PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 [177] 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Axle and gearbox advice?
  2. Replacing the timing belt.
  3. F20A - F18 Cranks...
  4. having probloms with h22 please help
  5. Wheel Sensors
  6. Short Shifter
  7. Race spots ?
  8. Axle Installation help!
  9. I need to convert Kmh to Mph on my dash
  10. For those of you having pre-detonation problems..
  11. question about axles
  12. battery relocation set up. double check my work to make sure i dont mess anything up
  13. Speaker Between the Rear Seats
  14. HATCH OR LUDE???
  15. C-Pillar Bar ?'s
  16. Cooling Issues
  17. 4th gen door panel and rear panel insert removal?
  18. Recommendations For Building The H22's Bottom End
  19. alignment - caster problem...
  20. yellow/red top ultimas really worth it?
  21. urgent ? for Accord Front lip install
  22. fitv help me
  23. Used Radiator... How much?
  24. tranny trouble, and how to change the fluid
  25. New Engine 96 prelude
  26. jdm f22b knock sensor
  27. voltage regualtor location
  28. Shifting Problem
  29. distributor cap?
  30. Powering steering busted?
  31. need the web page for Pspec short shifters
  32. Mid-engine Mini H22A1 cutting out.
  33. Hunting idle
  34. difference between h22 throttle bodies
  35. Manual Swap: Clutch fluid problem...not enough pressure to the slave cylinder to disengage the clut
  36. electrical issue
  37. catalytic convertor for a 95' prelude SE
  38. Whats the stock bore on a h22a1?
  39. CEL code 36
  40. h22 type s cam question
  41. lude Auto to 5 speed swap
  42. that is what signifies the acronym BLOCK ASSY. (DOT)
  43. need help with my ecu wiring and engine light on, PLEASE
  44. Are the H motors still produced?
  45. CEL at 30k?
  46. engine immobilizer / key security chip sensor
  47. fire problem 2k lude
  48. rpms
  49. Leather
  50. lower crank pulley for H23 Vtec conversion
  51. 93 prelude
  52. crank case ventalation
  53. For SALE: apexi VAFC piggyback ecu.
  54. Clutch Problems
  55. Newbie Lookin for A Prelude
  56. Brake Pressure
  57. A/C troubles...help!
  58. have a quick ecu question
  59. Need help with fuel system upgrade....
  60. wheres the pcv valve on a 97 lude?
  61. h22 valves??
  62. Wiring for VTEC?
  63. 4ws and spoliers
  64. Transmission? or Wire Maintenance?
  65. break or clutch?
  66. use motor oil as tranny fluid on h22??
  67. h23a-->h22 JDM swap questions for 93' lude
  68. Sold the lude...sad day
  69. I think its time for some flow bench testing...
  70. prelude stock radio security codes ?
  71. What are good aftermarket struts for stock suspension Type SH?
  72. 93' Prelude Project
  73. BEST TURBO MANIFOLD???
  74. 5TH GEN Shoft Shifter
  75. changing rotors and pads
  76. CAM Gears....
  77. Injen - AEM???
  78. Piggybacking a piggyback ?
  79. H22 Compression Debate
  80. Key Sensor alarm
  81. Brake light
  82. Oem Spoiler Brake Light
  83. turbo questions
  84. Disappointed with new suspension, a few questions?
  85. compression test #'s
  86. Need horn help, Installing momo wheel and hub, which is the horn wire?
  87. Prelude or wat?
  88. Is this power possible?
  89. * Honda Prelude BB2 OEM Rear Lip *
  90. Side skirt question
  91. prelude iacv
  92. EGR Removal
  93. h23a1 diagram
  94. springs or coil overs?
  95. please double check my coolant bypass/"blockplate" for my fitv -pics-
  96. h22a engine swamp and ca emissions requirements
  97. finished my swap
  98. Need help please....
  99. Recommendation - Shops around Alhambra/San Gabriel Area in SoCal
  100. flickering oil light
  101. CARB Headers...
  102. Superchargers for all Preludes! Petition
  103. d to see if you guys think it would work or not, im very sceptical about things like thisWhat do you
  104. KYB AGX Question
  105. 99.5% complete on project but need help. Vtec problem not a noob question.
  106. Very strange noise...
  107. Opinions Welcome - My soon to be new setup
  108. Mugen or Tanabe???
  109. Truth about Prospeed header
  110. TB not coming off... am i missing a screw somewhere?
  111. Where can i buy SMSP headers???
  112. Cruise control
  113. service manual
  114. removing coolant lines from fitv... TOO much coolant leak?
  115. Skunk2 valvetrain and rocker arms
  116. 4thgen camber problem
  117. prelude idle problem
  118. Tokico Springs.
  119. need some input, how much would you pay...
  120. Radiator Support.
  121. question about relocating the battery -- distribution block
  122. Need help anybody!!!
  123. Manual Swap: Car won't start...hooked up everything...
  124. cam gear set-up for stock 95 lude
  125. 90 Lude aftermarket seat rails
  126. Prelude Automatic timing belt adjuster
  127. Suspension Set up help
  128. Ghost Clutch pedal
  129. new track times
  130. Anyone had this problem? (searched)
  131. swap out a h23 and put in a h22???
  132. trouble getting to piston rod caps.....
