PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Transmission problems
  2. runs like crap
  3. intermediate shaft
  4. ACL Bearings
  5. can you put an f23a4 into a 95 prelude?
  6. cb7 h22 swap cranks but no spark HELP!!!!!!
  7. 92 prelude wont crank
  8. Convert obd1 to obd2 h22
  9. Quick Prelude Question (thinking about buying one)
  10. 5th Gen Type S swap questions
  11. ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Aug/Sep 2010
  12. ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Oct/Nov 2010
  13. ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Aug/Sep 2010
  14. ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Oct/Nov 2010
  15. H23a1 seized on highway, what next?
  16. won't go into gear.
  17. Wheel Bearing Help
  18. Help Needed to complete B20A Swap---Erratic Idle!---
  19. overheating...power to fan isn't strong. faulty gauge or bad groud somewhere?
  20. 88 prelude si 4ws failed smog, high NO at 25mph
  21. h22 compression
  22. clicking when turning???
  23. ABS not working - no light - suggestions?
  24. 5th gen ignition coil problem
  25. 5th gen air intake
  26. New To Preludes
  27. 1980 RHD Prelude Build Thread *OldSkool & 56k Warning*
  28. AC.. Lets gooo
  29. My own ac wireup..
  30. CB7 H22A SWAP HELP!!!!!
  31. I almost traded my prelude for a gsr...
  32. Help..h23 engine swap wont start
  33. BACK FROM THE DEAD, '90 Si
  34. 97h22a swap need help
  35. wiring harness - help!!
  36. Turbo
  37. need some imput, car died and now wont start
  38. speedo gauge/ fuel and temp dont work
  39. throttle body
  40. shifter cables
  41. 97 prelude climate control
  42. need a h22a4 SH
  43. F20b swap
  44. ball joint question
  45. a/c weak air
  46. What is this... Leak in rear under trunk...hope it's simple
  47. 4th Gen clock help
  48. H22A swap HELP MAP SENSOR and vacuum hoses
  49. H22a head onto F22a block product list and partial, if not all, DIY instructions?
  50. No high beams and no DRL lights.
  51. clanking noise...
  52. Horn & SRS Light
  53. Will 87mm headgasket work for 87.5mm bore?
  54. hid bulb type
  55. Do people steal Preludes?
  56. bad alternator symptoms
  57. Where does this plug go? h22a
  58. need more gear
  59. K&N typhoon system confusion!!
  60. fuel injector leds??
  61. Clutch pedal bracket problems..
  62. Stupid question about prelude.
  63. will my h23 dohc head fit on my f22b block and run?
  64. Help me let go.....
  65. Water in air conditioner, leakin inside, HELP!
  66. really bad gas milage please help
  67. b20a5
  68. h22 cylinder not firing
  69. Prelude 4thgen DRL problems
  70. M2F4 and lsd
  71. lights dim/idle problem/ engine almost dies
  72. jdm swap help
  73. 1990 prelude having starting issues
  74. Car jerking while accelerating help
  75. how do I remove the throttle body after taking out the 4 screws
  76. h22 turbo selection question
  77. 92 prelude h23a how do I do a throttle plate adjustment?
  78. where does this loose hose go?
  79. HELP - Window went down but wont come back up.
  80. problem with h22 on 2000rpm till 2500rpm
  81. bad oil pump
  82. rear window visor bb4
  83. Nsx brakes
  84. H22 to H23 swap
  85. need help with my 97 prelude sh it need a new motor
  86. Exhaling on turn-off
  87. Can 5th gen's be slammed?
  88. Overheating?
  89. Using thinner Headgasket
  90. 4th gen tachometer help
  91. front and rear strut bar question....
  92. What brand Fog Light and HID Headlight should I buy?
  93. Aggressive stance, post your ride. wheel spacers and camber.
  94. BB8 front bumper
  95. 88 prelude wheres the a/c clutch relay?
  96. 2 Part Question
  97. IAB delete question
  98. Trying to Bleed Radiator.
  99. Timing belt and balance shaft belt question
  100. G23 vtec
  101. '89 Surges Through Acceleration
  102. 92 prelude H23 Can anybody tell me what this loose hose is where it's supposed to go
  103. h22a1 going into prelude s what can i do to make the external coil work?
  104. Strange brake light problem
  105. help finding an engine builder
  106. VTEC solenoid gasket - installation - wet or dry?
  107. 94 prelude vtec
  108. h22a into 94 EG, no spark... 2 distributors, internal.. external.. which one?
  109. Please Help! H23 Cranks But Won't Fire! First Honda.
  110. how low to lower a prelude?
  111. what is the best motor for 92 prelude
  112. Trunk pole information??
  113. vtec not kickin in.....
  114. prelude cel service port?
  115. My prelude lacks balls. help?
  116. Rpm's Jumping, don't know what else to try.
  117. getting rid of stock oil cooler h22a
  118. VTEC HELP PLZ
  119. HELP WIT DA JDM FRONTZZ Y0!
  120. another vtec wiring question. sorry
  121. 1988 prelude 2.0 carb
  122. Will it work correctly? 2000 motor - 95 car
  123. Fastest stroker h22 preludes
  124. climate control
  125. EPIC FAIL day. Please help.
  126. help finding engine builder
  127. harmonic balancer help
  128. High Rev while in D4/sport shifter
  129. throttle cable length....will a civic cable fit?
