1 egr removal with p13.
- f series
- Help me figure out this part?
- removing the plastic gauge cover on 4th gen
- 4th gen-5th gen suspension
- need help
- F20 question, tensioner related
- Yes Yes another question about ps to manual steering conversion
- H23 head on a H22 block?
- Intake Question
- Black smoke out the exhaust ?
- Hondabond ?
- Wheel hop ?
- Why No Prelude Type R?
- Headlight and fog light out
- 91 swaps
- where can i get a lsd install
- fan control module location?
- probably a really stupid question
- need ecu codes for obd1 p13 (prelude vtec) ecu i already searched
- problem shifting
- ecu code 1259
- which turbocharger?
- What can you swap in to a 3rd Gen?
- In need of the experts opnion's!!!!
- APEX-i VTEC Controller for 5th generation information please!
- code p0401 HELP!!!!!!!!!!!!!!!!
- CEL: Code 1
- Car Dies Out
- h22 swap
- Prelude S Owners: Prop Valve Help
- hid projector lense
- FET quick release help please...
- The second drive of my 4th gen after the rebuild... question about Door Ajar
- 92-96 Prelude question: auto and manual have the same engine harness?
- h23 parts h22 parts make offer
- Broken Endlink
- Removal of pinstripe adhesive. Help.
- dynoed again. lower numbers than last time :(
- Track Speed Racing...
- GE Fuel Rail Install
- f22 engien
- Strange Clutch/Tranny Noise
- spark
- just replaced all my valves
- possible bent valve?
- Can an OBII scanner clear ATTS codes?
- jdm fenders did search
- JDM h22a! spinning tires... !! help
- kamikaze 4-1 header?
- Some BIGGGG random electrical problems
- Problem With Starter? on H22
- Honda OEM Nuts and Bolts or Home Depot...?
- Crucial Mods>>>>>>>>
- help with tranny
- Moroso Oil Pans?
- h22a temp switch
- best headers under 500 for h22
- 5th Gen Prelude, Won't start. Weir problem.
- H23Vtec Timing Problem
- Replacing Glass sunroof on 5th gen. How?
- Sleeves
- Installed: obx lsd (h22)
- How low does your WS hang?
- intake question
- locked thread...??????
- help! JDM H22 surging under low load, 2-3.5k rpms
- Valve Lash Adjustment
- Code 23 4th gen!!!
- ww rs lip (tape)