  133. dyno results
  134. So has anyone ever gotten around to actually making a traction bar for 5th or even 4th gens?
  135. oil pan?
  136. DC or GREDDY
  137. 97' SH power upgrades
  138. HELP! HOW DO I TAKE OUT MY STERRING WHEEL?
  139. where can i find prospeed headers?
  140. 92 Motor Mizzounts
  141. Pullys and Flywheel
  142. B21A1 to B20A5 swap details
  143. Questions for the builder of the engine your looking to buy?
  144. DC or MUGEN?
  145. Exhaust?!?!
  146. Manual Swap: 5th gen Engine mounts not fitting properly...
  147. 05 rsx tail lights
  148. H22A running horribly SLOW
  149. Where does this connector go? (pic)
  150. clutch question...
  151. Difficulty shifting into gear - 2001 SH
  152. think i JACKED UP my brakes
  153. Turbo H22...A little help please?..
  154. DIY: 4TH Gen Prelude CAI Install
  155. Emanage on H23
  156. timing belt help!
  157. Can mls head gasket be used more than once or twice?
  158. Taking off 4th gen front bumper
  159. Code 8?!?
  160. Burning Oil
  161. I'll be in upstate SC this weekend tuning...
  162. need help removing header
  163. Went to the Ref today, Smog: PASS, Visual: FAIL
  164. 1 blown shock
  165. horsepower > torque math correct???
  166. 98 Octane on H22. What to do? increase compression?
  167. Where does the clutch damper mount to?
  168. Whats Happening to my ROTORS??
  169. Head Swap???
  170. 4th gen trunk height.....search is fubar
  171. Can i swap a K20A in my 97 prelude?
  172. please help me find and accord rear lip for my 96 lude
  173. I am looking into Preludes, need a little info plz...
  174. my 95 lude is dying [i think]
  175. 92 type S a/c compressor with Si?
  176. could use some hp opinions
  177. Anyone running nitrous on stock timing?
  178. prelude motor
  179. 85 Lude, help!
  180. Remus muffler for 4th gen
  181. H22A Swap: A/C & P/S Questions
  182. does the 5th gen oil pan have a gasket?
  183. timing question
  184. AEM V2 intake system>?
  185. Need pics of clutch line...please post
  186. HELP ME PLEASE!!!
  187. Need Help with Jdm Headlights
  188. Please help, i need this problem fixed!
  189. Will rims of this size fit my lude>?
  190. h22: boost or n2o?
  191. oversized valves in semi stock head?
  192. Just looking for some help...
  193. 92-96 prelude mirrors
  194. 2001 Honda Prelude when starting the car I hear a fairly loud click coming from engine/transmission?
  195. brake upgrade
  196. Pulling my head. Need average machine shop costs.
  197. Need Help Please! Removing Axle from halfshaft...
  198. Where can I get a new iacv for a good price?
  199. If building h23 vtec, do i need to change oil pump to h22?
  200. Sweet smell from exhaust
  201. External coil need info
  202. My Car is F*cked-rain
  203. SSR Competition Wheels on 5th Gen
  204. failed smog at state ref... did most of the basic tune ups already... here are myNums
  205. AC problem with my 92 lude
  206. please post pic of amp power wire install
  207. Kaizenspeed Balance Shaft Removal Kit
  208. Balancer shaft yes or no question????????
  209. question about h23 starter and alternator
  210. type s piston clearance
  211. need info on lauching my lude
  212. what bulb or bulbs for dome light, reverse lights, and license plate holder?
  213. VAFC-II Initial Setup
  214. n/a or fi
  215. '95 Prelude, post-intake idle problems...
  216. tommorows gonna be a sad day........
  217. sold my precious lude today :(
  218. WTB: 5th Gen Prelude passenger airbag complete
  219. Tail Light help Please failed inspection.
  220. Swapping JDM for USDM H22 head...
  221. H22; Auto to H23 Manual Tensioner Help
  222. Highest Horsepower on a built NA h22 so far?
  223. Turbo H22a4 Yea Or Nay???? Opinions Please ( Current Setup Pic)
  224. Removing EGR from OBD1 H22 - Get rid of CEL?
  225. Timing problems
  226. h23 gearing??
  227. Took out A/C. What belt to use?
  228. Quietest 4th gen exhuast?
  229. Megan Racing Header on a h22a1 (prelude vtec)?
  230. molding
  231. Header Comparison: RMF Vs. SMSP JDM H22a Euro R
  232. What spark plug wires do i use for an f20 dohc non vtec?
  233. wheel offsets
  234. whats the most power it will flow
  235. need tail lights help
  236. Stock 4th Gen Prelude Colors
  237. for all u who have done 5th gen HID's and projector retrofits...
  238. to build or not to build that is the question
  239. 92 lude fuel pump location
  240. mysterious low oil
  241. 92 lude wont start please help
  242. Got another one for you all
  243. Vtec not working ?
  244. A little help would be greatly appreciated!
  245. clutch pedal stays DOWN
  246. anyone ever taken out their back seats?
  247. 97 prelude block with 94 head
  248. Header without exhaust..
  249. H22A5 (185hp) tuning. How can I get 10-12whp on a 5th gen Lude?
  250. assistance running power cable on 5th gen lude