  130. 93 circuit board
  131. main relay for 88 prelude
  132. is this lip kit website legit?
  133. Fuel line fitting size question h22
  134. Lower Ball Joint NUT removal and installation
  135. h23a1 let loose- now what?
  136. 5th gen shell...whats a decent offer
  137. Wheel upgrade
  138. BB4 tranny removal
  139. 01 prelude make over
  140. 92-96 prelude seats fitting eg civics
  141. h series engine help
  142. Clutch help
  143. what does the rear plug on the tranny go into
  144. power steering issue!?
  145. Fuel and Temp guage not working 94 BB4
  146. my prelude help
  147. Problem with Moonroof / Sunroof moving slow.
  148. First post and a lame question. . .
  149. carbon sleevs
  150. need some feedback quick! smoke coming from in dash
  151. need some speed
  152. Ignition output wire HELP!
  153. 1992 Honda Prelude Gas/Temp Gagues don't work?
  154. how to take the crank out
  155. 89mm ring gaps
  156. anyone make lower control arms for 4th gens?
  157. Best lightweight rim for BB6....
  158. 4ws and I dont know what to do :(
  159. keep blowing radiator fan fuses.... WTF
  160. Need an idea of what this is worth...
  161. F22 I NEED SPEED!!!!!!!
  162. type s lip
  163. H series close gear ratios?
  164. 5th gen prelude question
  165. p13 to p72 now no tacho
  166. Air diffuser for 5th lude
  167. Question about OBD1
  168. m2b4 shifting issues
  169. ebay headers!! LAME!!
  170. need help testing the TPS and ect circut.
  171. EGR Valve
  172. h22 swap help
  173. h22 tranny gear ratio changes
  174. Tranny//// shifter
  175. looking for a video
  176. h22a timming issue
  177. m2b4 lsd/housing w/ m2y4 gears and shafts?
  178. 97-01 Depo Projector Headlights
  179. f20b exhaust and cams?
  180. another swap problem...need help!!!
  181. New rims!!!
  182. Where is Prelude ABS Bleed Valve
  183. Faded rear seats...How to fix/replace?
  184. any issues if i block off egr valve?
  185. ECU for H23 to H22A
  186. H22 head knock?
  187. F series header vs h series
  188. 99 SH Clutch/Tranny Problem
  189. h23 AUTO transmission fluid
  190. 91 honda prelude pgmi question
  191. prelude swaps??
  192. !!!!!!!HELP!!!!!!!
  193. 97 Prelude AT - Issues
  194. 97 Prelude SH HELP
  195. h23a1 go fast parts?
  196. a/c-power steering question
  197. 5th Gen Winter beater - The Prelude no one wanted
  198. H22 Cam Decisons?
  199. does anyone make a megasquirt setup for the Lude?
  200. wtb 4th gen black leather interior plus door panels
  201. megan racing full coil over systems??
  202. 89 Prelude Si - Should I take the risk?
  203. Torco MTF vs HG MTF
  204. CANT FIND PART PLEASE HELP!!!!
  205. Prelude F20a4 help!!!!!
  206. vtec controller suggestions
  207. 97 Sh H22a4 Headers???
  208. Pep Boys Clutch Job as good as dealership?
  209. h23 head / h22a4 block
  210. JDM H22a
  211. Kamikazee H22 Header Dyno All Motor?
  212. Looking for a quick answer! JDM BB4 Headlights!
  213. 97 prelude Vtec problem
  214. Suspension noise
  215. rpm tach moves erratic than dies on h23a
  216. A/C Compressor Question
  217. Is iT PoSSiBLe To
  218. ANYONE FROM LOS AnGeLeS know?
  219. Knocking sound from H23V
  220. will you toss me a friggin link err somethin!!
  221. 91 honda prelude si b21a1
  222. Fuel injecter ohms/resistance reading on h22a
  223. H23A1 engine rebuild question
  224. A/C Compressor Question....
  225. jdm h22a wheel hp?
  226. Distibutor Problems!!!
  227. h22 sound like a subby...need HELP!!!
  228. 93 prelude doors
  229. progress rear sway endlink noise
  230. What a fun time i had today..
  231. ecu decision for jdm h22
  232. What should i do next
  233. buddy club racing sec coils (please help)
  234. H23A Vtec Blue Top Rod Length Vs. H23A1? Same or Not? Mystery...
  235. WB. Prelude Fog Lights
  236. voltage stabilizers
  237. '89 Prelude Si
  238. Changing Stock Cat
  239. K24a4 Any Good?
  240. rocker arms
  241. charging problem.. NEED HELP ASAP
  242. Stalled when i turned air on.
  243. 92 prelude doesnt start
  244. h22 dizzy questions
  245. does anybody here know
  246. Looking for experience with ACT HA3-XTSS Clutch
  247. Looking to copy a car
  248. hondata s200 vs s300
  249. Smokey.
  250. is this possible?
