PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 [250] 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. h23 plug gap
  2. 5th gen rotors?
  3. check this out! HID groupbuy!
  4. Completely stupid
  5. dipstick
  6. Question bout timing crower cams, idle, helpp!!!
  7. drag turbo kit?
  8. STR Throttle Body
  9. JUNKYARD TREASURE
  10. Please identify this
  11. 5th gen Prelude throttle body
  12. question about rear sway bars
  13. Where are all the JRSC Luders???
  14. flywheel install
  15. H22A TypeS Type S, Red Top CARB Legal
  16. h23 vtec/ vtec wont come on
  17. Guys with JDM one piece lights and HID's-
  18. What are the Pro's and Con's of replacing the Catalytic converter for an eliminator?
  19. OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!!
  20. JIC vs Tein
  21. question about ES bump stops
  22. Best Turbo Exhaust
  23. Autocrossing a SH?
  24. Technical EGR question...
  25. what are the symptoms of a slave cyclinder going bad..
  26. v-tec
  27. Lucas Oil
  28. portflow springs break timing belts
  29. N2O street usage.
  30. Stock intake question
  31. Prelude vs Miata
  32. autolite platinum or titanium plugs for F22a1?
  33. Rebuilding starter?
  34. I need help with friends h22a sensor locations...
  35. JDM Swap or keep it??
  36. Mugen Side Stripe
  37. 1/4 mile times for 4th gen all motor ?
  38. is there a different between auto wiring harness and manual for a 1992 prelude with a jdm vtec
  39. FS : stock h22 cams, valvesprings & retainers
  40. JDM Tranny
  41. how to pull head off w/ IM
  42. h23 crank h22 rods and pistons?
  43. Mugen Headlight Covers?
  44. Took the lude to Limerock yesterday
  45. hondata for my built h23 (i searched)
  46. headlights
  47. BLown H22a
  48. h22 into si any guides?
  49. MisterJung HID kit...
  50. what kinda exuast dont sound farty and tin can-ish
  51. Help needed with vtec system
  52. head weld good or bad?
  53. i need a knock sensor asap
  54. Need engine help....Honda Newb
  55. Good exhaust for 1986 Prelude Si??
  56. ****want a lude??*********
  57. what octane
  58. SMS Header Prototype #5 Polished
  59. 5th gen track times?
  60. 5th GEN Prelude JDM cam question?
  61. timing belt cover
  62. Boredom breeds design
  63. What times are possible...
  64. whats missing? i feel air moving in/out of it
  65. Cam Question?
  66. 5-bolt conversion
  67. Timing question
  68. H22A or not can anyone tell?
  69. Timing Question
  70. clutch question
  71. OEM CF trim vs. Other brands trim for interior
  72. Clutch Install Prob....
  73. 17" Rota's for a Prelude???
  74. question for boosted luders and staying cool
  75. h22 Block guard
  76. Speedo Connector
  77. how do i replace my timing belt?????????
  78. JRSC AUTOMATIC PRELUDE
  79. maintenace light differences?????
  80. 5th gen tranny code?
  81. p13 4-plug ECU.......P28,72ECU
  82. h22a4 tranny on h22a1
  83. hmm am I retarded or is my car?
  84. Tranny question
  85. decided to forego turbo'ing the h23... got this instead
  86. H22 balance shaft and oil pump alignment
  87. weird help needed........
  88. bent valves, price check?
  89. shocks
  90. fast help!! Dizzy bolts
  91. Apexi Dunk Prelude Exhaust
  92. ITR intake on h22
  93. Need some help.
  94. Just got myself some gm syncomesh... a question
  95. timing + or - how much???
  96. Removing 4th gen Cluster
  97. Car has some serious sputtering issues, possibly nitrous related...
  98. Changing Timing Belt Cost
  99. OEM Black Paint
  100. type sh shocks?????
  101. exedy cerametallic 3 puck sprung clutch , anyone using one?
  102. Help - Suspension thumping on 4th gen
  103. oddly noisy valvetrain...help please(already searched)
  104. Planning to boost 9lbs on my turbo kit will i need a new map sensor?
  105. Broke into 14.5! With my 5th gen today!
  106. how many whp is this good for with proper tuning and what to do next?
  107. Exhaust Question
  108. Cheap mods
  109. thinking of buying a prelude,please help me decide.
  110. is there a way to check o2 sensor on 5th gen
  111. JDM H22A...parts from H22A1 or H22A4 or doesnt matter?
  112. did a compression test..need to know what the numbers should be
  113. Type S Front Lip Mounting Problem
  114. LS-T vs H22a-T
  115. Is the front prelude emblem that's on the grill only on the later fifth gens?
  116. What to do to my H23?
  117. 97lude Engine power los
  118. Changing manual tranny fluid
  119. I got 245 in all 4 cylinders , comprestion test, is this good for a 11.0cr motor ?
  120. P14 pinouts
  121. how to take off cam gear cover case?
  122. JDM Honda Prelude
  123. Engine Swap for an 88 Prelude Help
  124. afc in h23
  125. tension rod quick help needed...
  126. All lude owners tell me what...
  127. 5 qts. - too much oil?
  128. Should I Hone My Block?
  129. 92 electrical system
  130. somewhat OT: my trip to alabama that killed my motor
  131. what year did honda introduce the prelude sr-v/vtec?
  132. SUCKS ASS
  133. 4th Gen riding low
  134. BloWn MotoR?
  135. Custom setup
  136. euro r - please tell me this statement isn't false
  137. s2000 dash in 4g?
  138. prepare for some stupid prelude motor mount questions....h22a
  139. p28 ecu
  140. check engine light is on, code po420
  141. short ram intake questions
  142. Need Pic of H22's Side ! ! !
  143. NEEDED: 97 H22A4 Crankshaft!!!!!!! MOD APPROVED!!!
  144. Drag gen 4 / Hondata pics and dyno graphs
  145. Radio wiring diagram/cd install
  146. Looking for a light weight 17 inch wheel for a 98 prelude... Please post recomendations, pics and we
  147. quick help please h23vtec
  148. Belt for NO AC in a 5th gen
  149. h22 RPM???
  150. timing belt install \ tdc question
  151. Rebuilding a JDM H22. What all should I change??
  152. Question about USDM/JDM/european headlights
  153. Hyper Clutches
  154. how low on sh before atts problems?
  155. 5th gen roll cage (help)
  156. exhaust system
  157. h23 knocking
  158. JG P&P TB and IM
  159. Jdm Digital Climate Control
  160. SYSTEM CHECKER HARNESS
  161. Strut bars
  162. 5th Gen motor mount question
  163. How to take off DRIVER Side FENDER!! HELP!!
  164. Brake caliper Qusetion.
  165. Gen4 question
  166. P13 ECU
  167. how much tranny fluid?
  168. what is the best coil-overs for 92-96 lude
  169. 92-96 Prelude JDM One Piece Headlights
  170. I JUST CRASHED!!!
  171. Header install problems
  172. SH?
  173. EGR valve removed, yet no code?
  174. Skunk2 Intake mani.. I think its out!!!
  175. Heating unit
  176. Time to introduce myself to Yall
  177. Removing Balancer shaft bearings
  178. aftermarket seats fitment (corbeau)
  179. Clutch and Flywheel question
  180. will a 97-00 type R shift knob fit a forth gen
  181. ECU's
  182. Transmission types
  183. 89 Motor Swap?
  184. 89 Lude parts?
  185. low compression pistons
  186. if i had a non type SH would it be easier?
  187. Should I do this? 1989 Honda Prelude-$300?!
  188. using a p28 in h22 lude vtec problems help!!!
  189. MSD Blaster SS Coil Install question...help!!!!!!!!!!!!!!!!!!
  190. Big power loss?
  191. getting slavage prelude
  192. h22 transmission codes
  193. door pannel ?
  194. shall i build or buy other car?? read...
  195. 4th gen, where did u put your hood pin
  196. Short Shifter
  197. Ball Bearing TurBO!?
  198. HeLp, H22a TurbO!
  199. hoses on the IM?
  200. HELP w/ Gauges!
  201. prelude front door speakers, how do i get em off
  202. A motor sounding noise after reverse and drive ....wtf is it?
  203. Anyone make CF OEM spoiler, sunroof, and trunk for 4th gen?
  204. 1992-1995 Prelude Si-- Auto to Manual conversion ( q's )
  205. 94 Prelude Sun Roof
  206. CEL 43
  207. 2point6's dyno 11/4/03
  208. JDM H22 red top with m2u4 trans. Is this the 220 hp ver ?
  209. Has anyone here ran VIR before???
  210. OEM H22 Cams
  211. 1994 Dome light
  212. cant figure out why my vtec quit.
  213. stock resonator
  214. yay i love long trips....
  215. safc install on a p14 ecu
  216. whats the wire colors on the map sensor
  217. strange vibrations?
  218. help!!!!
  219. question about running wires
  220. p14 ecu pinout?
  221. P/S Who needs it?
  222. idle problem when AC is on
  223. need help locateing someone
  224. scary noise
  225. code 1?
  226. 88 lude speed sensor where is it what does it look like?
  227. getting code 17 cant find speed sensor where is it?
  228. how to install a water pump into a 1990 honda prelude?
  229. helms manual scan for h23a
  230. How to make SAE dyno correction?
  231. Turbochargin a 97 SH Prelude
  232. CEL 9
  233. Relocating the battery....
  234. throwing engine codes
  235. gtech pro
  236. how to do Compression test?
  237. What's the voltage of a 3rd gen horn?
  238. fiberglass hood
  239. Help Stinky!!!
  240. injector harness
  241. refilling a/c
  242. Electronic control system 88 prelude location and description
  243. Greddy
  244. Turbo H22 Fit H23?
  245. I've heard an 89 prelude sunroof is compatable with an 88-89 CRX...
  246. Pro's & Cons of F20b vs. H22
  247. just curious
  248. ? bout ferrea rockers
  249. compression/burning oil
  250. 97 Prelude tranny swap for Accords 5 speed
